RF testing uart pin configuration issue
I am working on RF testing on the custom board.
I have configured the nrf UART TX in p1.04 and UART RX pin in p0.13.
UART TX pin is working fine, but the UART Rx is not working.
I tried on the NRF5340 DK, but it is not working on the DK either.
I need to use the p0.13 pin in my custom board.
In this project,
QSPI_IO0 is also using p0.13.So I commented the configuration of QSPI, which also didn't work.
What is the solution to configure the UART RX pin as p0.13?
Thank you.
    P0.13 is not connected to the pin header on the DK unless you have shorted the solder bridge mentioned here: https://docs.nordicsemi.com/bundle/ug_nrf5340_dk/page/UG/dk/hw_external_memory.html
    In the devictree? Please show the configuration you commented out.
    Vidar
  •   I commented in 2 files
    1) In nrf5340_cpuapp_common_pinctrl.dtsi,
            // qspi_default: qspi_default {
            //      group1 {
            //              psels = <NRF_PSEL(QSPI_SCK, 0, 17)>,
            //                      <NRF_PSEL(QSPI_IO0, 0, 13)>,
            //                      <NRF_PSEL(QSPI_IO1, 0, 14)>,
            //                      <NRF_PSEL(QSPI_IO2, 0, 15)>,
            //                      <NRF_PSEL(QSPI_IO3, 0, 16)>,
            //                      <NRF_PSEL(QSPI_CSN, 0, 18)>;
            //              nordic,drive-mode = <NRF_DRIVE_H0H1>;
            // qspi_sleep: qspi_sleep {
            //      group1 {
            //                      <NRF_PSEL(QSPI_IO3, 0, 16)>;
            //              low-power-enable;
            //      group2 {
            //              psels = <NRF_PSEL(QSPI_CSN, 0, 18)>;
            //              bias-pull-up;
    2) In nrf5340_cpuapp_common.dtsi
    // &qspi {
    //      status = "okay";
    //      pinctrl-0 = <&qspi_default>;
    //      pinctrl-1 = <&qspi_sleep>;
    //      pinctrl-names = "default", "sleep";
    //      mx25r64: mx25r6435f@0 {
    //              compatible = "nordic,qspi-nor";
    //              reg = <0>;
    //              /* MX25R64 supports only pp and pp4io */
    //              writeoc = "pp4io";
    //              /* MX25R64 supports all readoc options */
    //              readoc = "read4io";
    //              sck-frequency = <8000000>;
    //              jedec-id = [c2 28 17];
    //              sfdp-bfp = [
    //                      e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
    //                      ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
    //                      10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
    //                      30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
    //              size = <67108864>;
    //              has-dpd;
    //              t-enter-dpd = <10000>;
    //              t-exit-dpd = <35000>;
  • Thanks for confirming. Commenting the lines you did will free up P0.13. Does RX work if you swap TX/RX or assign RX to another pin?
  • Thanks for the reply.
    Yes, it is working when I use other pins except p0.13, p0.14, p0.15 and p0.16.
  • p0.13, p0.14, p0.15 and p0.16.
    Are all these pins accessible on your custom board?
