I have encountered issues flashing a NRF52833 board which is on a custom PCB. I have picked the project up from another developer so it is somewhat developed already. The project is using the v1.8.0 sdk. I have the SDK installed and worked, I am able to build the project without issue. I am developing with vs code and the nrf connect addon. Following instructions left by the previous developer I set the environment up, and build the hex file successfully. I used both jflash-lite and nrfconnect to flash. The first couple of attempts were successful and then the board became unresponsive. I have tried on 3 boards all which became unresponsive.
I went back to the original developer to work through the problem and I used his instance of the project for comparison, with his instance he could flash the device without issue. He has a copy of my instance inline with his (so that they became identical on his machine) and found that when flashing his board became unresponsive also.
The only additional changes I could find from previous releases in the build config were additional cmake cmds:
"-DBOARD_ROOT=\"c:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833\"",
"-Dmcuboot_DTC_OVERLAY_FILE=\"C:/ncs/v1.8.0/nrf/modules/mcuboot/usb.overlay\"",
"-Dmcuboot_OVERLAY_CONFIG=\"C:/ncs/v1.8.0/nrf/subsys/partition_manager/partition_manager_enabled.conf\""
I performed a full reinstallation of sdk and clean project without additional cmake cmds, and was able to eventually achieve flashing the device with a release config that was repeatable without issue...
Connecting to J-Link...
Bank selection: BankAddr=0x00000000 Enabled
Bank selection: BankAddr=0x10001000 Enabled
Loader selection: BankAddr=0x00000000 Loader=Default
Loader selection: BankAddr=0x10001000 Loader=Default
Connecting to target...
ERROR: Could not connect to target.
Done.
* Executing task: nRF Connect: Generate config nrf52833dk_nrf52833 for c:\Users\voidn_l4qz259\Documents\GitHub\Eclateral\AsclepiusFirmware\Asclepius_reader_nrf52833
Building Asclepius_reader_nrf52833
C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug c:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833 --pristine --board nrf52833dk_nrf52833 -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=c:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/prjDebugManufacturing.conf -DBOARD_ROOT=c:/users/voidn_l4qz259/documents/github/eclateral/asclepiusfirmware/asclepius_reader_nrf52833"
Including boilerplate (Zephyr base): C:/ncs/v1.8.0/zephyr/cmake/app/boilerplate.cmake
-- Application: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833
-- Zephyr version: 2.7.0 (C:/ncs/v1.8.0/zephyr), build: v2.7.0-ncs1
-- Found Python3: C:/ncs/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
-- Board: nrf52833dk_nrf52833
-- Cache files will be written to: C:/ncs/v1.8.0/zephyr/.cache
-- Found dtc: C:/ncs/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (c:/ncs/v1.8.0/toolchain/opt)
-- Found BOARD.dts: C:/ncs/v1.8.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts
-- Found devicetree overlay: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/boards/nrf52833dk_nrf52833.overlay
-- Generated zephyr.dts: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug/zephyr/dts.cmake
warning: BT_DIS_MODEL (defined at C:/ncs/v1.8.0/zephyr/subsys/bluetooth/services\Kconfig.dis:26,
subsys/bluetooth\services\Kconfig.dis:26) was assigned the value 'v0.0.1' but got the value ''.
Check these unsatisfied dependencies: ((BT_DIS && BT_CONN && BT_RPC_STACK) || (BT_DIS && BT_CONN &&
BT_HCI && BT)) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_DIS_MODEL.html and/or look up
BT_DIS_MODEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: BT_DIS_MANUF (defined at C:/ncs/v1.8.0/zephyr/subsys/bluetooth/services\Kconfig.dis:32,
subsys/bluetooth\services\Kconfig.dis:32) was assigned the value 'Eclateral' but got the value ''.
Parsing C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/Kconfig
Loaded configuration 'C:/ncs/v1.8.0/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig'
Merged configuration 'c:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/prjDebugManufacturing.conf'
Configuration saved to 'C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug/zephyr/.config'
Kconfig header saved to 'C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug/zephyr/include/generated/autoconf.h'
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_DIS_MANUF.html and/or look up
BT_DIS_MANUF in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
warning: BT_DIS_FW_REV_STR (defined at
C:/ncs/v1.8.0/zephyr/subsys/bluetooth/services\Kconfig.dis:117,
subsys/bluetooth\services\Kconfig.dis:117) was assigned the value 'v0.0.7' but got the value ''.
Check these unsatisfied dependencies: ((BT_DIS_FW_REV && BT_DIS && BT_CONN && BT_RPC_STACK) ||
(BT_DIS_FW_REV && BT_DIS && BT_CONN && BT_HCI && BT)) (=n). See
http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_BT_DIS_FW_REV_STR.html and/or look up
BT_DIS_FW_REV_STR in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
-- The C compiler identification is GNU 9.2.1
-- The CXX compiler identification is GNU 9.2.1
-- Found assembler: C:/ncs/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
CMake Warning at C:/ncs/v1.8.0/zephyr/subsys/bluetooth/host/CMakeLists.txt:103 (message):
CONFIG_BT_FIXED_PASSKEY is enabled
A fixed passkey is easy to deduce during the pairing procedure, do not use in
production.
CMake Warning at C:/ncs/v1.8.0/zephyr/subsys/usb/CMakeLists.txt:22 (message):
CONFIG_USB_DEVICE_VID has default value 0x2FE3.
This value is only for testing and MUST be configured for USB products.
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/voidn_l4qz259/Documents/GitHub/Eclateral/AsclepiusFirmware/Asclepius_reader_nrf52833/build_debug
[1/273] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[2/273] Generating include/generated/driver-validation.h
[3/273] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[4/273] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[5/273] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[6/273] Generating include/generated/offsets.h
[7/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
[8/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[9/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[10/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[11/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[12/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[13/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[14/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/dfu/img_util/flash_img.c.obj
[15/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[16/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[17/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[18/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[19/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[20/273] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[21/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[22/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/console/getline.c.obj
[23/273] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[24/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[25/273] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[26/273] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[27/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_line.c.obj
[28/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
[29/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/bluetooth/services/bas.c.obj
[30/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_store.c.obj
[31/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_nvs.c.obj
[32/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings_init.c.obj
[33/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_work_q.c.obj
[34/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[35/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_device.c.obj
[36/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_default.c.obj
[37/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/fs/nvs/nvs.c.obj
[38/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/settings/src/settings.c.obj
[39/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_transfer.c.obj
[40/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[41/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
[42/273] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/utils.c.obj
[43/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/stream/stream_flash.c.obj
[44/273] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/cmac_mode.c.obj
[45/273] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/aes_encrypt.c.obj
[46/273] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/ecc_dh.c.obj
[47/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
[48/273] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/aes_decrypt.c.obj
[49/273] Generating linker_zephyr_prebuilt.cmd
[50/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/class/cdc_acm.c.obj
[51/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
[52/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[53/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[54/273] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/usb/usb_descriptor.c.obj
[55/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[56/273] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[57/273] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[58/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[59/273] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v1.8.0/modules/crypto/tinycrypt/lib/source/ecc.c.obj
[60/273] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[61/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[62/273] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[63/273] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[64/273] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[65/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[66/273] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[67/273] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[68/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[69/273] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[70/273] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[71/273] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[72/273] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[73/273] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
[74/273] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[75/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/util/src/mcumgr_util.c.obj
[76/273] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[77/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/smp/src/smp.c.obj
[78/273] Linking C static library zephyr\arch\common\libisr_tables.a
[79/273] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[80/273] Building C object modules/tinycbor/CMakeFiles/..__modules__lib__tinycbor__zephyr.dir/C_/ncs/v1.8.0/modules/lib/tinycbor/src/cbor_buf_reader.c.obj
[81/273] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[82/273] Building C object modules/tinycbor/CMakeFiles/..__modules__lib__tinycbor__zephyr.dir/C_/ncs/v1.8.0/modules/lib/tinycbor/src/cborerrorstrings.c.obj
[83/273] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[84/273] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
[85/273] Building C object modules/segger/CMakeFiles/modules__segger.dir/SEGGER_RTT_zephyr.c.obj
[86/273] Building C object modules/tinycbor/CMakeFiles/..__modules__lib__tinycbor__zephyr.dir/C_/ncs/v1.8.0/modules/lib/tinycbor/src/cbor_buf_writer.c.obj
[87/273] Building C object modules/tinycbor/CMakeFiles/..__modules__lib__tinycbor__zephyr.dir/C_/ncs/v1.8.0/modules/lib/tinycbor/src/cborencoder.c.obj
[88/273] Building C object modules/tinycbor/CMakeFiles/..__modules__lib__tinycbor__zephyr.dir/C_/ncs/v1.8.0/modules/lib/tinycbor/src/cborparser_dup_string.c.obj
[89/273] Building C object modules/segger/CMakeFiles/modules__segger.dir/C_/ncs/v1.8.0/modules/debug/segger/SEGGER/SEGGER_RTT.c.obj
[90/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[91/273] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[92/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[93/273] Linking C static library zephyr\arch\common\libarch__common.a
[94/273] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[95/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[96/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[97/273] Building C object modules/tinycbor/CMakeFiles/..__modules__lib__tinycbor__zephyr.dir/C_/ncs/v1.8.0/modules/lib/tinycbor/src/cborparser.c.obj
[98/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[99/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[100/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[101/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[102/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[103/273] Linking C static library modules\segger\libmodules__segger.a
[104/273] Linking C static library modules\tinycbor\lib..__modules__lib__tinycbor__zephyr.a
[105/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[106/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
[107/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
[108/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
[109/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
[110/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
[111/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
[112/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
[113/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[114/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
[115/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
[116/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[117/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[118/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
[119/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
[120/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[121/273] Building C object CMakeFiles/app.dir/src/main.c.obj
../src/main.c: In function 'main':
../src/main.c:352:57: warning: passing argument 1 of 'fsm_notifyBatteryStatus' discards 'volatile' qualifier from pointer target type [-Wdiscarded-qualifiers]
352 | uint8_t timerFlag = fsm_notifyBatteryStatus(&checkBatteryStatusFlag);
In file included from ../src/main.c:24:
../src/fsm.h:30:42: note: expected 'uint8_t *' {aka 'unsigned char *'} but argument is of type 'volatile uint8_t *' {aka 'volatile unsigned char *'}
30 | uint8_t fsm_notifyBatteryStatus(uint8_t *readyToNotify);
[122/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
[123/273] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
[124/273] Building C object CMakeFiles/app.dir/src/spi_wrapper.c.obj
[125/273] Building C object CMakeFiles/app.dir/src/i2c_wrapper.c.obj
[126/273] Building C object CMakeFiles/app.dir/src/nrf52Port.c.obj
../src/nrf52Port.c: In function 'nrf52Port_toggleLed1Blue':
../src/nrf52Port.c:182:9: warning: unused variable 'i' [-Wunused-variable]
182 | int i = gpio_pin_toggle(LEDGpioPort0, LED1_BLUE);
../src/nrf52Port.c: In function 'nrf52Port_toggleLed1Green':
../src/nrf52Port.c:188:9: warning: unused variable 'i' [-Wunused-variable]
188 | int i = gpio_pin_toggle(LEDGpioPort0, LED1_GREEN);
../src/nrf52Port.c: In function 'nrf52Port_toggleLed1Red':
../src/nrf52Port.c:194:9: warning: unused variable 'i' [-Wunused-variable]
194 | int i = gpio_pin_toggle(LEDGpioPort1, LED1_RED);
At top level:
../src/nrf52Port.c:64:13: warning: 'initResetGpio' defined but not used [-Wunused-function]
64 | static void initResetGpio(void)
[127/273] Building C object CMakeFiles/app.dir/src/bq25121.c.obj
[128/273] Building C object CMakeFiles/app.dir/src/Impedance.c.obj
[129/273] Building C object CMakeFiles/app.dir/src/SqrWaveVoltammetry.c.obj
../src/SqrWaveVoltammetry.c: In function 'RampDacRegUpdate':
../src/SqrWaveVoltammetry.c:469:5: warning: enumeration value 'SWV_STATE3' not handled in switch [-Wswitch]
469 | switch (AppSWVCfg.RampStateSWV)
../src/SqrWaveVoltammetry.c:469:5: warning: enumeration value 'SWV_STATE4' not handled in switch [-Wswitch]
[130/273] Building C object CMakeFiles/app.dir/src/RampTest.c.obj
../src/RampTest.c: In function 'RampDacRegUpdate':
../src/RampTest.c:466:9: warning: enumeration value 'RAMP_STATE2' not handled in switch [-Wswitch]
466 | switch (AppRAMPCfg.RampState)
../src/RampTest.c:466:9: warning: enumeration value 'RAMP_STATE3' not handled in switch [-Wswitch]
[131/273] Building C object CMakeFiles/app.dir/src/EEPROM.c.obj
[132/273] Building C object CMakeFiles/app.dir/src/parser.c.obj
[133/273] Building C object CMakeFiles/app.dir/src/uart_interface.c.obj
[134/273] Building C object CMakeFiles/app.dir/src/build_config.c.obj
[135/273] Building C object CMakeFiles/app.dir/src/ChronoAmperometric.c.obj
../src/ChronoAmperometric.c:25:1: warning: missing braces around initializer [-Wmissing-braces]
25 | {
48 | .RtiaCalValue = 0,
../src/ChronoAmperometric.c: In function 'AppCHRONOAMPTransientMeasureGen':
../src/ChronoAmperometric.c:314:169: warning: suggest parentheses around arithmetic in operand of '|' [-Wparentheses]
314 | AD5940_WriteReg(REG_AFE_LPDACDAT0, (uint32_t)((AppCHRONOAMPCfg.Vzero - 200) / DAC6BITVOLT_1LSB) << 12 | (int32_t)((AppCHRONOAMPCfg.SensorBias) / DAC12BITVOLT_1LSB) + VzeroCode * 64);
[136/273] Building C object CMakeFiles/app.dir/src/AD5940_Temperature.c.obj
../src/AD5940_Temperature.c: In function 'AD5940_TempPlatformCfg':
../src/AD5940_Temperature.c:53:17: warning: unused variable 'gpio_cfg' [-Wunused-variable]
53 | AGPIOCfg_Type gpio_cfg;
[137/273] Building C object CMakeFiles/app.dir/src/AFE_interface.c.obj
../src/AFE_interface.c:2083:37: warning: "/*" within comment [-Wcomment]
2083 | if (resultsCanBeTaken == 1) /*(typeOfmeasurement != M_RET_TYPE_PRINT_CYCLE) && (typeOfmeasurement != 0)*/
../src/AFE_interface.c:2061:22: warning: 'pImp' defined but not used [-Wunused-variable]
2061 | static fImpPol_Type *pImp;
../src/AFE_interface.c:2059:14: warning: 'Re' defined but not used [-Wunused-variable]
2059 | static float Re = 0;
../src/AFE_interface.c:2045:32: warning: 'IMPMeasurement' defined but not used [-Wunused-variable]
2045 | static AFE_ParametersStructure IMPMeasurement =
../src/AFE_interface.c:2043:13: warning: 'startProcess' defined but not used [-Wunused-variable]
2043 | static bool startProcess = false;
../src/AFE_interface.c:2041:17: warning: 'dataCounter' defined but not used [-Wunused-variable]
2041 | static uint16_t dataCounter = 0; //counter of samples of one measurement
../src/AFE_interface.c:2040:16: warning: 'typeOfmeasurement' defined but not used [-Wunused-variable]
2040 | static uint8_t typeOfmeasurement = 0;
../src/AFE_interface.c:1867:13: warning: 'initPlatformFirstTimeWithWriteReg' defined but not used [-Wunused-function]
1867 | static void initPlatformFirstTimeWithWriteReg(void)
../src/AFE_interface.c:1398:13: warning: 'setVoltagesToZero' defined but not used [-Wunused-function]
1398 | static void setVoltagesToZero(void)
../src/AFE_interface.c:1066:13: warning: 'AFEOpenAllSwitches' defined but not used [-Wunused-function]
1066 | static void AFEOpenAllSwitches(void)
[138/273] Linking C static library zephyr\kernel\libkernel.a
[139/273] Building C object CMakeFiles/app.dir/src/usb.c.obj
../src/usb.c: In function 'usb_handler':
../src/usb.c:38:5: warning: enumeration value 'USB_DC_ERROR' not handled in switch [-Wswitch]
38 | switch (status)
../src/usb.c:38:5: warning: enumeration value 'USB_DC_RESET' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_CONFIGURED' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_SUSPEND' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_RESUME' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_INTERFACE' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_SET_HALT' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_CLEAR_HALT' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_SOF' not handled in switch [-Wswitch]
../src/usb.c:38:5: warning: enumeration value 'USB_DC_UNKNOWN' not handled in switch [-Wswitch]
../src/usb.c:49:9: warning: 'return' with a value, in function returning void [-Wreturn-type]
49 | return chargingStatus;
../src/usb.c:36:13: note: declared here
36 | static void usb_handler(enum usb_dc_status_code status, const uint8_t *param)
../src/usb.c: In function 'interrupt_handler':
../src/usb.c:61:18: warning: unused variable 'rb_len' [-Wunused-variable]
61 | int recv_len, rb_len;
../src/usb.c: In function 'USB_init':
../src/usb.c:80:11: warning: unused variable 'dtr' [-Wunused-variable]
80 | uint32_t dtr = 0U;
[140/273] Building C object CMakeFiles/app.dir/src/led.c.obj
../src/led.c:103:13: warning: 'resultNotValid' defined but not used [-Wunused-variable]
103 | static bool resultNotValid = true;
../src/led.c:82:13: warning: 'toggleLedsBatteryTooLow' defined but not used [-Wunused-variable]
82 | static bool toggleLedsBatteryTooLow = false;
../src/led.c:16:13: warning: 'toggleLedGreenMeasurementInProgress' defined but not used [-Wunused-variable]
16 | static bool toggleLedGreenMeasurementInProgress = false;
../src/led.c:15:13: warning: 'toggleLedsPercent' defined but not used [-Wunused-variable]
15 | static bool toggleLedsPercent = false;
[141/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[142/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[143/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[144/273] Building C object CMakeFiles/app.dir/src/ad5940.c.obj
../src/ad5940.c: In function 'AD5940_SoftRst':
../src/ad5940.c:2998:3: warning: implicit declaration of function 'printk'; did you mean 'printf'? [-Wimplicit-function-declaration]
2998 | printk("AFE Softrest Write Register successfull\n");
| printf
../src/ad5940.c: In function 'AD5940_ADCPGACal':
../src/ad5940.c:3224:31: warning: 'HSDACCode' may be used uninitialized in this function [-Wmaybe-uninitialized]
3224 | hsloop_cfg.WgCfg.WgCode = HSDACCode;
[145/273] Building C object CMakeFiles/app.dir/src/led_controller.c.obj
../src/led_controller.c: In function 'batteryStatusHandler':
../src/led_controller.c:40:5: warning: implicit declaration of function 'batteryLedControl' [-Wimplicit-function-declaration]
40 | batteryLedControl(GetChargingInProgress(), GetBatteryCapacity());
../src/led_controller.c: At top level:
../src/led_controller.c:136:6: warning: conflicting types for 'batteryLedControl'
136 | void batteryLedControl(bool chargingStatus, uint8_t batteryCapacity)
../src/led_controller.c:40:5: note: previous implicit declaration of 'batteryLedControl' was here
[146/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[147/273] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
[148/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[149/273] Building C object CMakeFiles/app.dir/src/BLE_module.c.obj
../src/BLE_module.c: In function 'receiveCharacteristicReadCallback':
../src/BLE_module.c:224:50: warning: format '%s' expects argument of type 'char *', but argument 2 has type 'int' [-Wformat=]
224 | printk("transmitReadCallback: BleCb.transmit = %s\n", lastCommand);
| | int
| char *
| %d
../src/BLE_module.c: In function 'transmitCharacteristicReadCallback':
../src/BLE_module.c:250:2: warning: 'return' with no value, in function returning non-void [-Wreturn-type]
250 | return;
../src/BLE_module.c:231:16: note: declared here
231 | static ssize_t transmitCharacteristicReadCallback(struct bt_conn *conn, const struct bt_gatt_attr *attr,
../src/BLE_module.c: In function 'receiveCharacteristicWriteCallback':
../src/BLE_module.c:263:65: warning: format '%d' expects argument of type 'int', but argument 2 has type 'uint8_t *' {aka 'unsigned char *'} [-Wformat=]
263 | printk("\nReceive parameter write callback: recevied packet = %d \n", receivedValue);
| int uint8_t * {aka unsigned char *}
| %hhn
../src/BLE_module.c: In function 'BLE_sendTestResults':
../src/BLE_module.c:406:35: warning: format '%d' expects a matching 'int' argument [-Wformat=]
406 | printk("get recevied command = %d\n");
| int
../src/BLE_module.c: In function 'uIDInformationWriteCallback':
../src/BLE_module.c:594:5: warning: implicit declaration of function 'EEPROM_writeUIDInformation'; did you mean 'EEPROM_readUIDInformation'? [-Wimplicit-function-declaration]
594 | EEPROM_writeUIDInformation(&uIDInformation[0]);
../src/BLE_module.c: In function 'BLE_getDeviceName':
../src/BLE_module.c:605:9: warning: return discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
605 | return bt_get_name();
../src/BLE_module.c:305:1: warning: control reaches end of non-void function [-Wreturn-type]
305 | }
At top level:
../src/BLE_module.c:514:31: warning: 'auth_cb_display' defined but not used [-Wunused-variable]
514 | static struct bt_conn_auth_cb auth_cb_display = {
[150/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[151/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[152/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[153/273] Building C object CMakeFiles/app.dir/src/fsm.c.obj
../src/fsm.c: In function 'fsm_initReaderState':
../src/fsm.c:408:40: warning: passing argument 1 of 'EEPROM_readUIDInformation' from incompatible pointer type [-Wincompatible-pointer-types]
408 | status = EEPROM_readUIDInformation(&uIDInfo);
| char (*)[32]
In file included from ../src/fsm.c:21:
../src/EEPROM.h:187:37: note: expected 'char *' but argument is of type 'char (*)[32]'
187 | int EEPROM_readUIDInformation(char *UidInfo);
../src/fsm.c:465:35: warning: passing argument 2 of 'k_timer_init' from incompatible pointer type [-Wincompatible-pointer-types]
465 | k_timer_init(&inactvityTimer, inactivityShutDown, NULL);
| void (*)(void)
In file included from C:/ncs/v1.8.0/zephyr/include/zephyr.h:18,
from ../src/fsm.c:7:
C:/ncs/v1.8.0/zephyr/include/kernel.h:1379:22: note: expected 'k_timer_expiry_t' {aka 'void (*)(struct k_timer *)'} but argument is of type 'void (*)(void)'
1379 | k_timer_expiry_t expiry_fn,
../src/fsm.c: In function 'fsm_standByBleConnectedState':
../src/fsm.c:549:9: warning: implicit declaration of function 'BLE_ClearTransmitReceivedCommand'; did you mean 'BLE_setTransmitReceivedCommand'? [-Wimplicit-function-declaration]
549 | BLE_ClearTransmitReceivedCommand();
../src/fsm.c: In function 'fsm_readingFlashState':
../src/fsm.c:600:13: warning: implicit declaration of function 'EEPROM_resetReadIndex'; did you mean 'EEPROM_readWriteIndex'? [-Wimplicit-function-declaration]
600 | EEPROM_resetReadIndex();
../src/fsm.c:601:13: warning: implicit declaration of function 'BLE_clearIndexCounter' [-Wimplicit-function-declaration]
601 | BLE_clearIndexCounter();
../src/fsm.c:602:13: warning: implicit declaration of function 'BLE_clearTestResultCommandFlag' [-Wimplicit-function-declaration]
602 | BLE_clearTestResultCommandFlag();
../src/fsm.c:603:13: warning: implicit declaration of function 'BLE_clearPacketNumber' [-Wimplicit-function-declaration]
603 | BLE_clearPacketNumber();
../src/fsm.c: In function 'fsm_receivingParametersState':
../src/fsm.c:631:5: warning: enumeration value 'LeverLifted' not handled in switch [-Wswitch]
631 | switch (CassetteLeverStatus)
../src/fsm.c: In function 'fsm_measuringState':
../src/fsm.c:739:9: warning: implicit declaration of function 'SetTemperatureForBLE' [-Wimplicit-function-declaration]
739 | SetTemperatureForBLE(temperature);
../src/fsm.c: In function 'fsm_bleSendingDataState':
../src/fsm.c:860:22: warning: implicit declaration of function 'BLE_getRequestedPacketIndex' [-Wimplicit-function-declaration]
860 | if ((BLE_getRequestedPacketIndex()+1) > (measurementIndex + 1) * maxNumberOfPacketsPerElectrode)
../src/fsm.c:876:21: warning: implicit declaration of function 'BLE_setIndexCounter' [-Wimplicit-function-declaration]
876 | BLE_setIndexCounter(BLE_getRequestedPacketIndex() - (measurementIndex * maxNumberOfPacketsPerElectrode));
../src/fsm.c:886:47: warning: format '%d' expects argument of type 'int', but argument 2 has type 'uint8_t (*)(void)' {aka 'unsigned char (*)(void)'} [-Wformat=]
886 | printk("device status is %d compared to %d\n", BLE_getDeviceStatus, DS_SENTINEL_VALUE);
| int uint8_t (*)(void) {aka unsigned char (*)(void)}
../src/fsm.c: In function 'parser_ParseCommandsMethod':
../src/fsm.c:1003:23: warning: implicit declaration of function 'atoi' [-Wimplicit-function-declaration]
1003 | int icValue = atoi(token + 2);
../src/fsm.c:1047:25: warning: implicit declaration of function 'EEPROM_writeUIDInformation'; did you mean 'EEPROM_readUIDInformation'? [-Wimplicit-function-declaration]
1047 | result = EEPROM_writeUIDInformation(&uIDInfo[0]);
../src/fsm.c: In function 'actionHandler':
../src/fsm.c:1102:18: warning: passing argument 1 of 'ReadPort' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1102 | ReadPort(token, command);
../src/fsm.c:113:28: note: expected 'char *' but argument is of type 'const char *'
113 | static void ReadPort(char* token,CommandInfo* command);
../src/fsm.c:1106:22: warning: passing argument 1 of 'ReadRegister' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1106 | ReadRegister(token, command);
../src/fsm.c:115:32: note: expected 'char *' but argument is of type 'const char *'
115 | static void ReadRegister(char* token,CommandInfo* command);
../src/fsm.c:1110:20: warning: passing argument 1 of 'ReadMemory' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1110 | ReadMemory(token, command);
../src/fsm.c:114:30: note: expected 'char *' but argument is of type 'const char *'
114 | static void ReadMemory(char* token,CommandInfo* command);
../src/fsm.c:1114:20: warning: passing argument 1 of 'ReadObject' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1114 | ReadObject(token, command);
../src/fsm.c:116:30: note: expected 'char *' but argument is of type 'const char *'
116 | static void ReadObject(char* token,CommandInfo* command);
../src/fsm.c:1118:19: warning: passing argument 1 of 'WritePort' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1118 | WritePort(token,command);
../src/fsm.c:109:29: note: expected 'char *' but argument is of type 'const char *'
109 | static void WritePort(char* token,CommandInfo* command);
../src/fsm.c:1122:23: warning: passing argument 1 of 'WriteRegister' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1122 | WriteRegister(token, command);
../src/fsm.c:111:33: note: expected 'char *' but argument is of type 'const char *'
111 | static void WriteRegister(char* token,CommandInfo* command);
../src/fsm.c:1126:21: warning: passing argument 1 of 'WriteMemory' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1126 | WriteMemory(token, command);
../src/fsm.c:110:31: note: expected 'char *' but argument is of type 'const char *'
110 | static void WriteMemory(char* token,CommandInfo* command);
../src/fsm.c:1130:21: warning: passing argument 1 of 'WriteObject' discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
1130 | WriteObject(token, command);
../src/fsm.c:112:31: note: expected 'char *' but argument is of type 'const char *'
112 | static void WriteObject(char* token,CommandInfo* command);
../src/fsm.c: In function 'WriteRegister':
../src/fsm.c:1263:78: warning: passing argument 3 of 'bq25121_writeRegister' makes integer from pointer without a cast [-Wint-conversion]
1263 | result = bq25121_writeRegister(&BQ25Dev, command->actionAddress, token);
| char *
In file included from ../src/fsm.c:24:
../src/bq25121.h:173:73: note: expected 'uint8_t' {aka 'unsigned char'} but argument is of type 'char *'
173 | int bq25121_writeRegister(BQ25121_Device *dev, uint8_t address, uint8_t value);
../src/fsm.c: In function 'ReadMemory':
../src/fsm.c:1522:13: warning: unused variable 'temp' [-Wunused-variable]
1522 | uint8_t temp;
At top level:
../src/fsm.c:140:16: warning: 'noMoreResultsInEEPROMFlag' defined but not used [-Wunused-variable]
140 | static uint8_t noMoreResultsInEEPROMFlag = 0; /*< signals when there is no more results in eeprom */
In file included from c:\ncs\v1.8.0\toolchain\opt\arm-none-eabi\include\stdio.h:800,
from ../src/ad5940.h:18,
from ../src/AFE_interface.h:16,
from ../src/parser.h:16,
from ../src/BLE_module.h:33,
from ../src/fsm.c:19:
../src/fsm.c: In function 'sendvalidResponse':
../src/fsm.c:1635:46: warning: '%d' directive output may be truncated writing between 1 and 3 bytes into a region of size 2 [-Wformat-truncation=]
1635 | snprintf(bytesCount, sizeof(bytesCount), "%d", command->noOfBytes);
../src/fsm.c:1635:47: note: format string is defined here
../src/fsm.c:1635:46: note: directive argument in the range [0, 255]
../src/fsm.c:1635:5: note: '__builtin_snprintf' output between 2 and 4 bytes into a destination of size 2
[154/273] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[155/273] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[156/273] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[157/273] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[158/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/uuid.c.obj
[159/273] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/dummy.c.obj
[160/273] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/rpa.c.obj
[161/273] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[162/273] Building C object zephyr/subsys/bluetooth/common/CMakeFiles/subsys__bluetooth__common.dir/log.c.obj
[163/273] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/power.c.obj
[164/273] Linking C static library app\libapp.a
[165/273] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[166/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/addr.c.obj
[167/273] Linking C static library zephyr\lib\posix\liblib__posix.a
[168/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_ecc.c.obj
[169/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/settings.c.obj
[170/273] Linking C static library zephyr\libzephyr.a
[171/273] Linking C static library zephyr\subsys\bluetooth\common\libsubsys__bluetooth__common.a
[172/273] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
[173/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_common.c.obj
[174/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/buf.c.obj
[175/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/ecc.c.obj
[176/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/l2cap.c.obj
[177/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/adv.c.obj
[178/273] Building C object zephyr/subsys/mgmt/mcumgr/CMakeFiles/subsys__mgmt__mcumgr.dir/buf.c.obj
[179/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/id.c.obj
[180/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/keys.c.obj
[181/273] Building C object zephyr/subsys/mgmt/mcumgr/CMakeFiles/subsys__mgmt__mcumgr.dir/smp.c.obj
[182/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/conn.c.obj
[183/273] Building C object zephyr/subsys/mgmt/mcumgr/CMakeFiles/subsys__mgmt__mcumgr.dir/smp_bt.c.obj
[184/273] Building C object zephyr/subsys/dfu/boot/CMakeFiles/subsys__dfu__boot.dir/mcuboot.c.obj
[185/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
[186/273] Building C object zephyr/drivers/sensor/nrf5/CMakeFiles/drivers__sensor__nrf5.dir/temp_nrf5.c.obj
[187/273] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[188/273] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
[189/273] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
[190/273] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[191/273] Linking C static library zephyr\subsys\mgmt\mcumgr\libsubsys__mgmt__mcumgr.a
[192/273] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[193/273] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twi.c.obj
[194/273] Linking C static library zephyr\drivers\sensor\nrf5\libdrivers__sensor__nrf5.a
[195/273] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
[196/273] Linking C static library zephyr\subsys\dfu\boot\libsubsys__dfu__boot.a
[197/273] Linking C static library zephyr\subsys\net\libsubsys__net.a
[198/273] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[199/273] Linking C static library zephyr\subsys\random\libsubsys__random.a
[200/273] Building C object zephyr/drivers/usb/device/CMakeFiles/drivers__usb__device.dir/usb_dc_nrfx.c.obj
[201/273] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[202/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/att.c.obj
[203/273] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_weak_impl.c.obj
[204/273] Linking C static library zephyr\drivers\i2c\libdrivers__i2c.a
[205/273] Linking C static library zephyr\drivers\console\libdrivers__console.a
[206/273] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[207/273] Building C object zephyr/drivers/hwinfo/CMakeFiles/drivers__hwinfo.dir/hwinfo_nrf.c.obj
[208/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/smp.c.obj
[209/273] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[210/273] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/__/__/misc/empty_file.c.obj
[211/273] Linking C static library zephyr\drivers\usb\device\libdrivers__usb__device.a
[212/273] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
[213/273] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spi.c.obj
[214/273] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/entropy_nrf5.c.obj
[215/273] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[216/273] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[217/273] Linking C static library zephyr\drivers\hwinfo\libdrivers__hwinfo.a
[218/273] Building C object modules/nrf/lib/multithreading_lock/CMakeFiles/..__nrf__lib__multithreading_lock.dir/multithreading_lock.c.obj
[219/273] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[220/273] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[221/273] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[222/273] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/gatt.c.obj
[223/273] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
[224/273] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/crypto.c.obj
[225/273] Building C object modules/nrf/drivers/mpsl/clock_control/CMakeFiles/..__nrf__drivers__mpsl__clock_control.dir/nrfx_clock_mpsl.c.obj
[226/273] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[227/273] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_internal.c.obj
[228/273] Linking C static library modules\nrf\lib\multithreading_lock\lib..__nrf__lib__multithreading_lock.a
[229/273] Building C object modules/nrf/subsys/mpsl/init/CMakeFiles/..__nrf__subsys__mpsl__init.dir/mpsl_init.c.obj
[230/273] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
[231/273] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[232/273] Building C object modules/nrf/drivers/mpsl/flash_sync/CMakeFiles/..__nrf__drivers__mpsl__flash_sync.dir/flash_sync_mpsl.c.obj
[233/273] Building C object modules/nrf/subsys/bluetooth/controller/CMakeFiles/..__nrf__subsys__bluetooth__controller.dir/hci_driver.c.obj
[234/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/mdk/system_nrf52833.c.obj
[235/273] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[236/273] Linking C static library zephyr\subsys\bluetooth\host\libsubsys__bluetooth__host.a
[237/273] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v1.8.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[238/273] Linking C static library modules\nrf\subsys\mpsl\init\lib..__nrf__subsys__mpsl__init.a
[239/273] Linking C static library modules\nrf\drivers\mpsl\clock_control\lib..__nrf__drivers__mpsl__clock_control.a
[240/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_systick.c.obj
[241/273] Linking C static library modules\nrf\subsys\bluetooth\controller\lib..__nrf__subsys__bluetooth__controller.a
[242/273] Linking C static library modules\nrf\drivers\mpsl\flash_sync\lib..__nrf__drivers__mpsl__flash_sync.a
[243/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[244/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[245/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_power.c.obj
[246/273] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[247/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spi.c.obj
[248/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
[249/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
[250/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[251/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/img_mgmt/port/zephyr/src/zephyr_img_mgmt_log.c.obj
[252/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/img_mgmt/src/img_mgmt_util.c.obj
[253/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/img_mgmt/src/img_mgmt.c.obj
[254/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/img_mgmt/src/img_mgmt_state.c.obj
[255/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ppi.c.obj
[256/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi.c.obj
[257/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/os_mgmt/src/os_mgmt.c.obj
[258/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cborattr/src/cborattr.c.obj
[259/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/os_mgmt/src/stubs.c.obj
[260/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/img_mgmt/port/zephyr/src/zephyr_img_mgmt.c.obj
[261/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/mgmt/src/mgmt.c.obj
[262/273] Building C object modules/mcumgr/CMakeFiles/..__modules__lib__mcumgr.dir/cmd/os_mgmt/port/zephyr/src/zephyr_os_mgmt.c.obj
[263/273] Linking C static library modules\mcumgr\lib..__modules__lib__mcumgr.a
[264/273] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_usbd.c.obj
[265/273] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[266/273] Linking C executable zephyr\zephyr_prebuilt.elf
[267/273] Generating linker.cmd
[268/273] Generating isr_tables.c, isrList.bin
[269/273] Generating dev_handles.c
[270/273] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[271/273] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[272/273] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[273/273] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 241812 B 512 KB 46.12%
SRAM: 54803 B 128 KB 41.81%
IDT_LIST: 0 GB 2 KB 0.00%
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Flash: Asclepius_reader_nrf52833/build_debug (active)
Flashing build_debug to 261010810
C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\Users\voidn_l4qz259\Documents\GitHub\Eclateral\AsclepiusFirmware\Asclepius_reader_nrf52833\build_debug --snr 261010810"
-- west flash: rebuilding
ninja: no work to do.
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: c:\Users\voidn_l4qz259\Documents\GitHub\Eclateral\AsclepiusFirmware\Asclepius_reader_nrf52833\build_debug\zephyr\zephyr.hex
[error] [ Worker] - Access protection is enabled, can't read device version.
[error] [ Client] - Encountered error -90: Command read_device_info executed for 14 milliseconds with result -90
[error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 14 milliseconds with result -90
[error] [ Worker] - Can't read memory descriptors, ap-protection is enabled.
[error] [ Client] - Encountered error -90: Command erase_file executed for 61 milliseconds with result -90
[error] [ nRF52] - Failed while detecting device memory block protection status!
[error] [ nRF52] - Failed while erasing device. -90: Access protection is enabled, can't read device version.
ERROR: The operation attempted is unavailable due to readback protection in
ERROR: your device. Please use --recover to unlock the device.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
ERROR: runners.nrfjprog: Flashing failed because the target must be recovered.
To fix, run "west flash --recover" instead.
Note: this will recover and erase all flash memory prior to reflashing.
FATAL ERROR: command exited with status 16: nrfjprog --program 'c:\Users\voidn_l4qz259\Documents\GitHub\Eclateral\AsclepiusFirmware\Asclepius_reader_nrf52833\build_debug\zephyr\zephyr.hex' --sectoranduicrerase -f NRF52 --snr 261010810
* The terminal process terminated with exit code: 16.
C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\Users\voidn_l4qz259\Documents\GitHub\Eclateral\AsclepiusFirmware\Asclepius_reader_nrf52833\build_debug --snr 261010810 --recover"
-- runners.nrfjprog: Recovering and erasing all flash memory.
Recovering device. This operation might take 30s.
Erasing user code and UICR flash areas.
Writing image to disable ap protect.
[ #################### ] 6.636s | Erase file - Done erasing
[ #################### ] 1.470s | Program file - Done programming
WARNING: A programming operation has been performed without --verify.
WARNING: Programming can fail without error.
Enabling pin reset.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 261010810 flashed successfully.
