nRF52840 - Old one works, new one doesn't
We had three nRF52840DK boards (PCA10056) for several years for use in development.  Then one died (or to be fair, I killed it), so we got two more that turned out to be newer.
I've got both the nRF Command Line Tools (e.g., nrfjprog) and nrfutil.  I understand nrfjprog is slated for obsolescence, so I'd like to switch to nrfutil, except that nrfutil does not yet support writing (and reading) to flash blocks or UICR addresses, and I must have that.  So nrfjprog is still the go-to tool.
What I'm seeing is that I can reliably program both old and new DKs with either tool.
Now, I'm using these DKs as programmers for the target hardware.  The target has a Tag-Connect footprint, and I'm using a 6-inch TC2030-CTX-NL cable.
The old DK works flawlessly, every time.  The new DK does not.
Furthermore, when I have the programming cable connected (to DEBUG_OUT, P19) and just hanging (a transmission-line stub?), the old DK will respond to commands but the new one never does.
So, with the cable hanging there, the new DK gets the following errors:
D:\home\dormand\>nrfjprog -f NRF52 --program project.hex --verify --chiperase --pinreset
[error] [ Client] - Encountered error -102: Command read_device_info executed for 140 milliseconds with result -102
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 30 milliseconds with result -102
Failed to read device memories.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
D:\home\dormand>nrfutil device program --firmware project.hex --options verify=VERIFY_READ,reset=RESET_PIN
[00:00:00] ------ 0% [1050227132] Failed, [jlink] JLINKARM_DLL_ERROR
Error: One or more program tasks failed:
* 1050227132: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink
More info - taking the stub programming cable off the new board (it won't respond to _anything_ with the cable present),
D:\home\dormand>nrfutil device device-info
serial_number: 000683450546
    boardVersion: PCA10056
    deviceFamily: NRF52_FAMILY
    deviceVersion: NRF52840_xxAA_REV2
    jlinkObFirmwareVersion: J-Link OB-SAM3U128-V2-NordicSemi compiled Jun 25 2024 17:06:37
    protectionStatus: NRFDL_PROTECTION_STATUS_NONE
serial_number: 001050227132
    deviceVersion: NRF52840_xxAA_REV3
    jlinkObFirmwareVersion: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
Error: Failed to device info one or more devices:
* id:8: No matching plugin found for operations to execute, code: UnsupportedDevice
I see both the device version is different and the JLink firmware is _Very_ different.  Very surprised to see anything "nrf5340" on a nRF52840DK board.
I believe I've seen the means on the DevZone for replacing the firmware, but I am reluctant to do so, since without the cable the board _does_ in fact program and _sometimes_ can succeed in programming a target.  This seems to be more of a hardware problem, if merely the presence of a 6-inch stub on P19 prevents the JLink from doiong _anything_.
My other newer DK behaves the same exact way.
    serial_number: 001050268011
* id:7: No matching plugin found for operations to execute, code: UnsupportedDevice
  • Should have mentioned:
    D:\home\dormand>nrfutil --version
    nrfutil 7.13.0 (8289424 2024-07-01)
    commit-hash: 82894242d19ff24a1541712312b3ea3af0ca8f85
    commit-date: 2024-07-01
    host: x86_64-pc-windows-msvc
    build-timestamp: 2024-07-01T07:37:50.864803700Z
    classification: nrf-external
    D:\home\dormand>nrfjprog --version
    nrfjprog version: 10.24.2 external
    JLinkARM.dll version: 8.14
    And I should have generated a log like the error message requested.  Now attached.
    [2025-Feb-21 11:16:22] [debug] --------------------------------------------------------------------------------
    [2025-Feb-21 11:16:22] [debug] nrfjprog -f NRF52 --program project.hex --verify --chiperase --pinreset --log
    [2025-Feb-21 11:16:22] [debug] nrfjprog version 10.24.2 external
    [2025-Feb-21 11:16:22] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2025-Feb-21 11:16:22] [ info] Library loaded, loading member functions.
    [2025-Feb-21 11:16:22] [ info] Member functions succesfully loaded.
    [2025-Feb-21 11:16:22] [debug] [ Client] - open
    [2025-Feb-21 11:16:22] [debug] [ Client] - start
    [2025-Feb-21 11:16:22] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 5b771a4c-a7fe-41fb-bba2-840579e92df1.
    [2025-Feb-21 11:16:22] [trace] [ Client] - Command open executed for 26 milliseconds with result 0
    [2025-Feb-21 11:16:22] [debug] [ Client] - config
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2025-Feb-21 11:16:22] [debug] [  JLink] - Logger sink registered in JLink logger
    [2025-Feb-21 11:16:22] [debug] [  nRF52] - open
    [2025-Feb-21 11:16:22] [debug] [  nRF52] - just_check_family
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - open_dll
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2025-Feb-21 11:16:22] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V814\JLink_x64.dll.
    [2025-Feb-21 11:16:22] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2025-Feb-21 11:16:22] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2025-Feb-21 11:16:22] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - Set batch mode
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - dll_version
    [2025-Feb-21 11:16:22] [ info] [SeggerBackend] - Segger dll version 8.14.  loaded.
    [2025-Feb-21 11:16:22] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
    [2025-Feb-21 11:16:22] [debug] [  nRF52] - config
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - enum_emu_snr
    [2025-Feb-21 11:16:22] [trace] [ Worker] - Command config executed for 1 milliseconds with result 0
    [2025-Feb-21 11:16:22] [debug] [ Client] - enum_emu_snr
    [2025-Feb-21 11:16:22] [trace] [ Client] - Command enum_emu_con_info executed for 14 milliseconds with result 0
    [2025-Feb-21 11:16:22] [debug] [ Client] - connect_to_emu_with_snr
    [2025-Feb-21 11:16:22] [debug] [  nRF52] - enum_emu_con_info
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - enum_emu_con_info
    [2025-Feb-21 11:16:22] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
    [2025-Feb-21 11:16:22] [debug] [  nRF52] - connect_to_emu_with_snr
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - ---just_get_num_emus
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2025-Feb-21 11:16:22] [debug] [SeggerBackend] - Segger logging enabled.
    [2025-Feb-21 11:16:22] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Feb 11 2025 17:15:35
    [2025-Feb-21 11:16:22] [trace] [  JLink] - Hardware: V1.00
    [2025-Feb-21 11:16:22] [trace] [  JLink] - S/N: 1050227132
    [2025-Feb-21 11:16:22] [trace] [  JLink] - OEM: SEGGER
    [2025-Feb-21 11:16:22] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2025-Feb-21 11:16:22] [trace] [  JLink] - Bootloader: 2021 May 18
    [2025-Feb-21 11:16:22] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2025-Feb-21 11:16:22] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2025-Feb-21 11:16:22] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2025-Feb-21 11:16:22] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2025-Feb-21 11:16:22] [trace] [  JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V814\JLinkGUIServer.exe
    [2025-Feb-21 11:16:22] [trace] [  JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V814\JLinkGUIServer.exe
    [2025-Feb-21 11:16:23] [trace] [ Client] - Command connect_to_emu_with_snr executed for 79 milliseconds with result 0
    [2025-Feb-21 11:16:23] [debug] [ Client] - read_connected_emu_snr
    [2025-Feb-21 11:16:23] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-Feb-21 11:16:23] [debug] [ Client] - read_device_info
    [2025-Feb-21 11:16:23] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V8.14 "
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 54.324ms returns "O.K."
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_HasError()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_Lock()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.001ms returns 0x01
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.001ms returns 0x00
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.007ms returns 0
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.648ms returns 0x00
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.005ms
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.084ms
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_GetSpeed()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.004ms returns 2000
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_GetSN()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.002ms returns 1050227132
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - read_device_family
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 68 milliseconds with result 0
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - read_connected_emu_snr
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - is_connected_to_emu
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_IsOpen()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.004ms returns 0x01
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - read_connected_emu_snr
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.003ms
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - read_device_info
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.002ms returns 0x01
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - Just_read_device_version
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - Just_readback_status
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - read_access_port_register
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - coresight_configure
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 1.775ms returns 0
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 101.508ms returns 0
    [2025-Feb-21 11:16:23] [error] [ Client] - Encountered error -102: Command read_device_info executed for 142 milliseconds with result -102
    [2025-Feb-21 11:16:23] [warning] Failed to read device info. Attempting to complete command anyways.
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - read_debug_port_idr
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - read_debug_port_register
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2025-Feb-21 11:16:23] [debug] [ Client] - read_memory_descriptors
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.553ms returns -1
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.561ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.562ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.530ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.610ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.535ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.511ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.491ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.525ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.522ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.658ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.663ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.552ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.548ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.495ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.472ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.500ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.490ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.481ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.467ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.461ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.496ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.482ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.543ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.483ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.470ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.489ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.516ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.471ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.459ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.499ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.494ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.460ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.542ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.478ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.458ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.477ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.824ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.539ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.505ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.115ms
    [2025-Feb-21 11:16:23] [error] [ Worker] - An unknown error.
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Command read_device_info executed for 127 milliseconds with result -102
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - read_memory_descriptors
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.017ms returns 0x01
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - Just_read_memory_descriptors
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.749ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.555ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.497ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.468ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.475ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.515ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.466ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.476ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.449ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.444ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.450ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.465ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.442ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.434ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.431ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.428ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.464ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.432ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.455ms returns -1
    [2025-Feb-21 11:16:23] [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 30 milliseconds with result -102
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.437ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.456ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.504ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.451ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.547ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.457ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.462ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.033ms
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Command read_memory_descriptors executed for 21 milliseconds with result -102
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - close
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - close
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - disconnect_from_emu
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - is_connected_to_device
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_IsConnected()
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.002ms returns FALSE
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.463ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.517ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.573ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.424ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.454ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.445ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.531ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.514ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.446ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.433ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.427ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.589ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.435ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.448ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.429ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.519ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.518ms returns -1
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.537ms returns -1
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - Ignore exception An unknown error.
    [2025-Feb-21 11:16:23] [trace] [  JLink] - - 0.024ms
    [2025-Feb-21 11:16:23] [trace] [  JLink] - JLINK_Close()
    [2025-Feb-21 11:16:23] [debug] [SeggerBackend] - Segger Backend closed.
    [2025-Feb-21 11:16:23] [debug] [  nRF52] - nRF family DLL closed
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Command close executed for 60 milliseconds with result 0
    [2025-Feb-21 11:16:23] [trace] [ Client] - Command close executed for 77 milliseconds with result 0
    [2025-Feb-21 11:16:23] [debug] [ Client] - terminate
    [2025-Feb-21 11:16:23] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2025-Feb-21 11:16:23] [trace] [ Worker] - Executed 9 commands for 281 milliseconds
    [2025-Feb-21 11:16:23] [debug] [ Client] - Worker process exited with code: 0
    [2025-Feb-21 11:16:23] [debug] [ Client] - Child process terminated with result 0
    [2025-Feb-21 11:16:23] [trace] [ Client] - Executed 9 commands for 383 milliseconds
    and the debug log for nrfutil
    [2025-02-21T18:36:03.065Z] [nrfutil-device] INFO - nrfutil-device (version = 2.3.6, platform = x86_64-pc-windows-msvc) invoked with program --firmware project.hex --options verify=VERIFY_READ,reset=RESET_PIN --log-level debug --log-output file --json
    [2025-02-21T18:36:03.065Z] [nrfutil-device] DEBUG - cargo = false, force_libnrfdl_lookup = false, force_nrfutil_libdir = false
    [2025-02-21T18:36:03.065Z] [nrfutil-device] DEBUG - Creating the nrfdl context via nrfdl_create_context_with_config: Plugin location is assumed to be C:\Users\dormand\.nrfutil\lib\nrfutil-device
    [2025-02-21T18:36:03.070Z] [nrfutil-device] DEBUG - [devkit] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    [2025-02-21T18:36:03.071Z] [nrfutil-device] INFO - [ProbeLib] [2025-02-21 18:36:03.071913Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V814\JLink_x64.dll with version 8.14
    [2025-02-21T18:36:03.129Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] open
    [2025-02-21T18:36:03.130Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] start
    [2025-02-21T18:36:03.154Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    [2025-02-21T18:36:03.154Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    [2025-02-21T18:36:03.154Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] open
    [2025-02-21T18:36:03.154Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] just_check_family
    [2025-02-21T18:36:03.154Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    [2025-02-21T18:36:03.154Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-02-21T18:36:03.155Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] jlink_dll_version
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] dll_version
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] close
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] close
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    [2025-02-21T18:36:03.174Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    [2025-02-21T18:36:03.190Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-02-21T18:36:03.241Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    [2025-02-21T18:36:03.243Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    [2025-02-21T18:36:03.243Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-02-21T18:36:03.250Z] [nrfutil-device] WARN - [JlinkARM] JlinkARM version non expected one found: JLink_V8.14 , expected: JLink_V7.94e
    [2025-02-21T18:36:03.250Z] [nrfutil-device] DEBUG - [boardController] Operation get_version_list failed with error code NRFDL_ERR_NOT_SUPPORTED
    [2025-02-21T18:36:03.251Z] [nrfutil-device] DEBUG - operation to get devices for : Ok("{\"operations\":[{\"operation\":{\"experimental\":{\"boot_sdfw\":false},\"firmware\":{\"file\":\"project.hex\"},\"reset\":\"RESET_PIN\",\"type\":\"program\",\"verify\":\"VERIFY_READ\"}}]}")
    [2025-02-21T18:36:03.251Z] [nrfutil-device] DEBUG - USBLister: enumerate
    [2025-02-21T18:36:03.251Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Enumerating device \\?\USB#VID_045E&PID_0745#5&30741cdd&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.251Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Device connected to hub: vid=, pid=, port=8
    [2025-02-21T18:36:03.251Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Hub device path: \\?\USB#ROOT_HUB30#4&C7355C0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 8, origin: {CB4D6ED3-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.251Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Starting DeviceIoControl
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: USB identifier: \\?\USB#VID_045E&PID_0745#5&30741cdd&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  containerID: {CB4D6ED3-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Enumerating device \\?\USB#VID_048D&PID_5702#5&30741cdd&0&11#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Device connected to hub: vid=, pid=, port=11
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Hub device path: \\?\USB#ROOT_HUB30#4&C7355C0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 11, origin: {CB4D6EE2-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Starting DeviceIoControl
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: USB identifier: \\?\USB#VID_048D&PID_5702#5&30741cdd&0&11#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  containerID: {CB4D6EE2-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Enumerating device \\?\USB#VID_046D&PID_085B#50E6182F#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Device connected to hub: vid=0BDA, pid=5411, port=3
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Hub device path: \\?\USB#VID_0BDA&PID_5411#5&30741CDD&0&7#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 3, origin: {5B49C84F-7CDC-5125-A2A4-CF3821DB7BCA}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: USB identifier: \\?\USB#VID_046D&PID_085B#50E6182F#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  containerID: {5B49C84F-7CDC-5125-A2A4-CF3821DB7BCA}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Enumerating device \\?\USB#VID_413C&PID_301A#5&30741cdd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Device connected to hub: vid=, pid=, port=10
    [2025-02-21T18:36:03.253Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Hub device path: \\?\USB#ROOT_HUB30#4&C7355C0&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 10, origin: {CB4D6EE1-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.254Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: USB identifier: \\?\USB#VID_413C&PID_301A#5&30741cdd&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.254Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  containerID: {CB4D6EE1-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.254Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Enumerating device \\?\USB#VID_05E3&PID_0752#9&2ee12ad4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.254Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Device connected to hub: vid=05E3, pid=0618, port=1
    [2025-02-21T18:36:03.254Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Hub device path: \\?\USB#VID_05E3&PID_0618#8&1390D9CF&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 1, origin: {CB4D6EF5-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.254Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Starting DeviceIoControl
    [2025-02-21T18:36:03.255Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: USB identifier: \\?\USB#VID_05E3&PID_0752#9&2ee12ad4&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.255Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  containerID: {CB4D6EF5-C900-11EF-B61D-806E6F6E6963}
    [2025-02-21T18:36:03.255Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Enumerating device \\?\USB#VID_1366&PID_1061#001050227132#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.255Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Device connected to hub: vid=0BDA, pid=5411, port=4
    [2025-02-21T18:36:03.255Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Hub device path: \\?\USB#VID_0BDA&PID_5411#6&24FC7038&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}, port number: 4, origin: {FDFCFC08-A25F-558E-976E-FCCE2F7CA827}
    [2025-02-21T18:36:03.255Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: Starting DeviceIoControl
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  serial number: 001050227132
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32: USB identifier: \\?\USB#VID_1366&PID_1061#001050227132#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBPlatformAPI::Win32:  containerID: {FDFCFC08-A25F-558E-976E-FCCE2F7CA827}
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBLister: Adding new device with id 1 and serial number: '{CB4D6ED3-C900-11EF-B61D-806E6F6E6963}'
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBLister: Adding new device with id 2 and serial number: '{CB4D6EE2-C900-11EF-B61D-806E6F6E6963}'
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBLister: Adding new device with id 3 and serial number: '{5B49C84F-7CDC-5125-A2A4-CF3821DB7BCA}'
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBLister: Adding new device with id 4 and serial number: '{CB4D6EE1-C900-11EF-B61D-806E6F6E6963}'
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBLister: Adding new device with id 5 and serial number: '{CB4D6EF5-C900-11EF-B61D-806E6F6E6963}'
    [2025-02-21T18:36:03.256Z] [nrfutil-device] DEBUG - USBLister: Adding new device with id 6 and serial number: '001050227132'
    [2025-02-21T18:36:03.258Z] [nrfutil-device] DEBUG - [devkit] enumerate: Device with ID 6 has board version PCA10056
    [2025-02-21T18:36:03.259Z] [nrfutil-device] DEBUG - Enumeration for plugin 'devkit' took 2 ms
    [2025-02-21T18:36:03.259Z] [nrfutil-device] INFO - [ProbeLib] [2025-02-21 18:36:03.259218Z] Opened J-Link DLL at C:\Program Files\SEGGER\JLink_V814\JLink_x64.dll with version 8.14
    [2025-02-21T18:36:03.260Z] [nrfutil-device] INFO - [ProbeLib] [2025-02-21 18:36:03.260568Z] Found 1 attached J-Link devices
    [2025-02-21T18:36:03.260Z] [nrfutil-device] DEBUG - Enumeration for plugin 'Probe' took 1 ms
    [2025-02-21T18:36:03.319Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] open
    [2025-02-21T18:36:03.319Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] start
    [2025-02-21T18:36:03.345Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] enum_emu_snr
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Logger sink registered in Segger backend logger
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][JLink][-] Logger sink registered in JLink logger
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] open
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] just_check_family
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] open_dll
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Set batch mode
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] dll_version
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] enum_emu_snr
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] enum_emu_snr
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] ---just_enum_emu_snr
    [2025-02-21T18:36:03.349Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] ---just_get_num_emus
    [2025-02-21T18:36:03.350Z] [nrfutil-device] DEBUG - [jlink] Found 1 JLink devices connected
    [2025-02-21T18:36:03.360Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] is_connected_to_emu
    [2025-02-21T18:36:03.360Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] close
    [2025-02-21T18:36:03.360Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] close
    [2025-02-21T18:36:03.360Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] disconnect_from_emu
    [2025-02-21T18:36:03.360Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][-] Segger Backend closed.
    [2025-02-21T18:36:03.360Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][-] nRF family DLL closed
    [2025-02-21T18:36:03.366Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-02-21T18:36:03.432Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] Worker process exited with code: 0
    [2025-02-21T18:36:03.434Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] Child process terminated with result 0
    [2025-02-21T18:36:03.434Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][-] terminate
    [2025-02-21T18:36:03.445Z] [nrfutil-device] DEBUG - Enumeration for plugin 'jlink' took 184 ms
    [2025-02-21T18:36:03.526Z] [nrfutil-device] DEBUG - [boardController] Found 10 HID devices.
    [2025-02-21T18:36:03.526Z] [nrfutil-device] DEBUG - Enumeration for plugin 'BOARDCONTROLLER' took 81 ms
    [2025-02-21T18:36:03.527Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Searching parent device for: \\?\ACPI#PNP0501#0#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
    [2025-02-21T18:36:03.527Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: PCI\VEN_8086&DEV_7A06&SUBSYS_50011458&REV_11\3&11583659&0&F8
    [2025-02-21T18:36:03.527Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device has 0 interfaces:
    [2025-02-21T18:36:03.527Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: ACPI\PNP0A08\0
    [2025-02-21T18:36:03.527Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: ACPI_HAL\PNP0C08\0
    [2025-02-21T18:36:03.527Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: ROOT\ACPI_HAL\0000
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: HTREE\ROOT\0
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device has 0 interfaces:
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Could not open register key: SYSTEM\CurrentControlSet\Enum\USB\VID_&PID_
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32]  serial port \\?\ACPI#PNP0501#0#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has no USB identifier, using container ID
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Searching parent device for: \\?\USB#VID_1366&PID_1061&MI_02#8&45E11BE&0&0002#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: USB\VID_1366&PID_1061\001050227132
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device has 1 interfaces:
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] - \\?\USB#VID_1366&PID_1061#001050227132#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.528Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32]  serial port \\?\USB#VID_1366&PID_1061&MI_02#8&45E11BE&0&0002#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\?\USB#VID_1366&PID_1061#001050227132#{A5DCBF10-6530-11D2-901F-00C04FB951ED}
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Searching parent device for: \\?\USB#VID_1366&PID_1061&MI_00#8&45E11BE&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device: USB\VID_1366&PID_1061\001050227132
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] Parent device has 1 interfaces:
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] - \\?\USB#VID_1366&PID_1061#001050227132#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32]  serial port \\?\USB#VID_1366&PID_1061&MI_00#8&45E11BE&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} has USB identifier \\?\USB#VID_1366&PID_1061#001050227132#{A5DCBF10-6530-11D2-901F-00C04FB951ED}
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [SerialPortListerHW::WIN32] try to map FTDI to segger device
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [serialport] serialport enumerate  device not found add new device sn: ''
    [2025-02-21T18:36:03.529Z] [nrfutil-device] INFO - plugin added new device: 7 sn:
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - [serialport] serialport enumerate update device: '001050227132'
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - Enumeration for plugin 'serialport' took 2 ms
    [2025-02-21T18:36:03.529Z] [nrfutil-device] DEBUG - Enumeration for plugin 'sdfu' took 0 ms
    [2025-02-21T18:36:03.530Z] [nrfutil-device] DEBUG - Enumeration for plugin 'mcuBoot' took 0 ms
    [2025-02-21T18:36:03.530Z] [nrfutil-device] DEBUG - Enumeration for plugin 'broken' took 0 ms
    [2025-02-21T18:36:03.530Z] [nrfutil-device] ERROR -  NRFDLException(19): plugin devkit query failed
    [2025-02-21T18:36:03.530Z] [nrfutil-device] ERROR -  NRFDLException(19): plugin Probe query failed
    [2025-02-21T18:36:03.530Z] [nrfutil-device] DEBUG - No serial-number or traits provided. But only one relevant device is connected. Will perform operation with Device { device: Object {"devkit": Object {"boardVersion": String("PCA10056"), "deviceFamily": String("NRF52_FAMILY")}, "id": Number(6), "probe": Object {}, "serialNumber": String("001050227132"), "serialPorts": Array [Object {"comName": String("COM6"), "manufacturer": String("Microsoft"), "path": String("\\\\?\\USB#VID_1366&PID_1061&MI_00#8&45E11BE&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}"), "productId": String("1061"), "serialNumber": String("001050227132"), "vcom": Number(0), "vendorId": String("1366")}, Object {"comName": String("COM5"), "manufacturer": String("Microsoft"), "path": String("\\\\?\\USB#VID_1366&PID_1061&MI_02#8&45E11BE&0&0002#{86e0d1e0-8089-11d0-9ce4-08003e301f73}"), "productId": String("1061"), "serialNumber": String("001050227132"), "vcom": Number(1), "vendorId": String("1366")}], "traits": Object {"boardController": Bool(false), "broken": Bool(false), "devkit": Bool(true), "jlink": Bool(true), "mcuBoot": Bool(false), "modem": Bool(false), "nordicDfu": Bool(false), "nordicUsb": Bool(false), "seggerUsb": Bool(true), "serialPorts": Bool(true), "usb": Bool(true)}, "usb": Object {"device": Object {"address": Number(43), "busNumber": Number(0), "descriptor": Object {"bDescriptorType": Number(1), "bcdDevice": Number(256), "idProduct": Number(4193), "idVendor": Number(4966)}}, "manufacturer": String("SEGGER"), "osDevicePath": String("\\\\?\\USB#VID_1366&PID_1061#001050227132#{a5dcbf10-6530-11d2-901f-00c04fb951ed}"), "product": String("J-Link"), "serialNumber": String("001050227132")}} }
    [2025-02-21T18:36:03.531Z] [nrfutil-device] DEBUG - [ProbeLib] [2025-02-21 18:36:03.531296Z] probe-plugin will check if the device is a NRF54H/NRF54L to determine if it should claim it
    [2025-02-21T18:36:03.531Z] [nrfutil-device] DEBUG - [ProbeLib] [2025-02-21 18:36:03.531319Z] The device is a devkit and is annotated with the device family during enumeration, checking that
    [2025-02-21T18:36:03.531Z] [nrfutil-device] DEBUG - [ProbeLib] [2025-02-21 18:36:03.531326Z] Device family nRF52 not NRF54H/NRF54L, not supported by probe-plugin
    [2025-02-21T18:36:03.531Z] [nrfutil-device] INFO - Loaded plugin C:\Users\dormand\.nrfutil\lib\nrfutil-device\10-nrfdl-jlink-plugin.nrfdl, starting to resolve symbols
    [2025-02-21T18:36:03.531Z] [nrfutil-device] DEBUG - [jlink] Initializing Jlink debug probe for device {"devkit":{"boardVersion":"PCA10056","deviceFamily":"NRF52_FAMILY"},"id":6,"probe":{},"serialNumber":"001050227132","serialPorts":[{"comName":"COM6","manufacturer":"Microsoft","path":"\\\\?\\USB#VID_1366&PID_1061&MI_00#8&45E11BE&0&0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73}","productId":"1061","serialNumber":"001050227132","vcom":0,"vendorId":"1366"},{"comName":"COM5","manufacturer":"Microsoft","path":"\\\\?\\USB#VID_1366&PID_1061&MI_02#8&45E11BE&0&0002#{86e0d1e0-8089-11d0-9ce4-08003e301f73}","productId":"1061","serialNumber":"001050227132","vcom":1,"vendorId":"1366"}],"traits":{"boardController":false,"broken":false,"devkit":true,"jlink":true,"mcuBoot":false,"modem":false,"nordicDfu":false,"nordicUsb":false,"seggerUsb":true,"serialPorts":true,"usb":true},"usb":{"device":{"address":43,"busNumber":0,"descriptor":{"bDescriptorType":1,"bcdDevice":256,"idProduct":4193,"idVendor":4966}},"manufacturer":"SEGGER","osDevicePath":"\\\\?\\USB#VID_1366&PID_1061#001050227132#{a5dcbf10-6530-11d2-901f-00c04fb951ed}","product":"J-Link","serialNumber":"001050227132"},"usbIdentifier":"\\\\?\\USB#VID_1366&PID_1061#001050227132#{A5DCBF10-6530-11D2-901F-00C04FB951ED}"} with serial number 001050227132
    [2025-02-21T18:36:03.531Z] [nrfutil-device] DEBUG - [jlink] Opening JLink DLL
    [2025-02-21T18:36:03.594Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] open
    [2025-02-21T18:36:03.594Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] start
    [2025-02-21T18:36:03.616Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Logger sink registered in Segger backend logger
    [2025-02-21T18:36:03.616Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][JLink][001050227132] Logger sink registered in JLink logger
    [2025-02-21T18:36:03.616Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][001050227132] open
    [2025-02-21T18:36:03.616Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][001050227132] just_check_family
    [2025-02-21T18:36:03.616Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] open_dll
    [2025-02-21T18:36:03.616Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] No J-Link DLL path was provided. Attempting to auto detect.
    [2025-02-21T18:36:03.619Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] connect_to_emu_with_snr
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Set batch mode
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] dll_version
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][001050227132] connect_to_emu_with_snr
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] is_connected_to_emu
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] connect_to_emu_with_snr
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_enum_emu_snr
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_get_num_emus
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_connect_to_emu_with_snr
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_connect_to_emu_without_snr
    [2025-02-21T18:36:03.634Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Segger logging enabled.
    [2025-02-21T18:36:03.673Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] read_device_family
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Connected emulator supports SWD speeds up to 2000kHz
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] SWD clock set to 2000kHz
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][001050227132] read_device_family
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] is_connected_to_emu
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] read_debug_port_idr
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] read_debug_port_register
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_read_debug_port_register
    [2025-02-21T18:36:03.679Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] coresight_configure
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] read_debug_port_idr
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] read_debug_port_register
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_read_debug_port_register
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_select_debug_port_register
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Select AP 255, DP Bank 0, AP Bank 255
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_abort_debug_action
    [2025-02-21T18:36:03.782Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Attempting to clear any configuration errors in debug port before closing connection.
    [2025-02-21T18:36:03.796Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_abort_debug_action
    [2025-02-21T18:36:03.796Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Attempting to clear any configuration errors in debug port before closing connection.
    [2025-02-21T18:36:03.800Z] [nrfutil-device] ERROR - [jlink] [NRFJPROG][Client][001050227132] Encountered error -102: Command read_device_family executed for 126 milliseconds with result -102
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_abort_debug_action
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Attempting to clear any configuration errors in debug port before closing connection.
    [2025-02-21T18:36:03.810Z] [nrfutil-device] ERROR - [jlink] [NRFJPROG][Worker][001050227132] An unknown error.
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][001050227132] close
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] is_connected_to_emu
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] close
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] disconnect_from_emu
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_disconnect_from_emu
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] is_connected_to_device
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_is_debug_region_powered
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_read_debug_port_register
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_select_debug_port_register
    [2025-02-21T18:36:03.810Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Select AP 255, DP Bank 0, AP Bank 255
    [2025-02-21T18:36:03.821Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] ---just_abort_debug_action
    [2025-02-21T18:36:03.821Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Attempting to clear any configuration errors in debug port before closing connection.
    [2025-02-21T18:36:03.832Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Ignore exception An unknown error.
    [2025-02-21T18:36:03.842Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][SeggerBackend][001050227132] Segger Backend closed.
    [2025-02-21T18:36:03.842Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][nRFXX][001050227132] nRF family DLL closed
    [2025-02-21T18:36:03.854Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] terminate
    [2025-02-21T18:36:03.889Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] Worker process exited with code: 0
    [2025-02-21T18:36:03.890Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] Worker process exited with code: 0
    [2025-02-21T18:36:03.891Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] Child process terminated with result 0
    [2025-02-21T18:36:03.891Z] [nrfutil-device] DEBUG - [jlink] [NRFJPROG][Client][001050227132] terminate
    [2025-02-21T18:36:03.907Z] [nrfutil-device] DEBUG - ~async_task id: 815076675180
    [2025-02-21T18:36:03.907Z] [nrfutil-device] DEBUG - Task 815076675180 is already completed
    [2025-02-21T18:36:03.907Z] [nrfutil-device] INFO - close plugin dll at path: C:\Users\dormand\.nrfutil\lib\nrfutil-device\10-nrfdl-jlink-plugin.nrfdl
  • Hi David,
    I do not have the exact nRF52840-DK that you are using.  But yes our newer nRF52 and nRF5340-DK are using the nrf5340 with special firmware from Segger as the Segger J-Link OB.  I definitely don't recommend reprogramming that SoC -- the firmware that goes on this nRF5340 is not available.  We stopped using the JLink OB chip (non Nordic version) on the DKs since we could not purchase them during the 2020-2022 allocation days.
    Yes nRF Command Line Tool is slated to be obsoleted but you are good for the near term.  And you have the correct version of nRF Util installed.
    I am not sure which of the the following you are doing but you might want to try the other method to see if that makes a difference.
    It's recommended to power the external board separately from the DK. The voltage on the external board must match that of the DK (typically 3V when powered through USB).
    If you're using the DK to power the target, make sure you've shorted the solder bridge SB47, but be cautious not to connect a separate power supply to the external board when SB47 is shorted nRF52840 DK User Guide.
    I have used the same Tag-Connect TC2030-CTX-NL cable so I don't think there should be any issues there.  It is not that long of a cable.
    I will turn control of this ticket back to our support team.
    Thanks
    Mike Sly
  • I'm not powering the target from the DK.
    I've just finished using the "new" DK to reprogram a set of target hardware today.  Worked every time.  My customer, OTOH, is having spotty results.  I can't actually say I have a lot of personal experience with programming with the "new" DK, since I've got my "old" DK serving in that role.  I think I'm going to swap them, though.
    What really blows me away, though, is how an "old" DK doesn't care if the stub cable is on P19 but the "new" DK absolutely refuses to do anything.  Like you say, a 6-inch stub isn't much of a stub.
  • There was a change in how the kit determines what programming port to use when we moved from the older OBDs to the nRF5340 OBDs. If you have followed the instructions to the letter and have ALL the signals wired then it should work seamlessly but if you have not wired all/done something not standard then you may see unexpected behavior.
    Recommendation is to check out the nRF52 DK user guide on our documentation siite, docs.nordicsemi.com/.../ext_programming_support_P19.html, (I have not gotten all the DK user guides updated yet) and see if your setup is correct according to this user guide (the new nRF52840 DKs have the same circuitry for external programming as new nRF52 DKs).
  • As mentioned above, I'm using a Tag-Connect TC2030 cable for programming.  TC2030 is a six-pin footprint.  Of the ten signals from P19, pins 7 and 8 are not connected, and pins 3, 5, and 9 are connected together _in the cable_.  I see that pin 3 is SWDO_SELECT.  So when the cable is connected to P19, SWDO_SELECT will be shorted to ground _in the cable_.
    Also as mentioned, I'm not powering the target through the cable.  So SB47 (corresponds to SB32 on the nRF52DK) remains in its as-delivered "open" state.
    Question: In the previous ODB, was P19 used if BOTH SWDO_SELECT is grounded AND pin 1 sees target voltage?  This would explain why my older DK doesn't care if the cable is present.  And in the newer ODB, P19 is used if SWDO_SELECT is grounded without looking if pin 1 sees target voltage?  So by merely having the cable connected, it thinks there's a target connected, but since there isn't actually a powered target connected, the JLink won't work?  This would explain why the newer DK won't do anything when the cable is connected but just hanging (a stub).
    If this is the case, this explains why programming doesn't work.  It doesn't explain so much why
    doesn't work, which appears to be talking directly to the OBD (reports board ID and firmware version, nothing to do with an external target).
    Interesting: The PCA10056 schematic shows a SB19 that connects pin 1 of P19 to VIO_REF.  On the newer DK, I see SB19 right next to SB47 adjacent to P19.  On the older DK, there is only SB47, which suggests to me that on the older DK, the voltage on P19-1 is being monitored under all circumstances.  Aha!  Yes, if I pull down the hardware files for board version 2.1.0, P19-1 is connected to EXT_VTG; no solder bridge.  Furthermore, the DK User Guide lists all the solder bridges EXCEPT for SB19.  Hence the statement in the DK User Guide (which apparently has not been updated for the newer design):
    "When the external board is powered, the interface MCU will detect the supply voltage of the board and
    program/debug the target chip on the external board instead of the onboard nRF52840 SoC."
    This is interesting, but this doesn't explain why my customer is having problems reliably programming powered external targets through P19 / TC2030.  There does not appear to be a technical reason.
