Error in SDK v3.0.1 when flashing: unexpected argument --x-ext-mem-config-file found
When flashing with SDK v3.0.1 the following error occurs:
-- west flash: using runner nrfutil
-- runners.nrfutil: mass erase requested
-- runners.nrfutil: reset after flashing requested
-- runners.nrfutil: Flashing file: *****\firmware\observer\build\merged.hex
error: unexpected argument '--x-ext-mem-config-file' found
  tip: a similar argument exists: '--x-qspi-config-file'
Usage: nrfutil device <--json|--json-pretty|--skip-overhead> <--json|--json-pretty> <--x-qspi-config-file <PATH>>
For more information, try '--help'.
-- runners.nrfutil: Board with serial number 1050202762 flashed successfully.
If I use Toolchain and SDK v2.9.1 it works without problems:
-- west flash: using runner nrfjprog
-- runners.nrfjprog: mass erase requested
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: *****\firmware\observer\build\merged.hex
[ #################### ]   0.304s | Erase file - Done erasing
[ #################### ]   0.544s | Program file - Done programming
[ #################### ]   0.553s | Verify file - Done verifying
Enabling pin reset.
Applying pin reset.
-- runners.nrfjprog: Board with serial number 1050202762 flashed successfully.
  • After reading this I tried nrfutil upgrade device again, and got the same response that it was already at the newest version (2.3.6). Then I discovered the self-upgrade command, and ran that, It did update. After that, nrfutil upgrade device did upgrade to 2.10.2. Again, this is on Windows 11.
  • i was facing issue is like
    logs :
    Flashing build_nrf54840dk to 1050266177
    C:\WINDOWS\system32\cmd.exe /d /s /c "west flash -d c:\Users\J\Downloads\ncs-inter-main\l9\l9_e5\build_nrf54840dk --dev-id 1050266177"
    -- west flash: rebuilding
    [0/10] Performing build step for 'l9_e5'
    ninja: no work to do.
    [1/10] Performing build step for 'mcuboot'
    [4/10] cmd.exe /C "cd /D C:\Users\J\Downloads\ncs-inter-main\l9\l9_e5\build_nrf54840dk\_sysbuild && C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.exe -E true"
    [6/9] No install step for 'mcuboot'
    [7/9] Completed 'mcuboot'
    [8/9] cmd.exe /C "cd /D C:\Users\J\Downloads\ncs-inter-main\l9\l9_e5\build_nrf54840dk\_sysbuild && C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.exe -E true"
    -- runners.nrfutil: Flashing file: C:\Users\J\Downloads\ncs-inter-main\l9\l9_e5\build_nrf54840dk\merged.hex
    -- runners.nrfutil: Board with serial number 1050266177 flashed successfully.
    * Terminal will be reused by tasks, press any key to close it.
    my issue resolved after this execution.
    if you facing same then will work for you...
    share your logs..
  • I tested it again today:
    nrfutil-device is already the newest version (2.3.6)
    [00:00:00] ###### 100% [Upgrade packages] Upgrade packages
    Then I tried self-upgrade (thanks to RogerC60 for the tip):
    > nrfutil self-upgrade
    Uninstalled nrfutil
    [00:00:02] ###### 100% [Install packages] Install packages
    and then upgrade device again:
    Downloading nrfutil-device-x86_64-pc-windows-msvc-2.10.2
    Verifying nrfutil-device-x86_64-pc-windows-msvc-2.10.2
    Updating nrfutil-device to 2.10.2
    [00:00:03] ###### 100% [Upgrade packages] Upgrade packages
    Now the upgrade and the flashing worked :-)
    Here is the log of the successful flashing:
    Flashing build to 1050202762
    C:\WINDOWS\system32\cmd.___ /d /s /c "west flash -d ****\observer\build --dev-id 1050202762 --erase"
    [0/5] Performing build step for 'observer'
    [2/5] No install step for 'observer'
    [3/5] Completed 'observer'
    [4/5] cmd.___ /C "cd /D ****\observer\build\_sysbuild && D:\Nordic\toolchains\0b393f9e1b\opt\bin\cmake.exe -E true"
    -- runners.nrfutil: Flashing file: ****\observer\build\merged.hex
    -- runners.nrfutil: Erasing non-volatile memory (ERASEALL)
    -- runners.nrfutil: Programming image
    -- runners.nrfutil: Verifying image
    -- runners.nrfutil: Reset
    Note: The download from www.nordicsemi.com/.../nRF-Util is outdated!
    Nordic needs to update the download here...
