nRF5340 debug interface not showing
I have a brand new nrf5340dk and the debug interface is not showing up when connected:
I have other nrf5340s that work so I'm sure its the board specific.
Board label says:
PCA1095
2.0.2
2024.21
1050008437
please can I have some help
  • programmer app log:
    14:24:05.489	Initialising the bundled nrfutil device
    14:24:07.241	Using the bundled core version for nrfutil device: 7.13.0
    14:24:07.700	Using nrfutil-device version: 2.6.4
    14:24:07.700	Using nrf-device-lib version: 0.17.35
    14:24:07.701	Using nrfjprog DLL version: 10.24.2
    14:24:07.701	Using JLink version: JLink_V8.10f
    14:24:07.702	Your version of SEGGER J-Link (8.10f) is newer than the one this app was tested with (7.94i). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
    14:24:32.950	Getting serial port options from the persistent store for 001050008437.pc-nrfconnect-programmer
    14:24:33.394	Getting serial port options from the persistent store for 001050008437.pc-nrfconnect-programmer
    14:24:34.136	Getting serial port options from the persistent store for 001050008437.pc-nrfconnect-programmer
    14:24:49.672	Selecting device with the serial number 001050008437
    14:24:50.936	Error: Failed with exit code 1. Failed to device info one or more devices: * 1050008437: [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1050008437))' was found, code: Generic. Message: Operation device-info failed, [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1050008437))' was found.
    14:24:50.936	Selected device with the serial number 001050008437
    14:24:50.937	Using nrfutil device to communicate with target via JLink
    14:24:51.773	Reading readback protection status for Application core
    14:24:51.773	Failed "reading readback protection status for application core". Error: code: 1, description: Generic, message: Batch task protection-get failed, [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1050008437))' was found
    14:24:51.954	Error: Failed with exit code 1. One or more batch tasks failed: - [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1050008437))' was found, code: Generic. Message: Batch task protection-get failed, [Probe] Emulator error: No emulator with connection info 'Usb(JLinkSerialNumber(1050008437))' was found.
  • Hi Chris,
    It does look like there is an issue with the Debug chip on this DK. I will consult with the team on what we can do regarding the same. In the meantime, could you attach what you see when you try:
    nrfjprog --ids
    and also when you try:
    nrfjprog --deviceversion
    -Priyanka
  • Neither of those commands return anything.
    are you going to send me a replacement?
  • Hi Chris,
    Yes, you can ask for a replacement for this from your supplier, from whom you obtained the DK from.
    Please let me know how it goes.
    -Priyanka
