I get the error "ImportError: Module use of python312.dll conflicts with this version of Python." when I try to flash my device using any Python version below 3.12.x. I get no error when I try to build the project.
However, when I set the global Python version to 3.12.0 using pyenv, it first and foremost correctly doesn't recognize the nrfutil package until I install it into the new version, which is a sign that it has correctly changed the version, but I also get a new error related to not having the package "constants." When I pip install that I get a third error:
versions\3.12.0\Lib\site-packages\nordicsemi\lister\windows\lister_win32.py", line 43, in <module>
from constants import DIGCF_PRESENT, DEVPKEY, DIGCF_DEVICEINTERFACE
ImportError: cannot import name 'DIGCF_PRESENT' from 'constants' (C:\Users\DripTooHard\.pyenv\pyenv-win\versions\3.12.0\Lib\site-packages\constants.py)Looking online, it seems like the fix to this issue is to downgrade to 3.8 or 3.9. But this just goes back to me having the original error.
I tried looking at the support information, and it seems like the toolchain is reffering to a Python 3.12.4 version?
// IMPORTANT: The following data can contain sensitive or confidential information about your environment.
// If you do not want others to see this information, make sure to remove it before sharing the data.
// For help and support, visit Nordic Semiconductor's DevZone at https://devzone.nordicsemi.com/.
"platform": {
"os": "win32",
"osVersion": "Windows 11 Home",
"osKernel": "10.0.26100",
"vscode": "1.96.4",
"electron": "32.2.6",
"node": "v20.18.1"
"system": {
"date": "2025-01-30T15:19:16.999Z",
"vscodeRoot": "d:\\DripTooHard\\Microsoft VS Code\\resources\\app",
"vscodeUptime": "00:12:00",
"osUptime": "00:36:06",
"cpu": "11th Gen Intel(R) Core(TM) i5-11400H @ 2.70GHz"
"workspace": {
"name": "record_launch_app",
"workspaceFile": null,
"folders": [
"d:\\ncs\\v2.8.0\\nrf\\samples\\nfc\\record_launch_app"
"sdks": [
"version": "v2.8.0",
"path": "d:\\ncs\\v2.8.0"
"activeBuild": "d:\\ncs\\v2.8.0\\nrf\\samples\\nfc\\record_launch_app\\build",
"apps": [
"workspace": "d:\\ncs\\v2.8.0\\nrf\\samples\\nfc\\record_launch_app",
"uri": "d:\\ncs\\v2.8.0\\nrf\\samples\\nfc\\record_launch_app",
"buildConfigurations": [
"id": "d:\\ncs\\v2.8.0\\nrf\\samples\\nfc\\record_launch_app\\build",
"name": "build",
"boardId": "nrf54l15dk/nrf54l15/cpuapp",
"type": "Sysbuild",
"isChild": false,
"isStale": false,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"sdk": "d:\\ncs\\v2.8.0",
"toolchain": "nRF Connect SDK Toolchain v2.8.0"
"toolchains": [
"version": "2.8.0",
"path": "c:\\ncs\\toolchains\\2d382dcd92"
"connectedDevices": [
"serialNumber": "001057733114"
"tools": {
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.8",
"C:\\Program Files\\SEGGER\\JLink_V794i\\JLink.exe": "7.94i",
"C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.0",
"C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\shims\\nrfutil": null,
"C:\\ncs\\toolchains\\2d382dcd92\\cmake": "3.21.0",
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\Scripts\\west.exe": "1.2.0",
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\python.exe": "3.12.4",
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\ninja.exe": "1.10.2",
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\gperf.exe": "3.1",
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\dtc.exe": "1.4.7",
"C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\gn.exe": "2201",
"C:\\ncs\\toolchains\\2d382dcd92\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
"arm-gdbPath": "c:\\ncs\\toolchains\\2d382dcd92\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
"riscv-gdbPath": "C:\\ncs\\toolchains\\2d382dcd92\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
"nrfutil": {
"nrfutil-device": {
"version": "2.7.9",
"binPath": "c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
"jlinkInfo": {
"name": "JlinkARM",
"version": "JLink_V7.94i",
"versionFormat": "string"
"nrfutil-toolchain-manager": {
"version": "0.14.4",
"binPath": "c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"HOME": "C:\\Users\\DripTooHard",
"HOMEDRIVE": "C:",
"HOMEPATH": "\\Users\\DripTooHard",
"PATH": "C:\\ncs\\toolchains\\2d382dcd92;C:\\ncs\\toolchains\\2d382dcd92\\mingw64\\bin;C:\\ncs\\toolchains\\2d382dcd92\\bin;C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin;C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\2d382dcd92\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\2d382dcd92\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\2d382dcd92\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files\\NVIDIA GPU Computing Toolkit\\CUDA\\v12.0\\bin;C:\\Program Files\\NVIDIA GPU Computing Toolkit\\CUDA\\v12.0\\libnvvp;C:\\Program Files\\Java\\jdk-19\\bin;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Microsoft\\jdk-11.0.12.7-hotspot\\bin;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Program Files\\PuTTY\\;C:\\Program Files\\GitHub CLI\\;C:\\Program Files\\dotnet\\;C:\\MinGW\\bin;C:\\Program Files (x86)\\sbt\\bin;C:\\Program Files\\nodejs\\;C:\\Program Files\\NVIDIA Corporation\\Nsight Compute 2022.4.0\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Users\\DripTooHard\\AppData\\Local\\Programs\\Python\\Python38-32;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git LFS;C:\\Users\\DripTooHard\\Downloads\\hugo_0.111.3_windows-amd64;C:\\Program Files\\Docker\\Docker\\resources\\bin;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\DripTooHard\\PycharmProjects\\pythonProject1\\msedgedriver.exe;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin\\arm-none-eabi-addr2line.exe;C:\\Users\\DripTooHard\\AppData\\Local\\Android\\Sdk\\platform-tools;C:\\Program Files\\Vagrant\\bin;C:\\Users\\DripTooHard\\Spin\\Bin;D:\\bin;D:\\Matlab\\runtime\\win64;D:\\Matlab\\bin;C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\bin;C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\shims;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\JetBrains\\PyCharm 2022.2.1\\bin;C:\\Users\\DripTooHard\\.dotnet\\tools;C:\\Program Files\\JetBrains\\IntelliJ IDEA 2022.2.1\\bin;C:\\Program Files\\JetBrains\\CLion 2022.2.1\\bin;C:\\Users\\DripTooHard\\AppData\\Roaming\\npm;C:\\Users\\DripTooHard\\go\\bin;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WinGet\\Packages\\Hugo.Hugo.Extended_Microsoft.Winget.Source_8wekyb3d8bbwe;C:\\Program Files\\JetBrains\\WebStorm 2023.3\\bin;D:\\DripTooHard\\Microsoft VS Code\\bin;",
"ZEPHYR_BASE": "d:\\ncs\\v2.8.0\\zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\2d382dcd92\\opt\\zephyr-sdk",
"PYTHONPATH": "C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin;C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\Lib;C:\\ncs\\toolchains\\2d382dcd92\\opt\\bin\\Lib\\site-packages"
"inherited": {
"HOMEDRIVE": "C:",
"Path": "C:\\Program Files\\NVIDIA GPU Computing Toolkit\\CUDA\\v12.0\\bin;C:\\Program Files\\NVIDIA GPU Computing Toolkit\\CUDA\\v12.0\\libnvvp;C:\\Program Files\\Java\\jdk-19\\bin;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Microsoft\\jdk-11.0.12.7-hotspot\\bin;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Program Files\\PuTTY\\;C:\\Program Files\\GitHub CLI\\;C:\\Program Files\\dotnet\\;C:\\MinGW\\bin;C:\\Program Files (x86)\\sbt\\bin;C:\\Program Files\\nodejs\\;C:\\Program Files\\NVIDIA Corporation\\Nsight Compute 2022.4.0\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Users\\DripTooHard\\AppData\\Local\\Programs\\Python\\Python38-32;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git LFS;C:\\Users\\DripTooHard\\Downloads\\hugo_0.111.3_windows-amd64;C:\\Program Files\\Docker\\Docker\\resources\\bin;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\DripTooHard\\PycharmProjects\\pythonProject1\\msedgedriver.exe;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin\\arm-none-eabi-addr2line.exe;C:\\Users\\DripTooHard\\AppData\\Local\\Android\\Sdk\\platform-tools;C:\\Program Files\\Vagrant\\bin;C:\\Users\\DripTooHard\\Spin\\Bin;D:\\bin;D:\\Matlab\\runtime\\win64;D:\\Matlab\\bin;C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\bin;C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\shims;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin;C:\\Users\\DripTooHard\\AppData\\Local\\Programs\\Python\\Python38-32;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\JetBrains\\PyCharm 2022.2.1\\bin;C:\\Users\\DripTooHard\\.dotnet\\tools;C:\\Program Files\\JetBrains\\IntelliJ IDEA 2022.2.1\\bin;C:\\MinGW\\bin;C:\\Program Files\\JetBrains\\CLion 2022.2.1\\bin;C:\\Users\\DripTooHard\\AppData\\Roaming\\npm;C:\\Users\\DripTooHard\\go\\bin;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WinGet\\Packages\\Hugo.Hugo.Extended_Microsoft.Winget.Source_8wekyb3d8bbwe;C:\\Program Files\\JetBrains\\WebStorm 2023.3\\bin;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin\\arm-none-eabi-addr2line.exe;C:\\Users\\DripTooHard\\AppData\\Local\\Android\\Sdk\\platform-tools;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WindowsApps;D:\\DripTooHard\\Microsoft VS Code\\bin;",
"PATH": "C:\\Program Files\\NVIDIA GPU Computing Toolkit\\CUDA\\v12.0\\bin;C:\\Program Files\\NVIDIA GPU Computing Toolkit\\CUDA\\v12.0\\libnvvp;C:\\Program Files\\Java\\jdk-19\\bin;C:\\Program Files\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\java8path;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Program Files\\Microsoft\\jdk-11.0.12.7-hotspot\\bin;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\NVIDIA Corporation\\NVIDIA NvDLISR;C:\\Program Files\\PuTTY\\;C:\\Program Files\\GitHub CLI\\;C:\\Program Files\\dotnet\\;C:\\MinGW\\bin;C:\\Program Files (x86)\\sbt\\bin;C:\\Program Files\\nodejs\\;C:\\Program Files\\NVIDIA Corporation\\Nsight Compute 2022.4.0\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\Users\\DripTooHard\\AppData\\Local\\Programs\\Python\\Python38-32;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\Git LFS;C:\\Users\\DripTooHard\\Downloads\\hugo_0.111.3_windows-amd64;C:\\Program Files\\Docker\\Docker\\resources\\bin;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\DripTooHard\\PycharmProjects\\pythonProject1\\msedgedriver.exe;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin\\arm-none-eabi-addr2line.exe;C:\\Users\\DripTooHard\\AppData\\Local\\Android\\Sdk\\platform-tools;C:\\Program Files\\Vagrant\\bin;C:\\Users\\DripTooHard\\Spin\\Bin;D:\\bin;D:\\Matlab\\runtime\\win64;D:\\Matlab\\bin;C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\bin;C:\\Users\\DripTooHard\\.pyenv\\pyenv-win\\shims;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin;C:\\Users\\DripTooHard\\AppData\\Local\\Programs\\Python\\Python38-32;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files\\JetBrains\\PyCharm 2022.2.1\\bin;C:\\Users\\DripTooHard\\.dotnet\\tools;C:\\Program Files\\JetBrains\\IntelliJ IDEA 2022.2.1\\bin;C:\\MinGW\\bin;C:\\Program Files\\JetBrains\\CLion 2022.2.1\\bin;C:\\Users\\DripTooHard\\AppData\\Roaming\\npm;C:\\Users\\DripTooHard\\go\\bin;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WinGet\\Packages\\Hugo.Hugo.Extended_Microsoft.Winget.Source_8wekyb3d8bbwe;C:\\Program Files\\JetBrains\\WebStorm 2023.3\\bin;C:\\Program Files (x86)\\Arm GNU Toolchain arm-none-eabi\\13.2 Rel1\\bin\\arm-none-eabi-addr2line.exe;C:\\Users\\DripTooHard\\AppData\\Local\\Android\\Sdk\\platform-tools;C:\\Users\\DripTooHard\\AppData\\Local\\Microsoft\\WindowsApps;D:\\DripTooHard\\Microsoft VS Code\\bin;"
"terminal": {
"defaultProfile": "PowerShell"
"config": {
"topdir": "",
"toolchain": {
"path": ""
"ozonePath": "",
"applications": [],
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": false
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": false,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"terminalProfile": {
"shell": null
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2025.1.127",
"path": "c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2025.1.127-win32-x64",
"isActive": true
"version": "2024.9.14",
"path": "c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.9.14",
"isActive": true
"version": "2024.12.15",
"path": "c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.12.15",
"isActive": true
"version": "2024.12.13",
"path": "c:\\Users\\DripTooHard\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.12.13",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.23.5",
"ms-vscode.js-debug": "1.96.0",
"Arm.arm-debugger": "1.4.4",
"Arm.cmsis-csolution": "1.46.0",
"Arm.device-manager": "1.13.1",
"Arm.embedded-debug": "1.2.2",
"Arm.environment-manager": "1.10.0",
"Arm.keil-studio-pack": "1.18.4",
"Arm.virtual-hardware": "0.6.3",
"cortex-debug.svd-viewer": "1.2.3",
"Draco.draco-dark": "0.0.3",
"eclipse-cdt.memory-inspector": "1.1.0",
"eclipse-cdt.peripheral-inspector": "1.5.1",
"formulahendry.code-runner": "0.12.2",
"GitHub.vscode-pull-request-github": "0.102.0",
"Ionide.Ionide-fsharp": "7.22.0",
"jdinhlife.gruvbox": "1.22.0",
"jeff-hykin.better-cpp-syntax": "1.27.1",
"lintangwisesa.arduino": "0.3.4",
"mnxn.fsharp-fsl-fsy": "0.0.1",
"mnxn.theme-golden-dracula": "1.2.8",
"ms-dotnettools.csharp": "2.61.28",
"ms-dotnettools.vscode-dotnet-pack": "1.0.13",
"ms-dotnettools.vscode-dotnet-runtime": "2.2.6",
"ms-toolsai.jupyter": "2024.11.0",
"ms-toolsai.jupyter-keymap": "1.1.2",
"ms-toolsai.jupyter-renderers": "1.0.21",
"ms-toolsai.vscode-jupyter-cell-tags": "0.1.9",
"ms-toolsai.vscode-jupyter-slideshow": "0.1.6",
"ms-vscode.cmake-tools": "1.19.52",
"ms-vscode.powershell": "2025.0.0",
"ms-vscode.vscode-serial-monitor": "0.13.1",
"platformio.platformio-ide": "3.3.4",
"redhat.vscode-yaml": "1.15.0",
"rokoroku.vscode-theme-darcula": "1.2.3",
"twxs.cmake": "0.0.17",
"vscjava.vscode-gradle": "3.16.4",
"yigits.nordic-vibes": "0.0.3"
}I am wondering if the fix would be to somehow change the python version in the toolchain, but I would like to hear first if you have any other suggestions? I have gone through my path and replaced all occurances of Python with a refference to 3.8.6, but once again, it appears that pyenv is correctly setting the right python versions, so this is most likely not a path issue.
