There is a problem sending auracast
I use nRF5340 audio DK,iso_time_sync example, can successfully send BIS data, then I use DK as controller, bumble(google.github.io/.../index.html) as host and it fails to send.
 I don't understand what went wrong. Can you give me some advice?
Here is the entire log
/mnt/c/Users/Mji/Downloads/bumble/apps$ BUMBLE_LOGLEVEL=DEBUG python auracast.py transmit --input file:audiomono.wav --input-format auto --broadcast-name bumble serial:/dev/ttyACM0,115200
DEBUG:asyncio:Using selector: EpollSelector
DEBUG:bumble.drivers:Probing driver class: rtk
DEBUG:bumble.drivers.rtk:USB metadata not found
DEBUG:bumble.drivers:Probing driver class: intel
DEBUG:bumble.drivers.intel:USB metadata not sufficient
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_RESET_COMMAND
DEBUG:bumble.host:### CONTROLLER -> HOST: HCI_COMMAND_COMPLETE_EVENT:
  num_hci_command_packets: 1
  command_opcode:          HCI_RESET_COMMAND
  return_parameters:       HCI_SUCCESS
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_SUPPORTED_COMMANDS_COMMAND
  command_opcode:          HCI_READ_LOCAL_SUPPORTED_COMMANDS_COMMAND
  return_parameters:
    status:             HCI_SUCCESS
    supported_commands: 2000800000c0000c0000e40000002822000000000000040000f7ffff7f00000030007ef6ffffff0720e4ffff0740000000000000000000000000000000000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  command_opcode:          HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  return_parameters:
    status:      HCI_SUCCESS
    le_features: dd7900f410000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_VERSION_INFORMATION_COMMAND
  command_opcode:          HCI_READ_LOCAL_VERSION_INFORMATION_COMMAND
  return_parameters:
    status:             HCI_SUCCESS
    hci_version:        14
    hci_subversion:     8346
    lmp_version:        14
    company_identifier: 89
    lmp_subversion:     8346
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  command_opcode:          HCI_READ_LOCAL_SUPPORTED_FEATURES_COMMAND
  return_parameters:
    status:       HCI_SUCCESS
    lmp_features: 0000000060000000
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_SET_EVENT_MASK_COMMAND:
  event_mask: ff9ffbbf07f8bf3d
  command_opcode:          HCI_SET_EVENT_MASK_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EVENT_MASK_COMMAND:
  le_event_mask: fffff7ff07e80300
  command_opcode:          HCI_LE_SET_EVENT_MASK_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_BUFFER_SIZE_V2_COMMAND
  command_opcode:          HCI_LE_READ_BUFFER_SIZE_V2_COMMAND
  return_parameters:
    status:                        HCI_SUCCESS
    le_acl_data_packet_length:     27
    total_num_le_acl_data_packets: 3
    iso_data_packet_length:        14
    total_num_iso_data_packets:    3
DEBUG:bumble.host:HCI LE flow control: le_acl_data_packet_length=27,total_num_le_acl_data_packets=3iso_data_packet_length=14,total_num_iso_data_packets=3
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_NUMBER_OF_SUPPORTED_ADVERTISING_SETS_COMMAND
  command_opcode:          HCI_LE_READ_NUMBER_OF_SUPPORTED_ADVERTISING_SETS_COMMAND
  return_parameters:
    status:                         HCI_SUCCESS
    num_supported_advertising_sets: 1
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_READ_MAXIMUM_ADVERTISING_DATA_LENGTH_COMMAND
  command_opcode:          HCI_LE_READ_MAXIMUM_ADVERTISING_DATA_LENGTH_COMMAND
  return_parameters:
    status:                      HCI_SUCCESS
    max_advertising_data_length: 62
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_READ_BD_ADDR_COMMAND
  command_opcode:          HCI_READ_BD_ADDR_COMMAND
  return_parameters:
    status:  HCI_SUCCESS
    bd_addr: 00:00:00:00:00:00/P
DEBUG:bumble.device:BD_ADDR: 00:00:00:00:00:00/P
DEBUG:bumble.keys:JSON keystore: /home/matt/.local/share/Bumble/Pairing/f0-f1-f2-f3-f4-f5.json
DEBUG:bumble.device:LE Random Address: F0:F1:F2:F3:F4:F5
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_RANDOM_ADDRESS_COMMAND:
  random_address: F0:F1:F2:F3:F4:F5
  command_opcode:          HCI_LE_SET_RANDOM_ADDRESS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_PARAMETERS_COMMAND:
  advertising_handle:               0
  advertising_event_properties:
  primary_advertising_interval_min: 160
  primary_advertising_interval_max: 320
  primary_advertising_channel_map:  CHANNEL_37|CHANNEL_38|CHANNEL_39
  own_address_type:                 RANDOM
  peer_address_type:                PUBLIC_DEVICE
  peer_address:                     00:00:00:00:00:00/P
  advertising_filter_policy:        0
  advertising_tx_power:             127
  primary_advertising_phy:          LE 1M
  secondary_advertising_max_skip:   0
  secondary_advertising_phy:        LE 1M
  advertising_sid:                  0
  scan_request_notification_enable: 0
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_PARAMETERS_COMMAND
  return_parameters:
    status:            HCI_SUCCESS
    selected_tx_power: 0
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_ADVERTISING_SET_RANDOM_ADDRESS_COMMAND:
  command_opcode:          HCI_LE_SET_ADVERTISING_SET_RANDOM_ADDRESS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_DATA_COMMAND:
  operation:           COMPLETE_DATA
  fragment_preference: 1
  advertising_data:    0616521840e201073062756d626c65
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_DATA_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_PARAMETERS_COMMAND:
  periodic_advertising_interval_min: 80
  periodic_advertising_interval_max: 160
  periodic_advertising_properties:   Properties.0
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_PARAMETERS_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_DATA_COMMAND:
  advertising_data:   35165118409c00010206000000000a020108020201030464000c0404656e670603446973636f01060503010000000206050302000000
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_DATA_COMMAND
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_EXTENDED_ADVERTISING_ENABLE_COMMAND:
  enable:                             1
  advertising_handles[0]:             0
  durations[0]:                       0
  max_extended_advertising_events[0]: 0
  command_opcode:          HCI_LE_SET_EXTENDED_ADVERTISING_ENABLE_COMMAND
Start Periodic Advertising
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_SET_PERIODIC_ADVERTISING_ENABLE_COMMAND:
  enable:             1
  command_opcode:          HCI_LE_SET_PERIODIC_ADVERTISING_ENABLE_COMMAND
Only 2 channels PCM configurations are supported
matt@HISNN1259:/mnt/c/Users/Mji/Downloads/bumble/apps$ BUMBLE_LOGLEVEL=DEBUG python auracast.py transmit --input file:audioclub.wav --input-format auto --broadcast-name bumble serial:/dev/ttyACM0,115200
  return_parameters:
    status:             HCI_SUCCESS
  return_parameters:
    status:      HCI_SUCCESS
  return_parameters:
    status:             HCI_SUCCESS
    hci_version:        14
    lmp_version:        14
  return_parameters:
    status:       HCI_SUCCESS
  return_parameters:
    status:                        HCI_SUCCESS
  return_parameters:
    status:                         HCI_SUCCESS
  return_parameters:
    status:                      HCI_SUCCESS
  return_parameters:
    status:  HCI_SUCCESS
  advertising_sid:                  0
  return_parameters:
    status:            HCI_SUCCESS
  enable:                             1
  durations[0]:                       0
  enable:             1
Encoding with 480 PCM samples per 100 byte frame
Setup BIG
/mnt/c/Users/Mji/Downloads/bumble/apps/auracast.py:948: FutureWarning: Only for testing.
  big = await device.create_big(
DEBUG:bumble.host:### HOST -> CONTROLLER: HCI_LE_CREATE_BIG_COMMAND:
  big_handle:            0
  num_bis:               2
  sdu_interval:          10000
  max_sdu:               100
  max_transport_latency: 65
  rtn:                   4
  phy:                   PhyBit.LE_2M
  packing:               0
  framing:               0
  encryption:            0
  broadcast_code:        00000000000000000000000000000000
DEBUG:bumble.host:### CONTROLLER -> HOST: HCI_COMMAND_STATUS_EVENT:
  status:                  HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR
  command_opcode:          HCI_LE_CREATE_BIG_COMMAND
WARNING:bumble.host:HCI_LE_CREATE_BIG_COMMAND failed (HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR)
ERROR:bumble.host:!!! Exception while sending command: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
  File "/home/matt/.local/lib/python3.10/site-packages/bumble/host.py", line 683, in send_command
    raise hci.HCI_Error(status)
bumble.hci.HCI_Error: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
!!! An error occurred while executing the command: HCI_Error(hci/HCI_UNSUPPORTED_FEATURE_OR_PARAMETER_VALUE_ERROR [0x11])
  • I added the prj.conf in the link, and compilation errors occurred:
     *  Executing task: nRF Connect: Generate config nrf52840dongle/nrf52840 for c:\ncs\bumble\hci_uart_0805-2
    Building hci_uart_0805-2
    C:\Windows\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/bumble/hci_uart_0805-2/build c:/ncs/bumble/hci_uart_0805-2 --pristine --board nrf52840dongle/nrf52840 -- -DBOARD_ROOT=c:/ncs/bumble/hci_uart_0805-2"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.2/zephyr/.cache
    -- Board: nrf52840dongle, qualifiers: nrf52840
    Parsing C:/ncs/v3.0.2/zephyr/share/sysbuild/Kconfig
    Loaded configuration 'C:/ncs/bumble/hci_uart_0805-2/build/_sysbuild/empty.conf'
    Merged configuration 'C:/ncs/bumble/hci_uart_0805-2/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/ncs/bumble/hci_uart_0805-2/build/zephyr/.config'
    Kconfig header saved to 'C:/ncs/bumble/hci_uart_0805-2/build/_sysbuild/autoconf.h'
       * Running CMake for hci_uart_0805-2 *
    -- Application: C:/ncs/bumble/hci_uart_0805-2
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.2/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.0.2/zephyr/boards/nordic/nrf52840dongle/nrf52840dongle_nrf52840.dts
    -- Generated zephyr.dts: C:/ncs/bumble/hci_uart_0805-2/build/hci_uart_0805-2/zephyr/zephyr.dts
    -- Generated pickled edt: C:/ncs/bumble/hci_uart_0805-2/build/hci_uart_0805-2/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/ncs/bumble/hci_uart_0805-2/build/hci_uart_0805-2/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/bumble/hci_uart_0805-2/build/hci_uart_0805-2/zephyr/dts.cmake
    warning: MPSL_TRIGGER_IPC_TASK_ON_RTC_START (defined at
    C:/ncs/v3.0.2/nrf\subsys\mpsl\init/Kconfig:50) was assigned the value 'y' but got the value 'n'.
    Check these unsatisfied dependencies: SOC_NRF5340_CPUNET (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START and/or
    look up MPSL_TRIGGER_IPC_TASK_ON_RTC_START in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    the manual might be helpful too.
    warning: MPSL_TRIGGER_IPC_TASK_ON_RTC_START_CHANNEL (defined at
    C:/ncs/v3.0.2/nrf\subsys\mpsl\init/Kconfig:59) was assigned the value '4' but got the value ''.
    Check these unsatisfied dependencies: MPSL_TRIGGER_IPC_TASK_ON_RTC_START (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MPSL_TRIGGER_IPC_TASK_ON_RTC_START_CHANNEL
    and/or look up MPSL_TRIGGER_IPC_TASK_ON_RTC_START_CHANNEL in the menuconfig/guiconfig interface. The
    Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices
    sections of the manual might be helpful too.
    warning: BT_CTLR_DTM_HCI (defined at subsys/bluetooth\controller\Kconfig.dtm:14) was assigned the
    value 'y' but got the value 'n'. Check these unsatisfied dependencies: BT_CTLR_DTM_HCI_SUPPORT (=n).
    See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_BT_CTLR_DTM_HCI and/or look up
    BT_CTLR_DTM_HCI in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Parsing C:/ncs/v3.0.2/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.2/zephyr/boards/nordic/nrf52840dongle/nrf52840dongle_nrf52840_defconfig'
    Merged configuration 'C:/ncs/bumble/hci_uart_0805-2/prj.conf'
    Merged configuration 'C:/ncs/bumble/hci_uart_0805-2/boards/nrf52840dongle_nrf52840.conf'
    Merged configuration 'C:/ncs/bumble/hci_uart_0805-2/build/hci_uart_0805-2/zephyr/.config.sysbuild'
    C:/ncs/bumble/hci_uart_0805-2/prj.conf:66: warning: attempt to assign the value 'y' to the undefined symbol IPC_RADIO_BT
    C:/ncs/bumble/hci_uart_0805-2/prj.conf:67: warning: attempt to assign the value 'y' to the undefined symbol IPC_RADIO_BT_HCI_IPC
    error: Aborting due to Kconfig warnings
    CMake Error at C:/ncs/v3.0.2/zephyr/cmake/modules/kconfig.cmake:396 (message):
      command failed with return code: 1
      C:/ncs/v3.0.2/nrf/cmake/modules/kconfig.cmake:36 (include)
      C:/ncs/v3.0.2/zephyr/cmake/modules/zephyr_default.cmake:133 (include)
      C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:5 (find_package)
    CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
      CMake configure failed for Zephyr project: hci_uart_0805-2
      cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.0.2/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.0.2/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    See also "C:/ncs/bumble/hci_uart_0805-2/build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe '-Bc:\ncs\bumble\hci_uart_0805-2\build' -GNinja -DBOARD=nrf52840dongle/nrf52840 -DBOARD_ROOT=c:/ncs/bumble/hci_uart_0805-2 '-SC:\ncs\v3.0.2\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\ncs\bumble\hci_uart_0805-2'
     *  The terminal process terminated with exit code: 1.
  • Add this Kconfig.sysbuild to app folder and add the ipc_radio configs for the net core by sysbuild/ipc_radio/prj.conf.
  • Hi, I added Kconfig.sysbuld and sysbuild\ipc_radio\prj.conf  in the hci uart project folder like below:
    Two images were compiled.
    After burning, running bumble, HCI_LE_CREATE_BIG_COMMAND did not have any errors.
