Can' get modem trace from custom board
6175.trace-2025-05-13T14-12-36.978Z.mtrace
I have a custom board build with an nrf9151. Right now I'd like to have the possibilty ti get modem trace. But it's look like I got crypted/corrupted data from UART1. So in my project I created an overlay file like this:
    chosen {
        nordic,modem-trace-uart = &uart1;
&i2c1 {
    status = "disabled";
&uart1 {
    current-speed = <1000000>;
    pinctrl-0 = <&uart1_default>;
    pinctrl-1 = <&uart1_sleep>;
Here is my board comon-pinctrl
&pinctrl {
	uart0_default: uart0_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 6)>,
				<NRF_PSEL(UART_RX, 0, 5)>;
	uart0_sleep: uart0_sleep {
		group1 {
			low-power-enable;
	uart1_default: uart1_default {
		group1 {
			psels = <NRF_PSEL(UART_TX, 0, 23)>,
				<NRF_PSEL(UART_RX, 0, 24)>;
	uart1_sleep: uart1_sleep {
		group1 {
			low-power-enable;
	i2c1_default: i2c1_default {
		group1 {
			psels = <NRF_PSEL(TWIM_SDA, 0, 26)>,
				<NRF_PSEL(TWIM_SCL, 0, 27)>;
	i2c1_sleep: i2c1_sleep {
		group1 {
			low-power-enable;
in my common file
&adc {
	status = "okay";
&gpiote {
	status = "okay";
&gpio0 {
	status = "okay";
&uart0 {
	status = "okay";
	current-speed = <115200>;
	pinctrl-0 = <&uart0_default>;
	pinctrl-1 = <&uart0_sleep>;
&i2c1 {
	status = "okay";
	pinctrl-0 = <&i2c1_default>;
	pinctrl-1 = <&i2c1_sleep>;
So I think my board def and overlay are good...
In my prj.conf
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_LOG=y
CONFIG_DEBUG=y
CONFIG_ASSERT=y
CONFIG_NRF_MODEM_LOG=y
CONFIG_SERIAL=y
CONFIG_AT_HOST_LIBRARY=y
CONFIG_NRF_MODEM_LIB_TRACE=y
Ok so with all this configuration I'm able to send AT command via serial (UART0) example if I send `AT+CGMR` I got mfw_nrf91x1_2.0.2. and when my custom board boot I have serial terminal showing this:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
[00:00:00.308,868] <inf> LOG: Sample started.
[00:00:00.308,990] <inf> nrf_modem: Initializing libmodem 2.6.1-lte-11b6ed4846a8
[00:00:00.556,304] <inf> nrf_modem: RPC ready
[00:00:00.556,671] <inf> nrf_modem_lib_trace: Trace thread ready
[00:00:00.558,258] <inf> nrf_modem_lib_trace: Trace level override: 2
[00:00:00.689,941] <inf> LOG: Waiting for LTE connect event.
So I presume UART0 works well and my firmware also. Right now I want to get modem trace so I plugged an CP2102 to my UART1, when my board boot I can see Rx led on my cp2102 blinking rapidly, so I presume lot of data coming to this UART1.
I open Cellular monitor and I select my cp2102 plug on UART1 and I let modem trace database in autoselect, in this configuration, cellular monitor never checked in green number 1 TRACE step. So after I try to specify my databse (v2.02 like AT+CGMR return mfw_nrf91x1_2.0.2) and now I have a mtrace file but all data inside look corrupted or crypted (I've attached an example with my post). I managed lot of test, always same prblem, even if I try to reset my board during cellular monitor detect phase.
Any thoughts?
  • simon884 said:
    Ok so I've try to use RTTviewer with my nrf9160-DK board, I'm able to connect to my custom board build with nrf9151.
    But In therminal I only see my LOG_INF message, don't see any log from modem. Should I use AT_CLIENT sample? I've added in my prj.conf 3 above lines.
    The modem trace is not supposed to be output on the same channel as the application log. It is most likely being written to a file, if things are set up correctly. Please review this document for how to perform modem trace over RTT.
  • Yes I've followed your link but when I try to run
     nrfjprog --reset && JLinkRTTLogger -Device NRF9151_XXAA -If SWD -Speed 50000 /test.bin
    My bord reboot and I got this result:
    Applying system reset.
    Run.
    SEGGER J-Link RTT Logger
    Compiled Jun 11 2025 12:25:04
    (c) 2016-2017 SEGGER Microcontroller GmbH, www.segger.com
             Solutions for real time microcontroller applications
    Default logfile path: /Users/XXXXX/Library/Application Support/SEGGER
    Shutting down... Done.%
    And If I open JLinkRTTViewer and connect to my bord I see on the windows log coming from LOG_INF
    And my prj.conf
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_FLOAT_SCANF=y
    CONFIG_LOG=y
    CONFIG_LOG_BUFFER_SIZE=4096
    CONFIG_DEBUG=y
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    CONFIG_MODEM_KEY_MGMT=y
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_SOCKETS_OFFLOAD=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_SERIAL=y
    CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=n
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=n
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
  • Make sure you are using the JLink v8.18. Did you check the "Default logfile path: /Users/XXXXX/Library/Application Support/SEGGER/" for any log files?
  • I have nothing in SEGGER folder... I don't know if I'm using the good version because if I try to do JLinkRTTLogger -? no return.
    I' ve just folow this answer, changing nrf9160 by nrf9151. But I'm not able to see
    Connected to:
      SEGGER J-Link (unknown)
      S/N: XXXXXXXXXXX
    For information, I'm using JLink over nrf9160-dk board.
    My prj.conf used with at_client sample (using soft sim onomondo)
    # Copyright (c) 2019 Nordic Semiconductor ASA
    # General config
    CONFIG_ASSERT=y
    ### Onomondo SoftSIM ###
    CONFIG_SOFTSIM_DEBUG=y
    CONFIG_SOFTSIM_LOG_LEVEL_ERR=y
    CONFIG_SOFTSIM_BUNDLE_TEMPLATE_HEX=y
    CONFIG_SOFTSIM_STATIC_PROFILE_ENABLE=y
    # GSMA TS.48 USIM profile (standard test profile) replace with actual Onomondo profile
    CONFIG_SOFTSIM_STATIC_PROFILE="XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    CONFIG_SERIAL=y
    # AT host library
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=3072
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    But do you know what version you are using? You should check this first. If it is too recent, it might not be fully supported.
