nRF54L15 - unable to provision key
I get error provisioning key on nRF54L15 and NCS 3.0.1. I tried using "Erase all" in nRF connect SDK Programmer, but it doesn't help. Please check also the attached log.
nrf54l15dk/nrf54l15/cpuapp/ns is used.
PS H:\cup> python H:/ncs/v3.0.1/bootloader/mcuboot/scripts/imgtool.py keygen -t ed25519 -k private_key.pem
PS H:\cup> west ncs-provision upload -s nrf54l15 -k private_key.pem
nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_j8mc7y15\keyfile.json --traits jlink
Error: One or more key provisioning tasks failed:
 * 1057746146: [Probe] Device error: Tried to provision 1 keys, 1 keyslot(s) failed to be provisioned (Generic)
Uploading failed!
PS H:\cup> nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_j8mc7y15\keyfile.json --traits jlink --log-level trace --log-output stdout --json > log.txt
sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="\${APP_DIR}/private_key.pem"
SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y
prj.conf:
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="nRF54L15-PDK"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
# Enable FOTA over Bluetooth LE
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
Output on a virtual COM port:
*** Booting MCUboot v2.1.0-dev-ae1ee57f3906 ***
*** Using nRF Connect SDK v3.0.1-9eb5615da66b ***
*** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
E: ED25519 signature verification failed -136
E: Image in the primary slot is not valid!
E: Unable to find bootable image
0675.log.txt
  • I am also on ENGB silicon. Trying to do this on NCS v3.0.2.
    Igor said:
    According to your link, this seems to be Engineering B and NOT supported in NCS 3.
    This is correct, Engineering B is not supported. Apologies for not suggesting this before and simply assuming you were using Rev 1... Again thank you Sebastian for bringing this up.
    Igor said:
    This SoC is part of PCA10156 0.8.1 2024.41. I would like to point out that some other person from Nordic assured me it is compatible, but obviously isn't....
    Ah, I see where the fault has happened. There's a mismatch in https://docs.nordicsemi.com/bundle/ncs-3.0.0/page/nrf/app_dev/device_guides/nrf54l/index.html w.r.t the supported device.
    1. This link comp matrix for DK and SDK states that 0.8.1 DK/PDK uses engineering B, i.e it's a PDK
    2. This link Comp matrix for SoC version and SDK says that 0.8.1 is not usable after NCS v2.8.0
    3. The documentation/guide for getting started with 54L15, i.e https://docs.nordicsemi.com/bundle/ncs-3.0.0/page/nrf/app_dev/device_guides/nrf54l/index.html states that you can use nRF54L15 PDK, which is a fault in the documentation. I believe you (as well as potentially other including myself) have been mislead by this..
    Igor said:
    I downgraded to NCS 2.9.1 and it works. So it seems to be something related to NCS 3.0
    SoC is N54L15 QFAABB 2433AA.
    The fact that it works for NCS v2.9.1 is interesting though... My best hypothesis is that rev 0.8.1 was not tested/tagged to be supported in NCS v2.9.1 (hence the lack of mentioning this device in the support matrix), but that the silicon on 0.8.1 and 0.9.1 are similar enough that it's still compatible (for atleast some things) in NSC v2.9.1
    I will create a Tech doc ticket to review and update this immediately and verify if my reasoning based on the Datasheet docs (1. and 2.) overrules the development guide doc (3.)
    Andreas
  • According to Developing with nRF54L Series there is also a nRF54L15 DK v0.9.3 but it is not even mentioned in compatibility matrix. Please fix also that.
  • I've added that to the tech doc ticket now,
    andreas
  • Now I got a new DK ver 0.9.3 (not even mentioned in compatibility matrix). It has SoC QFAAC0 (also missing in compatibility matrix).
    However, it still doesn't work with NCS 3.0.1. I tried also with NCS 3.0.2 (also not mentioned in compatibility matrix) but I get the same result.
    After manual nrfutil upgrade it seems to work, despite the fact that the nrfutil version seems to be the same.
       Please:
    - update compatibility matrix with the mentioned DK, SoC and NCS versions
    - clarify documentation regarding nrfutil version
    PS H:\cup> imgtool keygen -t ed25519 -k private_key3.pem
    PS H:\cup> nrfjprog --recover
    Recovering device. This operation might take 30s.
    Erasing user code and UICR flash areas.
    nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_mu8r74uh\keyfile.json --traits jlink
     * 1057783423: [Probe] Device error: Tried to provision 1 keys, 1 keyslot(s) failed to be provisioned (Generic)
    Uploading failed!
    PS H:\cup> nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_mu8r74uh\keyfile.json --traits jlink --log-level trace --log-output stdout --json > log.txt
    PS H:\cup> nrfutil --version
    nrfutil 7.13.0 (8289424 2024-07-01)
    commit-hash: 82894242d19ff24a1541712312b3ea3af0ca8f85
    commit-date: 2024-07-01
    host: x86_64-pc-windows-msvc
    build-timestamp: 2024-07-01T07:37:50.864803700Z
    classification: nrf-external
    PS H:\cup> nrfutil upgrade
    Downloading nrfutil-device-x86_64-pc-windows-msvc-2.11.2
    Verifying nrfutil-device-x86_64-pc-windows-msvc-2.11.2
    Updating nrfutil-device to 2.11.2
    nrfutil-nrf5sdk-tools is already the newest version (1.1.0)
    Downloading nrfutil-suit-x86_64-pc-windows-msvc-0.9.0
    Verifying nrfutil-suit-x86_64-pc-windows-msvc-0.9.0
    Updating nrfutil-suit to 0.9.0
    nrfutil-toolchain-manager is already the newest version (0.15.0)
    [00:00:04] ###### 100% [Upgrade packages] Upgrade packages
    nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_w7l429m0\keyfile.json --traits jlink
    Uploaded
