[SAADC] Zephyr's SAADC Driver (DMA Design choices analysis)
Setup:
NCS v2.8.0
nRF52840
I would like to ask about the implementation of Zephyr's SAADC driver (`adc_nrfx_saadc.c`).
In the project I'm working on, I need to sample the ADC at 16 kHz.
However, I don't need to process every individual sample in the application. Instead, I would prefer to collect around 320 samples (equivalent to 20 ms of data) and then raise an interrupt. DMA seems like a perfect fit for this use case.
Initially, I thought that by using the `struct adc_sequence_options`—specifically the `extra_samplings` field—the SAADC driver would configure the `RESULT.MAXCNT` register to match the total number of samples (including `extra_samplings`), and thus trigger an interrupt only after all samples had been collected.
However, this does not appear to be the case. For each `adc_sequence` triggered by `adc_read()` or `adc_async_read()`, the driver calls `nrf_saadc_buffer_init()` with a buffer size (`RESULT.MAXCNT`) equal only to the number of channels selected for that sequence.
In my case, with a single channel, this results in `RESULT.MAXCNT = 1`, which causes the SAADC interrupt to fire after each individual sample—even if `extra_samplings` is set to a higher value.
This means the MCU is being interrupted every 62.5 μs, which is far too frequent for my application.
**My questions are:**
0. Am I correct in my understanding above?
1. Why was this design decision made in the SAADC driver implementation? What benefit does it provide?
2. What would be the best way to extend the SAADC driver to fully support single-channel continuous conversion mode, without needing to fork the driver?
3. What happens if an ADC sequence is triggered while another is still running? Will the previous sequence be aborted?
I look forward to your response.
Pawel
  • The ADC drivers are written with low power usage in mind and not to be compatible to audio frequency.
    I would recommend not to fork the driver but to write a new one from scratch, possibly even without the NRFX hardware abstraction layer, as I have not check if this layer allows high sampling frequencies either.
    The idea is to do something similar to the audio/I²S drivers, particularly how these handle lots of data with the k_mem_slab_ stuff.
