Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
  • Can you please provide patches/diff files for your changes into the micropy repo?
    Hey Hakon.
    I see your point but I think it's gonna be really hard to give you the diff since our repo is a private repo that branched off the main micropython repo ~6-8 months ago. In the meantime both our and the main micropython branches were updated a lot, so it will be hard to tell the actual differences. I ended up getting the micropython repo locally and doing a diff, and this is the diff just for the /ports/zephyr folder:
    zephyr_diff.txt.zip
    It has ~184MB when uncompressed and ~4 million lines. :))
    That's why I wanted to do it simply on my side.
    Try running without mbedtls debug logs, or adjust the log level:
    Interesting point! I disabled CONFIG_LOG_MODE_IMMEDIATE and applied the 3 CONFIG_ changes that you mentioned. Sadly the behaviour seems to be the same, but with less logs:
    00:08:15.788,177] <inf> wifimod: Connection requested
    [00:08:15.788,238] <inf> wifimod: ==================
    [00:08:15.788,269] <inf> wifimod: State: SCANNING
    [00:08:15.788,330] <inf> wifimod: Net If state: 5
    [00:08:16.088,470] <inf> wifimod: ==================
    [00:08:16.088,500] <inf> wifimod: State: AUTHENTICATING
    [00:08:16.088,562] <inf> wifimod: Net If state: 5
    [00:08:16.238,159] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000f4b8, pkt=0x20063718, st=0, user_data=(nil)
    [00:08:16.253,173] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000f4b8, pkt=0x200636d8, st=0, user_data=(nil)
    [00:08:16.270,080] <inf> wifimod: Wi-Fi connect result: status...
    [00:08:16.270,111] <inf> wifimod: Connected
    [00:08:16.308,197] <dbg> net_sock: zsock_close_ctx: (rx_q[0]): close: ctx=0x2000f358, fd=3
    [00:08:16.308,319] <dbg> net_sock: zsock_close_ctx: (rx_q[0]): close: ctx=0x2000f408, fd=5
    [00:08:16.308,807] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x2000f358, fd=3
    [00:08:16.309,387] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x2000f408, fd=5
    [00:08:16.339,Waiting for IP address...
    752] <inf> net_dhcpv4: Received: 192.168.0.250
    [00:08:16.339,965] <inf> net_config: IPv4 address: 192.168.0.250
    [00:08:16.339,965] <inf> net_config: Lease time: 7200 seconds
    [00:08:16.339,996] <inf> net_config: Subnet: 255.255.255.0
    [00:08:16.340,026] <inf> net_config: Router: 192.168.0.1
    [00:08:16.340,118] <inf> wifimod: Net MGMT: Got IP via DHCP
    DHCP IP address: 192.168.0.250
    [00:08:16.389,221] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
    Resolving google.com...
    Resolved: [(1, 1, 6, '', ('142.251.39.14', 443))]
    Success!
    Using system DNS resolver...
    Querying DNS for google.com (type 1)...
    [00:08:17.405,334] <dbg> net_dns_resolve: dns_write: (mp_main): [0] submitting work to server idx 0 for id 62375 hash 59079
    semaphore wait...1
    [00:08:17.649,932] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000f358, pkt=0x200636d8, st=0, user_data=(nil)
    DNS CALLBACK: status=-100
    DNS CALLBACK: status=-103
    Giving semaphore on info == NULL
    something...1
    Trying to initialize socket...
    Family: 1, socktype: 1, proto: 259
    [00:08:17.652,130] <dbg> net_sock_tls: tls_alloc: (mp_main): Allocated TLS context, 0x2000d3d8
    [00:08:17.652,954] <dbg> net_sock: zsock_socket_internal: (mp_main): socket: ctx=0x2000f568, fd=16
    Returned value: 15
    Done initializing socket!
    Performing TLS setup...
    TLS setup complete.
    Connecting to: ('142.251.39.14', 443)
    Trying 1...
    1 is done
    2 is done
    3 is done
    [00:08:19.712,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:08:19.717,498] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:08:19.717,559] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:08:19.717,590] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    --- 57 messages dropped ---
    [00:08:19.723,052] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    --- 38 messages dropped ---
    [00:08:19.830,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  c0 09 c0 13 00 33 00 3d 00 35 c0 2a c0 0f c0 26  .....3.=.5.*...&
    --- 60 messages dropped ---
    [00:08:19.892,761] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (68 bytes)
    --- 12 messages dropped ---
    [00:08:19.895,996] raceback (most recent call last):
      File "<stdin>", line 1, in <module>
      File "sock_test.py", line 68, in step_1
    OSError: [Errno 113] ECONNABORTED
  • Hey Håkon,
    We just had a call with Alexander Rawstone, in which we provided him with the local version of the https_client sample project. If you recall from earlier in this thread, I tried setting the host in the https_client  to google.com and adding the certificate that you mentioned but the connection didn't work out. I undid the hostname in the Kconfig for the https_sample, so it's back to example.com. I left some google certs in the project there (mainly I used r1, but I tried others also). So, when I wanted to try google.com as a host, I changed the Kconfig, made a copy of r1.pem and then renamed that copy to DigiCertGlobalG3.pem.
    If you are running NCS v3.0.0, you need to add:
    CONFIG_MBEDTLS_RSA_C=y
    Since you already have the changes in-place, I suspect that this is the only option that you're missing. It shall then print something like this:
    *** Booting nRF Connect SDK v3.0.2-89ba1294ac9b ***
    *** Using Zephyr OS v4.0.99-f791c49f492c ***
    HTTPS client sample started
    Bringing network interface up
    Provisioning certificate
    CA certificate already exists, sec tag: 42
    Connecting to the network
    Connected
    Network connectivity established and IP address assigned
    Looking up google.com
    Resolved 216.58.207.238 (AF_INET)
    Connecting to google.com:443
    Sent 60 bytes
    Received 631 bytes
    >        HTTP/1.1 301 Moved Permanently
    Finished, closing socket.
    Disconnected
    Network connectivity lost
    Disconnected from the network
    uart:~$
    I will post the full change, for simplicity.
    Here's a git .patch file showing the changes needed for net/https_client in ncs v3.0.0:
    https_client_ncs3.0_google.patch
    place this in the path/to/ncs3.0.0/nrf/samples/net/https_client/ folder, and write:
    git apply https_client_ncs3.0_google.patch
    If your tree is unmodified, it shall apply cleanly.
    Note: I am disabling IPv6 on my end. This is an local network issue with the test-network that I am using, so disabling CONFIG_NET_IPV6 is optional.
    Håkon
  • Sadly it still doesn't work:
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    uart:~$
    uart:~$
    uart:~$
    uart:~$
    uart:~$
    uart:~$
    Connected
    Resolved 142.251.39.78 (AF_INET)
    Dead here...56. ret value = -9984
    Dead here...66. cert_failed = 1
    connect() failed, err: 113
    Disconnected
    Edit 1: the two "Dead here..." messages that you see are prints that I included somewhere in ssl_tls.c to see what can potentially cause the TLS handshake to fail. I can comment them but I'm pretty sure the behaviour would be the same. I also want to confirm: the r1.pem is the one that was in that archive, right? More precisely this:
    r1.pem.zip
    Edit 2: Since I have no more ideas, I applied your changes, built and flashed the target and it didn't work, I decided to simply archive and add the sample project here, which will include the build folder:
    1581.https_client.zip
    this line:
    is -0x2700 in hex, ie, mbedtls verification error.
    The r1.pem.zip holds something that differs from the one downloaded from google:
    https://i.pki.goog/r1.pem
    Could you triple check that you're using the correct root CA?
    Håkon
