About GPIO pin problem.
Hello Developers,
I am working with the nRF52833 microcontroller using segger embedded studio with the latest SDK. My issue is that I can configure and use all GPIOs except P0.18. I'm unsure why this is happening.
In my case, I am using a basic LED blink code with a green LED, but when I try to toggle it using P0.18, it does not work. However, all other pins function correctly.
Can anyone help me to resolve this issue?
#include <stdio.h>
#include <nrf_gpio.h>
//LED1
#define G_LED1         NRF_GPIO_PIN_MAP(0,18)
#define LDO_TRANS_PIN2       NRF_GPIO_PIN_MAP(1, 1)
void configure_pins(void)
    nrf_gpio_cfg(G_LED1, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_CONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_S0S1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_cfg(LDO_TRANS_PIN1, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNEC_GPIO_PIN_NOPULL, NRF_GPIO_PIN_S0S1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_pin_set(LDO_TRANS_PIN1);
void delay_ms(uint32_t ms)
    for (uint32_t i = 0; i < (ms * 850); i++);
void delay_s(uint32_t s)
    delay_ms(s * 2000);
    configure_pins();
    while (1)
     nrf_gpio_pin_toggle(G_LED1);
     printf("G_LED1 status: %d\n", nrf_gpio_pin_read(G_LED1));
     delay_s(1);
  • On the nRF52833 P0.18 is optionally available as an active-low reset pin. To restore io pin mode look for and remove the setting for using the pin as a reset and then do a FLASH erase to erase UICR. P0.18: Once a reset pin always a reset pin until a UICR erase.
    4.5 UICR — User information configuration registers
    Register Offset Description
    PSELRESET[0] 0x200 Mapping of the nRESET function (see POWER chapter for details)
    PSELRESET[1] 0x204 Mapping of the nRESET function (see POWER chapter for details)
    Note: All PSELRESET registers have to contain the same value for a pin mapping to be valid. If values are not the same, there will be no nRESET function exposed on a GPIO. As a result, the device will always start independently of the levels present on any of the GPIOs.
  • #include <stdio.h>
    #include <stdint.h>
    #include "nrf_gpio.h"
    #include "nrf_nvmc.h"
    #include "nrf.h"
    // Define GPIO Pins
    // Function to check and erase UICR if P0.18 is set as nRESET
    void disable_reset_pin(void)
        if (NRF_UICR->PSELRESET[0] != 0xFFFFFFFF || NRF_UICR->PSELRESET[1] != 0xFFFFFFFF)
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Een; // Enable erase mode
            while (NRF_NVMC->READY == NVMC_READY_READY_Busy);
            NRF_NVMC->ERASEUICR = 1; // Erase UICR
            NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren; // Disable erase mode
            NVIC_SystemReset(); // Reset MCU to apply changes
        nrf_gpio_cfg(LDO_TRANS_PIN2, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT,
        nrf_gpio_pin_set(LDO_TRANS_PIN2); // Set P1.1 HIGH
        delay_ms(s * 2000);
    // Main function
        disable_reset_pin();
        configure_pins();
        while (1)
            delay_s(1);
    I am erasing the UICR but still the pin is not working as GPIO
  • This code is run following every NVIC_SystemReset(), which will stop the pin working as a GPIO:
        /* Configure GPIO pads as pPin Reset pin if Pin Reset capabilities desired. If CONFIG_GPIO_AS_PINRESET is not
          defined, pin reset will not be available. One GPIO (see Product Specification to see which one) will then be
          reserved for PinReset and not available as normal GPIO. */
        #if defined (CONFIG_GPIO_AS_PINRESET)
            if (((NRF_UICR->PSELRESET[0] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos)) ||
                ((NRF_UICR->PSELRESET[1] & UICR_PSELRESET_CONNECT_Msk) != (UICR_PSELRESET_CONNECT_Connected << UICR_PSELRESET_CONNECT_Pos))){
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos; // Write Enable
                while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
                NRF_UICR->PSELRESET[0] = 21;
                NRF_UICR->PSELRESET[1] = 21;
                NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos; // Read-only Enable
                // UICR changes require a reset to be effective
                NVIC_SystemReset();
    CONFIG_GPIO_AS_PINRESET is used in the project file Pre-Processor options list and must be either removed or altered say to "notCONFIG_GPIO_AS_PINRESET"
