Sorry for the many tickets the past few days, but I am ramping up to start a nRF Connect SDK project on a nRF91 modem and have encountered some initial growing pains (And other bugs). Hopefully this will be my last one for a while since this is my remaining hurdle for starting a new project. I am new to Zephyr and the NRF Connect SDK.
- OS: Windows 11
- SDK/Toolchain: 2.9.0
From my understanding, it is not possible to save a build configuration in the nRF Connect VS Code extension per this guide: https://docs.nordicsemi.com/bundle/nrf-connect-vscode/page/guides/build_config.html#how-to-save-a-build-configuration-as-a-preset
From the guide "Sysbuild configurations cannot be saved as presets".
There are a bunch of configuration options in the build configuration wizard. If there is no way to save this when sharing a project via version control, it is prone to user error of selecting the wrong configuration items, resulting in the application building differently for different developers, which obviously is not good.
I am looking for a workaround for this.
Question: Since the nRF Connect extension cannot save the build configuration for sysbuild projects, what CLI commands can I use to generate the build configuration automatically with my predefined board that the nRF Connect VS Code extension will then "see" when I edit the build configuration?
As a test, I captured the output when creating a build configuration using the nRF Connect extension. The only selection I made was to set the board to 'nrf9161dk/nrf9161/ns':
Building application
C:\Windows\system32\cmd.e x e /d /s /c "west build --build-dir c:/ncs_workspace/test_app/application/build c:/ncs_workspace/test_app/application --pristine --board nrf9161dk/nrf9161/ns --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE"
-- west build: generating a build system ...
Please note that I had to space out the text cmd."e x e" in the above command because otherwise the Devzone would return the error "Could not create ticket" when trying to post it.
From the above, I created the following batch script and added the command above:
@echo off set BOARD_NAME=nrf9161dk/nrf9161/ns set BUILD_DIR=application/build set APP_DIR=application REM Clean existing build directory if exist %BUILD_DIR% ( echo Cleaning existing build directory... rmdir /s /q %BUILD_DIR% ) REM Generate build configuration echo Creating build configuration for board: %BOARD_NAME% west build --build-dir %BUILD_DIR% %APP_DIR% --pristine --board %BOARD_NAME% --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE REM Check if build succeeded if %ERRORLEVEL%==0 ( echo Build configuration succeeded! ) else ( echo Build configuration failed. exit /b 1 )
I run this in the nRF Connect terminal within VS Code. The build configuration succeeds with the following output:
PS C:\ncs_workspace\test_app> PS C:\ncs_workspace\test_app> .\build_config.bat Creating build configuration for board: nrf9161dk/nrf9161/ns -- west build: generating a build system Loading Zephyr module(s) (Zephyr base): sysbuild_default -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: C:/ncs_workspace/test_app/external/zephyr/.cache -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf9161dk, Revision: 0.9.0, qualifiers: nrf9161/ns Parsing C:/ncs_workspace/test_app/external/zephyr/share/sysbuild/Kconfig Loaded configuration 'C:/ncs_workspace/test_app/application/build/_sysbuild/empty.conf' Merged configuration 'C:/ncs_workspace/test_app/application/build/_sysbuild/empty.conf' Merged configuration 'C:/ncs_workspace/test_app/application/build/_sysbuild/empty.conf' Configuration saved to 'C:/ncs_workspace/test_app/application/build/zephyr/.config' Kconfig header saved to 'C:/ncs_workspace/test_app/application/build/_sysbuild/autoconf.h' -- ********************************* * Running CMake for application * ********************************* Loading Zephyr default modules (Zephyr base). -- Application: C:/ncs_workspace/test_app/application -- CMake version: 3.21.0 -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: C:/ncs_workspace/test_app/external/zephyr/.cache -- Zephyr version: 3.7.99 (C:/ncs_workspace/test_app/external/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: nrf9161dk, Revision: 0.9.0, qualifiers: nrf9161/ns -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk) -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk) -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6") -- Found BOARD.dts: C:/ncs_workspace/test_app/external/zephyr/boards/nordic/nrf9161dk/nrf9161dk_nrf9161_ns.dts -- Generated zephyr.dts: C:/ncs_workspace/test_app/application/build/application/zephyr/zephyr.dts -- Generated devicetree_generated.h: C:/ncs_workspace/test_app/application/build/application/zephyr/include/generated/zephyr/devicetree_generated.h -- Including generated dts.cmake file: C:/ncs_workspace/test_app/application/build/application/zephyr/dts.cmake warning: Deprecated symbol NET_SOCKETS_POSIX_NAMES is enabled. Parsing C:/ncs_workspace/test_app/external/zephyr/Kconfig Loaded configuration 'C:/ncs_workspace/test_app/external/zephyr/boards/nordic/nrf9161dk/nrf9161dk_nrf9161_ns_defconfig' Merged configuration 'C:/ncs_workspace/test_app/application/prj.conf' Merged configuration 'C:/ncs_workspace/test_app/application/build/application/zephyr/.config.sysbuild' Configuration saved to 'C:/ncs_workspace/test_app/application/build/application/zephyr/.config' Kconfig header saved to 'C:/ncs_workspace/test_app/application/build/application/zephyr/include/generated/zephyr/autoconf.h' -- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38") -- The C compiler identification is GNU 12.2.0 -- The CXX compiler identification is GNU 12.2.0 -- The ASM compiler identification is GNU -- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe =========== Generating psa_crypto_config =============== Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False Backup: CONFIG_MBEDTLS_THREADING: False Backup: CONFIG_MBEDTLS_THREADING_ALT: False =========== Checkpoint: backup =============== Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False Restore: CONFIG_MBEDTLS_THREADING: False Restore: CONFIG_MBEDTLS_THREADING_ALT: False =========== End psa_crypto_config =============== =========== Generating psa_crypto_library_config =============== Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: False Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False Backup: CONFIG_MBEDTLS_THREADING: False Backup: CONFIG_MBEDTLS_THREADING_ALT: False =========== Checkpoint: backup =============== Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: False Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False Restore: CONFIG_MBEDTLS_THREADING: False Restore: CONFIG_MBEDTLS_THREADING_ALT: False =========== End psa_crypto_library_config =============== -- Setting build type to 'MinSizeRel' as none was specified. -- Configuring done -- Generating done -- Build files have been written to: C:/ncs_workspace/test_app/application/build/application Dropping partition 'nrf_modem_lib_trace' since its size is 0. Dropping partition 'nonsecure_storage' since it is empty. -- Configuring done -- Generating done -- Build files have been written to: C:/ncs_workspace/test_app/application/build Build configuration succeeded! PS C:\ncs_workspace\test_app>
I can see the build configuration in VS Code, yay!:
However, when I attempt to edit the build configuration with VS Code, I see the following (The board is incorrect):
Any idea why the configurator doesn't display the correct board and shows the yellow text warning? Any suggestions on how I can achieve my goal?
Derek
