There is a problem sending auracast
I use nRF5340 audio DK,iso_time_sync example, can successfully send BIS data, then I use DK as controller, bumble(google.github.io/.../index.html) as host and it fails to send.
 I don't understand what went wrong. Can you give me some advice?
Here is the entire log
/mnt/c/Users/Mji/Downloads/bumble/apps$ BUMBLE_LOGLEVEL=DEBUG python auracast.py transmit --input file:audiomono.wav --input-format auto --broadcast-name bumble serial:/dev/ttyACM0,115200
DEBUG:asyncio:Using selector: EpollSelector
DEBUG:bumble.drivers:Probing driver class: rtk
DEBUG:bumble.drivers.rtk:USB metadata not found
DEBUG:bumble.drivers:Probing driver class: intel
DEBUG:bumble.drivers.intel:USB metadata not sufficient
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_RESET_COMMAND
DEBUG:bumble.host:### CONTROLLER -> HOST: HCI_COMMAND_COMPLETE_EVENT:
  num_hci_command_packets: 1
  command_opcode:          HCI_RESET_COMMAND
  return_parameters:       HCI_SUCCESS
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_SUPPORTED_COMMANDS_COMMAND
  command_opcode:          HCI_READ_LOCAL_SUPPORTED_COMMANDS_COMMAND
  return_parameters:
    status:             HCI_SUCCESS
    supported_commands: 2000800000c0000c0000e40000002822000000000000040000f7ffff7f00000030007ef6ffffff0720e4ffff0740000000000000000000000000000000000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  command_opcode:          HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  return_parameters:
    status:      HCI_SUCCESS
    le_features: dd7900f410000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_VERSION_INFORMATION_COMMAND
  command_opcode:          HCI_READ_LOCAL_VERSION_INFORMATION_COMMAND
  return_parameters:
    status:             HCI_SUCCESS
    hci_version:        14
    hci_subversion:     8346
    lmp_version:        14
    company_identifier: 89
    lmp_subversion:     8346
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  command_opcode:          HCI_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  return_parameters:
    status:       HCI_SUCCESS
    lmp_features: 0000000060000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_SET_EVENT_MASK_COMMAND:
  event_mask: ff9ffbbf07f8bf3d
  command_opcode:          HCI_SET_EVENT_MASK_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EVENT_MASK_COMMAND:
  le_event_mask: fffff7ff07e80300
  command_opcode:          HCI_LE_SET_EVENT_MASK_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_BUFFER_SIZE_V2_COMMAND
  command_opcode:          HCI_LE_READ_BUFFER_SIZE_V2_COMMAND
  return_parameters:
    status:                        HCI_SUCCESS
    le_acl_data_packet_length:     27
    total_num_le_acl_data_packets: 3
    iso_data_packet_length:        14
    total_num_iso_data_packets:    3
DEBUG:bumble.host:HCI LE flow control: le_acl_data_packet_length=27,total_num_le_acl_data_packets=3iso_data_packet_length=14,total_num_iso_data_packets=3
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_NUMBER_OF_SUPPORTED_ADVERTISING_SETS_COMMAND
  command_opcode:          HCI_LE_READ_NUMBER_OF_SUPPORTED_ADVERTISING_SETS_COMMAND
  return_parameters:
    status:                         HCI_SUCCESS
    num_supported_advertising_sets: 1
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_MAXIMUM_ADVERTISING_DATA_LENGTH_COMMAND
  command_opcode:          HCI_LE_READ_MAXIMUM_ADVERTISING_DATA_LENGTH_COMMAND
  return_parameters:
    status:                      HCI_SUCCESS
    max_advertising_data_length: 62
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_BD_ADDR_COMMAND
  command_opcode:          HCI_READ_BD_ADDR_COMMAND
  return_parameters:
    status:  HCI_SUCCESS
    bd_addr: 00:00:00:00:00:00/P
DEBUG:bumble.device:BD_ADDR: 00:00:00:00:00:00/P
DEBUG:bumble.keys:JSON keystore: /home/matt/.local/share/Bumble/Pairing/f0-f1-f2-f3-f4-f5.json
DEBUG:bumble.device:LE Random Address: F0:F1:F2:F3:F4:F5
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_RANDOM_ADDRESS_COMMAND:
  random_address: F0:F1:F2:F3:F4:F5
  command_opcode:          HCI_LE_SET_RANDOM_ADDRESS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_PARAMETERS_COMMAND:
  advertising_handle:               0
  advertising_event_properties:
  primary_advertising_interval_min: 160
  primary_advertising_interval_max: 320
  primary_advertising_channel_map:  CHANNEL_37|CHANNEL_38|CHANNEL_39
  own_address_type:                 RANDOM
  peer_address_type:                PUBLIC_DEVICE
  peer_address:                     00:00:00:00:00:00/P
  advertising_filter_policy:        0
  advertising_tx_power:             127
  primary_advertising_phy:          LE 1M
  secondary_advertising_max_skip:   0
  secondary_advertising_phy:        LE 1M
  advertising_sid:                  0
  scan_request_notification_enable: 0
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_PARAMETERS_COMMAND
  return_parameters:
    status:            HCI_SUCCESS
    selected_tx_power: 0
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_ADVERTISING_SET_RANDOM_ADDRESS_COMMAND:
  command_opcode:          HCI_LE_SET_ADVERTISING_SET_RANDOM_ADDRESS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_DATA_COMMAND:
  operation:           COMPLETE_DATA
  fragment_preference: 1
  advertising_data:    0616521840e201073062756d626c65
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_DATA_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_PARAMETERS_COMMAND:
  periodic_advertising_interval_min: 80
  periodic_advertising_interval_max: 160
  periodic_advertising_properties:   Properties.0
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_PARAMETERS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_DATA_COMMAND:
  advertising_data:   35165118409c00010206000000000a020108020201030464000c0404656e670603446973636f01060503010000000206050302000000
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_DATA_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_ENABLE_COMMAND:
  enable:                             1
  advertising_handles[0]:             0
  durations[0]:                       0
  max_extended_advertising_events[0]: 0
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_ENABLE_COMMAND
Start Periodic Advertising
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_ENABLE_COMMAND:
  enable:             1
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_ENABLE_COMMAND
Only 2 channels PCM configurations are supported
matt@HISNN1259:/mnt/c/Users/Mji/Downloads/bumble/apps$ BUMBLE_LOGLEVEL=DEBUG python auracast.py transmit --input file:audioclub.wav --input-format auto --broadcast-name bumble serial:/dev/ttyACM0,115200
  return_parameters:
    status:             HCI_SUCCESS
  return_parameters:
    status:      HCI_SUCCESS
  return_parameters:
    status:             HCI_SUCCESS
    hci_version:        14
    lmp_version:        14
  return_parameters:
    status:       HCI_SUCCESS
  return_parameters:
    status:                        HCI_SUCCESS
  return_parameters:
    status:                         HCI_SUCCESS
  return_parameters:
    status:                      HCI_SUCCESS
  return_parameters:
    status:  HCI_SUCCESS
  advertising_sid:                  0
  return_parameters:
    status:            HCI_SUCCESS
  enable:                             1
  durations[0]:                       0
  enable:             1
Encoding with 480 PCM samples per 100 byte frame
Setup BIG
/mnt/c/Users/Mji/Downloads/bumble/apps/auracast.py:948: FutureWarning: Only for testing.
  big = await device.create_big(
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_CREATE_BIG_COMMAND:
  big_handle:            0
  num_bis:               2
  sdu_interval:          10000
  max_sdu:               100
  max_transport_latency: 65
  rtn:                   4
  phy:                   PhyBit.LE_2M
  packing:               0
  framing:               0
  encryption:            0
  broadcast_code:        00000000000000000000000000000000
DEBUG:bumble.host:### CONTROLLER -> HOST: HCI_COMMAND_STATUS_EVENT:
  status:                  HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR
  command_opcode:          HCI_LE_CREATE_BIG_COMMAND
WARNING:bumble.host:HCI_LE_CREATE_BIG_COMMAND failed (HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR)
ERROR:bumble.host:!!! Exception while sending command: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
  File "/home/matt/.local/lib/python3.10/site-packages/bumble/host.py", line 683, in send_command
    raise hci.HCI_Error(status)
bumble.hci.HCI_Error: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
!!! An error occurred while executing the command: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
    You could build the hci_uart sample with EXTRA_CONF_FILE='debug.conf' and connect the net core via RTT to check if it works as expected. You could also capture HCI packets in Wireshark and provide the output PCAP file to help investigate the issue.
    -Amanda H.
  • Hi, Sorry for the late reply.
    I don't know how to do this: build the hci_uart sample with EXTRA_CONF_FILE='debug.conf' and connect the net core via RTT to check if it works as expected.
    I recompiled the hci uart example according to docs.nordicsemi.com/.../hci_logger.html
    But when I use bumble to test, It looks like there is a problem with hci communication
    I enabled Monitor protocol over UART, so prj.conf will increase CONFIG_BT_DEBUG_MONITOR_UART=y and reduce CONFIG_CONSOLE=n.
    CONFIG_STDOUT_CONSOLE=n
    CONFIG_UART_CONSOLE=n
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_BT=y
    CONFIG_BT_HCI_RAW=y
    CONFIG_BT_HCI_RAW_H4=y
    CONFIG_BT_HCI_RAW_H4_ENABLE=y
    CONFIG_BT_BUF_ACL_RX_SIZE=255
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=255
    CONFIG_BT_CTLR_ASSERT_HANDLER=y
    CONFIG_BT_MAX_CONN=16
    CONFIG_BT_CTLR_DTM_HCI=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=512
    # Workaround: Unable to allocate command buffer when using K_NO_WAIT since
    # Host number of completed commands does not follow normal flow control.
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    Another question: Why can other programs sysbuild compile two hex, one application mcu and one network mcu, but hci uart only has one application mcu?
    It appears that Bumble is attempting to initialize the controller, but is receiving invalid responses. Does the hci_uart work as expected?
    Do you get the same result if testing with the NCS v3.0.2 iso_time_sync sample?
    There is no multi-image build config to support that combination.
  • Hi Amanda, I don't quite understand this question: "Does the hci_uart work as expected?"
    I can run the iso_time_sync example on the nRF5340 audioDK without issue.
    I have some doubts whether the combination of hci_uart as net core and empty_app_core as app core can work properly.
    You can see my original question, I use hci uart as app core, the net core image of other examples, the controller is responsive.
    According to the figure, it shows the controller doesn't support "creating BIG".
    Probably you just use the default setting of the controller configs.
    You can refer to the configs used in the audio project:
    https://github.com/nrfconnect/sdk-nrf/blob/v3.0.2/applications/nrf5340_audio/sysbuild/ipc_radio/prj.conf
    Since the default one for hci_uart might not enable LE audio-related features.
