BT4 usb dongle with bluesoleil
I'd like to use a std USB BT4 dongle (trendnet TBW-106UB), that install me a bluesoleil stack for bluetooth under Win7 to dialog with cutom BT4 device using a NRF51822 (actually it's the eval bord PCA10028) with S110 + custom app firmware
My goal is to log some sensors , and to get the sensors log using a custom service at this time I use NRFuart service with the PCA10031 + mastermulator DLL + custom VB.net soft and it works ! But I'd like to use more std BT dongle...
any advice to use std dongle + bluesoleil is welcome...
other question: final app will be to use an app on IOS or android phone, The idea is to made a temp logger that will be a central... and to make an app on phone that will be advertiser, So, if the device, get an advertisement from custom APP, it will connect and and send his log to the phone. This idea is to avoid the device sending any RF signal... if not asked for !
Can you confirm me that in central mode a system will NOT send any RF signal ?
Can you tell if all BT4 phone(andoid/IOS) can be used as advertiser ?
kind regards herve
  • According to manufacturer page TBW-106UB dongle supports Bluetooth classic 2.1 whereas nRF5x chips use Bluetooth LE aka Smart. This is very different protocol. In order to talk to BLE devices you need BLE enabled dongle i.e. nRF51-Dongle
    As for mobile phones most Android devices can't act as BLE peripheral. Even recent flagship devices like Nexus 5. It is also firmware version dependent (preview versions of Android Marshmallow for N5 had BLE adveriser enabled but it was removed in final release). So currently I wouldn't count on that functionality. If you have particular device you want to test install Nordics Master Controll panel for Android and chceck if "Advertiser" tab works.
  • Thanks for your answer...
    about the USB dongle it's TBW-106UB v02r ( manufacturer page so I think it's BT4 ! I do not see how to use it...
    about phone as BLE periphal... I keep this in mind !
  • Are you using bluesoleil as a development tool or for end product purposes. If it is for development I would recommend using our pc-ble-driver or just use a phone as suggested in the comments.
    A central will not send any packets, instead it will be scanning for advertisements. However this requires a lot more power than sending advertisement packet and isn't a very common approach. As long as power isn't a limitation I don't see any reason this wouldn't work.
    Most iOS phones can be used as advertisers. If I remember correctly iOS has had peripheral support since iOS 7 (could be 6). For Android I think this was introduced with version 5.
