Hi
I tried to put descriptor on the characteristic recently and it didn't seem to work. Is there something wrong with that?
/*Initialize alert service parameter and add charactoristics to the service*/
uint32_t ble_alert_init(ble_nus_t * p_alert, ble_nus_init_t const * p_alert_init)
uint32_t err_code;
ble_uuid_t ble_uuid;
ble_uuid128_t alert_base_uuid = ALERT_BASE_UUID;
VERIFY_PARAM_NOT_NULL(p_alert);
VERIFY_PARAM_NOT_NULL(p_alert_init);
/*Initialize the second custom service structure.*/
p_alert->data_handler = p_alert_init->data_handler;
err_code = sd_ble_uuid_vs_add(&alert_base_uuid, &p_alert->uuid_type);
//VERIFY_SUCCESS(err_code);
ble_uuid.type = p_alert->uuid_type;
ble_uuid.uuid = BLE_UUID_ALERT_SERVICE;
/*Add second custom service.*/
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&ble_uuid,
&p_alert->service_handle);
/**@snippet [Adding proprietary characteristic to the SoftDevice] */
ble_add_char_params_t add_char_params;
ble_add_char_user_desc_t user_desc_config_struct;
ble_add_char_user_desc_t user_desc_alert_struct;
// Initialize and add the Configuration Characteristic
memset(&add_char_params, 0, sizeof(add_char_params));
add_char_params.uuid = BLE_UUID_NUS_CONFIG_CHARACTERISTIC;
add_char_params.uuid_type = p_alert->uuid_type;
add_char_params.max_len = sizeof(uint8_t);
add_char_params.init_len = sizeof(uint8_t);
add_char_params.is_var_len = false;
add_char_params.p_init_value = &Threshold;
add_char_params.char_props.read = 1;
add_char_params.char_props.write_wo_resp = 1;
add_char_params.read_access = SEC_OPEN;
add_char_params.write_access = SEC_OPEN;
static char user_desc_config[] = "CONFIGURATION";
user_desc_config_struct.p_char_user_desc = (uint8_t*)user_desc_config;
user_desc_config_struct.max_size = strlen(user_desc_config);
user_desc_config_struct.size = strlen(user_desc_config);
user_desc_config_struct.is_var_len = false;
add_char_params.p_user_descr = &user_desc_config_struct;
err_code = characteristic_add(p_alert->service_handle, &add_char_params, &p_alert->tx_handles);
if (err_code != NRF_SUCCESS)
return err_code;
// Initialize and add the Alert Characteristic
uint8_t sampledata[] = "HELLO_LUMOS";
add_char_params.uuid = BLE_UUID_NUS_ALERT_CHARACTERISTIC;
add_char_params.max_len = sizeof(sampledata);
add_char_params.init_len = strlen((char*)sampledata);
add_char_params.is_var_len = true;
add_char_params.p_init_value = sampledata;
add_char_params.char_props.notify = 1;
add_char_params.cccd_write_access = SEC_OPEN;
static char user_desc_alert[] = "ALERTS";
user_desc_alert_struct.p_char_user_desc = (uint8_t*)user_desc_alert;
user_desc_alert_struct.max_size = strlen(user_desc_alert);
user_desc_alert_struct.size = strlen(user_desc_alert);
add_char_params.p_user_descr = &user_desc_alert_struct;
err_code = characteristic_add(p_alert->service_handle, &add_char_params, &p_alert->rx_handles);
return err_code;
If I take the following code that adds characteristic, descriptor will be displayed successfully,I want to know why my code above won't display descriptor.
uint32_t err_code;
uint8_t value[130] = {0x00};
uint8_t data_len = 0;
&ble_uuid,
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_gatts_attr_md_t attr_md;
memset(&cccd_md, 0, sizeof(cccd_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
static char *text1 = "CONFIGUARTION";
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write_wo_resp = 1;
char_md.p_char_user_desc = (uint8_t*) text1;
char_md.char_user_desc_size = strlen(text1);
char_md.char_user_desc_max_size = strlen(text1);
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = &cccd_md;
char_md.p_sccd_md = NULL;
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 1;
memset(&attr_char_value, 0, sizeof(attr_char_value));
/* Add config char */
ble_uuid.uuid = BLE_UUID_NUS_CONFIG_CHARACTERISTIC;
data_len = 1;
/*Get Device configuration Length.*/
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = data_len;
attr_char_value.init_offs = 0;
attr_char_value.max_len = data_len;
attr_char_value.p_value = &Threshold;
//printf("\nThreshold %d\n",Threshold);
sd_ble_gatts_characteristic_add(p_alert->service_handle,
&char_md,
&attr_char_value,
static char *text2 = "ALERTS";
char_md.char_props.notify = 1;
char_md.p_char_user_desc = (uint8_t *)text2; //NULL;
char_md.char_user_desc_size = strlen(text2);
char_md.char_user_desc_max_size = strlen(text2);
ble_uuid.uuid = BLE_UUID_NUS_ALERT_CHARACTERISTIC;
attr_md.rd_auth = 1;
attr_md.vlen = 1;
memset(value, 0x00, sizeof(value));
char *sampledata = "HELLO_LUMOS";
data_len = strlen(sampledata);
attr_char_value.max_len = strlen(sampledata);
attr_char_value.p_value = (uint8_t*)sampledata;
return sd_ble_gatts_characteristic_add(p_alert->service_handle,
&char_md,
&attr_char_value,
Best regard
