nRF5340 AUDIO DK
We are considering to develop an appliance based on the nRF5340 AUDIO DK.
The nRF5340 AUDIO DK contains the VM3011-U1microphone that is absolute on the market.
Does Nordic has a recommended substituted microphone that has a low power always-on Sound Detection feature?
Thanks for your respond.
    Nordic does unfortunately not have any list over components that we recommend over other for components such as microphones. You will have to do any required evaluation yourself w.r.t the scope of your project and to make sure that your components fits the electrical characteristics of the board and SoC you're using.
    Andreas
  • Hi Andreas,
    Thanks for your reply.
    Let me be sure that I understand, for the moment, there is not a valid hardware (and software) reference design for the  nRF5340 Audio application (since some of the nRF5340 AUDIO  DK BOM is obsolete and cannot be purchased) ?
    Amos
  • Hi again Amos,
    That's a good follow up question. There might've come a new reference design with for instance a different PDM microphone, but I haven't found one. The previous reply I got from the Audio team a few months back was that we didn't have a preferred component for a new PDM microphone, and that when evaluating a new one the following had to be considered
    1. PDM interface on nRF5340 would only support 16KHz, cannot be higher
    2. Customer would need to check the PDM part from nRF5340 for choosing the proper component.
    3. Customer would need to check the VIO setting, since now it is 1.8v on nRF5340 ADK, but nRF5340 can also support 3v IO
    I will check in again with the team if this has changed, but a reply may have to wait until after Easter (around the 22nd).
    Andreas
  • Hi Andreas,
    Thanks a lot for this answer.
    Amos
  • Hi again Amos,
    I got a verification from the Audio team that we don't have a ref design with a replacement PDM mic that we use. You will have to choose the PDM mic you want based on your needs and based on the previously mentioned criteria
    Andreas
