Issue on SX128X using nRF Connect SDK 3.0.0
Hello everyone,
I'm developing an application using the SX128x radio with the LoRaWAN Basic Modem.
The project runs successfully on a custom board based on the nRF5340 using nRF Connect SDK v2.9.0.
Now, I'm migrating to use nRF Connect SDK v3.0.0.
However, when running the same code with SDK v3.0.0, no SPI activity is observed on the oscilloscope—it's completely silent.
I currently use SPI0. No LOG Erros from spi API or spi device was showed. The spi code:
* \file      smtc_hal_spi.c
* \brief     SPI Hardware Abstraction Layer implementation
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include <soc.h>
#include <zephyr/kernel.h>
#include <zephyr/types.h>
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#include "smtc_hal_spi.h"
#include "smtc_hal_mcu.h"
#include "smtc_hal_dbg_trace.h"
LOG_MODULE_REGISTER(smtc_hal_spi, LOG_LEVEL_INF);
#define SPIOP SPI_WORD_SET(8) | SPI_TRANSFER_MSB
const struct spi_dt_spec spi_radio = SPI_DT_SPEC_GET(DT_NODELABEL(sx1280), SPIOP, 0);
static int err;
void hal_spi_init(void) {
    err = spi_is_ready_dt(&spi_radio);
    if (!err) {
        SMTC_HAL_TRACE_ERROR("Error: SPI device is not ready, err: %d", err);
void hal_spi_de_init(void) {
    err = spi_release(&spi_radio, &spi_radio.config);
    if (err) {
        SMTC_HAL_TRACE_ERROR("Error: SPI device release failed, err: %d", err);
void hal_spi_out(uint8_t* txBuffer, uint16_t size) {
    struct spi_buf tx_spi_buf = {.buf = txBuffer, .len = size};
    struct spi_buf_set tx_spi_buf_set = {.buffers = &tx_spi_buf, .count = 1};
    err = spi_write_dt(&spi_radio, &tx_spi_buf_set);
    if (err < 0) {
        SMTC_HAL_TRACE_ERROR("spi_write_dt() failed, err: %d", err);
void hal_spi_in_out(uint8_t* txBuffer, uint16_t txBuffer_size, uint8_t* rxBuffer, uint16_t rxBuffer_size) {
    struct spi_buf tx_spi_buf = {.buf = txBuffer, .len = txBuffer_size};
    struct spi_buf rx_spi_bufs = {.buf = rxBuffer, .len = rxBuffer_size};
    struct spi_buf_set rx_spi_buf_set = {.buffers = &rx_spi_bufs, .count = 1};
    err = spi_transceive_dt(&spi_radio, &tx_spi_buf_set, &rx_spi_buf_set);
    if (err < 0) {
        SMTC_HAL_TRACE_ERROR("spi_transceive_dt() failed, err: %d", err);
My pinctrl:
&pinctrl {
	i2c1_default: i2c1_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 1, 2)>,
                    <NRF_PSEL(TWIM_SCL, 1, 3)>;
            bias-pull-up;
            nordic,drive-mode = <NRF_DRIVE_E0E1>;
	i2c1_sleep: i2c1_sleep {
		group1 {
			low-power-enable;
	pwm0_backlight_default: pwm0_backlight_default {
        group1 {
            psels = <NRF_PSEL(PWM_OUT0, 0, 31)>;
            nordic,invert;
            bias-pull-down;
    pwm0_backlight_sleep: pwm0_backlight_sleep {
        group1 {
            low-power-enable;
	pwm1_leds_default: pwm1_leds_default {
        group1 {
            psels = <NRF_PSEL(PWM_OUT0, 0, 17)>;
            bias-pull-down;
        group2 {
            psels = <NRF_PSEL(PWM_OUT1, 0, 28)>;
            bias-pull-down;
    pwm1_leds_sleep: pwm1_leds_sleep {
        group1 {
            low-power-enable;
        group2 {
            low-power-enable;
    pwm2_motor_default: pwm2_motor_default {
        group1 {
            psels = <NRF_PSEL(PWM_OUT0, 0, 12)>;
            nordic,invert;
            bias-pull-down;
    pwm2_motor_sleep: pwm2_motor_sleep {
        group1 {
            low-power-enable;
    pwm3_buzzer_default: pwm3_buzzer_default {
        group1 {
            psels = <NRF_PSEL(PWM_OUT0, 0, 16)>;
            nordic,drive-mode = <NRF_DRIVE_H0H1>;
            nordic,invert;
            bias-pull-down;
    pwm3_buzzer_sleep: pwm3_buzzer_sleep {
        group1 {
            low-power-enable;
    spi0_sx128x_default: spi0_sx128x_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 22)>,
                    <NRF_PSEL(SPIM_MOSI, 0, 0)>,
                    <NRF_PSEL(SPIM_MISO, 0, 4)>;
            bias-pull-down;
    spi0_sx128x_sleep: spi0_sx128x_sleep {
        group1 {
            low-power-enable;
    spi3_st7789v_default: spi3_st7789v_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 1, 13)>,
                    <NRF_PSEL(SPIM_MOSI, 0, 30)>,
                    <NRF_PSEL(SPIM_MISO, 1, 7)>;
            bias-pull-down;
    spi3_st7789v_sleep: spi3_st7789v_sleep {
        group1 {
            low-power-enable;
My .dts:
 * Copyright (c) 2020 Nordic Semiconductor ASA
/dts-v1/;
#include <nordic/nrf5340_cpuapp_qkaa.dtsi>
#include "aura_nrf5340_cpuapp-pinctrl.dtsi"
#include <zephyr/dt-bindings/input/input-event-codes.h>
#include <zephyr/dt-bindings/mipi_dbi/mipi_dbi.h>
	model = "Aura NRF5340 Application";
	compatible = "nordic,nrf5340-dk-nrf5340-cpuapp";
	chosen {
		zephyr,sram = &sram0_image;
		zephyr,flash = &flash0;
		zephyr,code-partition = &slot0_partition;
		zephyr,sram-secure-partition = &sram0_s;
		zephyr,sram-non-secure-partition = &sram0_ns;
		zephyr,bt-hci = &bt_hci_ipc0;
		nordic,802154-spinel-ipc = &ipc0;
		zephyr,ieee802154 = &ieee802154;
		zephyr,display = &st7789v;
		zephyr,rtc = &rv_8263_c8;
	mipi_dbi_st7789v {
		compatible = "zephyr,mipi-dbi-spi";
		spi-dev = <&spi3>;
        dc-gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>;
        reset-gpios = <&gpio1 5 GPIO_ACTIVE_LOW>;
		write-only;
		#address-cells = <1>;
		#size-cells = <0>;
		st7789v: st7789v@0 {
			compatible = "sitronix,st7789v";
			mipi-max-frequency = <8000000>;
			reg = <0>;
			width = <240>;
			height = <240>;
			x-offset = <80>;
			y-offset = <0>;
			vcom = <0x19>;
			gctrl = <0x35>;
			vrhs = <0x12>;
			vdvs = <0x20>;
			mdac = <0xA0>;
			gamma = <0x01>;
			colmod = <0x05>;
			lcm = <0x2c>;
			porch-param = [0c 0c 00 33 33];
			cmd2en-param = [5a 69 02 01];
			pwctrl1-param = [a4 a1];
			pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
			nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
			ram-param = [00 F0];
			rgb-param = [CD 08 14];
			// mipi-mode = <MIPI_DBI_MODE_SPI_4WIRE>;
			mipi-mode = "MIPI_DBI_MODE_SPI_4WIRE";
	gpio_fwd: nrf-gpio-forwarder {
		compatible = "nordic,nrf-gpio-forwarder";
		status = "okay";
		// uart {
		// 	//gpios = <&gpio1 1 0>, <&gpio1 0 0>, <&gpio0 11 0>, <&gpio0 10 0>;
		/* Forward pins for NORA-B12 FEM */
		norab12fem {
			gpios = <&gpio1 8 0>, <&gpio1 9 0>;
	pwmleds {
		compatible = "pwm-leds";
		backlight: backlight {
			pwms = <&pwm0 0 PWM_MSEC(50) PWM_POLARITY_NORMAL>;
			label = "backlight";
		led_red: led_red {
            pwms = <&pwm1 0 PWM_MSEC(50) PWM_POLARITY_NORMAL>;
            label = "led_red";
        led_blue: led_blue {
            pwms = <&pwm1 1 PWM_MSEC(50) PWM_POLARITY_NORMAL>;
            label = "led_blue";
		motor: motor {
			pwms = <&pwm2 0 PWM_MSEC(50) PWM_POLARITY_NORMAL>;
			label = "motor";
		buzzer: buzzer {
			pwms = <&pwm3 0 PWM_MSEC(50) PWM_POLARITY_NORMAL>;
			label = "buzzer";
	pins_io {
		compatible = "gpio-keys";
		key1: key1 {
			gpios = <&gpio1 4 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "key1";
			zephyr,code = <INPUT_KEY_0>;
		en_motor: en_motor {
			gpios = <&gpio0 8 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
			label = "en_motor";
	zephyr,user {
		io-channels = <&adc 5>;
		bq24040-gpios = <&gpio0 24 0>;
	aliases {
		watchdog0  = &wdt0;
&vregmain {
	regulator-initial-mode = <NRF5X_REG_MODE_DCDC>;
&vregradio {
&vregh {
	status = "okay";
&adc {
	#size-cells = <0>;
	status = "okay";
	channel@5 {
		reg = <5>;
		zephyr,gain = "ADC_GAIN_1_2";
		zephyr,reference = "ADC_REF_INTERNAL";
		zephyr,acquisition-time = <ADC_ACQ_TIME_MAX>;
		zephyr,input-positive = <NRF_SAADC_AIN5>;
		zephyr,resolution = <12>;
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
&i2c1 {
    status = "okay";
    label = "I2C_1";
    pinctrl-0 = <&i2c1_default>;
    pinctrl-1 = <&i2c1_sleep>;
    zephyr,concat-buf-size = <128>;
	rv_8263_c8: rv-8263-c8@51 {
        compatible = "microcrystal,rv-8263-c8";
        reg = <0x51>;
        status = "okay";
        clkout = <0>;
        int-gpios = <&gpio1 0 (GPIO_PULL_UP)>;
    bmi270: bmi270@68 {
        compatible = "bosch,bmi270";
        reg = <0x68>;
        irq-gpios = <&gpio0 20 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>;
        // invert-x;
        // invert-y;
&pwm0 {
	status = "okay";
	pinctrl-0 = <&pwm0_backlight_default>;
	pinctrl-1 = <&pwm0_backlight_sleep>;
&pwm1 {
    status = "okay";
    pinctrl-0 = <&pwm1_leds_default>;
    pinctrl-1 = <&pwm1_leds_sleep>;
&pwm2 {
    status = "okay";
    pinctrl-0 = <&pwm2_motor_default>;
    pinctrl-1 = <&pwm2_motor_sleep>;
&pwm3 {
    status = "okay";
    pinctrl-0 = <&pwm3_buzzer_default>;
    pinctrl-1 = <&pwm3_buzzer_sleep>;
&spi0 {
	status = "okay";
	cs-gpios = <&gpio0 1 GPIO_ACTIVE_LOW>;
	overrun-character = <0x00>;
	pinctrl-0 = <&spi0_sx128x_default>;
	pinctrl-1 = <&spi0_sx128x_sleep>;
	sx1280: sx1280@0 {
		compatible = "semtech,sx1262";
		status = "okay";
		reg = <0x0>;
		spi-max-frequency = <1000000>;
		reset-gpios = <&gpio0 10 GPIO_ACTIVE_HIGH>;
		busy-gpios = <&gpio0 15 GPIO_ACTIVE_HIGH>;
		dio1-gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>;
&spi3 {
	status = "okay";
	cs-gpios = <&gpio0 2 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi3_st7789v_default>;
	pinctrl-1 = <&spi3_st7789v_sleep>;
&ieee802154 {
	status = "okay";
zephyr_udc0: &usbd {
	compatible = "nordic,nrf-usbd";
	status = "okay";
&qspi {
	status = "disabled";
&nfct {
/* Include default memory partition configuration file */
#include <common/nordic/nrf5340_cpuapp_partition.dtsi>
Has anyone experienced a similar issue or can offer guidance on this behavior?
Thanks a lot in advance!
