bt_enable() error: BUS FAULT Instruction bus error
I am trying to implement a ble module in a fall detection application. I added a ble_service based on the BLE fundamentals course lesson 3, which works just fine alone, but when added to the project, the code apparently builds fine for both cores, but flashing gives me this:
*** Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.587,127] <inf> BLE_MODULE: Starting BLE module
[00:00:00.587,127] <inf> BLE_MODULE: Callbacks okay
[00:00:00.588,012] <err> os: ***** BUS FAULT *****
[00:00:00.588,012] <err> os:   Instruction bus error
[00:00:00.588,012] <err> os: r0/a1:  0x00000000  r1/a2:  0x0000003c  r2/a3:  0x00000000
[00:00:00.588,043] <err> os: r3/a4:  0x01460abb r12/ip:  0x48009808 r14/lr:  0x00001b97
[00:00:00.588,043] <err> os:  xpsr:  0x01000000
[00:00:00.588,043] <err> os: Faulting instruction address (r15/pc): 0x01460aba
[00:00:00.588,073] <err> os: >>> ZEPHYR FATAL ERROR 27: Unknown error on CPU 0
[00:00:00.588,104] <err> os: Current thread: 0x20000710 (unknown)
[00:00:00.672,302] <err> os: Halting system
Any idea??
Im attaching the project in this issue.
Thanks!!
fall_detection.zip
    Can you share your "west build" command?
    Do you use NCS v2.8.0?
    Can you provide full application log?
    Dejan
  • Hi, Dejan!!
    I'm using 2.9.0.
    For shure, here they are:
    [00:00:00.455,322] <dbg> bmi270: write_config_file: writing config file max_fifo
    [00:00:00.525,634] <inf> BLE_MODULE: Starting BLE module
    [00:00:00.525,634] <inf> BLE_MODULE: Callbacks okay
    [00:00:00.526,519] <err> os: ***** BUS FAULT *****
    [00:00:00.526,519] <err> os:   Instruction bus error
    [00:00:00.526,519] <err> os: r0/a1:  0x00000000  r1/a2:  0x0000003c  r2/a3:  0x00000000
    [00:00:00.526,550] <err> os: r3/a4:  0x01460abb r12/ip:  0x48019808 r14/lr:  0x00001b97
    [00:00:00.526,550] <err> os:  xpsr:  0x01000000
    [00:00:00.526,550] <err> os: Faulting instruction address (r15/pc): 0x01460aba
    [00:00:00.526,580] <err> os: >>> ZEPHYR FATAL ERROR 27: Unknown error on CPU 0
    [00:00:00.526,611] <err> os: Current thread: 0x20000710 (unknown)
    [00:00:00.610,778] <err> os: Halting system
     *  Executing task: nRF Connect: Build [pristine]: fall_detection/build
    Building fall_detection
    west build --build-dir /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection --pristine --board nrf5340dk/nrf5340/cpuapp -- -DNCS_TOOLCHAIN_VERSION=NONE -DDTC_OVERLAY_FILE=nrf5340dk_nrf5340_cpuapp.overlay -DBOARD_ROOT=/Users/joaovitor/my_boards
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/[email protected]/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /Users/joaovitor/Library/Caches/zephyr
    CMake Warning at /opt/nordic/ncs/v2.9.0/zephyr/cmake/modules/boards.cmake:136 (message):
      BOARD_ROOT element without a 'boards' subdirectory:
      Hints:
        - if your board directory is '/foo/bar/boards/my_board' then add '/foo/bar' to BOARD_ROOT, not the entire board directory
        - if in doubt, use absolute paths
      cmake/modules/sysbuild_default.cmake:15 (include)
      /opt/nordic/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      /opt/nordic/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      /opt/nordic/ncs/v2.9.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    -- Board: nrf5340dk, qualifiers: nrf5340/cpuapp
    Parsing /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/Kconfig.sysbuild
    Loaded configuration '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/_sysbuild/empty.conf'
    Merged configuration '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/_sysbuild/empty.conf'
    Configuration saved to '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/zephyr/.config'
    Kconfig header saved to '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/_sysbuild/autoconf.h'
       * Running CMake for fall_detection *
    -- Application: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/python (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
    -- Zephyr version: 3.7.99 (/opt/nordic/ncs/v2.9.0/zephyr)
      Hints:
      /opt/nordic/ncs/v2.9.0/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      /opt/nordic/ncs/v2.9.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      CMakeLists.txt:2 (find_package)
    -- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/ncs/v2.9.0/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: nrf5340dk_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v2.9.0/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v2.9.0/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/prj.conf'
    Merged configuration '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/.config.sysbuild'
    Configuration saved to '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/.config'
    Kconfig header saved to '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/b8efef2ad5/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    CMake Warning at /opt/nordic/ncs/v2.9.0/zephyr/CMakeLists.txt:130 (message):
      The environment variable 'CPPFLAGS' was set to
      -I/opt/homebrew/opt/llvm/include, but Zephyr ignores flags from the
      environment.  Use 'cmake -DEXTRA_CPPFLAGS=-I/opt/homebrew/opt/llvm/include'
      instead.
      The environment variable 'LDFLAGS' was set to -L/opt/homebrew/opt/llvm/lib,
      but Zephyr ignores flags from the environment.  Use 'cmake
      -DEXTRA_LDFLAGS=-L/opt/homebrew/opt/llvm/lib' instead.
    -- libmetal version: 1.6.0 (/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection)
    -- Build type:
    -- Host:    Darwin/arm64
    -- Target:  Generic/arm
    -- Machine: arm
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- open-amp version: 1.6.1 (/opt/nordic/ncs/v2.9.0/modules/lib/open-amp/open-amp)
    -- Looking for include file fcntl.h
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h - found
    -- Setting build type to 'MinSizeRel' as none was specified.
    -- Using ccache: /opt/nordic/ncs/toolchains/b8efef2ad5/bin/ccache
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection
       * Running CMake for ipc_radio *
    -- Application: /opt/nordic/ncs/v2.9.0/nrf/applications/ipc_radio
      Hints:
      CMakeLists.txt:9 (find_package)
    -- Board: nrf5340dk, qualifiers: nrf5340/cpunet
    -- Found BOARD.dts: /opt/nordic/ncs/v2.9.0/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v2.9.0/nrf/applications/ipc_radio/Kconfig
    Loaded configuration '/opt/nordic/ncs/v2.9.0/zephyr/boards/nordic/nrf5340dk/nrf5340dk_nrf5340_cpunet_defconfig'
    Merged configuration '/opt/nordic/ncs/v2.9.0/nrf/applications/ipc_radio/prj.conf'
    Merged configuration '/opt/nordic/ncs/v2.9.0/nrf/applications/ipc_radio/overlay-bt_hci_ipc.conf'
    Merged configuration '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/.config.sysbuild'
    Configuration saved to '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/.config'
    Kconfig header saved to '/Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/include/generated/zephyr/autoconf.h'
      instead.
    -- libmetal version: 1.6.0 (/opt/nordic/ncs/v2.9.0/nrf/applications/ipc_radio)
    -- Build type:
    -- Machine: arm
    -- Machine: arm
    CMake Warning at /opt/nordic/ncs/v2.9.0/zephyr/CMakeLists.txt:952 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
    CMake Warning at /opt/nordic/ncs/v2.9.0/zephyr/CMakeLists.txt:2133 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio
    -- Configuring done
    -- Generating done
    [1/237] Preparing syscall dependency handling
    [6/237] Generating include/generated/zephyr/version.h
    -- Zephyr version: 3.7.99 (/opt/nordic/ncs/v2.9.0/zephyr), build: v3.7.99-ncs2
    [237/237] Linking C executable zephyr/zephyr.elf
               FLASH:      108560 B         1 MB     10.35%
                 RAM:       77156 B       448 KB     16.82%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/fall_detection/zephyr/zephyr.elf for board: nrf5340dk
    [1/204] Preparing syscall dependency handling
    [6/204] Generating include/generated/zephyr/version.h
    [204/204] Linking C executable zephyr/zephyr.elf
               FLASH:      168880 B       256 KB     64.42%
                 RAM:       46560 B        64 KB     71.04%
               SRAM1:          0 GB        64 KB      0.00%
    Generating files from /Users/joaovitor/Documents/programming/Tiresias_applications/fall_detection/build/ipc_radio/zephyr/zephyr.elf for board: nrf5340dk
    [20/20] Generating ../merged_CPUNET.hex
    Thank you for additional details.
    Which exercise from the lesson 3 have you been using as a starting point?
    Can you provide more information about the changes that you implemented?
    Dejan
  • Hey,
    I've been using Ex1 of Lesson 3.
    First of all I've implemented it inside a directory (BLE) within src and shown the compiler with CMakeLists:
    cmake_minimum_required(VERSION 3.20.0)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(fall_detection)
    target_sources(app PRIVATE
        src/main.c
        src/led/led.c
        src/fall_detection/fall_detection.c
        src/BLE/ble_service.c
    # NORDIC SDK APP END
    zephyr_library_include_directories(.)
    Then I declared everything in a header file and implemented most of the original main function in a function called ble_service_init:
    int ble_service_init(void) {
    	int err;
    	LOG_INF("Starting BLE module\n");
    	// Register our custom callbacks
    	bt_conn_cb_register(&connection_callbacks);
    	LOG_INF("Callbacks okay\n");
    	err = bt_enable(NULL);
    	if (err) {
    		LOG_ERR("Bluetooth init failed (err %d)", err);
    		return -1;
    	LOG_INF("Bluetooth initialized");
    	err = bt_le_adv_start(adv_param, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
    	if (err) {
    		LOG_ERR("Advertising failed to start (err %d)", err);
    		return -1;
    	LOG_INF("Advertising successfully started");
    	return -1;
    I call this function in main(). I also defined a ble_service_thread with lower priority only containing k_sleep for testing purposes.
    I think that's all..
    João.
  • Hi Joao, (EDIT: targeted wrong person here at first)
    West is warning you about that the BOARD_ROOT. Perhaps remove that parameter so that you get rid of the warning. Never get used to warnings!
    I have no experience with this SoC which has 2 MCUs. Perhaps you have only flashed the application and missed flashing the BLE Controller part. You can read about that here:
    Working with nRF5340 DK
    And also here:
    nRF Connect SDK Tutorial - Part 1 - 2.2.1 Build a BLE example (nRF5340) - Nordic Q&A - Nordic DevZone - Nordic DevZone
    Perhaps you can consider to register your callbacks after you have initialized the Bluetooth module. But I doubt that it is the source of the error.
    When attaching source code, next time, please try not to include your generated binaries in it.
    Good luck with your project!
