nRF54L15 - unable to provision key
I get error provisioning key on nRF54L15 and NCS 3.0.1. I tried using "Erase all" in nRF connect SDK Programmer, but it doesn't help. Please check also the attached log.
nrf54l15dk/nrf54l15/cpuapp/ns is used.
PS H:\cup> python H:/ncs/v3.0.1/bootloader/mcuboot/scripts/imgtool.py keygen -t ed25519 -k private_key.pem
PS H:\cup> west ncs-provision upload -s nrf54l15 -k private_key.pem
nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_j8mc7y15\keyfile.json --traits jlink
Error: One or more key provisioning tasks failed:
 * 1057746146: [Probe] Device error: Tried to provision 1 keys, 1 keyslot(s) failed to be provisioned (Generic)
Uploading failed!
PS H:\cup> nrfutil device x-provision-keys --key-file [redacted]\Temp\nrfutil_j8mc7y15\keyfile.json --traits jlink --log-level trace --log-output stdout --json > log.txt
sysbuild.conf:
SB_CONFIG_BOOTLOADER_MCUBOOT=y
SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="\${APP_DIR}/private_key.pem"
SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=y
SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y
prj.conf:
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="nRF54L15-PDK"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
# Enable FOTA over Bluetooth LE
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
Output on a virtual COM port:
*** Booting MCUboot v2.1.0-dev-ae1ee57f3906 ***
*** Using nRF Connect SDK v3.0.1-9eb5615da66b ***
*** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
I: Starting bootloader
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Image index: 0, Swap type: none
E: ED25519 signature verification failed -136
E: Image in the primary slot is not valid!
E: Unable to find bootable image
0675.log.txt
    Maybe the SoC version vs SDK was a red herring and the issue was nrfutil device version (tool used by nrfutil for programming). I see in L29 in the terminal window attached that nrfutil-device is uppgraded to v2.11.2, meaning that you might've had a nrfutil device version that were too old.
    I don't assume that you do, but do you know the version you previously had?  do you know which version of nrfutil device you're running that does not work for NCS v3.0.0 but did work for NCS 2.9.1 (check with 'nrfutil device --version')?
    Nonetheless I will add a comment w.r.t to the internal ticket.
    Andreas
  • In my previous post you can see:
    1. get version
    2. manual upgrade
    3. get version
    I don't see the difference in nrfutil versions. But you can see that nrfutil-device-x86_64-pc-windows-msvc-2.11.2  and nrfutil-suit-x86_64-pc-windows-msvc-0.9.0 was downloaded.
    I don't know why versions of all installed components are not displayed.
    Here is the version of the current nrfutil device. I have no idea what was the version before. The only thing that I can tell you is that, according to my logs, it was installed between 10th and 20th March this year.
    PS H:\cup\build_1> nrfutil device --version
    nrfutil-device 2.11.2 (481d897 2025-05-26)
    commit-hash: 481d897514d9cdb5b565c726e709cca667a0985c
    commit-date: 2025-05-26
    host: x86_64-pc-windows-msvc
    build-timestamp: 2025-05-26T11:20:01.692223900Z
    classification: nrf-external
    Detected SEGGER J-Link version: JLink_V8.40
    The device command version you are currently using was tested with a different J-Link version (JLink_V8.18) than the one you have installed (JLink_V8.40). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
    1. get version
    2. manual upgrade
    3. get version
    Yes, i see that.
    Noted. Well, since the issue was w.r.t nrfutil device, the only thing that's remaining here for now as I see it is updating the compatability matrices. I'll discuss with the nrfutil devs if nrfutil --version should also list subcomponents to avoid issues like this in the future.
    Andreas
  • on SDK version 3.2.0 provisioning now works however you need to provision it with west ncs-provision upload -k key.pem --keyname BL_PUBKEY
