Doing AES/ECB encryption in nRF54L15 board
I am using the nRF Connect SDK v2.9.0. While working on the nRF52840 board, I used the library zephyr/crypto/crypto.h to perform AES/ECB encryption.
Part of the code I wrote is
 #define CRYPTO_DEV_COMPAT nordic_nrf_ecb
static const struct device *const dev = DEVICE_DT_GET_ONE(CRYPTO_DEV_COMPAT);
This worked fine with the nRF52840 board, when I replaced the board with nRF54L15, I got compilation errors in the above lines
    I am working on your case and will update it when I collect enough information.
    Amanda H.
    Could you try this unofficial patch 0001-drivers-add-support-for-nRF54L-ECB.patch? My colleague makes some changes to support ECB on nRF54L.
  • When I applied this patch file, I got these errors
  • You can refer to the patch and modify it manually.
     drivers/crypto/Kconfig.nrf_ecb  | 11 ++++++-
     drivers/crypto/crypto_nrf_ecb.c | 56 ++++++++++++++++++++++++++++++++-
     dts/common/nordic/nrf54l15.dtsi |  7 +++++
     3 files changed, 72 insertions(+), 2 deletions(-)
    diff --git a/drivers/crypto/Kconfig.nrf_ecb b/drivers/crypto/Kconfig.nrf_ecb
    index 624baedab09..9945ed62de6 100644
    --- a/drivers/crypto/Kconfig.nrf_ecb
    +++ b/drivers/crypto/Kconfig.nrf_ecb
    @@ -10,6 +10,15 @@ config CRYPTO_NRF_ECB
     	# Bluetooth controller uses the ECB peripheral directly
     	# (see subsys/bluetooth/controller/ll_sw/nordic/hal/nrf5/ecb.c),
     	# hence this driver cannot be enabled together with it.
    -	depends on !BT_CTLR
    +	# Temperary remove dependcy for Gazell and BLE coexistence demo
     	help
     	  Enable nRF HAL-based AES ECB encryption driver
    +config CRYPTO_NRF_ECB_MULTIUSER
    +	bool
    +	depends on CRYPTO_NRF_ECB
    +	default y if BT_CTLR
    +	help
    +	  Reassign ECB pointers right before encryption to ensure proper values.
    +	  This must be done if the ECB peripheral may be used bypassing this
    +	  driver's API (e.g. Bluetooth Controller bypasses the Zephyr driver).
    diff --git a/drivers/crypto/crypto_nrf_ecb.c b/drivers/crypto/crypto_nrf_ecb.c
    index 9fa354738ae..d7331e2f42f 100644
    --- a/drivers/crypto/crypto_nrf_ecb.c
    +++ b/drivers/crypto/crypto_nrf_ecb.c
    @@ -8,6 +8,7 @@
     #include <zephyr/crypto/crypto.h>
     #include <hal/nrf_ecb.h>
    +#include <zephyr/sys/byteorder.h>
     #define DT_DRV_COMPAT nordic_nrf_ecb
    @@ -17,6 +18,10 @@
     LOG_MODULE_REGISTER(crypto_nrf_ecb, CONFIG_CRYPTO_LOG_LEVEL);
     struct ecb_data {
    +#if defined(CONFIG_SOC_SERIES_NRF54LX)
    +	nrf_vdma_job_t in_job;
    +	nrf_vdma_job_t out_job;
    +#endif /* CONFIG_SOC_SERIES_NRF54LX */
     	uint8_t key[ECB_AES_KEY_SIZE];
     	uint8_t cleartext[ECB_AES_BLOCK_SIZE];
     	uint8_t ciphertext[ECB_AES_BLOCK_SIZE];
    @@ -46,6 +51,39 @@ static int do_ecb_encrypt(struct cipher_ctx *ctx, struct cipher_pkt *pkt)
     		memcpy(drv_state.data.cleartext, pkt->in_buf,
     		       ECB_AES_BLOCK_SIZE);
    +	uint32_t *key_reverse = (uint32_t *)drv_state.data.key;
    +	/* AES key order should be reversed on nRF54L */
    +	nrf_ecb_key_set(NRF_ECB00, (uint32_t[]){
    +		__builtin_bswap32(key_reverse[3]),
    +		__builtin_bswap32(key_reverse[2]),
    +		__builtin_bswap32(key_reverse[1]),
    +		__builtin_bswap32(key_reverse[0]),
    +	if (IS_ENABLED(CONFIG_CRYPTO_NRF_ECB_MULTIUSER)) {
    +		nrf_ecb_in_ptr_set(NRF_ECB00, &drv_state.data.in_job);
    +		nrf_ecb_out_ptr_set(NRF_ECB00, &drv_state.data.out_job);
    +	drv_state.data.in_job.size = pkt->in_len;
    +	drv_state.data.out_job.size = pkt->in_len;
    +	nrf_ecb_event_clear(NRF_ECB00, NRF_ECB_EVENT_END);
    +	nrf_ecb_event_clear(NRF_ECB00, NRF_ECB_EVENT_ERROR);
    +	nrf_ecb_task_trigger(NRF_ECB00, NRF_ECB_TASK_START);
    +	while (!(nrf_ecb_event_check(NRF_ECB00, NRF_ECB_EVENT_END) ||
    +		 nrf_ecb_event_check(NRF_ECB00, NRF_ECB_EVENT_ERROR))) {
    +	if (nrf_ecb_event_check(NRF_ECB00, NRF_ECB_EVENT_ERROR)) {
    +		LOG_ERR("ECB operation error");
    +		return -EIO;
    +#else
    +		nrf_ecb_data_pointer_set(NRF_ECB, &drv_state.data);
     	nrf_ecb_event_clear(NRF_ECB, NRF_ECB_EVENT_ENDECB);
     	nrf_ecb_event_clear(NRF_ECB, NRF_ECB_EVENT_ERRORECB);
    @@ -57,19 +95,35 @@ static int do_ecb_encrypt(struct cipher_ctx *ctx, struct cipher_pkt *pkt)
     		return -EIO;
     	if (pkt->out_buf != drv_state.data.ciphertext) {
     		memcpy(pkt->out_buf, drv_state.data.ciphertext,
     	pkt->out_len = pkt->in_len;
     	return 0;
     static int nrf_ecb_driver_init(const struct device *dev)
     	ARG_UNUSED(dev);
    +	/* Magic number in nRF54L15 OPS v0.5b page 251 8.7.2 EasyDMA */
    +	#define NRF_VDMA_ATTRIBUTE_ECB 11
    +	drv_state.data.in_job.p_buffer = (uint8_t *)&drv_state.data.cleartext;
    +	drv_state.data.in_job.size = 0;
    +	drv_state.data.in_job.attributes = NRF_VDMA_ATTRIBUTE_ECB;
    +	drv_state.data.out_job.p_buffer = (uint8_t *)&drv_state.data.ciphertext;
    +	drv_state.data.out_job.size = 0;
    +	drv_state.data.out_job.attributes = NRF_VDMA_ATTRIBUTE_ECB;
    +#else
     	drv_state.in_use = false;
     	return 0;
    diff --git a/dts/common/nordic/nrf54l15.dtsi b/dts/common/nordic/nrf54l15.dtsi
    index d3c0c551823..6a0e2a11fad 100644
    --- a/dts/common/nordic/nrf54l15.dtsi
    +++ b/dts/common/nordic/nrf54l15.dtsi
    @@ -658,6 +658,13 @@
     					regulator-initial-mode = <NRF5X_REG_MODE_LDO>;
    +			ecb00: ecb@47000 {
    +					compatible = "nordic,nrf-ecb";
    +					reg = <0x47000 0x1000>;
    +					interrupts = <0x47 0x1>;
    +					status = "okay";
     		rram_controller: rram-controller@5004b000 {
    2.37.3.windows.1
  • The nrf54l15.dtsi that I have seems different from the nrf54l15.dtsi you have.
    I didn`t find  regulator-initial-mode = <NRF5X_REG_MODE_LDO>; in it
    Here is the file that I have
    nrf54l15.dtsi
