Cis mode - Mic issues
With this setup in Issue with Stereo Sound from External Codec on nRF5340 DK (SDK v2.6.2) , I successfully built a CIS mode using my nRF5340 DKs, enabling stereo sound while the microphone is active.
However, I am currently experiencing several issues:
  • The recorded microphone signal is accelerated, playing back faster than it was recorded.
  • The input signal quality is poor when using an analog microphone, but it improves significantly with a digital microphone.
  • When using the microphone and playing audio through the headset simultaneously, the recorded sound is barely audible (very low signal strength).
  • Occasionally, one of the DKs disconnects, causing a complete loss of audio.
Any insights into what might be causing these issues? and how might they be solved?
Thank you in advance—I truly appreciate your time and support.
Abdulmohaimen Algamoudi
  • Hi Dejan,
    Thank you for your feedback.
    However, the issue with the accelerated microphone signal persists even when using a single headset board connected to the gateway, running the initial code from the nRF SDK (without no modification with on board codec and using the jack onboard nrf5340 by pluginng headphone with mic to it). You might want to try the initial setup pf the sdk yourself—by enabling:
    CONFIG_STREAM_BIDIRECTIONAL=y
    in the prj.conf file, you should be able to hear the accelerated  recorded microphone signal.
    The main problem for me right now is the accelerated microphone signal. Ideally, I can like to use just one headset board and still achieve a proper CIS mode that handles both left and right channels.
    Could you advise how to fix this microphone issue? It occurs even with the initial configuration of the nrf SDK, or using only one headset board and the extarnal hardware codec.
    Thanks in advance!
    Abdulmohaimen
  • Hi Abdulmohaimen,
    Is scenario the same as shown in the picture previously, just with one headset instead of two? Which code changes (specified in your second ticket) are now relevant to gateway and headset? Please provide details about the setup and code changes in this case. If you want to keep your code changes private, you can specify changes in your second ticket. If you do so, please let me know here.
    Dejan
  • Hi Dejan,
    Yes, it's the same, with the same changes applied. However, as I mentioned earlier, the issue with the accelerated mic signal also occurs with the default configuration of the nRF5340 Audio DK and its original SDK code. Both scenarios are shown in the figure below.
    Abdulmohaimen
  • Hi Abdulmohaimen,
    The issue might be related to CPU. Bidirectional communication with USB can stress CPU too much on a gateway side so that it cannot handle MIC return properly. This can lead to some packets being dropped which causes audio stream to become distorted. Potential solution could be switching to 16 KHz as default for bidirectional communication. You could try to test (make a trial) using the following latest branch
    https://github.com/rick1082/sdk-nrf/commits/cis_stereo_audio_sink_pre280/
    Please not that this is a demo branch and therefore there is no warranty or support guarantee. The code in this demo branch is provided as-is. You should do your own testing to check and verify desired functionality.
    Dejan
  • Hi Dejan,
    I’ve tested the demo in both scenarios, and I believe it demonstrates improved performance (especially with the initial configuration scenario, where i think that i have problem with the codec configration or maybe because of the I2S, almost because of the i2S because i tried that with Pixel Google phone and was all fine). Since I’m currently out of the office, I’ll test it again using a different headset with a digital microphone once I’m back. I plan to be there at the beginning of next week and will update you as soon as possible.
    In the meantime, I still have three remaining technical questions regarding this project:
    1. Audio Output Issues in CIS Mode
    Sometimes when using CIS mode, even though the headset and gateway appear to be connected and synchronized, I can't hear any audio output. I’ve noticed that pressing the reset button on both devices—sometimes once, sometimes multiple times—resolves the issue. Do you have any insight into what might be causing this behavior? Is there a known fix or workaround?
    2. Dual Microphone Setup on NRF5340 Audio DK
    Is it possible to use two different microphones with a single NRF5340 Audio DK headset? For my case, I need one microphone for the left channel and another for the right. As far as I know, my hardware codec supports this setup—can you confirm whether this configuration is supported?
    [EXTRA ]3. MCLK Frequency and Synchronization Issues
    What is the exact MCLK frequency that the chip provides over I²S? I tested this with two different operating systems and observed two different values. Additionally, I attempted to bypass the default MCLK and provide an external 12.288 MHz MCLK (as suggested in other DevZone tickets). However, this led to synchronization issues—one board's LED remained off and no audio was output. Could you clarify the expected MCLK configuration and whether external clocking is supported and stable?
    Once again, I want to sincerely thank you for your time, effort, and support. We’re getting very close to resolving all potential issues, and I truly appreciate your continued support.
    Abdulmohaimen
