The difference between prj.conf and prj_release.conf
Since I encountered some issues, I would like to confirm the differences between these two files once again.
Apart from debug messages, can prj.conf be used for the final product release?
Are there any other important considerations, such as BIN file encryption or similar matters?
    I previously tried using only CONFIG_NRF_SECURE_APPROTECT_LOCK, but it did not disable the Flash read function. That’s why I attempted to enable all three configurations.
    By the way, the SDK version I’m using is 2.9.0.
    I have previously tried using SB_CONFIG_APPROTECT_LOCK=y. Unfortunately, it resulted in a compilation error.
    (v2.9.0) C:\nordic_prj\DL02_S2MB_KPD_Small> west build -p -b dl02_s2mb_kpd_small/nrf5340/cpuapp -- -DBOARD_ROOT=C:/nordic_prj/DL02_S2MB_KPD_Small -DCONF_FILE=prj.conf
    -- west build: making build dir C:\nordic_prj\DL02_S2MB_KPD_Small\build pristine
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.9.0/zephyr/.cache
    -- Board: dl02_s2mb_kpd_small, qualifiers: nrf5340/cpuapp
    Parsing C:/nordic_prj/DL02_S2MB_KPD_Small/Kconfig.sysbuild
    Loaded configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/_sysbuild/empty.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/sysbuild.conf'
    Configuration saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/zephyr/.config'
    Kconfig header saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/_sysbuild/autoconf.h'
    CMake Error at C:/ncs/v2.9.0/nrf/sysbuild/CMakeLists.txt:617 (set_config_bool):
      set_config_bool Function invoked with incorrect arguments for function
      named: set_config_bool
      cmake/modules/sysbuild_extensions.cmake:583 (nrf_PRE_CMAKE)
      cmake/modules/sysbuild_extensions.cmake:583 (cmake_language)
      cmake/modules/sysbuild_images.cmake:16 (sysbuild_module_call)
      cmake/modules/sysbuild_default.cmake:20 (include)
      C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/ncs/v2.9.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Using NCS Toolchain 2.8.20241119.782234748775 for building. (C:/ncs/toolchains/b620d30767/cmake)
    -- Zephyr version: 3.7.99 (C:/ncs/v2.9.0/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/nordic_prj/DL02_S2MB_KPD_Small/boards/sunion/dl02_s2mb_kpd_small/dl02_s2mb_kpd_small_nrf5340_cpuapp.dts
    -- Found devicetree overlay: C:/nordic_prj/DL02_S2MB_KPD_Small/sysbuild/mcuboot/boards/dl02_s2mb_kpd_small_nrf5340_cpuapp.overlay
    -- Found devicetree overlay: C:/ncs/v2.9.0/nrf/modules/mcuboot/flash_sim.overlay
    'label' is marked as deprecated in 'properties:' in C:/ncs/v2.9.0/zephyr/dts/bindings\mtd\jedec,spi-nor.yaml for node /soc/peripheral@50000000/spi@c000/mx25r6435f@0.
    node '/soc/peripheral@50000000/i2c@9000/outside@5B' compatible 'sunion,outside' has unknown vendor prefix 'sunion'
    node '/soc/peripheral@50000000/i2c@9000/store@50' compatible 'sunion,eeprom' has unknown vendor prefix 'sunion'
    node '/soc/peripheral@50000000/i2c@9000/timer@32' compatible 'sunion,rtc' has unknown vendor prefix 'sunion'
    -- Generated zephyr.dts: C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot/zephyr/dts.cmake
    warning: Experimental symbol ISR_TABLES_LOCAL_DECLARATION is enabled.
    Parsing C:/ncs/v2.9.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/boards/sunion/dl02_s2mb_kpd_small/dl02_s2mb_kpd_small_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/sysbuild/mcuboot/prj.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/sysbuild/mcuboot/boards/dl02_s2mb_kpd_small_nrf5340_cpuapp.conf'
    Merged configuration 'C:/ncs/v2.9.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Setting build type to 'MinSizeRel' as none was specified.
    MCUBoot bootloader key file: C:/ncs/v2.9.0/bootloader/mcuboot/root-ec-p256.pem
    MCUBoot bootloader encryption key file: C:/nordic_prj/DL02_S2MB_KPD_Small/custom_key_dir/encryption_key.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic_prj/DL02_S2MB_KPD_Small/build/mcuboot
       * Running CMake for ipc_radio *
    -- Application: C:/ncs/v2.9.0/nrf/applications/ipc_radio
    -- Board: dl02_s2mb_kpd_small, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: C:/nordic_prj/DL02_S2MB_KPD_Small/boards/sunion/dl02_s2mb_kpd_small/dl02_s2mb_kpd_small_nrf5340_cpunet.dts
    -- Generated zephyr.dts: C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio/zephyr/dts.cmake
    Parsing C:/ncs/v2.9.0/nrf/applications/ipc_radio/Kconfig
    Loaded configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/boards/sunion/dl02_s2mb_kpd_small/dl02_s2mb_kpd_small_nrf5340_cpunet_defconfig'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/sysbuild/ipc_radio/prj.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/sysbuild/ipc_radio/boards/dl02_s2mb_kpd_small_nrf5340_cpunet.conf'
    Merged configuration 'C:/ncs/v2.9.0/nrf/applications/ipc_radio/overlay-bt_hci_ipc.conf'
    Merged configuration 'C:/ncs/v2.9.0/nrf/applications/ipc_radio/overlay-802154.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio/zephyr/.config'
    Kconfig header saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio/zephyr/include/generated/zephyr/autoconf.h'
    -- libmetal version: 1.6.0 (C:/ncs/v2.9.0/nrf/applications/ipc_radio)
    -- Build type:
    -- Host:    Windows/AMD64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.6.1 (C:/ncs/v2.9.0/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    CMake Warning at C:/ncs/v2.9.0/zephyr/CMakeLists.txt:952 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
      No SOURCES given to Zephyr library: drivers__gpio
    CMake Warning at C:/ncs/v2.9.0/zephyr/CMakeLists.txt:2133 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic_prj/DL02_S2MB_KPD_Small/build/ipc_radio
       * Running CMake for b0n *
    -- Application: C:/ncs/v2.9.0/nrf/samples/nrf5340/netboot
    -- Generated zephyr.dts: C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n/zephyr/dts.cmake
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:42) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: SERIAL_HAS_DRIVER (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up UART_CONSOLE in
    the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
    Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    Parsing C:/ncs/v2.9.0/nrf/samples/nrf5340/netboot/Kconfig
    Merged configuration 'C:/ncs/v2.9.0/nrf/samples/nrf5340/netboot/prj.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n/zephyr/.config'
    Kconfig header saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n/zephyr/include/generated/zephyr/autoconf.h'
      No SOURCES given to Zephyr library: drivers__serial
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic_prj/DL02_S2MB_KPD_Small/build/b0n
       * Running CMake for DL02_S2MB_KPD_Small *
    -- Application: C:/nordic_prj/DL02_S2MB_KPD_Small
    -- Found devicetree overlay: C:/nordic_prj/DL02_S2MB_KPD_Small/boards/dl02_s2mb_kpd_small_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small/zephyr/dts.cmake
    warning: Deprecated symbol MBEDTLS_LEGACY_CRYPTO_C is enabled.
    warning: Deprecated symbol NET_SOCKETS_POSIX_NAMES is enabled.
    warning: Experimental symbol GPIO_ENABLE_DISABLE_INTERRUPT is enabled.
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/prj.conf'
    Merged configuration 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small/zephyr/.config.sysbuild'
    Configuration saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small/zephyr/.config'
    Kconfig header saved to 'C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: False
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    ################### OPENTHREAD REPORT ###################
    + Target device: nrf5340
    + Thread version: v1.4
    + OpenThread library feature set: Minimal Thread Device (MTD)
    + Thread device type: Sleepy End Device (SED)
    + OpenThread Library: openthread/lib/nrf5340_cpuapp/soft-float/v1.4/mtd/
    + OpenThread NCS revision: ncs-thread-reference-20241002
    + OpenThread NCS SHA: ee86dc26d
    + NCS revision: v2.9.0
    + NCS SHA: 7787b26498
    + No differences in the used Thread library in comparison to the NCS v2.8.0 release.
    ###################        END        ###################
    -- libmetal version: 1.6.0 (C:/nordic_prj/DL02_S2MB_KPD_Small)
    -- Build type:
    -- Machine: arm
    -- Machine: arm
    CMake Warning at C:/ncs/v2.9.0/nrfxlib/openthread/cmake/extensions.cmake:123 (message):
       CONFIG_MBEDTLS_ASN1_PARSE_C=y is required by the precompiled OpenThread libraries, but it has been configured differently in the current build.
       The minimal crypto configuration is stored under "Crypto configuration" section at: C:/ncs/v2.9.0/nrfxlib/openthread/lib/nrf5340_cpuapp/soft-float/v1.4/mtd//openthread_lib_configuration.txt
      C:/ncs/v2.9.0/nrfxlib/openthread/CMakeLists.txt:79 (check_openthread_dependencies)
       CONFIG_MBEDTLS_ASN1_WRITE_C=y is required by the precompiled OpenThread libraries, but it has been configured differently in the current build.
       CONFIG_MBEDTLS_USE_PSA_CRYPTO=y is required by the precompiled OpenThread libraries, but it has been configured differently in the current build.
    -- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found version "3.12.4") found components: Interpreter
    -- Including signing script: C:/ncs/v2.9.0/nrf/cmake/sysbuild/image_signing.cmake
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic_prj/DL02_S2MB_KPD_Small/build/DL02_S2MB_KPD_Small
    -- Found partition manager static configuration : C:/nordic_prj/DL02_S2MB_KPD_Small/pm_static_dl02_s2mb_kpd_small_nrf5340_cpuapp.yml
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_1' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary_1' is not included in the dynamic resolving since it is statically defined.
    Partition 'pcd_sram' is not included in the dynamic resolving since it is statically defined.
    Dropping partition 'hw_unique_key_partition' since its size is 0.
    See also "C:/nordic_prj/DL02_S2MB_KPD_Small/build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\b620d30767\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/b620d30767/opt/bin/python.exe '-BC:\nordic_prj\DL02_S2MB_KPD_Small\build' -GNinja -DBOARD=dl02_s2mb_kpd_small/nrf5340/cpuapp -DBOARD_ROOT=C:/nordic_prj/DL02_S2MB_KPD_Small -DCONF_FILE=prj.conf '-SC:\ncs\v2.9.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\nordic_prj\DL02_S2MB_KPD_Small'
  • Also set SB_CONFIG_SECURE_APPROTECT_LOCK=y.
    The errors is a bug of some sort: It should return a warning or something instead. I will report it internally
