Cis mode - Mic issues
With this setup in Issue with Stereo Sound from External Codec on nRF5340 DK (SDK v2.6.2) , I successfully built a CIS mode using my nRF5340 DKs, enabling stereo sound while the microphone is active.
However, I am currently experiencing several issues:
  • The recorded microphone signal is accelerated, playing back faster than it was recorded.
  • The input signal quality is poor when using an analog microphone, but it improves significantly with a digital microphone.
  • When using the microphone and playing audio through the headset simultaneously, the recorded sound is barely audible (very low signal strength).
  • Occasionally, one of the DKs disconnects, causing a complete loss of audio.
Any insights into what might be causing these issues? and how might they be solved?
Thank you in advance—I truly appreciate your time and support.
Abdulmohaimen Algamoudi
  • Hi Abdulmohaimen,
    Abdulmohaimen said:
    1. Audio Output Issues in CIS Mode
    Sometimes when using CIS mode, even though the headset and gateway appear to be connected and synchronized, I can't hear any audio output. I’ve noticed that pressing the reset button on both devices—sometimes once, sometimes multiple times—resolves the issue. Do you have any insight into what might be causing this behavior? Is there a known fix or workaround?
    We are not able to see this situation on our end. Can this issue be replicated using nrf5340_audio-dk? Could you please share the log and point out the timing when the issue appears?
    Abdulmohaimen said:
    2. Dual Microphone Setup on NRF5340 Audio DK
    Is it possible to use two different microphones with a single NRF5340 Audio DK headset? For my case, I need one microphone for the left channel and another for the right. As far as I know, my hardware codec supports this setup—can you confirm whether this configuration is supported?
    In our demo branch, we only send single MIC stream and decode one MIC stream on the gateway side. Current audio project does not support what you try to achieve, but you can try to further study application and modify it yourself.
    Abdulmohaimen said:
    [EXTRA ]3. MCLK Frequency and Synchronization Issues
    What is the exact MCLK frequency that the chip provides over I²S? I tested this with two different operating systems and observed two different values. Additionally, I attempted to bypass the default MCLK and provide an external 12.288 MHz MCLK (as suggested in other DevZone tickets). However, this led to synchronization issues—one board's LED remained off and no audio was output. Could you clarify the expected MCLK configuration and whether external clocking is supported and stable?
    Did you configure nRF5340 as I2S slave? Do you want to ignore MCLK from nRF5340 and use another clock source?
    Since it is nrf5340 that needs to tune I2S clock speed to sync with BLE activity, it is important to use nrf5340 as I2S master and let nrf5340 handle the clock system.
    Dejan
  • Hi Dejan,
    Since the latest edit you provided works better with the initial conditiond of nrf5340audio dk, and before continuing with the other potentials. I'd first like to confirm everything with my MCLK before proceeding further.
    I'm using the nRF5340 in master mode, where it provides the MCLK to my external hardware codec. I tried measuring the MCLK using two different oscilloscopes, but I got two different values: 3.471 MHz and 6.14386 MHz. And for both:
    • BCLK: 1.536 MHz
    • WCLK: 48,000 Hz
    What are the actual frequencies of the Master Clock (MCLK), Bit Clock (BCLK), and Word Clock (WCLK) generated by the nRF5340 Audio DK via the I²S interface?
    I also tried enabling the Bypass mode in audio_i2s.c to generate a 12.288 MHz MCLK.
    static nrfx_i2s_config_t cfg = {
    	/* Pins are configured by pinctrl. */
    	.skip_gpio_cfg = true,
    	.skip_psel_cfg = true,
    	.irq_priority = DT_IRQ(I2S_NL, priority),
    	.mode = NRF_I2S_MODE_MASTER,
    	.format = NRF_I2S_FORMAT_I2S,
    	.alignment = NRF_I2S_ALIGN_LEFT,
    	.ratio = CONFIG_AUDIO_RATIO,
    	.mck_setup = 0x66666000,
    #if (CONFIG_AUDIO_BIT_DEPTH_16)
    	.sample_width = NRF_I2S_SWIDTH_16BIT,
    #elif (CONFIG_AUDIO_BIT_DEPTH_32)
    	.sample_width = NRF_I2S_SWIDTH_32BIT,
    #else
    #error Invalid bit depth selected
    #endif /* (CONFIG_AUDIO_BIT_DEPTH_16) */
    	.channels = NRF_I2S_CHANNELS_STEREO,
    	.clksrc = NRF_I2S_CLKSRC_ACLK,
    	.enable_bypass = true,
    However, after doing this, the boards no longer synchronize—the synchronization LED remains off, and no audio can be heard. i find in the log files the following:
    Headset:
    HL [00:11:00.798,736] <wrn> audio_datapath: Data received, total under-runs: 657816
    --- 13 messages dropped ---
    HL [00:11:00.851,440] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:00.917,785] <inf> audio_datapath: Drft comp state: INIT
    --- 11 messages dropped ---
    HL [00:11:00.968,292] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:01.018,768] <wrn> audio_datapath: Data received, total under-runs: 658036
    HL [00:11:01.069,274] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:01.119,781] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:01.170,288] <inf> audio_datapath: Drft comp state: INIT
    --- 10 messages dropped ---
    HL [00:11:01.220,794] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:01.271,270] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:01.318,756] <wrn> audio_datapath: Data received, total under-runs: 658336
    --- 12 messages dropped ---
    HL [00:11:01.371,520] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    --- 14 messages dropped ---
    HL [00:11:01.438,781] <wrn> audio_datapath: Data received, total under-runs: 658456
    HL [00:11:01.491,546] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    --- 16 messages dropped ---
    HL [00:11:01.558,776] <wrn> audio_datapath: Data received, total under-runs: 658576
    HL [00:11:01.611,450] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:01.671,447] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:01.738,769] <wrn> audio_datapath: Data received, total under-runs: 658756
    HL [00:11:01.798,767] <wrn> audio_datapath: Data received, total under-runs: 658816
    HL [00:11:01.851,470] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    --- 15 messages dropped ---
    HL [00:11:01.918,792] <wrn> audio_datapath: Data received, total under-runs: 658936
    HL [00:11:01.971,466] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.029,327] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:02.079,803] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:02.130,310] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:02.180,816] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:02.231,628] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.298,797] <wrn> audio_datapath: Data received, total under-runs: 659316
    HL [00:11:02.361,572] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.428,802] <wrn> audio_datapath: Data received, total under-runs: 659446
    HL [00:11:02.481,475] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.551,483] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.618,804] <wrn> audio_datapath: Data received, total under-runs: 659636
    HL [00:11:02.671,569] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.735,839] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:02.781,585] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:02.838,806] <wrn> audio_datapath: Data received, total under-runs: 659856
    HL [00:11:02.908,813] <wrn> audio_datapath: Data received, total under-runs: 659926
    HL [00:11:02.961,517] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    --- 17 messages dropped ---
    HL [00:11:03.018,829] <wrn> audio_datapath: Data received, total under-runs: 660036
    HL [00:11:03.078,826] <wrn> audio_datapath: Data received, total under-runs: 660096
    HL [00:11:03.138,824] <wrn> audio_datapath: Data received, total under-runs: 660156
    HL [00:11:03.188,842] <wrn> audio_datapath: Data received, total under-runs: 660206
    HL [00:11:03.241,363] <inf> audio_datapath: Drft comp state: CALIB
    --- 9 messages dropped ---
    HL [00:11:03.291,534] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:03.358,825] <wrn> audio_datapath: Data received, total under-runs: 660376
    HL [00:11:03.418,334] <wrn> audio_datapath: Data received, total under-runs: 660435
    HL [00:11:03.471,527] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:03.538,330] <wrn> audio_datapath: Data received, total under-runs: 660555
    HL [00:11:03.591,522] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:03.658,355] <wrn> audio_datapath: Data received, total under-runs: 660675
    HL [00:11:03.711,547] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:03.778,839] <wrn> audio_datapath: Data received, total under-runs: 660796
    HL [00:11:03.831,604] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:03.897,399] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:03.947,875] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:03.991,577] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:04.049,377] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.099,884] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.150,390] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.200,897] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.251,373] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.301,391] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:04.351,684] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:04.402,893] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.453,399] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.503,906] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:04.553,924] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:04.604,431] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:04.654,907] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:04.705,413] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:04.755,920] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:04.801,605] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:04.858,886] <wrn> audio_datapath: Data received, total under-runs: 661876
    HL [00:11:04.928,375] <wrn> audio_datapath: Data received, total under-runs: 661945
    HL [00:11:04.988,403] <wrn> audio_datapath: Data received, total under-runs: 662005
    HL [00:11:05.041,625] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.101,623] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.160,430] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:05.210,418] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:05.260,925] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:05.311,431] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:05.361,694] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.421,691] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.488,403] <wrn> audio_datapath: Data received, total under-runs: 662505
    HL [00:11:05.541,625] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.608,428] <wrn> audio_datapath: Data received, total under-runs: 662625
    HL [00:11:05.664,947] <inf> audio_datapath: Drft comp state: INIT
    HL [00:11:05.711,700] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.778,411] <wrn> audio_datapath: Data received, total under-runs: 662795
    HL [00:11:05.831,726] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:05.898,437] <wrn> audio_datapath: Data received, total under-runs: 662915
    HL [00:11:05.951,721] <wrn> bt_le_audio_tx: HCI ISO TX overrun on stream 0x20010ebc - Single print
    HL [00:11:06.018,432] <wrn> audio_datapath: Data received, total under-runs: 663035
    HL [00:11:06.069,458] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:06.119,964] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:06.170,440] <inf> audio_datapath: Drft comp state: CALIB
    HL [00:11:06.220,458] <inf> audio_datapath: Drft comp state: INIT
    gateway:
    *** Using Zephyr OS v3.7.99-0bc3393fb112 ***
    GW [00:00:00.383,789] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.416,229] <inf> fw_info:
             nRF5340 Audio nRF5340 Audio DK cpuapp
             NCS base version: 2.8.0
             Cmake run : Sat Apr 12 17:32:22 2025
    GW [00:00:00.416,229] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.416,229] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.487,091] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 6.0 (0x0e), Revision 8270
    GW [00:00:00.487,335] <inf> bt_mgmt: Local identity addr: D3:C8:9D:D1:BE:66 (random)
    GW [00:00:00.487,457] <inf> audio_usb: Ready for USB host to send/receive.
    GW [00:00:00.490,814] <inf> bt_mgmt_scan: Local addr: 52:23:FB:F5:FA:C2 (random). May time out. Updates not printed
    GW [00:00:00.490,814] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:00.928,436] <inf> bt_mgmt_scan: Creating connection to device: 4E:F1:C7:BD:7C:33 (random)
    GW [00:00:01.138,488] <inf> bt_mgmt: Connected: 4E:F1:C7:BD:7C:33 (random)
    GW [00:00:01.138,519] <inf> main: Connection event. Num connections: 1
    GW [00:00:01.381,072] <inf> main: Security changed
    GW [00:00:01.571,136] <inf> bt_vol_ctlr: VCS discover finished
    GW [00:00:01.941,284] <inf> main: Set members found: 1 of 2
    GW [00:00:01.942,474] <inf> bt_mgmt_scan: Local addr: 52:23:FB:F5:FA:C2 (random). May time out. Updates not printed
    GW [00:00:01.942,474] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:02.241,027] <inf> unicast_client: Discovered 1 sink endpoint(s) for device 0
    GW [00:00:02.642,120] <inf> unicast_client: Discovered 1 source endpoint(s) for device 0
    GW [00:00:02.662,139] <inf> unicast_client: LEFT sink stream configured
    GW [00:00:02.662,170] <inf> le_audio: LC3 codec config for sink:
    GW [00:00:02.662,170] <inf> le_audio:   Frequency: 24000 Hz
    GW [00:00:02.662,170] <inf> le_audio:   Duration: 10000 us
    GW [00:00:02.662,170] <inf> le_audio:   Channel allocation: 0x1
    GW [00:00:02.662,170] <inf> le_audio:   Octets per frame: 40 (32000 bps)
    GW [00:00:02.662,170] <inf> le_audio:   Frames per SDU: 1
    GW [00:00:02.701,110] <inf> unicast_client: LEFT source stream configured
    GW [00:00:02.701,141] <inf> le_audio: LC3 codec config for source:
    GW [00:00:02.701,171] <inf> le_audio:   Frequency: 16000 Hz
    GW [00:00:02.701,171] <inf> le_audio:   Duration: 10000 us
    GW [00:00:02.701,171] <inf> le_audio:   Channel allocation: 0x1
    GW [00:00:02.701,171] <inf> le_audio:   Octets per frame: 40 (32000 bps)
    GW [00:00:02.701,171] <inf> le_audio:   Frames per SDU: 1
    GW [00:00:03.461,059] <inf> unicast_client: Stream 0x200121c4 started
    GW [00:00:03.468,017] <inf> audio_usb: USB RX first data received.
    GW [00:00:03.641,418] <inf> unicast_client: Stream 0x200122c4 started
    GW [00:02:28.181,335] <inf> bt_mgmt: Disconnected: F5:FD:57:29:5F:67 (random), reason 0x08
    GW [00:02:28.181,365] <inf> main: Disconnection event. Num connections: 0
    GW [00:02:28.185,211] <inf> bt_mgmt_scan: Local addr: 52:23:FB:F5:FA:C2 (random). May time out. Updates not printed
    GW [00:02:28.185,211] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:02:28.185,211] <inf> unicast_client: Stream 0x200121c4 stopped. Reason 8
    GW [00:02:28.185,241] <inf> unicast_client: Stream 0x200122c4 stopped. Reason 8
    GW [00:02:28.189,208] <wrn> unicast_client: No active streams
    GW [00:02:28.189,208] <wrn> main: Sending operation cancelled
    *** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
    GW [00:00:00.385,955] <inf> board_version: Compatible board/HW version found: 1.0.0
    GW [00:00:00.418,334] <inf> fw_info:
             Cmake run : Sun Apr 13 23:16:11 2025
    GW [00:00:00.418,334] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.418,334] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.489,166] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 6.0 (0x0e), Revision 8270
    GW [00:00:00.489,379] <inf> bt_mgmt: Local identity addr: D3:C8:9D:D1:BE:66 (random)
    GW [00:00:00.489,501] <inf> audio_usb: Ready for USB host to send/receive.
    GW [00:00:00.492,736] <inf> bt_mgmt_scan: Local addr: 77:B5:09:96:97:D9 (random). May time out. Updates not printed
    GW [00:00:00.492,767] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:00.921,936] <inf> bt_mgmt_scan: Creating connection to device: 40:DC:AC:77:E4:D3 (random)
    GW [00:00:01.030,395] <inf> bt_mgmt: Connected: 40:DC:AC:77:E4:D3 (random)
    GW [00:00:01.030,426] <inf> main: Connection event. Num connections: 1
    GW [00:00:01.272,857] <inf> main: Security changed
    GW [00:00:01.462,951] <inf> bt_vol_ctlr: VCS discover finished
    GW [00:00:01.843,017] <inf> main: Set members found: 1 of 2
    GW [00:00:01.844,268] <inf> bt_mgmt_scan: Local addr: 77:B5:09:96:97:D9 (random). May time out. Updates not printed
    GW [00:00:01.844,299] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:02.142,822] <inf> unicast_client: Discovered 1 sink endpoint(s) for device 0
    GW [00:00:02.543,975] <inf> unicast_client: Discovered 1 source endpoint(s) for device 0
    GW [00:00:02.563,964] <inf> unicast_client: LEFT sink stream configured
    GW [00:00:02.563,995] <inf> le_audio: LC3 codec config for sink:
    GW [00:00:02.563,995] <inf> le_audio:   Frequency: 24000 Hz
    GW [00:00:02.563,995] <inf> le_audio:   Duration: 10000 us
    GW [00:00:02.564,025] <inf> le_audio:   Channel allocation: 0x1
    GW [00:00:02.564,025] <inf> le_audio:   Octets per frame: 40 (32000 bps)
    GW [00:00:02.564,025] <inf> le_audio:   Frames per SDU: 1
    GW [00:00:02.602,935] <inf> unicast_client: LEFT source stream configured
    GW [00:00:02.602,966] <inf> le_audio: LC3 codec config for source:
    GW [00:00:02.602,966] <inf> le_audio:   Frequency: 16000 Hz
    GW [00:00:02.602,966] <inf> le_audio:   Duration: 10000 us
    GW [00:00:02.602,996] <inf> le_audio:   Channel allocation: 0x1
    GW [00:00:02.602,996] <inf> le_audio:   Octets per frame: 40 (32000 bps)
    GW [00:00:02.602,996] <inf> le_audio:   Frames per SDU: 1
    GW [00:00:03.362,792] <inf> unicast_client: Stream 0x200121ec started
    GW [00:00:03.369,689] <inf> audio_usb: USB RX first data received.
    GW [00:00:03.543,304] <inf> unicast_client: Stream 0x200122ec started
    how is it possible to solve this?
    Thanks in advance!
    Abdulmohaimen
  • Hey Dejan,
    is there ny news? Looking foewaed for your support.
    Thanks in advance!
    Abdulmohaimen
  • Hi Abdulmohaimen,
    You could try to check settings on the codec side.
    I expect to get back to you with additional information by the end of next week.
    Dejan
  • Hi Abdulmohaimen,
    MCLK value should be close to 6.144 MHz. With currently used ratio of 128 and ratio * LRCK = MCLK (see LRCK in the documentation), MCLK is expected to be 6.144 MHz. You could try to check on the oscilloscope using higher sampling rate (more than twice of 6.144 MHz).
    As for bypass mode, it is expected for MCLK to be 12.288 MHz. It might be that your codec is not configured properly. You can check your codec settings.
    Dejan
