UBX devkit & Custom board not responding in bootloader or app
Hello NRF crew
Setup:
Bootloader: MCUBOOT
RTOS: Zephyr
NRF toolchain: v2.6.1
Dev board: ubx_bmd360eval_nrf52811
Custom board: nrf52811 mounted without a DCDC converter, no extermal crystal and a LED
Problem
For a long time my setup worked fine and i could flash both boards, with different overlays and they would work as supposed. One day my west setup in VSCode stopped working, so i started making a custom toolchain, with west, docker, make and all the neccesary dependencies, to make a Zephyr project with the NRF SDK.
This is now working and building/Compiling the project. Cool, but now i cannot get any of the boards to respond on either RTT or UART. If i enable the bootloader, the LED indicating that the bootloader is active is on and never leaves the bootloader state.
If i remove the bootloader, the app is put on the boards, but it will not respond on anything either. I have tried flashing the boards with the files (Zephyr.hex, merged.hex and app_update.bin).
To flash the boards i have tried using the GUI flash tool from NRF Connect, NRFJprog and JLink, same outcome from all of them.
I am having trouble putting a debugger on the boards, with this setup.
I am worried it is because of memory l
ayout og some config makes it all crash. Hope someone can help me, thanks in advance.
mcuboot.conf
# Disable DCDC converter
CONFIG_BOARD_ENABLE_DCDC=n
# Use internal clock source
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
# Enable logging for MCUboot
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_INF=y
# Enable Serial Recovery over UART
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_UART=y
# Disable UART, since Serial Recovery uses it
CONFIG_UART_CONSOLE=n
# Configure boolader to use only one slot.
CONFIG_SINGLE_APPLICATION_SLOT=y
# Turn on a LED so we can see when Serial Recovery mode is active
CONFIG_MCUBOOT_INDICATION_LED=y
# Wait before booting
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU=y
CONFIG_BOOT_SERIAL_WAIT_FOR_DFU_TIMEOUT=5000
# No BOOT signature, used to remove TinyCrypt and MBEDTLS see: devzone.nordicsemi.com/.../using-zephyr-and-mcuboot-without-image-signatures
#CONFIG_BOOT_SIGNATURE_TYPE_NONE=y
prj.conf
CONFIG_GPIO=y
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable logging
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
# RTT console
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
# UART console
#Enable bluetooth subsystem
CONFIG_BT=y
CONFIG_BT_OBSERVER=y
CONFIG_BT_SCAN=y
# Enable Extended Scanning
CONFIG_BT_EXT_ADV=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_EXT_SCAN_BUF_SIZE=1650
# Zephyr Bluetooth LE Controller needs 16 event buffers to generate Extended
# Advertising Report for receiving the complete 1650 bytes of data
CONFIG_BT_BUF_EVT_RX_COUNT=8
# Set maximum scan data length for Extended Scanning in Bluetooth LE Controller
CONFIG_BT_CTLR_SCAN_DATA_LEN_MAX=1650
# Increase Zephyr Bluetooth LE Controller Rx buffer to receive complete chain
# of PDUs
CONFIG_BT_CTLR_RX_BUFFERS=8
#Was 16
#Needed for full Extended advertising support
CONFIG_BT_LL_SW_SPLIT=y
CONFIG_RING_BUFFER=y
#Disable signed images, used to remove TinyCrypt and MBEDTLS
#CONFIG_SIGN_IMAGES=n
# Lock stack sizes
CONFIG_MAIN_STACK_SIZE=512
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
pm_static.yml
mcuboot: #TODO Shrink this to just the mcuboot region
address: 0x0
end_address: 0xC000 # 48 KB
placement:
before:
- mcuboot_primary
region: flash_primary
mcuboot_pad:
address: 0xC000
end_address: 0xC800
placement:
before:
- mcuboot_primary_app
size: 0x800 # 2 KB
app:
address: 0xC800
end_address: 0x2e000
placement:
align:
start: 0x1000 # Align to 4 KB boundary of flash sector
size: 0x21800 # 136 KB
mcuboot_primary:
address: 0xC000
orig_span: &id001
- app
- mcuboot_pad
sharers: 0x1
size: 0x22000 # 136 KB
span: *id001
mcuboot_primary_app:
address: 0xC800
orig_span: &id002
- app
span: *id002
storage:
address: 0x2e000
end_address: 0x30000
size: 0x2000 # 8 KB
sram_primary:
address: 0x20000000
end_address: 0x20006000
region: sram_primary
size: 0x6000 # 24 KB
    Did you have a bootloader before your original setup started failing?
    How did it start failing in the first place?
    What does this mean? There is a debugger present on your board? And you are able to program it, right?
    How do you flash it? Do you use a command? VS Code?
    What tools are you trying to use to read the RTT or UART? Have you tried external terminals? J-Link RTT Viewer or Putty?
    Edvin
  • Hello Edvin,
    Yes i was already using the MCUBOOT bootloader and it worked flawless before.
    I have now mounted a debugger via arm-non-eabi GDB and Jlink GDB server.
    I have tried flashing it with the NRF connect GUI, JlinkEXE and nrfjprog, all with the same outcome.
    I have been using the Nrf connect vscode extension and JLinkRTTViewer for RTT view
    From what i can see on the debugger my error is either a Stack or Heap problem
    The configs that i use to change the behaviour is:
    Fullscreen
    1
    2
    3
    4
    5
    6
    # Enable MPU
    CONFIG_ARM_MPU=n
    # Enable hardware stack protection
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_STACK_SENTINEL=y
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
  • Here are most of the different errors i meet in the GDB debugger.
    Note: After all these errors, the board always reset and start from the beginning again. It seems to me, that when i change the configs shown before, that the errors change
    Reading symbols from build/zephyr/zephyr.elf...
    Remote debugging using localhost:2331
    mpsc_pbuf_alloc (buffer=buffer@entry=0x20000560 <log_buffer>, wlen=wlen@entry=6, timeout=...)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/lib/os/mpsc_pbuf.c:366
    warning: 366 /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/lib/os/mpsc_pbuf.c: No such file or directory
    (gdb) bt
    #0 mpsc_pbuf_alloc (buffer=buffer@entry=0x20000560 <log_buffer>, wlen=wlen@entry=6, timeout=...)
    #1 0x00011272 in msg_alloc (buffer=buffer@entry=0x20000560 <log_buffer>, wlen=wlen@entry=6)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/subsys/logging/log_core.c:611
    #2 0x00002c3a in z_log_msg_alloc (wlen=wlen@entry=6)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/subsys/logging/log_core.c:620
    #3 0x00011342 in z_log_msg_simple_create (source=0x16430 <log_const_os>, level=level@entry=1,
    data=data@entry=0x20004d1c <z_main_stack+412>, len=len@entry=1)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/subsys/logging/log_msg.c:76
    #4 0x00011396 in z_impl_z_log_msg_simple_create_0 (source=<optimized out>, level=level@entry=1,
    fmt=fmt@entry=0x17234 "***** HARD FAULT *****") at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/subsys/logging/log_msg.c:138
    #5 0x00003ec8 in z_log_msg_simple_create_0 (fmt=0x17234 "***** HARD FAULT *****", level=1, source=<optimized out>)
    at /home/kba/md_bt_sniffer/nrf_bt_app/app/build/zephyr/include/generated/syscalls/log_msg.h:38
    #6 hard_fault (esf=0x20004a08 <z_interrupt_stacks+2056>, recoverable=recoverable@entry=0x20004d67 <z_main_stack+487>)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c:769
    #7 0x0001172a in fault_handle (esf=esf@entry=0x20004a08 <z_interrupt_stacks+2056>, fault=fault@entry=3,
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c:850
    #8 0x00003fb2 in z_arm_fault (msp=<optimized out>, psp=<optimized out>, exc_return=<optimized out>,
    callee_regs=<optimized out>) at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c:1119
    #9 0x00004030 in z_arm_usage_fault () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault_s.S:102
    #10 <signal handler called>
    #11 chunk_field (f=SIZE_AND_USED, c=11712, h=0x20000688 <logging_thread>)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/lib/os/heap.h:116
    #12 chunk_size (c=11712, h=0x20000688 <logging_thread>) at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/lib/os/heap.h:144
    #13 right_chunk (c=11712, h=0x20000688 <logging_thread>) at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/lib/os/heap.h:206
    #14 split_chunks (h=0x20000688 <logging_thread>, lc=<optimized out>, rc=11712)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/lib/os/heap.c:121
    #15 0x00000000 in ?? ()
    Breakpoint 1, 0x0000a9a8 in SystemInit () at /home/kba/md_bt_sniffer/nrf_bt_app/modules/hal/nordic/nrfx/mdk/system_nrf52.c:189
    189 in /home/kba/md_bt_sniffer/nrf_bt_app/modules/hal/nordic/nrfx/mdk/system_nrf52.c
    (gdb)
    (gdb) bt
    #0 0x0000a702 in SystemInit () at /home/kba/md_bt_sniffer/nrf_bt_app/modules/hal/nordic/nrfx/mdk/system_nrf52.c:283
    #1 0x00002318 in z_arm_reset () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/reset.S:97
    Backtrace stopped: previous frame identical to this frame (corrupt stack?)
    (gdb) bt
    #0 0x000026b4 in z_arm_init_arch_hw_at_boot () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/scb.c:140
    #1 0x000025e4 in z_arm_reset () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/reset.S:112
    (gdb) bt
    #0 z_arm_init_arch_hw_at_boot () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/scb.c:112
    #1 0x000023ea in z_impl_k_thread_abort (thread=0x0 <z_impl_k_str_out>)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/thread_abort.c:28
    z_arm_clear_arm_mpu_config () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/scb.c:60
    warning: 60 /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/scb.c: No such file or directory
    Breakpoint 1, 0x000023c6 in z_arm_is_synchronous_svc (esf=<optimized out>)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c:731
    731 in /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c
    0x00002334 in usage_fault (esf=0x0 <z_impl_k_str_out>)
    at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c:559
    warning: 559 /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/fault.c: No such file or directory
    Program received signal SIGTRAP, Trace/breakpoint trap.
    z_arm_reset () at /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/reset.S:73
    warning: 73 /home/kba/md_bt_sniffer/nrf_bt_app/zephyr/arch/arm/core/cortex_m/reset.S: No such file or directory
    in gdb:
    frame 7
    print /x *esf
    This will give you the faulting regs, similar to what is outputted via the log module.
    You can then use add2line on the faulting register(s) to backtrace where the fault occurred:
    https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-2-debugging/topic/exercise-2-11/
    mcuboot.conf
    Have you also disabled dcdc in prj.conf? It does not seem to set 32k configuration either in your prj.conf file.
    This defaults to the zephyr open source stack. I would strongly recommend that you use the SoftDevice Controller LL.
    Håkon
