NRF52832 low power mode / sleep mode [ZephyrsOS]
Hi guys,
I'm working on this project which was basically a migration from STM32 to the nordic NRF52832 in order to enable the BLE beaconing mode.
It has been a challenge to make all of the project to run on ZephyrsOS. However, the code is now at a state where all the previous functions are validated and working. I'm now missing the low power consumption mode. This is a battery powered project so the target consumption in idle state should be around 100uA.
Hardware details:
 - Custom PCB
 - LIS3DHTR accelerometer always powered
 - EG915 Quectel with Mosfet for turning it off
 - TDC1000 with Mosfet for turning it off
 - MCP9700Ax-E/TO temperature sensor with Mosfet for turning it off
Requirements:
 - Every 24H run the TDC1000 and MCP9700 and get a sample. Publish the sample using the EG915 and go back to sleep.
 - Use LIS3DHTR to force a sample if high motion detected (interrupt pin), but this can wait.
I've read this article that explains the difference between system_off and system_on and for the NRF52832 I think I don't have other option than going with the system_on. System_off requires external pins to wake up (no timer based option) so it will not work for the 24H requirement. However, as a comparison I've tested the example system_off with my device_tree overlay:
nrf52dk_nrf52832.overlay
// To get started, press Ctrl+Space (or Option+Esc) to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https: //docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https: //docs.nordicsemi.com/bundle/nrf-connect-vscode/page/guides/ncs_configure_app.html#devicetree-support-in-the-extension
	aliases {
		modem-uart = &uart0;
		modem = &modem;
		gasket-temp-sensor = &gasket_temp_sensor;
		ambient-temp-sensor = &ambient_temp_sensor;
		enable-level-sense = &enable_level_sense;
		enable-modem-power = &enable_modem_power;
		modem-pwr-key = &modem_pwr_key;
		modem-rst-key = &modem_rst_key;
		dbg-rx = &dbg_rx;
		dbg-tx = &dbg_tx;
		tdc1000-en = &tdc1000_en_pin;
		tdc1000-rst = &tdc1000_rst_pin;
		tdc1000-trigger = &tdc1000_trigger_pin;
		tdc1000-chsel = &tdc1000_chsel_pin;
		tdc1000-start = &tdc1000_start_pin;
		tdc1000-stop = &tdc1000_stop_pin;
		tdc1000-errb = &tdc1000_errb_pin;
	gasket_temp_sensor: gasket_temp_sensor {
		compatible = "microchip,mcp970x";
		status = "okay";
		family = "MCP9700/9700A";
		io-channels = <&adc 0>;
		friendly-name = "Gasket Temperature";
	ambient_temp_sensor: ambient_temp_sensor {
		status = "okay";
		io-channels = <&adc 1>;
		friendly-name = "Ambient Temperature";
	zephyr,user {
		io-channels = <&adc 2>;
		io-channel-names = "battery_voltage";
	enable_level_sense: enable_level_sense {
		compatible = "power-switch";
		gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>;
	enable_modem_power: enable_modem_power {
		gpios = <&gpio0 14 GPIO_ACTIVE_HIGH>;
	modem_pwr_key: modem_pwr_key {
		gpios = <&gpio0 23 GPIO_ACTIVE_HIGH>;
	modem_rst_key: modem_rst_key {
		gpios = <&gpio0 19 GPIO_ACTIVE_HIGH>;
	tdc1000_en_pin: tdc1000_en_pin {
		gpios = <&gpio0 26 GPIO_ACTIVE_HIGH>;
	tdc1000_rst_pin: tdc1000_rst_pin {
		gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>;
	tdc1000_trigger_pin: tdc1000_trigger_pin {
		gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
	tdc1000_chsel_pin: tdc1000_chsel_pin {
		gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>;
	tdc1000_start_pin: tdc1000_start_pin {
		compatible = "input-switch";
		gpios = <&gpio0 29 (GPIO_PULL_DOWN)>;
	tdc1000_stop_pin: tdc1000_stop_pin {
		gpios = <&gpio0 28 (GPIO_PULL_DOWN)>;
	tdc1000_errb_pin: tdc1000_errb_pin {
		gpios = <&gpio0 30 0>;
	leds {
		compatible = "gpio-leds";
		dbg_rx: dbg_rx {
			gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
		dbg_tx: dbg_tx {
			gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>;
&gpio0 {
	status = "okay";
&adc {
	status = "okay";
	#address-cells = <1>;
	#size-cells = <0>;
	channel@0 {
		reg = <0>;
		zephyr,gain = "ADC_GAIN_1_3";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS,10)>;
		zephyr,input-positive = <NRF_SAADC_AIN0>;
		zephyr,resolution = <12>; /* 0.055C per ADC step */
		zephyr,oversampling = <2>; /* x4 */
	channel@1 {
		reg = <1>;
		zephyr,input-positive = <NRF_SAADC_AIN1>;
	channel@2 {
		reg = <2>;
		zephyr,gain = "ADC_GAIN_1_4";
		zephyr,reference = "ADC_REF_VDD_1_4";
		zephyr,acquisition-time = <ADC_ACQ_TIME_DEFAULT>;
		zephyr,input-positive = <NRF_SAADC_AIN2>;
		zephyr,vref-mv = <825>;
&i2c0 {
	status = "okay";
	pinctrl-0 = <&i2c0_default>;
	pinctrl-1 = <&i2c0_sleep>;
	lis3dh@19 {
		compatible = "st,lis2dh";
		reg = <0x19>;
		irq-gpios = <&gpio0 5 GPIO_INT_WAKEUP>;
		disconnect-sdo-sa0-pull-up;
&spi1 {
	status = "okay";
	cs-gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi1_default>;
	pinctrl-1 = <&spi1_sleep>;
	gendev: gendev@0 {
		status = "okay";
		compatible = "vnd,spi-device";
		reg = <0>;
		spi-max-frequency = <1600000>;
		label = "GenDev";
&uart0 {
	status = "okay";
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
	modem: modem {
		status = "disabled";
		compatible = "quectel,bg9x";
		mdm-power-gpios = <&gpio0 23 0>;
		mdm-reset-gpios = <&gpio0 19 0>;
&rtc0 {
	status = "okay";
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_default>;
	pinctrl-1 = <&pwm0_sleep>;
	tdc_clk_in: tdc_clk_in {
		status = "okay";
		compatible = "pwm-clock";
		#clock-cells = <1>;
		pwms = <&pwm0 0 PWM_HZ(4000000) PWM_POLARITY_NORMAL>;
&pinctrl {
	i2c0_default: i2c0_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SCL, 0, 13)>, <NRF_PSEL(TWIM_SDA, 0, 12)>;
	i2c0_sleep: i2c0_sleep {
		group1 {
			low-power-enable;
	spi1_default: spi1_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 22)>,
			        <NRF_PSEL(SPIM_MOSI, 0, 20)>,
			        <NRF_PSEL(SPIM_MISO, 0, 17)>;
	spi1_sleep: spi1_sleep {
		group1 {
			low-power-enable;
	pwm0_default: pwm0_default {
		group1 {
			psels = <NRF_PSEL(PWM_OUT0, 0, 27)>; // TDC_CLK_8MHZ
	pwm0_sleep: pwm0_sleep {
		group1 {
			low-power-enable;
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 16)>, <NRF_PSEL(UART_RX, 0, 15)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
&reg {
	regulator-initial-mode = <NRF5X_REG_MODE_LDO>;
// &gpiote0 {
//     interrupts = <6 1>;
and I got a average consumption of around 40uA.
When I try the system_off in my project it doesn't work and the consumption is around 6mA.
nrf52kbd_nrf52832.overlay
	aliases {
		modem = &modem;
		dbg-rx = &dbg_rx;
		dbg-tx = &dbg_tx;
		status = "okay";
		status = "okay";
	zephyr,user {
	leds {
		dbg_rx: dbg_rx {
		dbg_tx: dbg_tx {
&gpio0 {
	status = "okay";
&adc {
	status = "okay";
	#size-cells = <0>;
	channel@0 {
		reg = <0>;
	channel@1 {
		reg = <1>;
	channel@2 {
		reg = <2>;
&i2c0 {
	status = "okay";
	lis3dh@19 {
		reg = <0x19>;
&spi1 {
	status = "okay";
	gendev: gendev@0 {
		status = "okay";
		reg = <0>;
		label = "GenDev";
&uart0 {
	status = "okay";
	modem: modem {
&rtc0 {
	status = "okay";
&pwm0 {
	status = "okay";
		status = "okay";
		#clock-cells = <1>;
&pinctrl {
		group1 {
		group1 {
			low-power-enable;
		group1 {
		group1 {
			low-power-enable;
		group1 {
		group1 {
			low-power-enable;
		group1 {
		group1 {
			low-power-enable;
&reg {
// &gpiote0 {
prj.conf
CONFIG_SENSOR=y
CONFIG_LIS2DH=y
CONFIG_I2C=y
CONFIG_GPIO=y
CONFIG_LOG=n
CONFIG_USE_SEGGER_RTT=n
CONFIG_CONSOLE=n
CONFIG_RTT_CONSOLE=n
CONFIG_UART_CONSOLE=n
CONFIG_SERIAL=y
CONFIG_ADC=y
CONFIG_MCP970X=y
CONFIG_BT=y
CONFIG_PWM=y
CONFIG_CLOCK_CONTROL=y
CONFIG_SPI=y
CONFIG_WDT_LOG_LEVEL_INF=n
CONFIG_WATCHDOG=n
CONFIG_WDT_DISABLE_AT_BOOT=n
CONFIG_REQUIRES_FLOAT_PRINTF=y
CONFIG_BT_DEVICE_NAME="Beacon"
CONFIG_MAIN_THREAD_PRIORITY=10
CONFIG_LIS2DH_TRIGGER_GLOBAL_THREAD=y
CONFIG_LIS2DH_ACCEL_RANGE_2G=y
CONFIG_LIS2DH_OPER_MODE_LOW_POWER=y
CONFIG_LIS2DH_ODR_1=y
CONFIG_LIS2DH_ODR_RUNTIME=y
CONFIG_NRFX_TIMER0=y
CONFIG_NRFX_PPI=y
CONFIG_PM_DEVICE=y
CONFIG_POWEROFF=y
main.c
#include <stdio.h>
#include <stdbool.h>
#include <stdlib.h>
#include <zephyr/kernel.h>
#include <zephyr/usb/usb_device.h>
#include <zephyr/usb/usbd.h>
#include <zephyr/drivers/uart.h>
// #include <zephyr/drivers/watchdog.h>
#include <zephyr/pm/device.h>
#include <zephyr/sys/poweroff.h>
#include <zephyr/sys/util.h>
#include "accel_reader.h"
#include "tank_reader.h"
#include "cellular_handler.h"
#include "ble_handler.h"
/****************************************************** Asserts *******************************************************/
/****************************************************** Defines *******************************************************/
#define SLEEP_TIME_FOR_FLUSHING_MS 5000
// #define WDT_OPT 0
/****************************************************** Typedefs ******************************************************/
/***************************************************** Constants ******************************************************/
LOG_MODULE_REGISTER(main, LOG_LEVEL_INF);
const struct device *const sensor = DEVICE_DT_GET_ANY(st_lis2dh);
/***************************************************** Variables ******************************************************/
/*********************************************** Internal Declarations ************************************************/
/***************************************************** Functions ******************************************************/
    while (1)
        int err;
        /* Power down the ACCEL reader device */
        err = pm_device_action_run(sensor, PM_DEVICE_ACTION_SUSPEND);
        if (err) {
            LOG_ERR("pm_device_action_run() failed (%d)\n", err);
        sys_poweroff();
    return 0;
/************************************************* Internal Functions *************************************************/
What could be the issue here? The only difference are the proj.conf files and the fact that in my project I'm using the nrf52kbd_nrf52832.overlay instead of the nrf52dk_nrf52832.overlay. Btw, I'm using the PPK2 to do the measurements.
Also, any suggestions/advices on how can I achieve the best low power performance?
Thank you for the ongoing support,
Fernando Fontes
  • Hi Simon,
    What do you suggest to check if the current is actually going to the nRF52? Cut the CS line and measure there?
    The TDC1000 which is where the CS pins connects to is being powered via two different pmos:
    Since the pmos is off there's no voltage going to the supply pins (VDD1, VDD2, VIO). There is always some leakage but not enough to power the TDC1000. That's why it's super strange the 6mA. Shouldn't the gpio_pin_configure_dt(&cs_gpio,GPIO_OUTPUT_INACTIVE) make the pin to low logic level? Meaning, 0V? That would make almost impossible for current to be flowing trough the CS pin.
    ppk2-6mA.ppk2ppk2-50u.ppk2
    I've uploaded the 6mA (1 min) version and the 50uA (3 min) version. Sorry, reduced to 1 min when I saw the file size :).
    Fernando Fontes
  • Hi everyone,
    Following up on this investigation, I’ve conducted several tests:
    1. Unsoldered the TDC1000 from the PCB
      • No improvements. The average current remained around 42µA.
      • However, I no longer needed to configure cs_gpio as INPUT to achieve this current.
      • This suggests that the TDC1000 is responsible for drawing 6mA when the pin is not set as input, likely due to leakage.
    2. Unsoldered the LIS3DH from the PCB
      • Significant improvements. The average current dropped from 42µA to 2.5µA, which is close to the expected minimum when not using the DC-DC converter.
    3. Unsoldered the Quectel modem from the PCB
      • No improvements.
    Since the LIS3DH’s expected consumption in low-power mode is about 1µA, the 42µA reading didn’t make sense. With the LIS3DH removed, the current consumption was as expected, confirming that the I2C pull-ups were not the issue. However, if LIS_INT is at logic level 0, a current of 33µA is expected—adding this to the 2.5µA explains the measured increase.
    To further investigate, I re-soldered the LIS3DH and removed R30, which resulted in an average current consumption of 3.26µA.
    At this point, I believe the issue is mostly resolved, and I don't expect to get much lower consumption. I also attempted to set the LIS_INT pin to OUTPUT_HIGH before going to sleep, expecting it to resolve the issue, but it didn't. Since the correct current consumption is observed with the LIS3DH removed, it seems that the LIS3DH itself is pulling INT1 low. I’ll continue investigating potential configurations within the LIS3DH to address this (change the interrupt polarity for instance).
    This brings me close to a final solution. However, I have one remaining question:
    I can't use system off since I need periodic wake-ups. What is the best approach to optimize power consumption in system on mode? I assume calling pm_device_action_run(..., PM_DEVICE_ACTION_SUSPEND) is the correct approach, but what’s the best way to sleep until the next wake-up? Is k_sleep() sufficient, or should I rely on the RTC for better efficiency?
    Fernando Fontes
  • Hi Fernando
    Glad to hear a lot here is resolved on your end with testing.
    Regarding system ON mode, k_sleep should be sufficient I believe. The RTC should be used if you need a counter to keep track of time or similar while in sleep mode, but should not be necessary in otherwise.
    Simon
  • I have a similar situation that is making me arrive at this same conclusion:
    I need to maintain the RTC even in "low-power" mode so that I can maintain the day/time on an nrf52832-based custom board. I am understanding I will likely need to implement this in software without entering system off mode.
    I have seen in several blogs that I cannot use sys_poweroff(), as this will halt all clock sources. However I do have an external crystal hooked up to p0.00 and p0.01. Is it true that I still can't use sys_poweroff() even if I have an external clock source?
    When I use sys_poweroff() I can boot back up on button press and I see 46uA drawn while in system off mode. This is good enough for now and I think I can get it lower. However when I replace sys_poweroff() with k_sleep(K_FOREVER) I see 1.44mA drawn. I know my hardware is different but if I am still powering down all peripherals the same way, what would be the reason for the difference between the sys_poweroff()drawing 46uA and k_sleep drawing 1.44mA?
  • Hi Robert
    The 32.768kHz crystal connected to P0.00 and P0.01 will also not be counted by the nRF52832 while in system OFF mode, as the CPU is turned off entirely.
    1.44mA sounds very high if all peripherals are turned off, so I think something hasn't been shut down correctly, that tthe sys_poweroff() is taking care of for you. It's hard to say based on this what exactly, so I suggest you create a new DevZone ticket where you describe in detail what you're doing, what you're trying to do, and what goes wrong exactly.
    Simon
