I've been struggling through creating the needed exhibits for FCC certification as a fully modular product. I keep expecting there to be example documents or templates for many of these exhibits, but so far have found next to nothing. Is everyone else just re-inventing the wheel every time someone builds a product using this chip? I've managed to slog through creating several of these exhibits, but looking at the Operational Description exhibit, and the Frequency Block Diagram exhibit I'm feeling a bit lost. It would be great if there were some examples out there that I could look at. Is anyone aware of any resources in that direction that I have perhaps overlooked?
for reference the TCB is requesting the following:
This file must contain the following information for each radio:
For all devices, an operational description of all circuitry and devices provided for determining and stabilizing frequency, for suppression of spurious radiation, for limiting modulation, and for limiting power shall be provided. This description must agree and relate to the block diagram and schematics of the radio.
Describe the modulation scheme; including the type of modulation, and a description of the modulating signal (e.g. video, audio, or data). Where applicable, include the maximum data rate, modulation index, and maximum transmit time during any 100 ms period. Make reference to any applicable interoperability standards or communication protocols.
For unlicensed rule parts (Part 15 and 18), also include a description of the ground system and antenna, if any, used with the device.
For licensed devices, provide a description of the emissions designator.
For licensed devices, provide information on the manufacturers rated power or the specific operating power levels. If the output power is variable, describe the means provided for variation of power.
For licensed rule parts, NOT operating under Parts 15 and/or 18, provide the dc voltages applied to and dc currents into the several elements of the final radio frequency amplifying stage of the device over the power range for normal operation.
If the device is a Part 15.231(b) periodic transmitter, describe compliance with the timing requirements of 15.231(a) of the FCC rules.
If the device is a Part 15.247 frequency hopping transmitter, describe compliance of the associated receiver with 15.247(a)(1) of the FCC rules. Specifically, explain how the receiver’s input bandwidth matches the hopping channel bandwidth of the corresponding transmitter and how the receiver shifts frequencies in synchronization with the transmitted signal.
If the device is a Part 15.247 frequency-hopping transmitter, describe how the device meets the definition of a frequency-hopping spread spectrum system found in Section 2.1. The description should include the number of hopping frequencies, the time of occupancy (dwell time) per hopping channel, and an explanation of how the hopping sequence is generated (provide an example of the hopping channel sequence). Also include a description of how each of the EUT’s hopping channels is used equally on average.
If the device is a Part 15.247 frequency-hopping transmitter, describe how the EUT does not have the ability to coordinate with other FHSS systems in an effort to avoid the simultaneous occupancy of individual hopping frequencies by multiple transmitters.
NOTE: All of the above information associated for FHSS is also required for licensed devices using FHSS technology.
If the device is a Part 15.247 Digital Transmission System (DTS), provide a description of which protocols are used (i.e. 802.11b/g/n etc).
If the device is a Part 15.407 transmitter, per FCC 15.407(c) include a statement that the device will automatically discontinue transmission in case of either absence of information to transmit or operational failure.
If the device is a Part 15.407 transmitter, provide a description of which protocols are used (i.e. 802.11a/ac/ax/etc)
If the device is a Part 15,407 transmitter operating in the DFS bands, provide information on the security protocol implemented.
For all other Part 15 transmitters, provide a brief description of the circuit functions as well as a description of how the device works.
Frequency Block Diagram of each Radio
This file must contain a block diagram showing the frequency of all oscillators in the device. The signal path and frequency shall be indicated at each block. The tuning range(s) and intermediate frequency(ies) shall be indicated at each block (e.g. LO, IF, XMIT Output).
NOTE: The reason all oscillators in the device are required is due to the FCC reiterating that the highest frequency measured is not only contingent upon the clocks in the radio, but any clock in the device. Consequently, an accounting of all clocks/oscillators in the device must be made/shown in the block diagram.
