MCUBoot Fails to Boot Updated Image on Custom nRF7002 Board (is25lp064 SPI NOR)
Dear Team,
I am experiencing issues updating the firmware image on my custom board based on the nRF7002, using an external SPI NOR flash (is25lp064, 8MB). The board is running nRF Connect SDK v2.9.1. I am able to build and run, and update the new application successfully on the nRF7002DK, but encounter problems when performing an image update on my custom board.
Here's a breakdown of my process and where the issue occurs:
Steps Completed:
  1. Build: Built the application using the following command:
    west build --build-dir build --pristine --board nrf7002dk/nrf5340/cpuapp --sysbuild -- -DCONF_FILE="prj.conf" -DDTC_OVERLAY_FILE="app.overlay"
  2. Initial Flash: Flashed the built application to my custom board.
  3. Image Update: While running the main app (not bootloader), I used Auterm to upload a new application image to slot 1 with the test flag.
  4. Verification: Verified that the image hash reported by Auterm matches the hash report from ```imgtool dumpinfo build/spi/zephyr/zephyr.signed.bin```
  5. Reset: Reset the board to trigger MCUBoot to perform the image swap.
Issue:
  • On reset, MCUBoot logs indicate:
    [00:00:00.299,407] <inf> mcuboot: Starting bootloader
    [00:00:00.306,243] <dbg> mcuboot: boot_slots_compatible: Non-optimal sector distribution, slot0 has 237 usable sectors (240 assigned) but slot1 has 240 assigned
    [00:00:00.321,502] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.332,031] <inf> mcuboot: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
    [00:00:00.342,285] <inf> mcuboot: Boot source: none
    [00:00:00.363,220] <inf> mcuboot: Image index: 0, Swap type: test
    [00:00:02.815,612] <err> mcuboot: Image in the secondary slot is not valid!
    [00:00:03.027,984] <inf> mcuboot: Bootloader chainload address offset: 0x10000
    [00:00:03.035,797] <inf> mcuboot: Jumping to the first image slot
    The program then freezes. Attempting to reset and revert to the previous image also fails, with logs showing:
    [00:00:00.250,427] <inf> spi_nor: is25lp064d@0: 8 MiBy flash
    [00:00:00.256,683] <dbg> spi_nor: spi_nor_process_bfp: Erase 4096 with 20
    [00:00:00.264,068] <dbg> spi_nor: spi_nor_process_bfp: Erase 32768 with 52
    [00:00:00.271,575] <dbg> spi_nor: spi_nor_process_bfp: Erase 65536 with d8
    [00:00:00.279,052] <dbg> spi_nor: spi_nor_process_bfp: Page size 256 bytes
    *** Booting MCUboot v2.1.0-dev-12e5ee106034 ***
    *** Using nRF Connect SDK v2.9.1-60d0d6c8d42d ***
    *** Using Zephyr OS v3.7.99-ca954a6216c9 ***
    [00:00:00.299,468] <inf> mcuboot: Starting bootloader
    [00:00:00.306,304] <dbg> mcuboot: boot_slots_compatible: Non-optimal sector distribution, slot0 has 237 usable sectors (240 assigned) but slot1 has 240 assigned
    [00:00:00.321,594] <inf> mcuboot: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3
    [00:00:00.332,031] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    [00:00:00.342,376] <inf> mcuboot: Boot source: none
    [00:00:00.362,823] <wrn> mcuboot: Failed reading image headers; Image=0
    [00:00:00.370,269] <err> mcuboot: Image in the primary slot is not valid!
    [00:00:00.377,929] <err> mcuboot: Unable to find bootable image
    This issue does not occur when tested with nRF7002DK (by  #define CONFIG_TEST_DK_BOARD 1 in the overlay fiiles my attached project source code) where the same process works as expected and I were able to update to new firmware
Device and Software Details:
  • Device: Custom nRF7002-based board
  • External Flash: is25lp064 (8MB SPI NOR)
  • nRF Connect SDK Version: v2.9.1
Additional Information:
  • Partition table is attached (debug_data/partition.txt).
  • Full UART logs for the custom board are attached (debug_data/log/custom_board).
  • SPI flash command traces are provided (debug_data/spi_commands).
  • Working build/log for the nRF7002DK is available in (debug_data/log/7002dk_working).
Could you kindly help identify if there are any known issues, misconfigurations, or specific steps I might be missing regarding MCUBoot, partitioning, or image update flow for a custom board with external SPI NOR flash? I am happy to provide any further configuration files or logs as needed. Thank you in advance for your expertise and assistance.
Sincerely,
Thuan.
spi_help.zip
