Hi
I had a device that did not start up - because it was waiting for the 32KHz clock to be stable.
Br
GoodOld
Hi
Br
GoodOld
Can you share the full part number and datasheet of the crystal that you are using?
regards
Jared
The part number for 32KHz Xtal is Q-SC20A03220C5AAEF, please see the datasheet in the attachment.SC-20A 12.5pF 20ppm.pdf
Br
GoodOld
Hi Niels,
That crystal is out of spec, maximum internal load capacitance for external LFXO on nRF54L15 is 9 pF.
regards
Jared
So I tried to set the value to an impossible number to see what error message would come.
I got this:
devicetree error: value of property 'load-capacitance-femtofarad' on /clocks/lfxo in C:/work/SapheZFirmware_ado_master/Lucid/build_2_9_1/mcuboot/zephyr/zephyr.dts.pre (5002) is not in 'enum' list in C:/ncs/v2.9.1/zephyr/dts/bindings\clock\nordic,nrf-lfxo.yaml ([4000, 4500, 5000, 5500, 6000, 6500, 7000, 7500, 8000, 8500, 9000, 9500, 10000, 10500, 11000, 11500, 12000, 12500, 13000, 13500, 14000, 14500, 15000, 15500, 16000, 16500, 17000, 17500, 18000])
It seems to me that it can be from 4pF to 18pF.
Please explain.
Regards
GoodOld
Based on that error message I would assume that this driver supports all of our devices. We have different max load capacitance across our product series. This is a HW limitation, so that is what will be the limiting factor regardless of options in SW.
regards
Jared
