JLink loading into a secured nRF54 device
i'm working "bare-metal" with the nRF54-DK, loading from the command-line by directly calling JLink....
often (but not always) i receive the following message from JLink:
clicking through this, my image loads just fine....
is there something i should do in my target firmware to "unsecure" the device???
at this stage, i'm in development and am constantly re-flashing my HW
  • Not sure if this will help, but this is what I use:
    // nrf54L15 UICR Arm Cortex-M33
    // To program a hex file:
    // In .\nRF5_SDK_17.1.0_ddde560\examples\peripheral\blinky\pca10156\blank\iar\_build
    //  nrfjprog -v
    //    nrfjprog version: 10.24.2 external
    //    JLinkARM.dll version: 7.94e
    //  nrfjprog --recover
    //  nrfjprog --memwr 0x00FFD080 --val 0x00000003
    //  nrfjprog --program blinky_pca10156.hex --chiperase --verify -r --log
    // Example:
    //    .\nRF5_SDK_17.1.0_ddde560\examples\peripheral\blinky\pca10156\blank\iar\_build>nrfjprog --recover
    //    Recovering device. This operation might take 30s.
    //    Erasing user code and UICR flash areas.
    //    .\nRF5_SDK_17.1.0_ddde560\examples\peripheral\blinky\pca10156\blank\iar\_build>nrfjprog --memwr 0x00FFD080 --val 0x00000003
    //    Parsing parameters.
    //    Writing.
    //    .\nRF5_SDK_17.1.0_ddde560\examples\peripheral\blinky\pca10156\blank\iar\_build>nrfjprog --program blinky_pca10156.hex --chiperase --verify -r --log
    //    [ #################### ]   0.263s | Erase file - Done erasing
    //    [ #################### ]   0.197s | Program file - Done programming
    //    [ #################### ]   0.072s | Verify file - Done verifying
    //    Applying system reset.
    //    Run.
  • long story, but i'm using the jlink CLI directly and not `nrfjprog`....  any hint as to what i need to do???  sounds like a mass-erase is required???
  • Make sure this line is called in your code at application start: github.com/.../system_nrf54l.c. It opens up the debugger.
