There is a problem sending auracast
I use nRF5340 audio DK,iso_time_sync example, can successfully send BIS data, then I use DK as controller, bumble(google.github.io/.../index.html) as host and it fails to send.
 I don't understand what went wrong. Can you give me some advice?
Here is the entire log
/mnt/c/Users/Mji/Downloads/bumble/apps$ BUMBLE_LOGLEVEL=DEBUG python auracast.py transmit --input file:audiomono.wav --input-format auto --broadcast-name bumble serial:/dev/ttyACM0,115200
DEBUG:asyncio:Using selector: EpollSelector
DEBUG:bumble.drivers:Probing driver class: rtk
DEBUG:bumble.drivers.rtk:USB metadata not found
DEBUG:bumble.drivers:Probing driver class: intel
DEBUG:bumble.drivers.intel:USB metadata not sufficient
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_RESET_COMMAND
DEBUG:bumble.host:### CONTROLLER -> HOST: HCI_COMMAND_COMPLETE_EVENT:
  num_hci_command_packets: 1
  command_opcode:          HCI_RESET_COMMAND
  return_parameters:       HCI_SUCCESS
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_SUPPORTED_COMMANDS_COMMAND
  command_opcode:          HCI_READ_LOCAL_SUPPORTED_COMMANDS_COMMAND
  return_parameters:
    status:             HCI_SUCCESS
    supported_commands: 2000800000c0000c0000e40000002822000000000000040000f7ffff7f00000030007ef6ffffff0720e4ffff0740000000000000000000000000000000000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  command_opcode:          HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  return_parameters:
    status:      HCI_SUCCESS
    le_features: dd7900f410000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_VERSION_INFORMATION_COMMAND
  command_opcode:          HCI_READ_LOCAL_VERSION_INFORMATION_COMMAND
  return_parameters:
    status:             HCI_SUCCESS
    hci_version:        14
    hci_subversion:     8346
    lmp_version:        14
    company_identifier: 89
    lmp_subversion:     8346
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  command_opcode:          HCI_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  return_parameters:
    status:       HCI_SUCCESS
    lmp_features: 0000000060000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_SET_EVENT_MASK_COMMAND:
  event_mask: ff9ffbbf07f8bf3d
  command_opcode:          HCI_SET_EVENT_MASK_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EVENT_MASK_COMMAND:
  le_event_mask: fffff7ff07e80300
  command_opcode:          HCI_LE_SET_EVENT_MASK_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_BUFFER_SIZE_V2_COMMAND
  command_opcode:          HCI_LE_READ_BUFFER_SIZE_V2_COMMAND
  return_parameters:
    status:                        HCI_SUCCESS
    le_acl_data_packet_length:     27
    total_num_le_acl_data_packets: 3
    iso_data_packet_length:        14
    total_num_iso_data_packets:    3
DEBUG:bumble.host:HCI LE flow control: le_acl_data_packet_length=27,total_num_le_acl_data_packets=3iso_data_packet_length=14,total_num_iso_data_packets=3
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_NUMBER_OF_SUPPORTED_ADVERTISING_SETS_COMMAND
  command_opcode:          HCI_LE_READ_NUMBER_OF_SUPPORTED_ADVERTISING_SETS_COMMAND
  return_parameters:
    status:                         HCI_SUCCESS
    num_supported_advertising_sets: 1
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_MAXIMUM_ADVERTISING_DATA_LENGTH_COMMAND
  command_opcode:          HCI_LE_READ_MAXIMUM_ADVERTISING_DATA_LENGTH_COMMAND
  return_parameters:
    status:                      HCI_SUCCESS
    max_advertising_data_length: 62
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_BD_ADDR_COMMAND
  command_opcode:          HCI_READ_BD_ADDR_COMMAND
  return_parameters:
    status:  HCI_SUCCESS
    bd_addr: 00:00:00:00:00:00/P
DEBUG:bumble.device:BD_ADDR: 00:00:00:00:00:00/P
DEBUG:bumble.keys:JSON keystore: /home/matt/.local/share/Bumble/Pairing/f0-f1-f2-f3-f4-f5.json
DEBUG:bumble.device:LE Random Address: F0:F1:F2:F3:F4:F5
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_RANDOM_ADDRESS_COMMAND:
  random_address: F0:F1:F2:F3:F4:F5
  command_opcode:          HCI_LE_SET_RANDOM_ADDRESS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_PARAMETERS_COMMAND:
  advertising_handle:               0
  advertising_event_properties:
  primary_advertising_interval_min: 160
  primary_advertising_interval_max: 320
  primary_advertising_channel_map:  CHANNEL_37|CHANNEL_38|CHANNEL_39
  own_address_type:                 RANDOM
  peer_address_type:                PUBLIC_DEVICE
  peer_address:                     00:00:00:00:00:00/P
  advertising_filter_policy:        0
  advertising_tx_power:             127
  primary_advertising_phy:          LE 1M
  secondary_advertising_max_skip:   0
  secondary_advertising_phy:        LE 1M
  advertising_sid:                  0
  scan_request_notification_enable: 0
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_PARAMETERS_COMMAND
  return_parameters:
    status:            HCI_SUCCESS
    selected_tx_power: 0
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_ADVERTISING_SET_RANDOM_ADDRESS_COMMAND:
  command_opcode:          HCI_LE_SET_ADVERTISING_SET_RANDOM_ADDRESS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_DATA_COMMAND:
  operation:           COMPLETE_DATA
  fragment_preference: 1
  advertising_data:    0616521840e201073062756d626c65
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_DATA_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_PARAMETERS_COMMAND:
  periodic_advertising_interval_min: 80
  periodic_advertising_interval_max: 160
  periodic_advertising_properties:   Properties.0
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_PARAMETERS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_DATA_COMMAND:
  advertising_data:   35165118409c00010206000000000a020108020201030464000c0404656e670603446973636f01060503010000000206050302000000
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_DATA_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_ENABLE_COMMAND:
  enable:                             1
  advertising_handles[0]:             0
  durations[0]:                       0
  max_extended_advertising_events[0]: 0
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_ENABLE_COMMAND
Start Periodic Advertising
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_ENABLE_COMMAND:
  enable:             1
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_ENABLE_COMMAND
Only 2 channels PCM configurations are supported
matt@HISNN1259:/mnt/c/Users/Mji/Downloads/bumble/apps$ BUMBLE_LOGLEVEL=DEBUG python auracast.py transmit --input file:audioclub.wav --input-format auto --broadcast-name bumble serial:/dev/ttyACM0,115200
  return_parameters:
    status:             HCI_SUCCESS
  return_parameters:
    status:      HCI_SUCCESS
  return_parameters:
    status:             HCI_SUCCESS
    hci_version:        14
    lmp_version:        14
  return_parameters:
    status:       HCI_SUCCESS
  return_parameters:
    status:                        HCI_SUCCESS
  return_parameters:
    status:                         HCI_SUCCESS
  return_parameters:
    status:                      HCI_SUCCESS
  return_parameters:
    status:  HCI_SUCCESS
  advertising_sid:                  0
  return_parameters:
    status:            HCI_SUCCESS
  enable:                             1
  durations[0]:                       0
  enable:             1
Encoding with 480 PCM samples per 100 byte frame
Setup BIG
/mnt/c/Users/Mji/Downloads/bumble/apps/auracast.py:948: FutureWarning: Only for testing.
  big = await device.create_big(
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_CREATE_BIG_COMMAND:
  big_handle:            0
  num_bis:               2
  sdu_interval:          10000
  max_sdu:               100
  max_transport_latency: 65
  rtn:                   4
  phy:                   PhyBit.LE_2M
  packing:               0
  framing:               0
  encryption:            0
  broadcast_code:        00000000000000000000000000000000
DEBUG:bumble.host:### CONTROLLER -> HOST: HCI_COMMAND_STATUS_EVENT:
  status:                  HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR
  command_opcode:          HCI_LE_CREATE_BIG_COMMAND
WARNING:bumble.host:HCI_LE_CREATE_BIG_COMMAND failed (HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR)
ERROR:bumble.host:!!! Exception while sending command: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
  File "/home/matt/.local/lib/python3.10/site-packages/bumble/host.py", line 683, in send_command
    raise hci.HCI_Error(status)
bumble.hci.HCI_Error: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
!!! An error occurred while executing the command: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
  • I selected the target board as nrf5340dk/nrf5340/cpuapp and it compiled successfully and flashed it in, but I think it can't run properly on the nrf5340 audio DK.
    I used bumble to test HCI_RESET_COMMAND and it didn't respond
  • I use nRF5340 audio DK,iso_time_sync example, can successfully send BIS data, then I use DK as controller, bumble
    Is this your setup still?
    Something like this:
    PC-> Bumble -> nRF5340-DK   <wireless-link>    nRF5340 AUDIO DK.
  •  I use Nrf5340 audio DK as controller, bumble(google.github.io/.../index.html) as host and it fails to send.
    PC-> Bumble -> nRF5340 audio DK,
    I haven't used the nrf5340 DK, sorry for confusing you.
    Sigurd is out of the office, so I take this case again.
    Are you able to run the iso_time_sync example on the nRF5340 audioDK without issue?
    chelalv said:
    After flashing, VCOM0 COM18:
    I have previously flashed the iso_time_sync example,
    This is probably caused the net core has not flashed the image correctly. If you are using VS Code, the default build setting would also build for net Core. Please check the programming log to ensure the netcore got flashed.
    Let me know your current status.
    Amana H.
  • Hi Amanda, I can run the iso_time_sync example on the nRF5340 audioDK without issue.
    I can now compile empty_app_core successfully,  nrf5340 empty_app_core compilation failed
    I now use hci_uart to flash net core and empty_app_core to flash app core
    The following is the log of hci_uart compilation and flash
     *  Executing task: nRF Connect: Generate config nrf5340_audio_dk/nrf5340/cpunet for c:\ncs\hci_uart
    Building hci_uart
    C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/hci_uart/build c:/ncs/hci_uart --pristine --board nrf5340_audio_dk/nrf5340/cpunet -- -DBOARD_ROOT=c:/ncs/peripheral_hr;c:/ncs/iso_time_sync;c:/ncs/iso_time_sync_1;c:/ncs/peripheral_with_multiple_identities;c:/ncs/hci_uart"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.2/zephyr/.cache
    -- Board: nrf5340_audio_dk, qualifiers: nrf5340/cpunet
    Parsing C:/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/ncs/hci_uart/build/_sysbuild/empty.conf'
    Merged configuration 'C:/ncs/hci_uart/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/ncs/hci_uart/build/zephyr/.config'
    Kconfig header saved to 'C:/ncs/hci_uart/build/_sysbuild/autoconf.h'
       * Running CMake for hci_uart *
    -- Application: C:/ncs/hci_uart
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.2/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.0.2/zephyr/boards/nordic/nrf5340_audio_dk/nrf5340_audio_dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: C:/ncs/hci_uart/build/hci_uart/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/hci_uart/build/hci_uart/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/hci_uart/build/hci_uart/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/hci_uart/build/hci_uart/zephyr/dts.cmake
    warning: BT_CTLR_DTM_HCI (defined at subsys/bluetooth\controller\Kconfig.dtm:14) was assigned the
    value 'y' but got the value 'n'. Check these unsatisfied dependencies: BT_CTLR_DTM_HCI_SUPPORT (=n).
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_CTLR_DTM_HCI and/or look up
    BT_CTLR_DTM_HCI in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Parsing C:/ncs/v3.0.2/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.2/zephyr/boards/nordic/nrf5340_audio_dk/nrf5340_audio_dk_nrf5340_cpunet_defconfig'
    Merged configuration 'C:/ncs/hci_uart/prj.conf'
    Merged configuration 'C:/ncs/hci_uart/build/hci_uart/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/hci_uart/build/hci_uart/zephyr/.config'
    Kconfig header saved to 'C:/ncs/hci_uart/build/hci_uart/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/hci_uart/build/hci_uart
    -- Configuring done
    -- Generating done
    [4/175] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.2/zephyr), build: v4.0.99-ncs1-2
    [175/175] Linking C executable zephyr\zephyr.elf
               FLASH:      143868 B       256 KB     54.88%
                 RAM:       36612 B        64 KB     55.87%
               SRAM1:          0 GB        64 KB      0.00%
            IDT_LIST:          0 GB        32 KB      0.00%
    Generating files from C:/ncs/hci_uart/build/hci_uart/zephyr/zephyr.elf for board: nrf5340_audio_dk
    [10/10] Generating ../merged.hex
     *  Executing task: nRF Connect: Flash: hci_uart/hci_uart (active)
    Flashing hci_uart to 1050193411
    C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\ncs\hci_uart\build --domain hci_uart --dev-id 1050193411"
    -- west flash: rebuilding
    [0/5] Performing build step for 'hci_uart'
    ninja: no work to do.
    [2/5] No install step for 'hci_uart'
    [3/5] Completed 'hci_uart'
    [4/5] cmd.exe /C "cd /D C:\ncs\hci_uart\build\_sysbuild && C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.exe -E true"
    -- west flash: using runner nrfutil
    -- runners.nrfutil: reset after flashing requested
    -- runners.nrfutil: Flashing file: C:\ncs\hci_uart\build\merged.hex
    -- runners.nrfutil: Erasing address ranges touched by firmware
    -- runners.nrfutil: Programming image
    -- runners.nrfutil: Verifying image
    -- runners.nrfutil: Reset
    -- runners.nrfutil: Board with serial number 1050193411 flashed successfully.
    empty_app_core compilation and flash log
     *  Executing task: nRF Connect: Generate config nrf5340_audio_dk/nrf5340/cpuapp for c:\ncs\empty_app_core
    Building empty_app_core
    C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/empty_app_core/build c:/ncs/empty_app_core --pristine --board nrf5340_audio_dk/nrf5340/cpuapp -- -DBOARD_ROOT=c:/ncs/peripheral_hr;c:/ncs/iso_time_sync;c:/ncs/iso_time_sync_1;c:/ncs/peripheral_with_multiple_identities;c:/ncs/hci_uart"
    -- Board: nrf5340_audio_dk, qualifiers: nrf5340/cpuapp
    Loaded configuration 'C:/ncs/empty_app_core/build/_sysbuild/empty.conf'
    Merged configuration 'C:/ncs/empty_app_core/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/ncs/empty_app_core/build/zephyr/.config'
    Kconfig header saved to 'C:/ncs/empty_app_core/build/_sysbuild/autoconf.h'
       * Running CMake for empty_app_core *
    -- Application: C:/ncs/empty_app_core
    -- Found BOARD.dts: C:/ncs/v3.0.2/zephyr/boards/nordic/nrf5340_audio_dk/nrf5340_audio_dk_nrf5340_cpuapp.dts
    -- Generated zephyr.dts: C:/ncs/empty_app_core/build/empty_app_core/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/empty_app_core/build/empty_app_core/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/empty_app_core/build/empty_app_core/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/empty_app_core/build/empty_app_core/zephyr/dts.cmake
    warning: THREAD_STACK_INFO (defined at kernel/Kconfig:189) was assigned the value 'n' but got the
    value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_THREAD_STACK_INFO and/or
    look up THREAD_STACK_INFO in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: BOOT_DELAY (defined at kernel/Kconfig:472) was assigned the value '0' but got the value ''.
    Check these unsatisfied dependencies: MULTITHREADING (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BOOT_DELAY and/or look up BOOT_DELAY in the
    menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
    and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: PRINTK (defined at subsys/debug/Kconfig:220) was assigned the value 'n' but got the value
    'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PRINTK and/or look up PRINTK in
    the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration
    Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too.
    warning: EARLY_CONSOLE (defined at subsys/debug/Kconfig:239) was assigned the value 'n' but got the
    value 'y'. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_EARLY_CONSOLE and/or look up
    EARLY_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    warning: Deprecated symbol DEPRECATED_UART_NRFX_UARTE_LEGACY_SHIM is enabled.
    Loaded configuration 'C:/ncs/v3.0.2/zephyr/boards/nordic/nrf5340_audio_dk/nrf5340_audio_dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'C:/ncs/empty_app_core/prj.conf'
    Merged configuration 'C:/ncs/empty_app_core/build/empty_app_core/zephyr/.config.sysbuild'
    Configuration saved to 'C:/ncs/empty_app_core/build/empty_app_core/zephyr/.config'
    Kconfig header saved to 'C:/ncs/empty_app_core/build/empty_app_core/zephyr/include/generated/zephyr/autoconf.h'
    CMake Warning at C:/ncs/v3.0.2/zephyr/soc/nordic/nrf53/CMakeLists.txt:11 (message):
          Your application may be affected by the anomaly 160 that concerns the
          nRF5340 SoC. The related workaround cannot be applied, because your
          application has the system clock disabled (CONFIG_SYS_CLOCK_EXISTS=n).
          Consider enabling the system clock to apply the workaround.
          At your own risk, you can suppress this warning by setting
          CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=n.
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/empty_app_core/build/empty_app_core
    -- Configuring done
    -- Generating done
    [4/119] Generating include/generated/zephyr/version.h
    [119/119] Linking C executable zephyr\zephyr.elf
               FLASH:        8008 B         1 MB      0.76%
                 RAM:        3368 B       448 KB      0.73%
    Generating files from C:/ncs/empty_app_core/build/empty_app_core/zephyr/zephyr.elf for board: nrf5340_audio_dk
     *  Executing task: nRF Connect: Flash: empty_app_core/empty_app_core (active)
    Flashing empty_app_core to 1050193411
    C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\ncs\empty_app_core\build --domain empty_app_core --dev-id 1050193411"
    [0/5] Performing build step for 'empty_app_core'
    [2/5] No install step for 'empty_app_core'
    [3/5] Completed 'empty_app_core'
    [4/5] cmd.exe /C "cd /D C:\ncs\empty_app_core\build\_sysbuild && C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.exe -E true"
    -- runners.nrfutil: Flashing file: C:\ncs\empty_app_core\build\merged.hex
