Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
    Edit: I'm still hoping that you'll agree to a call so we can solve this faster.
    A call will not help, as I need to be able to recreate the scenario on my end. The issue is that it works in a contained sample, ie. https_client, but not in your sample. To be able to pinpoint this, I will need to run both scenarios, and then start trickling down to how they two differ.
    You will need to be able to provide a way for me to run your system at my end, and this is still not possible, because I am still lacking deps in your micropy port. Please use "git" (git diff / git status) to your advantage, which is a great tool to ensure that sources are sync'ed.
    At this time, I am one step further, but blocked by a new dep, which is modnetwork_globals.h:
    ../../lib/littlefs/lfs2_util.c /opt/repos/micropython/ports/zephyr/main.c /opt/repos/micropython/ports/zephyr/help.c /opt/repos/micropython/ports/zephyr/machine_i2c.c /opt/repos/micropython/ports/zephyr/machine_spi.c /opt/repos/micropython/ports/zephyr/machine_pin.c /opt/repos/micropython/ports/zephyr/machine_timer.c /opt/repos/micropython/ports/zephyr/modbluetooth_zephyr.c /opt/repos/micropython/ports/zephyr/modsocket.c /opt/repos/micropython/ports/zephyr/modzephyr.c /opt/repos/micropython/ports/zephyr/modzsensor.c /opt/repos/micropython/ports/zephyr/mphalport.c /opt/repos/micropython/ports/zephyr/uart_core.c /opt/repos/micropython/ports/zephyr/zephyr_device.c /opt/repos/micropython/ports/zephyr/zephyr_storage.c /opt/repos/micropython/ports/zephyr/mpthreadport.c
    /opt/repos/micropython/ports/zephyr/modsocket.c:51: warning: "DEBUG_printf" redefined
       51 |  #define DEBUG_printf printf
    In file included from /opt/repos/micropython/ports/zephyr/modsocket.c:33:
    /opt/repos/micropython/ports/zephyr/mpthreadport.c:38: note: this is the location of the previous definition
       38 | #define DEBUG_printf(...) // printk("_thread: " __VA_ARGS__)
    In file included from /opt/repos/micropython/ports/zephyr/../../py/mpconfig.h:89,
                     from /opt/repos/micropython/ports/zephyr/../../py/obj.h:31,
                     from /opt/repos/micropython/ports/zephyr/../../py/objlist.h:29,
                     from /opt/repos/micropython/ports/zephyr/../../extmod/modnetwork.c:31:
    /opt/repos/micropython/ports/zephyr/mpconfigport_full.h:135:55: fatal error: ports/zephyr/modnetwork_globals.h: No such file or directory
      135 | #define MICROPY_PY_NETWORK_MODULE_GLOBALS_INCLUDEFILE "ports/zephyr/modnetwork_globals.h"
    compilation terminated.
    In file included from /opt/repos/micropython/build/zephyr/tfm/api_ns/interface/include/psa/crypto.h:16,
                     from /opt/repos/micropython/ports/zephyr/../../ports/zephyr/modos.c:39,
                     from /opt/repos/micropython/ports/zephyr/../../extmod/modos.c:64:
    /opt/repos/micropython/build/zephyr/tfm/api_ns/interface/include/psa/crypto_platform.h:23:10: fatal error: mbedtls/private_access.h: No such file or directory
       23 | #include "mbedtls/private_access.h"
    Thanks for sharing the .c file, but:
    You need to locate the ".config" file, as this also holds what is not selected/configured, and I can use this directly to run your configuration.
    You mention using macos earlier. Here's how to do this on mac/*nix based system.
    1. open your terminal, cd into the application folder
    2. use "find" to locate the .config file: find -name ".config" .
    3. You will see two hits:
    find . -name ".config"
    ./zephyr/.config
    ./https_client/zephyr/.config
    Since my application is named "https_client", this is where my .config file will be located.
    4. Open the file:
    open path/to/build/application/zephyr/.config
    This should open the file in vi on macos (or whichever editor you have chosen).
    You can open it in vscode by replacing "open" with "code"
    Did some checks towards my local https_client sample, by diffing and found that you lack these two settings in mbedtls:
    CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED=y
    CONFIG_PSA_WANT_ALG_CHACHA20=y
    Also, adjust this to a higher value to avoid any potential restriction due to heap allocation failure:
    CONFIG_HEAP_MEM_POOL_SIZE # currently 64k, should be 80k
    Also the CONFIG_NET_PKT* configurations are low in your configuration. Try these values:
    CONFIG_NET_PKT_RX_COUNT=14
    CONFIG_NET_PKT_TX_COUNT=14
    CONFIG_NET_BUF_RX_COUNT=36
    CONFIG_NET_BUF_TX_COUNT=36
    Håkon
  • Hey Håkon,
    Let's start with the .config file. You were absolutely right when you said that it has to be there. Using your command:
    root@Tudors-MacBook zephyr # find . -name ".config"
    ./build/zephyr/.config
    ./build/zephyr/zephyr/.config
    So, digging a bit deeper, I found that macOS considers files that start with . as hidden -> that's why I didn't see them. I'm terribly sorry for this mishap. -.-
    That aside, based on the two files indicated by your command, here are the two .config files:
    SB_CONFIG_BOARD="nrf7002dk"
    SB_CONFIG_BOARD_REVISION=""
    SB_CONFIG_BOARD_NRF7002DK=y
    SB_CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP_NS=y
    SB_CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp/ns"
    SB_CONFIG_SOC="nrf5340"
    SB_CONFIG_SOC_SERIES="nrf53"
    SB_CONFIG_SOC_FAMILY="nordic_nrf"
    SB_CONFIG_SOC_TOOLCHAIN_NAME="amd_acp_6_0_adsp"
    SB_CONFIG_SOC_FAMILY_NORDIC_NRF=y
    SB_CONFIG_SOC_SERIES_NRF53X=y
    SB_CONFIG_SOC_NRF5340_CPUAPP=y
    SB_CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # Sysbuild image configuration
    # Modules
    # Available modules.
    # nrf (/opt/nordic/ncs/v3.0.0/nrf)
    SB_CONFIG_PARTITION_MANAGER=y
    # SB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    SB_CONFIG_BUILD_OUTPUT_BIN=y
    SB_CONFIG_BUILD_OUTPUT_HEX=y
    SB_CONFIG_BOARD_IS_NON_SECURE=y
    SB_CONFIG_APPCORE_REMOTE_BOARD_TARGET_CPUCLUSTER="cpuapp"
    SB_CONFIG_APPCORE_REMOTE_DOMAIN="CPUAPP"
    SB_CONFIG_SUPPORT_NETCORE=y
    SB_CONFIG_NETCORE_REMOTE_BOARD_TARGET_CPUCLUSTER="cpunet"
    SB_CONFIG_NETCORE_REMOTE_DOMAIN="CPUNET"
    # Network core configuration
    SB_CONFIG_SUPPORT_NETCORE_EMPTY=y
    SB_CONFIG_SUPPORT_NETCORE_HCI_IPC=y
    SB_CONFIG_SUPPORT_NETCORE_RPC_HOST=y
    SB_CONFIG_SUPPORT_NETCORE_802154_RPMSG=y
    SB_CONFIG_SUPPORT_NETCORE_IPC_RADIO=y
    SB_CONFIG_NETCORE_NONE=y
    # SB_CONFIG_NETCORE_EMPTY is not set
    # SB_CONFIG_NETCORE_HCI_IPC is not set
    # SB_CONFIG_NETCORE_RPC_HOST is not set
    # SB_CONFIG_NETCORE_802154_RPMSG is not set
    # SB_CONFIG_NETCORE_IPC_RADIO is not set
    # end of Network core configuration
    # Secure Bootloader
    # SB_CONFIG_SECURE_BOOT_APPCORE is not set
    # SB_CONFIG_SECURE_BOOT_NETCORE is not set
    # end of Secure Bootloader
    SB_CONFIG_SUPPORT_QSPI_XIP=y
    # Bluetooth Fair Pair
    SB_CONFIG_BT_FAST_PAIR_MODEL_ID=0x1000000
    SB_CONFIG_BT_FAST_PAIR_ANTI_SPOOFING_PRIVATE_KEY=""
    # end of Bluetooth Fair Pair
    # SB_CONFIG_MATTER is not set
    # Wi-Fi
    SB_CONFIG_WIFI_NRF70=y
    SB_CONFIG_WIFI_NRF70_SYSTEM_MODE=y
    # SB_CONFIG_WIFI_NRF70_SCAN_ONLY is not set
    # SB_CONFIG_WIFI_NRF70_OFFLOADED_RAW_TX is not set
    # SB_CONFIG_WIFI_NRF70_RADIO_TEST is not set
    # SB_CONFIG_WIFI_NRF70_SYSTEM_WITH_RAW_MODES is not set
    SB_CONFIG_WIFI_PATCHES_EXT_FLASH_DISABLED=y
    # SB_CONFIG_WIFI_PATCHES_EXT_FLASH_STORE is not set
    # end of Wi-Fi
    # SUIT
    # SB_CONFIG_SUIT_ENVELOPE is not set
    # SB_CONFIG_SUIT_BUILD_RECOVERY is not set
    # SB_CONFIG_SUIT_BUILD_FLASH_COMPANION is not set
    # SB_CONFIG_SUIT_BUILD_AB_UPDATE is not set
    # SB_CONFIG_SUIT_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set
    # end of SUIT
    # SUIT provisioning
    # SB_CONFIG_SUIT_MPI_GENERATE is not set
    # end of SUIT provisioning
    # SB_CONFIG_HPF is not set
    # SB_CONFIG_APPROTECT_USE_UICR is not set
    # SB_CONFIG_APPROTECT_LOCK is not set
    # SB_CONFIG_APPROTECT_USER_HANDLING is not set
    SB_CONFIG_APPROTECT_NO_SYSBUILD=y
    # SB_CONFIG_SECURE_APPROTECT_USE_UICR is not set
    # SB_CONFIG_SECURE_APPROTECT_LOCK is not set
    # SB_CONFIG_SECURE_APPROTECT_USER_HANDLING is not set
    SB_CONFIG_SECURE_APPROTECT_NO_SYSBUILD=y
    # TF-M
    # SB_CONFIG_TFM_OTP_PSA_CERTIFICATE_REFERENCE is not set
    # end of TF-M
    SB_CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/opt/nordic/ncs/v3.0.0/nrf)
    SB_CONFIG_ZEPHYR_HOSTAP_MODULE=y
    SB_CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    SB_CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    SB_CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    SB_CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    SB_CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    SB_CONFIG_ZEPHYR_CJSON_MODULE=y
    SB_CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    SB_CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    SB_CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    SB_CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    SB_CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    SB_CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    SB_CONFIG_ZEPHYR_COREMARK_MODULE=y
    SB_CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    SB_CONFIG_ZEPHYR_CHRE_MODULE=y
    SB_CONFIG_ZEPHYR_LZ4_MODULE=y
    SB_CONFIG_ZEPHYR_NANOPB_MODULE=y
    SB_CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    SB_CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    SB_CONFIG_ZEPHYR_FATFS_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_ST_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    SB_CONFIG_ZEPHYR_LIBLC3_MODULE=y
    SB_CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    SB_CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    SB_CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    SB_CONFIG_ZEPHYR_LVGL_MODULE=y
    SB_CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    SB_CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    SB_CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    SB_CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    SB_CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    SB_CONFIG_ZEPHYR_SEGGER_MODULE=y
    SB_CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    SB_CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    SB_CONFIG_ZEPHYR_ZCBOR_MODULE=y
    SB_CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    SB_CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    SB_CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # Unavailable modules, please install those via the project manifest.
    # end of Modules
    # SB_CONFIG_WARN_EXPERIMENTAL is not set
    SB_CONFIG_WARN_DEPRECATED=y
    SB_CONFIG_SUPPORT_BOOTLOADER=y
    SB_CONFIG_SUPPORT_BOOTLOADER_MCUBOOT_ZEPHYR=y
    SB_CONFIG_BOOTLOADER_NONE=y
    # SB_CONFIG_BOOTLOADER_MCUBOOT is not set
    # Build options
    # SB_CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # end of Build options
    2063.config
    When adding the three options that you mentioned:
    I get the following build error:
    dules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.o.d -o secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/drivers/nrf_oberon/CMakeFiles/oberon_psa_driver.dir/opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.o -c /opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.c
    In file included from /opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include/mbedtls/build_info.h:192,
                     from /opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include/psa/build_info.h:18,
                     from /opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include/psa/crypto_platform.h:32,
                     from /opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/include/psa/crypto.h:16,
                     from /opt/nordic/ncs/v3.0.0/modules/crypto/oberon-psa-crypto/oberon/drivers/oberon_spake2p.c:15:
    /opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/mbedtls/check_config.h:333:2: error: #error "MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED defined, but not all prerequisites"
      333 | #error "MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED defined, but not all prerequisites"
    /opt/nordic/ncs/v3.0.0/modules/crypto/mbedtls/include/mbedtls/check_config.h:344:2: error: #error "MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED defined, but not all prerequisites"
      344 | #error "MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED defined, but not all prerequisites"
    I'll try to solve it on my side.
    And of course, the file that you requested:
  • Build error solved by adding:
    CONFIG_MBEDTLS_DHM_C=y
    But interestingly enough, now I don't get as far as before in the TLS handshake. New log with your proposed modifications for the extra crypto algos:
    [00:00:00.670,562] <dbg> net_dns_resolve: dns_resolve_init_locked: (main): [0] 8.8.8.8
    [00:00:00.678,985] <dbg> net_dns_resolve: dns_resolve_init_locked: (main): [1] 8.8.4.4
    [00:00:00.687,774] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2000a998, fd=3
    [00:00:00.696,990] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Service WEST_TOPDIR/zephyr/subsys/net/lib/dhcpv4/dhcpv4_server.c:1535 has 1 pollable sockets
    [00:00:00.713,226] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Service WEST_TOPDIR/zephyr/subsys/net/lib/dns/resolve.c:41 has 2 pollable sockets
    [00:00:00.728,546] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Monitoring 3 socket entries
    [00:00:00.739,593] <dbg> net_sock: zsock_socket_internal: (main): socket: ctx=0x2000aa48, fd=5
    *** Booting nRF Connect SDK v3.0.0-3bfc46578e42 ***
    *** Using Zephyr OS v4.0.99-a0e545cb437a ***
    [00:00:00.758,544] <inf> net_config: Initializing network
    [00:00:00.764,373] <inf> net_config: Waiting interface 1 (0x20008df8) to be up...
    [00:00:00.773,468] <inf> wifi_supplicant: wpa_supplicant initialized
    [00:00:00.780,761] <inf> net_config: IPv4 address: 192.168.1.1
    [00:00:00.787,048] <inf> net_config: Running dhcpv4 client...
    MicroPython 9ea566c69-dirty on 2025-06-02; zephyr-nrf7002dk with nrf5340
    Type "help()" for more information.
    >>> import sock_test
    >>> sock_test.step_1()
    Starting nrf7002dk with CPU frequency: 64 MHz
    Scan requested
    Num  | SSID                             (len) | Chan | RSSI | Security | BSSID
    1    | Sony_5_IV                        9     | 6    | -43  | WPA2-PSK | 22:93:C7:96:18:A7
    2    | SWEET&COFFEE                     12    | 9    | -53  | WPA2-PSK | E8:6E:44:09:5D:3C
    3    | MAZZER-12797577                  15    | 6    | -58  | WPA-PSK | 60:8A:10:C3:46:89
    4    |                                  0     | 161  | -60  | WPA2-PSK | EA:6E:44:99:5D:3D
    5    | SWEET&COFFEE                     12    | 161  | -61  | WPA2-PSK | E8:6E:44:09:5D:3D
    6    | HUAWEI-sBJ9                      11    | 11   | -61  | WPA-PSK | 88:CF:98:70:23:54
    7    | DIGI-JdZ3                        9     | 2    | -66  | WPA2-PSK | 74:31:AF:13:CC:61
    8    | DIGI-cPJ7                        9     | 13   | -68  | WPA2-PSK | AC:CC:36:52:94:31
    9    | EXP_Guest                        9     | 1    | -69  | WPA-PSK | 9E:DA:C4:18:AE:30
    10   | DIGI-dRb7                        9     | 13   | -71  | WPA2-PSK | 14:18:2A:40:28:A1
    11   | SENZOR PLANET _EXT               18    | 5    | -71  | WPA-PSK | 1C:3B:F3:97:86:06
    12   | DIGI-24-40F4                     12    | 1    | -71  | WPA-PSK | D4:B7:09:03:40:F4
    13   | DIGI_eeaea1                      11    | 1    | -72  | WPA2-PSK | C0:B1:01:EE:AE:A1
    14   | EXP2                             4     | 1    | -73  | WPA-PSK | 98:DA:C4:18:AE:3F
    15   | Rovacutest_5G                    13    | 44   | -75  | WPA2-PSK | 90:9A:4A:9E:D7:CB
    16   | Tenda_391100                     12    | 7    | -75  | WPA-PSK | 50:0F:F5:39:11:01
    17   |                                  30    | 5    | -75  | WPA2-PSK | BA:A6:E6:A6:23:0D
    18   | Digi Wi-Fi                       10    | 3    | -76  | WPA2-PSK | 14:18:2A:37:C7:31
    19   |                                  0     | 13   | -77  | WPA2-PSK | AA:40:A0:70:10:17
    20   | DIGI-aKn9                        9     | 6    | -77  | WPA2-PSK | 40:AE:30:92:E4:6B
    21   |                                  0     | 5    | -77  | WPA2-PSK | DE:47:32:AE:F4:F7
    22   | DIGI-jSN3                        9     | 3    | -77  | WPA2-PSK | 74:31:AF:15:D8:11
    23   | Vivi-Guest                       10    | 13   | -79  | OPEN  | AE:40:A0:70:10:17
    24   | GynOffline                       10    | 5    | -79  | WPA2-PSK | 5C:A6:E6:A6:23:0B
    25   | AT_401_RAC_056905_WW_4c11        25    | 11   | -80  | WPA2-PSK | 4C:BC:E9:81:4C:11
    26   | DIGI-23Sx                        9     | 12   | -81  | WPA2-PSK | 28:F8:D6:E6:20:21
    27   |                                  0     | 48   | -82  | WPA2-PSK | 16:18:2A:80:28:A1
    28   | DIGI-dRb7                        9     | 48   | -83  | WPA2-PSK | 14:18:2A:40:28:A9
    29   | DIGI-cPJ7                        9     | 36   | -83  | WPA2-PSK | AC:CC:36:52:94:39
    30   |                                  15    | 44   | -84  | WPA2-PSK | 74:31:AF:13:CC:69
    31   | [LG_Wall-Mount A/C]df38          23    | 11   | -84  | WPA2-PSK | A6:36:C7:93:DF:38
    32   |                                  0     | 36   | -84  | WPA2-PSK | AE:CC:36:52:94:31
    33   | DIGI-JdZ3                        9     | 44   | -85  | WPA2-PSK | 74:31:AF:13:CC:6A
    34   | Tenda_391100_5G                  15    | 40   | -85  | WPA-PSK | 50:0F:F5:39:11:05
    35   |                                  0     | 100  | -86  | WPA2-PSK | 70:A7:41:44:1D:06
    36   |                                  0     | 52   | -87  | WPA2-PSK | 06:20:84:94:04:F0
    37   | EXP2_5G                          7     | 48   | -88  | WPA-PSK | 98:DA:C4:18:AE:3E
    38   | EXP_GUEST_5G                     12    | 48   | -88  | WPA-PSK | 9E:DA:C4:18:AE:3F
    39   |                                  0     | 44   | -88  | WPA2-PSK | 7A:8C:B5:5B:6D:08
    40   | Medical Motion MESH              19    | 36   | -89  | WPA2-PSK | 38:6B:1C:2C:73:9C
    41   | TP-Link_7879_5G                  15    | 48   | -89  | WPA2-PSK | 5C:E9:31:AC:78:7B
    42   |                                  0     | 48   | -89  | WPA2-PSK | 5E:E9:31:EC:78:79
    43   | DIGI-aKn9                        9     | 48   | -89  | WPA2-PSK | 40:AE:30:92:E4:6D
    44   | DIGI-E7ZN                        9     | 52   | -89  | WPA2-PSK | 04:20:84:14:04:F0
    45   |                                  0     | 116  | -92  | WPA2-PSK | A0:40:A0:70:10:19
    Scan request done
    Found 45 networks.
    Network ID: Sony_5_IV & Network MAC: 22:93:C7:96:18:A7
    Network ID: SWEET&COFFEE & Network MAC: E8:6E:44:09:5D:3C
    Network ID: MAZZER-12797577 & Network MAC: 60:8A:10:C3:46:89
    Network ID:  & Network MAC: EA:6E:44:99:5D:3D
    Network ID: SWEET&COFFEE & Network MAC: E8:6E:44:09:5D:3D
    Network ID: HUAWEI-sBJ9 & Network MAC: 88:CF:98:70:23:54
    Network ID: DIGI-JdZ3 & Network MAC: 74:31:AF:13:CC:61
    Network ID: DIGI-cPJ7 & Network MAC: AC:CC:36:52:94:31
    Network ID: EXP_Guest & Network MAC: 9E:DA:C4:18:AE:30
    Network ID: DIGI-dRb7 & Network MAC: 14:18:2A:40:28:A1
    Network ID: SENZOR PLANET _EXT & Network MAC: 1C:3B:F3:97:86:06
    Network ID: DIGI-24-40F4 & Network MAC: D4:B7:09:03:40:F4
    Network ID: DIGI_eeaea1 & Network MAC: C0:B1:01:EE:AE:A1
    Network ID: EXP2 & Network MAC: 98:DA:C4:18:AE:3F
    Network ID: Rovacutest_5G & Network MAC: 90:9A:4A:9E:D7:CB
    Network ID: Tenda_391100 & Network MAC: 50:0F:F5:39:11:01
    Network ID:  & Network MAC: BA:A6:E6:A6:23:0D
    Network ID: Digi Wi-Fi & Network MAC: 14:18:2A:37:C7:31
    Network ID:  & Network MAC: AA:40:A0:70:10:17
    Network ID: DIGI-aKn9 & Network MAC: 40:AE:30:92:E4:6B
    Network ID:  & Network MAC: DE:47:32:AE:F4:F7
    Network ID: DIGI-jSN3 & Network MAC: 74:31:AF:15:D8:11
    Network ID: Vivi-Guest & Network MAC: AE:40:A0:70:10:17
    Network ID: GynOffline & Network MAC: 5C:A6:E6:A6:23:0B
    Network ID: AT_401_RAC_056905_WW_4c11 & Network MAC: 4C:BC:E9:81:4C:11
    Network ID: DIGI-23Sx & Network MAC: 28:F8:D6:E6:20:21
    Network ID:  & Network MAC: 16:18:2A:80:28:A1
    Network ID: DIGI-dRb7 & Network MAC: 14:18:2A:40:28:A9
    Network ID: DIGI-cPJ7 & Network MAC: AC:CC:36:52:94:39
    Network ID:  & Network MAC: 74:31:AF:13:CC:69
    Network ID: [LG_Wall-Mount A/C]df38 & Network MAC: A6:36:C7:93:DF:38
    Network ID:  & Network MAC: AE:CC:36:52:94:31
    Network ID: DIGI-JdZ3 & Network MAC: 74:31:AF:13:CC:6A
    Network ID: Tenda_391100_5G & Network MAC: 50:0F:F5:39:11:05
    Network ID:  & Network MAC: 70:A7:41:44:1D:06
    Network ID:  & Network MAC: 06:20:84:94:04:F0
    Network ID: EXP2_5G & Network MAC: 98:DA:C4:18:AE:3E
    Network ID: EXP_GUEST_5G & Network MAC: 9E:DA:C4:18:AE:3F
    Network ID:  & Network MAC: 7A:8C:B5:5B:6D:08
    Network ID: Medical Motion MESH & Network MAC: 38:6B:1C:2C:73:9C
    Network ID: TP-Link_7879_5G & Network MAC: 5C:E9:31:AC:78:7B
    Network ID:  & Network MAC: 5E:E9:31:EC:78:79
    Network ID: DIGI-aKn9 & Network MAC: 40:AE:30:92:E4:6D
    Network ID: DIGI-E7ZN & Network MAC: 04:20:84:14:04:F0
    Network ID:  & Network MAC: A0:40:A0:70:10:19
    MAC: F4:CE:36:00:1C:F4
    [00:00:36.985,260] <inf> wifimod: Connection requested
    [00:00:36.990,875] <inf> wifimod: ==================
    [00:00:36.996,978] <inf> wifimod: State: SCANNING
    [00:00:37.002,197] <inf> wifimod: Net If state: 5
    [00:00:37.307,586] <inf> wifimod: ==================
    [00:00:37.312,927] <inf> wifimod: State: AUTHENTICATING
    [00:00:37.318,695] <inf> wifimod: Net If state: 5
    [00:00:37.608,245] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000aaf8, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:00:37.627,960] <inf> wifimod: ==================
    [00:00:37.633,941] <inf> wifimod: State: 4WAY_HANDSHAKE
    [00:00:37.639,770] <inf> wifimod: Interface Mode: STATION
    [00:00:37.646,270] <inf> wifimod: Link Mode: WIFI 6 (802.11ax/HE)
    [00:00:37.652,893] <inf> wifimod: SSID: Sony_5_IV
    [00:00:37.658,050] <inf> wifimod: BSSID: 22:93:C7:96:18:A7
    [00:00:37.664,001] <inf> wifimod: Band: 2.4GHz
    [00:00:37.668,884] <inf> wifimod: Channel: 6
    [00:00:37.673,614] <inf> wifimod: Security: WPA2-PSK
    [00:00:37.679,046] <inf> wifimod: MFP: Disable
    [00:00:37.683,929] <inf> wifimod: RSSI: -44
    [00:00:37.690,582] <dbg> net_sock_packet: zpacket_received_cb: (rx_q[0]): ctx=0x2000aaf8, pkt=0x2005eb40, st=0, user_data=(nil)
    [00:00:37.715,728] <inf> wifimod: Net If state: 6
    [00:00:37.728,881] <inf> wifimod: Wi-Fi connect result: status...
    [00:00:37.735,382] <inf> wifimod: Connected
    [00:00:38.007,934] <dbg> net_sock: zsock_close_ctx: (rx_q[0]): close: ctx=0x2000a998, fd=3
    [00:00:38.016,784] <dbg> net_sock: zsock_close_ctx: (rx_q[0]): close: ctx=0x2000aa48, fd=5
    [00:00:38.025,970] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x2000a998, fd=3
    [00:00:38.035,797] <dbg> net_sock: zsock_socket_internal: (rx_q[0]): socket: ctx=0x2000aa48, fd=5
    [00:00:38.046,813] <dbg> net_sock_svc: socket_service_thread: (net_socket_service): Received restart event.
    [00:00:38.171,600] <inf> net_dhcpv4: Received: 192.168.157.8
    [00:00:38.177,825] <inf> net_config: IPv4 address: 192.168.157.8
    [00:00:38.184,234] <inf> net_config: Lease time: 3599 seconds
    [00:00:38.190,490] <inf> net_config: Subnet: 255.255.255.0
    [00:00:38.196,441] <inf> net_config: Router: 192.168.157.80
    [00:00:38.202,545] <inf> wifimod: Net MGMT: Got IP via DHCP
    DHCP IP address: 192.168.157.8
    Resolving google.com...
    Using system DNS resolver...
    Querying DNS for google.com (type 1)...
    [00:00:43.056,488] <dbg> net_dns_resolve: dns_write: (mp_main): [0] submitting work to server idx 0 for id 18998 hash 59079
    semaphore wait...1
    [00:00:43.517,852] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000a998, pkt=0x2005eb40, st=0, user_data=(nil)
    DNS CALLBACK: status=-100
    DNS CALLBACK: status=-103
    Giving semaphore on info == NULL
    something...1
    Resolved: [(1, 1, 6, '', ('172.217.20.14', 443))]
    Success!
    Trying to initialize socket...
    Family: 1, socktype: 1, proto: 259
    [00:00:43.551,208] <dbg> net_sock_tls: tls_alloc: (mp_main): Allocated TLS context, 0x20009c30
    [00:00:43.561,004] <dbg> net_sock: zsock_socket_internal: (mp_main): socket: ctx=0x2000aba8, fd=16
    Returned value: 15
    Done initializing socket!
    Performing TLS handshake...
    Trying 1...
    Failed to set cipher suite list: -11 is done
    2 is done
    3 is done
    TLS Handshake complete.
    Connecting to: ('172.217.20.14', 443)
    [00:00:43.688,262] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:00:43.707,824] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:43.718,109] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:43.728,698] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:43.739,288] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:00:43.751,953] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:43.762,542] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:43.773,162] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:00:43.785,736] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0921: => write client hello
    [00:00:43.797,546] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: dumping 'client hello, random bytes' (32 bytes)
    [00:00:43.811,187] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0000:  01 1f b7 f4 29 da ec 7a 50 0d 36 a8 5f d6 b8 df  ....)..zP.6._...
    [00:00:43.826,995] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0010:  19 a8 d7 69 e3 33 e8 d1 5f b6 35 42 fa 27 10 14  ...i.3.._.5B.'..
    [00:00:43.842,559] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0512: dumping 'session id' (0 bytes)
    [00:00:43.854,492] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:00:43.870,452] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:00:43.886,230] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 006b, TLS-DHE-RSA-WITH-AES-256-CBC-SHA256
    [00:00:43.901,824] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:00:43.917,510] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:00:43.933,044] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0039, TLS-DHE-RSA-WITH-AES-256-CBC-SHA
    [00:00:43.948,364] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:00:43.964,324] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:00:43.980,102] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0067, TLS-DHE-RSA-WITH-AES-128-CBC-SHA256
    [00:00:43.995,697] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:00:44.011,383] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:00:44.026,916] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0033, TLS-DHE-RSA-WITH-AES-128-CBC-SHA
    [00:00:44.042,266] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:00:44.057,525] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:00:44.072,509] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:00:44.088,195] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:00:44.103,637] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:00:44.119,506] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:00:44.135,101] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:00:44.150,360] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:00:44.165,344] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:00:44.181,030] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:00:44.196,472] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:00:44.212,341] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    [00:00:44.227,935] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0388: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:00:44.240,325] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0397: client hello, got 25 cipher suites
    [00:00:44.252,593] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0041: client hello, adding server name extension: google.com
    [00:00:44.266,601] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0231: client hello, adding supported_groups extension
    [00:00:44.279,968] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(001d)
    [00:00:44.291,442] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: x25519 ( 1d )
    [00:00:44.302,917] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(0017)
    [00:00:44.314,392] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: secp256r1 ( 17 )
    [00:00:44.326,110] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: dumping 'Supported groups extension' (6 bytes)
    [00:00:44.339,569] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: 0000:  00 04 00 1d 00 17                                ......
    [00:00:44.354,217] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9503: adding signature_algorithms extension
    [00:00:44.366,516] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [603] ecdsa_secp521r1_sha512
    [00:00:44.379,821] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [603] ecdsa_secp521r1_sha512
    [00:00:44.393,218] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [601] rsa_pkcs1_sha512
    [00:00:44.406,005] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [601] rsa_pkcs1_sha512
    [00:00:44.418,853] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [503] ecdsa_secp384r1_sha384
    [00:00:44.432,189] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [503] ecdsa_secp384r1_sha384
    [00:00:44.445,556] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [501] rsa_pkcs1_sha384
    [00:00:44.458,343] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [501] rsa_pkcs1_sha384
    [00:00:44.471,221] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [403] ecdsa_secp256r1_sha256
    [00:00:44.484,527] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [403] ecdsa_secp256r1_sha256
    [00:00:44.497,924] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9523: got signature scheme [401] rsa_pkcs1_sha256
    [00:00:44.510,681] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9532: sent signature scheme [401] rsa_pkcs1_sha256
    [00:00:44.523,529] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0105: client hello, adding supported_point_formats extension
    [00:00:44.538,055] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    [00:00:44.551,605] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0165: generating new ecjpake parameters
    [00:00:44.664,733] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0338: client hello, adding extended_master_secret extension
    [00:00:44.679,138] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0372: client hello, adding session ticket extension
    [00:00:44.692,901] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0689: client hello, total extension length: 395
    [00:00:44.705,780] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: dumping 'client hello extensions' (395 bytes)
    [00:00:44.719,238] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0000:  01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f 67 6c  ...........googl
    [00:00:44.735,046] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0010:  65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00 17 00  e.com...........
    [00:00:44.750,885] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0020:  0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 03 04  ................
    [00:00:44.766,693] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0030:  01 00 0b 00 02 01 00 01 00 01 4a 41 04 65 f3 ec  ..........JA.e..
    [00:00:44.782,531] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0040:  2e 71 a9 4f 34 63 43 d4 a8 44 9f b9 bf 9d d5 09  .q.O4cC..D......
    [00:00:44.798,339] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0050:  c1 87 39 0b ea e0 a5 9c 7b d5 bd 48 c6 fc d0 00  ..9.....{..H....
    [00:00:44.814,147] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0060:  c8 e0 f7 fd a8 96 b2 fa 51 09 c1 ca 1b 7a 92 2d  ........Q....z.-
    [00:00:44.829,956] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0070:  a1 91 ff b9 7e 2e 46 fd 47 15 86 34 03 41 04 5d  ....~.F.G..4.A.]
    [00:00:44.845,764] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0080:  a3 60 bc ce cb eb 52 30 2f b5 36 13 f1 d0 2e 5a  .`....R0/.6....Z
    [00:00:44.861,602] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0090:  b5 cb 1e e1 ae 79 e0 53 ad 5f 5c ab b4 10 e6 70  .....y.S._\....p
    [00:00:44.877,410] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00a0:  9c 0e e1 98 ee 74 0a 08 0c d4 02 06 66 5a e7 e3  .....t......fZ..
    [00:00:44.893,218] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00b0:  76 f9 d2 a2 63 1a 50 9b af ff 1b 00 42 3c f0 20  v...c.P.....B<.
    [00:00:44.909,027] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00c0:  3b 0d 7e 4a f1 4c 2a 37 ed 47 1e 3c 14 fa a9 f5  ;.~J.L*7.G.<....
    [00:00:44.924,835] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00d0:  bc 59 a5 1b 14 22 b1 ef 54 e7 0c f4 fc 44 30 ca  .Y..."..T....D0.
    [00:00:44.940,673] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00e0:  41 04 d3 fc 3e ab d5 dd 42 d8 2e 63 10 76 7a 37  A...>...B..c.vz7
    [00:00:44.956,481] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00f0:  d6 8d a6 21 69 1a fb a1 11 7f 39 6d c5 73 3e f7  ...!i.....9m.s>.
    [00:00:44.972,290] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0100:  ff 3c dc 2b 21 d9 fe 5f 1c 63 8a 53 1b 97 70 84  .<.+!.._.c.S..p.
    [00:00:44.988,098] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0110:  20 35 71 f9 d8 99 4f 68 cf 55 25 9f 89 cb b8 e9   5q...Oh.U%.....
    [00:00:45.003,906] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0120:  00 3d 41 04 27 b9 f4 65 73 cf aa 45 43 9d bd 45  .=A.'..es..EC..E
    [00:00:45.019,744] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0130:  d1 ba 6d 0e 58 01 e5 16 58 d9 41 fc 98 7c f9 f0  ..m.X...X.A..|..
    [00:00:45.035,552] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0140:  80 13 0d d5 53 ba aa 22 eb 55 d8 6f 09 fd 08 78  ....S..".U.o...x
    [00:00:45.051,361] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0150:  dd f2 2d 65 ec 78 6a 2b 05 54 ee 1e fa a8 43 71  ..-e.xj+.T....Cq
    [00:00:45.067,169] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0160:  51 73 82 25 20 b6 e2 65 0c f0 2c 39 dc 2c 06 43  Qs.% ..e..,9.,.C
    [00:00:45.082,977] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0170:  26 3f ce 2d bc df 6d ee a2 4a ce c0 4f d8 7b 48  &?.-..m..J..O.{H
    [00:00:45.098,754] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0180:  08 c3 b1 a9 87 00 17 00 00 00 23                 ..........#
    [00:00:45.115,112] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:00:45.126,617] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:00:45.137,268] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 490
    [00:00:45.151,367] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (495 bytes)
    [00:00:45.167,022] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 01 ea 01 00 01 e6 03 03 01 1f b7 f4 29  ...............)
    [00:00:45.184,478] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  da ec 7a 50 0d 36 a8 5f d6 b8 df 19 a8 d7 69 e3  ..zP.6._......i.
    [00:00:45.201,965] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  33 e8 d1 5f b6 35 42 fa 27 10 14 00 00 32 c0 24  3.._.5B.'....2.$
    [00:00:45.219,421] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  c0 28 00 6b c0 0a c0 14 00 39 c0 23 c0 27 00 67  .(.k.....9.#.'.g
    [00:00:45.236,907] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  c0 09 c0 13 00 33 00 3d 00 35 c0 2a c0 0f c0 26  .....3.=.5.*...&
    [00:00:45.254,394] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0050:  c0 05 00 3c 00 2f c0 29 c0 0e c0 25 c0 04 00 ff  ...<./.)...%....
    [00:00:45.271,881] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0060:  01 00 01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f  .............goo
    [00:00:45.289,367] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0070:  67 6c 65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00  gle.com.........
    [00:00:45.306,854] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0080:  17 00 0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04  ................
    [00:00:45.324,340] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0090:  03 04 01 00 0b 00 02 01 00 01 00 01 4a 41 04 65  ............JA.e
    [00:00:45.341,796] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00a0:  f3 ec 2e 71 a9 4f 34 63 43 d4 a8 44 9f b9 bf 9d  ...q.O4cC..D....
    [00:00:45.359,283] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00b0:  d5 09 c1 87 39 0b ea e0 a5 9c 7b d5 bd 48 c6 fc  ....9.....{..H..
    [00:00:45.376,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00c0:  d0 00 c8 e0 f7 fd a8 96 b2 fa 51 09 c1 ca 1b 7a  ..........Q....z
    [00:00:45.394,226] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00d0:  92 2d a1 91 ff b9 7e 2e 46 fd 47 15 86 34 03 41  .-....~.F.G..4.A
    [00:00:45.411,712] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00e0:  04 5d a3 60 bc ce cb eb 52 30 2f b5 36 13 f1 d0  .].`....R0/.6...
    [00:00:45.429,168] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00f0:  2e 5a b5 cb 1e e1 ae 79 e0 53 ad 5f 5c ab b4 10  .Z.....y.S._\...
    [00:00:45.446,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0100:  e6 70 9c 0e e1 98 ee 74 0a 08 0c d4 02 06 66 5a  .p.....t......fZ
    [00:00:45.464,141] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0110:  e7 e3 76 f9 d2 a2 63 1a 50 9b af ff 1b 00 42 3c  ..v...c.P.....B<
    [00:00:45.481,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0120:  f0 20 3b 0d 7e 4a f1 4c 2a 37 ed 47 1e 3c 14 fa  . ;.~J.L*7.G.<..
    [00:00:45.499,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0130:  a9 f5 bc 59 a5 1b 14 22 b1 ef 54 e7 0c f4 fc 44  ...Y..."..T....D
    [00:00:45.516,571] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0140:  30 ca 41 04 d3 fc 3e ab d5 dd 42 d8 2e 63 10 76  0.A...>...B..c.v
    [00:00:45.534,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0150:  7a 37 d6 8d a6 21 69 1a fb a1 11 7f 39 6d c5 73  z7...!i.....9m.s
    [00:00:45.551,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0160:  3e f7 ff 3c dc 2b 21 d9 fe 5f 1c 63 8a 53 1b 97  >..<.+!.._.c.S..
    [00:00:45.568,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0170:  70 84 20 35 71 f9 d8 99 4f 68 cf 55 25 9f 89 cb  p. 5q...Oh.U%...
    [00:00:45.586,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0180:  b8 e9 00 3d 41 04 27 b9 f4 65 73 cf aa 45 43 9d  ...=A.'..es..EC.
    [00:00:45.603,881] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0190:  bd 45 d1 ba 6d 0e 58 01 e5 16 58 d9 41 fc 98 7c  .E..m.X...X.A..|
    [00:00:45.621,368] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01a0:  f9 f0 80 13 0d d5 53 ba aa 22 eb 55 d8 6f 09 fd  ......S..".U.o..
    [00:00:45.638,824] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01b0:  08 78 dd f2 2d 65 ec 78 6a 2b 05 54 ee 1e fa a8  .x..-e.xj+.T....
    [00:00:45.656,280] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01c0:  43 71 51 73 82 25 20 b6 e2 65 0c f0 2c 39 dc 2c  CqQs.% ..e..,9.,
    [00:00:45.673,767] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01d0:  06 43 26 3f ce 2d bc df 6d ee a2 4a ce c0 4f d8  .C&?.-..m..J..O.
    [00:00:45.691,223] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01e0:  7b 48 08 c3 b1 a9 87 00 17 00 00 00 23 00 00     {H..........#..
    [00:00:45.708,343] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:00:45.718,933] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:00:45.730,468] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:1014: <= write client hello
    [00:00:45.741,851] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:45.752,471] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 495, out_left: 495
    [00:00:45.765,441] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 495 (-0xfffffe11)
    [00:00:45.778,167] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:00:45.788,787] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:00:45.801,361] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:00:45.813,262] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:45.823,760] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:45.834,289] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:00:45.845,489] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:00:45.856,658] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:46.026,458] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:00:46.038,055] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:46.048,339] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:46.058,929] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:46.069,519] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:00:46.082,092] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:00:46.093,994] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:46.104,492] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:46.115,020] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:00:46.126,251] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:00:46.138,275] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:00:46.151,702] <w[00:00:46.155,578] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_data=(nil)
    rn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:46.175,933] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:46.190,460] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 3f                                   ....?
    [00:00:46.206,756] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 63
    [00:00:46.220,794] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:46.231,323] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 68
    [00:00:46.242,645] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 68
    [00:00:46.253,936] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 63 (-0xffffffc1)
    [00:00:46.267,852] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:46.278,411] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (68 bytes)
    [00:00:46.293,609] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 3d c5 42 02  ....?...;..h=.B.
    [00:00:46.311,096] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  34 6f 04 20 97 47 4d fd a2 3f 81 f4 77 38 f8 66  4o. .GM..?..w8.f
    [00:00:46.328,582] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  c5 f2 07 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  ...DOWNGRD......
    [00:00:46.346,069] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:00:46.363,403] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  00 23 00 00                                      .#..
    [00:00:46.379,638] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 63, type = 2, hslen = 63
    [00:00:46.393,218] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 63, 0..63 of 63
    [00:00:46.405,731] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (68 bytes)
    [00:00:46.420,349] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 3d c5 42 02  ....?...;..h=.B.
    [00:00:46.437,805] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  34 6f 04 20 97 47 4d fd a2 3f 81 f4 77 38 f8 66  4o. .GM..?..w8.f
    [00:00:46.455,291] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  c5 f2 07 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  ...DOWNGRD......
    [00:00:46.472,778] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:00:46.490,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  00 23 00 00                                      .#..
    [00:00:46.506,652] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:00:46.517,150] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: dumping 'server hello, version' (2 bytes)
    [00:00:46.530,609] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: 0000:  03 03                                            ..
    [00:00:46.545,471] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1291: server hello, current time: 1748878658
    [00:00:46.558,624] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: dumping 'server hello, random bytes' (32 bytes)
    [00:00:46.572,753] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0000:  68 3d c5 42 02 34 6f 04 20 97 47 4d fd a2 3f 81  h=.B.4o. .GM..?.
    [00:00:46.589,782] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0010:  f4 77 38 f8 66 c5 f2 07 44 4f 57 4e 47 52 44 01  .w8.f...DOWNGRD.
    [00:00:46.605,957] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1363: server hello, session id len.: 0
    [00:00:46.618,560] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1364: dumping 'server hello, session id' (0 bytes)
    [00:00:46.632,202] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1388: no session has been resumed
    [00:00:46.644,378] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1391: server hello, chosen ciphersuite: c009
    [00:00:46.657,470] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1392: server hello, compress alg.: 0
    [00:00:46.669,921] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1427: server hello, chosen ciphersuite: TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:00:46.685,852] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1448: server hello, total extension length: 19
    [00:00:46.699,401] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1518: found extended_master_secret extension
    [00:00:46.712,524] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1466: found renegotiation extension
    [00:00:46.724,853] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1545: found supported_point_formats extension
    [00:00:46.738,067] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0844: point format selected: 0
    [00:00:46.751,892] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1531: found session_ticket extension
    [00:00:46.764,312] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1662: <= parse server hello
    [00:00:46.776,184] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:46.786,773] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:46.797,393] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:46.810,485] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:46.821,533] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:46.832,031] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:46.842,529] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:00:46.853,790] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:00:46.864,990] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:00:46.878,417] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:46.888,977] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:46.903,442] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:46.919,738] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:00:46.933,959] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:46.944,488] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 6331
    [00:00:46.956,512] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 6331
    [00:00:46.967,987] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1291 (-0xfffffaf5)
    [00:00:46.981,750] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6331
    [00:00:46.993,438] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:47.455,322] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_data=(nil)
    [00:00:47.466,949] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:47.477,233] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:47.487,823] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:47.498,443] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:47.511,535] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:47.522,552] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:47.533,050] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:47.543,579] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 5
    [00:00:47.555,023] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:47.566,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:47.580,902] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:47.597,198] 00:00:47.600,555] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005eb80, st=0, user_data=(nil)
    m<inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:00:47.624,420] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:47.634,948] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 6331
    [00:00:47.647,277] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6331
    [00:00:47.659,027] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:00:47.672,790] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6331
    [00:00:47.684,478] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:47.903,289] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:00:47.914,886] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:47.925,170] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:47.935,760] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:47.946,380] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:47.959,472] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:47.970,489] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:47.980,987] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:47.991,516] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 5
    [00:00:48.002,960] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:48.014,312] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:48.028,778] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:48.045,074] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966:[00:00:48.054,870] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_dat)
    [00:00:48.072,265] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:48.082,794] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 6331
    [00:00:48.095,092] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6331
    [00:00:48.106,842] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:00:48.120,605] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6331
    [00:00:48.132,293] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:48.489,990] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_data=(nil)
    [00:00:48.501,617] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:48.511,901] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:48.522,491] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:48.533,233] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:48.546,417] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:48.557,434] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:48.567,932] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:48.578,460] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 5
    [00:00:48.589,904] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:48.601,348] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:48.615,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:48.632,171] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:00:48.646,392] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:48.656,921] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 6331
    [00:00:48.669,128] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6331
    [00:00:48.680,877] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 682 (-0xfffffd56)
    [00:00:48.694,549] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4706, nb_want: 6331
    [00:00:48.706,237] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:48.719,635] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_data=(nil)
    [00:00:48.731,414] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:48.741,699] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:48.752,288] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:48.762,908] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:48.776,000] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:48.787,017] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:48.797,546] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:48.808,074] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4706, nb_want: 5
    [00:00:48.819,488] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:48.830,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:48.844,512] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:48.860,809] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:00:48.875,061] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:48.885,589] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4706, nb_want: 6331
    [00:00:48.897,827] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4706, nb_want: 6331
    [00:00:48.909,576] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 682 (-0xfffffd56)
    [00:00:48.923,217] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6331
    [00:00:48.934,936] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:49.248,107] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_data=(nil)
    [00:00:49.259,948] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:49.270,843] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:49.281,463] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:49.292,053] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:49.305,175] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:49.316,192] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:49.326,690] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:49.337,219] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 5
    [00:00:49.349,182] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:49.362,579] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:49.377,136] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:49.393,463] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:00:49.407,684] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:49.418,212] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 6331
    [00:00:49.430,450] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6331
    [00:00:49.442,169] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 682 (-0xfffffd56)
    [00:00:49.455,841] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 6070, nb_want: 6331
    [00:00:49.467,529] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:00:51.150,909] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=0x2005ebc0, st=0, user_data=(nil)
    [00:00:51.162,811] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4661: => handshake
    [00:00:51.173,400] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:00:51.184,936] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:00:51.195,556] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:00:51.208,648] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8093: => parse certificate
    [00:00:51.219,696] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:00:51.230,194] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:51.240,722] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 6070, nb_want: 5
    [00:00:51.252,136] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:51.262,695] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:00:51.277,160] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b6                                   .....
    [00:00:51.293,457] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6326
    [00:00:51.307,678] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:00:51.318,206] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 6070, nb_want: 6331
    [00:00:51.330,017] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 6070, nb_want: 6331
    [00:00:51.341,766] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 261 (-0xfffffefb)
    [00:00:51.355,346] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:00:51.365,905] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (6331 bytes)
    [00:00:51.381,286] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 18 b6 0b 00 18 b2 00 18 af 00 0e 31 30  ..............10
    [00:00:51.398,773] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  82 0e 2d 30 82 0d 15 a0 03 02 01 02 02 10 66 86  ..-0..........f.
    [00:00:51.416,259] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  f0 7e 70 d7 df c2 09 4c b8 5a 34 d6 e3 d8 30 0d  .~p....L.Z4...0.
    [00:00:51.433,746] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:00:51.451,202] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:00:51.468,688] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:00:51.486,175] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:00:51.503,662] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:00:51.521,118] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0080:  30 35 31 32 30 38 34 32 35 38 5a 17 0d 32 35 30  0512084258Z..250
    [00:00:51.538,604] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0090:  38 30 34 30 38 34 32 35 37 5a 30 17 31 15 30 13  804084257Z0.1.0.
    [00:00:51.556,091] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:00:51.573,547] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:00:51.591,033] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 0a a6  ..*.H.=....B....
    [00:00:51.608,520] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00d0:  db af e0 06 99 b8 6f 52 89 c4 25 83 94 32 5c 27  ......oR..%..2\'
    [00:00:51.626,007] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00e0:  b9 94 42 1d 87 49 f5 1d c7 c8 2e 2f 3b 23 d2 df  ..B..I...../;#..
    [00:00:51.643,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00f0:  e9 8c 33 79 94 86 0e 25 80 b3 ae 8e 72 22 5d ba  ..3y...%....r"].
    [00:00:51.660,949] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0100:  ef ce 7c 6f 30 55 e7 6c 1d 4b 02 70 fa 9d a3 82  ..|o0U.l.K.p....
    [00:00:51.678,436] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0110:  0c 1a 30 82 0c 16 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:00:51.695,922] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:00:51.713,409] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:00:51.730,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:00:51.748,382] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0150:  04 16 04 14 ad 60 2e a1 68 d6 19 19 03 fa a3 0e  .....`..h.......
    [00:00:51.765,838] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0160:  ad d6 24 d8 fa 28 88 3e 30 1f 06 03 55 1d 23 04  ..$..(.>0...U.#.
    [00:00:51.783,325] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:00:51.800,811] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:00:51.818,298] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:00:51.835,784] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:00:51.853,240] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:00:51.870,727] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:00:51.888,214] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:00:51.905,700] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:00:51.923,156] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:00:51.940,643] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:00:51.958,129] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:00:51.975,585] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:00:51.993,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:00:52.010,528] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:00:52.027,984] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:00:52.045,471] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:00:52.062,927] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:00:52.080,383] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:00:52.097,869] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:00:52.115,325] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:00:52.132,812] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:00:52.150,268] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:00:52.167,755] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:00:52.185,241] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:00:52.202,697] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:00:52.220,184] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:00:52.237,640] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:00:52.255,126] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:00:52.272,583] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:00:52.290,069] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:00:52.307,525] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:00:52.325,012] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:00:52.342,468] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:00:52.359,954] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:00:52.377,410] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:00:52.394,897] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:00:52.412,353] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:00:52.429,840] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:00:52.447,296] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:00:52.464,782] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:00:52.482,269] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:00:52.499,755] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:00:52.517,211] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:00:52.534,698] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:00:52.552,185] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:00:52.569,671] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:00:52.587,127] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:00:52.604,614] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:00:52.622,100] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:00:52.639,587] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:00:52.657,043] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:00:52.674,530] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:00:52.691,986] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:00:52.709,472] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:00:52.726,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:00:52.744,415] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:00:52.761,901] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:00:52.779,357] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:00:52.796,844] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:00:52.814,331] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:00:52.831,817] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:00:52.849,273] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:00:52.866,760] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:00:52.884,246] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:00:52.901,733] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:00:52.919,189] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:00:52.936,676] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:00:52.954,132] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:00:52.971,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:00:52.989,105] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:00:53.006,561] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:00:53.024,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:00:53.041,534] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:00:53.058,990] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:00:53.076,477] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:00:53.093,933] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:00:53.111,419] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:00:53.128,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:00:53.146,331] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:00:53.163,818] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:00:53.181,304] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:00:53.198,760] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:00:53.216,217] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:00:53.233,703] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:00:53.251,159] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:00:53.268,615] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:00:53.286,102] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:00:53.303,558] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:00:53.321,044] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:00:53.338,500] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:00:53.355,987] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:00:53.373,443] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:00:53.390,930] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:00:53.408,416] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:00:53.425,872] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:00:53.443,359] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:00:53.460,845] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:00:53.478,332] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:00:53.495,788] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:00:53.513,275] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:00:53.530,761] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:00:53.548,248] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:00:53.565,704] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:00:53.583,190] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:00:53.600,677] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:00:53.618,133] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:00:53.635,620] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:00:53.653,106] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:00:53.670,593] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:00:53.688,049] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:00:53.705,535] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:00:53.723,022] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:00:53.740,509] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:00:53.757,995] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:00:53.775,451] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:00:53.792,938] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:00:53.810,394] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:00:53.827,880] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:00:53.845,367] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:00:53.862,823] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:00:53.880,310] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:00:53.897,766] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:00:53.915,252] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:00:53.932,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:00:53.950,195] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:00:53.967,681] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:00:53.985,137] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:00:54.002,624] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:00:54.020,080] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:00:54.037,567] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:00:54.055,053] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:00:54.072,509] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:00:54.089,996] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:00:54.107,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:00:54.124,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:00:54.142,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:00:54.159,912] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:00:54.177,398] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:00:54.194,885] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:00:54.212,341] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:00:54.229,827] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:00:54.247,314] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:00:54.264,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:00:54.282,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:00:54.299,743] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:00:54.317,230] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:00:54.334,716] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:00:54.352,203] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:00:54.369,659] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:00:54.387,145] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:00:54.404,632] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:00:54.422,119] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:00:54.439,575] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:00:54.457,061] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:00:54.474,548] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:00:54.492,004] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:00:54.509,490] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:00:54.526,977] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:00:54.544,464] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:00:54.561,920] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:00:54.579,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:00:54.596,862] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:00:54.614,349] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:00:54.631,835] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:00:54.649,291] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:00:54.666,778] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:00:54.684,265] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:00:54.701,751] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:00:54.719,207] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:00:54.736,694] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:00:54.754,150] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:00:54.771,636] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c20:  2e 63 72 6c 30 82 01 04 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:00:54.789,123] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c30:  79 02 04 02 04 81 f5 04 81 f2 00 f0 00 76 00 12  y............v..
    [00:00:54.806,610] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c40:  f1 4e 34 bd 53 72 4c 84 06 19 c3 8f 3f 7a 13 f8  .N4.SrL.....?z..
    [00:00:54.824,096] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c50:  e7 b5 62 87 88 9c 6d 30 05 84 eb e5 86 26 3a 00  ..b...m0.....&:.
    [00:00:54.841,583] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c60:  00 01 96 c3 e0 5c f7 00 00 04 03 00 47 30 45 02  .....\......G0E.
    [00:00:54.859,039] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c70:  20 1c e0 9b 52 a9 80 66 96 5d 3c ac 95 5f 89 00   ...R..f.]<.._..
    [00:00:54.876,525] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c80:  56 ee ff 83 af d8 57 81 cb e1 c4 4d 54 bb 98 49  V.....W....MT..I
    [00:00:54.894,012] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c90:  61 02 21 00 e9 6c 7d ed 74 7d 27 7d 77 1a 50 49  a.!..l}.t}'}w.PI
    [00:00:54.911,499] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ca0:  71 9a be fd 48 96 d2 26 08 d1 cb 0a 61 a9 d8 19  q...H..&....a...
    [00:00:54.928,985] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cb0:  a9 f4 1b 3c 00 76 00 cc fb 0f 6a 85 71 09 65 fe  ...<.v....j.q.e.
    [00:00:54.946,472] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cc0:  95 9b 53 ce e9 b2 7c 22 e9 85 5c 0d 97 8d b6 a9  ..S...|"..\.....
    [00:00:54.963,958] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cd0:  7e 54 c0 fe 4c 0d b0 00 00 01 96 c3 e0 61 73 00  ~T..L........as.
    [00:00:54.981,445] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ce0:  00 04 03 00 47 30 45 02 21 00 a5 49 83 b5 26 2f  ....G0E.!..I..&/
    [00:00:54.998,931] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cf0:  0b db a4 e4 3a eb 5b 00 de 0c 11 33 0d 3a 18 5a  ....:.[....3.:.Z
    [00:00:55.016,418] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d00:  04 d9 d9 3e 3b 09 6e f6 f5 eb 02 20 27 dc ba ac  ...>;.n.... '...
    [00:00:55.033,905] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d10:  81 f1 f9 aa ce d2 ac eb 49 d4 dc 0a 69 8a 27 73  ........I...i.'s
    [00:00:55.051,391] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d20:  92 f0 cd b3 bf 68 08 7b 87 cc 73 19 30 0d 06 09  .....h.{..s.0...
    [00:00:55.068,878] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d30:  2a 86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00  *.H.............
    [00:00:55.086,334] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d40:  26 13 af 72 da b9 21 65 71 d4 c0 0f 3e 95 5f 24  &..r..!eq...>._$
    [00:00:55.103,820] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d50:  ac 98 6f 3b 55 ac 27 0e 1b b5 a1 21 6e 77 ba dc  ..o;U.'....!nw..
    [00:00:55.121,307] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d60:  f6 73 1a 2c e9 93 62 bf 99 6f e1 3c 66 a6 da 60  .s.,..b..o.<f..`
    [00:00:55.138,793] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d70:  97 fd c9 a1 1d 8c 3e ab 60 c1 1f 87 09 ea 9d 33  ......>.`......3
    [00:00:55.156,250] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d80:  54 03 69 39 76 1b db 91 d1 d7 97 1a 36 3a 6c 9f  T.i9v.......6:l.
    [00:00:55.173,736] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d90:  01 dd 47 59 5c 47 ee 6f 12 b3 bb bd 48 da b9 4e  ..GY\G.o....H..N
    [00:00:55.191,223] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0da0:  85 6c 62 54 a1 5e b9 2f 64 21 0b c8 30 24 1f e1  .lbT.^./d!..0$..
    [00:00:55.208,679] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0db0:  b1 8e 0e 9f 5f d8 ed e3 72 e1 27 81 33 7f 68 ef  ...._...r.'.3.h.
    [00:00:55.226,165] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dc0:  6b 81 de cf 5c cd 87 7f 68 b5 af a3 7f 4a 4c 1e  k...\...h....JL.
    [00:00:55.243,652] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dd0:  61 74 a9 7c 35 f9 e0 35 b3 9e 91 b4 86 b1 f4 45  at.|5..5.......E
    [00:00:55.261,108] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0de0:  4f 27 9b 5f 16 49 fe 59 e7 ac bb c3 e7 1e 73 3b  O'._.I.Y......s;
    [00:00:55.278,594] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0df0:  af 92 17 46 15 f7 4e 44 f4 94 a8 30 f5 c1 dd f8  ...F..ND...0....
    [00:00:55.296,081] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e00:  62 29 26 1e a7 7f f6 d2 8c 27 22 10 40 0d ea 21  b)&......'".@..!
    [00:00:55.313,568] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e10:  4b f2 f1 82 2d e3 51 0d 45 a8 df 38 52 56 ba b2  K...-.Q.E..8RV..
    [00:00:55.331,054] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e20:  57 a5 8f 66 c4 08 4f 81 67 08 27 5e 4a 8e 2b 65  W..f..O.g.'^J.+e
    [00:00:55.348,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e30:  90 0a d4 70 e3 34 56 b9 6f 4e 43 4f 3c 5b 89 05  ...p.4V.oNCO<[..
    [00:00:55.366,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e40:  00 05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02  ...0...0........
    [00:00:55.383,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e50:  02 10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10  ......|L.....f..
    [00:00:55.401,000] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e60:  7b 98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05  {.0...*.H.......
    [00:00:55.418,457] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e70:  00 30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53  .0G1.0...U....US
    [00:00:55.435,943] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e80:  31 22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c  1"0 ..U....Googl
    [00:00:55.453,430] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e90:  65 20 54 72 75 73 74 20 53 65 72 76 69 63 65 73  e Trust Services
    [00:00:55.470,886] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ea0:  20 4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47   LLC1.0...U....G
    [00:00:55.488,372] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0eb0:  54 53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33  TS Root R10...23
    [00:00:55.505,859] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ec0:  31 32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30  1213090000Z..290
    [00:00:55.523,315] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ed0:  32 32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09  220140000Z0;1.0.
    [00:00:55.540,802] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ee0:  06 03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55  ..U....US1.0...U
    [00:00:55.558,288] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ef0:  04 0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74  ....Google Trust
    [00:00:55.575,775] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f00:  20 53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55   Services1.0...U
    [00:00:55.593,261] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f10:  04 03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a  ....WR20.."0...*
    [00:00:55.610,748] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f20:  86 48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30  .H.............0
    [00:00:55.628,234] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f30:  82 01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8  ............E.p.
    [00:00:55.645,690] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f40:  53 9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac  S......FWW}...Z.
    [00:00:55.663,177] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f50:  46 f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16  F......../......
    [00:00:55.680,664] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f60:  5e a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59  ^......x/J.....Y
    [00:00:55.698,150] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f70:  3c 0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c  <......$.&..[dv|
    [00:00:55.715,606] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f80:  14 c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35  ../z..L.......#5
    [00:00:55.733,062] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f90:  20 a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9   ..i..N?.Y.`....
    [00:00:55.750,549] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fa0:  20 53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d   S...6Sm`M....v.
    [00:00:55.768,035] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fb0:  5c 08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2  \......sk..n.Oz.
    [00:00:55.785,522] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fc0:  f2 02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab  .....c..1.-u0...
    [00:00:55.802,978] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fd0:  c2 6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05  .n......g..%Wt..
    [00:00:55.820,465] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fe0:  b4 e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61  .....(..z..q..Ma
    [00:00:55.837,951] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ff0:  2e 61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d  .aW........y)...
    [00:00:55.855,194] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 6326, type = 11, hslen = 6326
    [00:00:55.869,232] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 6326, 0..6326 of 6326
    [00:00:55.883,178] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (6331 bytes)
    [00:00:55.897,949] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 18 b6 0b 00 18 b2 00 18 af 00 0e 31 30  ..............10
    [00:00:55.915,435] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  82 0e 2d 30 82 0d 15 a0 03 02 01 02 02 10 66 86  ..-0..........f.
    [00:00:55.932,922] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  f0 7e 70 d7 df c2 09 4c b8 5a 34 d6 e3 d8 30 0d  .~p....L.Z4...0.
    [00:00:55.950,408] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:00:55.967,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:00:55.985,382] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:00:56.002,868] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:00:56.020,355] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:00:56.037,841] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0080:  30 35 31 32 30 38 34 32 35 38 5a 17 0d 32 35 30  0512084258Z..250
    [00:00:56.055,328] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0090:  38 30 34 30 38 34 32 35 37 5a 30 17 31 15 30 13  804084257Z0.1.0.
    [00:00:56.072,814] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:00:56.090,301] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:00:56.107,788] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 0a a6  ..*.H.=....B....
    [00:00:56.125,274] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00d0:  db af e0 06 99 b8 6f 52 89 c4 25 83 94 32 5c 27  ......oR..%..2\'
    [00:00:56.142,730] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00e0:  b9 94 42 1d 87 49 f5 1d c7 c8 2e 2f 3b 23 d2 df  ..B..I...../;#..
    [00:00:56.160,217] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00f0:  e9 8c 33 79 94 86 0e 25 80 b3 ae 8e 72 22 5d ba  ..3y...%....r"].
    [00:00:56.177,673] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0100:  ef ce 7c 6f 30 55 e7 6c 1d 4b 02 70 fa 9d a3 82  ..|o0U.l.K.p....
    [00:00:56.195,159] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0110:  0c 1a 30 82 0c 16 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:00:56.212,646] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:00:56.230,133] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:00:56.247,619] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:00:56.265,106] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0150:  04 16 04 14 ad 60 2e a1 68 d6 19 19 03 fa a3 0e  .....`..h.......
    [00:00:56.282,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0160:  ad d6 24 d8 fa 28 88 3e 30 1f 06 03 55 1d 23 04  ..$..(.>0...U.#.
    [00:00:56.300,048] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:00:56.317,535] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:00:56.335,021] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:00:56.352,508] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:00:56.369,995] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:00:56.387,481] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:00:56.404,968] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:00:56.422,454] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:00:56.439,941] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:00:56.457,397] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:00:56.474,884] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:00:56.492,370] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:00:56.509,826] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:00:56.527,313] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:00:56.544,799] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:00:56.562,286] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:00:56.579,772] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:00:56.597,259] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:00:56.614,715] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:00:56.632,202] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:00:56.649,688] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:00:56.667,175] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:00:56.684,631] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:00:56.702,117] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:00:56.719,573] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:00:56.737,060] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:00:56.754,547] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:00:56.772,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:00:56.789,489] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:00:56.806,945] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:00:56.824,432] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:00:56.841,918] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:00:56.859,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:00:56.876,861] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:00:56.894,348] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:00:56.911,804] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:00:56.929,290] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:00:56.946,777] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:00:56.964,233] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:00:56.981,719] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:00:56.999,206] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:00:57.016,693] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:00:57.034,149] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:00:57.051,635] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:00:57.069,122] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:00:57.086,608] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:00:57.104,095] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:00:57.121,551] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:00:57.139,038] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:00:57.156,524] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:00:57.174,011] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:00:57.191,467] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:00:57.208,953] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:00:57.226,440] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:00:57.243,896] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:00:57.261,383] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:00:57.278,839] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:00:57.296,325] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:00:57.313,812] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:00:57.331,268] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:00:57.348,754] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:00:57.366,241] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:00:57.383,728] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:00:57.401,214] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:00:57.418,670] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:00:57.436,157] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:00:57.453,643] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:00:57.471,099] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:00:57.488,586] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:00:57.506,072] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:00:57.523,559] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:00:57.541,015] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:00:57.558,502] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:00:57.575,988] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:00:57.593,475] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:00:57.610,961] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:00:57.628,417] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:00:57.645,904] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:00:57.663,391] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:00:57.680,847] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:00:57.698,333] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:00:57.715,820] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:00:57.733,306] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:00:57.750,762] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:00:57.768,249] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:00:57.785,736] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:00:57.803,222] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:00:57.820,678] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:00:57.838,165] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:00:57.855,651] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:00:57.873,107] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:00:57.890,594] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:00:57.908,050] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:00:57.925,537] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:00:57.943,023] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:00:57.960,510] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:00:57.977,966] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:00:57.995,452] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:00:58.012,939] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:00:58.030,395] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:00:58.047,882] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:00:58.065,368] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:00:58.082,824] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:00:58.100,311] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:00:58.117,797] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:00:58.135,253] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:00:58.152,740] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:00:58.170,227] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:00:58.188,476] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:00:58.205,932] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:00:58.223,419] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:00:58.240,905] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:00:58.258,361] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:00:58.275,848] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:00:58.293,334] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:00:58.310,791] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:00:58.328,277] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:00:58.345,733] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:00:58.363,220] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:00:58.380,706] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:00:58.398,162] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:00:58.415,649] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:00:58.433,135] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:00:58.450,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:00:58.468,078] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:00:58.485,534] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:00:58.503,021] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:00:58.520,477] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:00:58.537,963] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:00:58.555,419] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:00:58.572,906] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:00:58.590,393] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:00:58.607,849] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:00:58.625,335] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:00:58.642,822] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:00:58.660,308] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:00:58.677,764] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:00:58.695,251] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:00:58.712,707] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:00:58.730,194] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:00:58.747,680] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:00:58.765,167] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:00:58.782,623] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:00:58.800,109] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:00:58.817,596] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:00:58.835,052] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:00:58.852,539] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:00:58.870,025] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:00:58.887,481] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:00:58.904,968] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:00:58.922,424] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:00:58.939,910] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:00:58.957,397] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:00:58.974,884] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:00:58.992,340] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:00:59.009,826] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:00:59.027,282] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:00:59.044,769] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:00:59.062,225] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:00:59.079,711] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:00:59.097,167] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:00:59.114,654] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:00:59.132,110] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:00:59.149,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:00:59.167,053] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:00:59.184,509] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:00:59.201,995] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:00:59.219,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:00:59.236,938] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:00:59.254,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:00:59.271,911] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:00:59.289,367] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c20:  2e 63 72 6c 30 82 01 04 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:00:59.306,854] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c30:  79 02 04 02 04 81 f5 04 81 f2 00 f0 00 76 00 12  y............v..
    [00:00:59.324,340] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c40:  f1 4e 34 bd 53 72 4c 84 06 19 c3 8f 3f 7a 13 f8  .N4.SrL.....?z..
    [00:00:59.341,827] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c50:  e7 b5 62 87 88 9c 6d 30 05 84 eb e5 86 26 3a 00  ..b...m0.....&:.
    [00:00:59.359,283] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c60:  00 01 96 c3 e0 5c f7 00 00 04 03 00 47 30 45 02  .....\......G0E.
    [00:00:59.376,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c70:  20 1c e0 9b 52 a9 80 66 96 5d 3c ac 95 5f 89 00   ...R..f.]<.._..
    [00:00:59.394,226] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c80:  56 ee ff 83 af d8 57 81 cb e1 c4 4d 54 bb 98 49  V.....W....MT..I
    [00:00:59.411,712] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c90:  61 02 21 00 e9 6c 7d ed 74 7d 27 7d 77 1a 50 49  a.!..l}.t}'}w.PI
    [00:00:59.429,199] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ca0:  71 9a be fd 48 96 d2 26 08 d1 cb 0a 61 a9 d8 19  q...H..&....a...
    [00:00:59.446,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cb0:  a9 f4 1b 3c 00 76 00 cc fb 0f 6a 85 71 09 65 fe  ...<.v....j.q.e.
    [00:00:59.464,141] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cc0:  95 9b 53 ce e9 b2 7c 22 e9 85 5c 0d 97 8d b6 a9  ..S...|"..\.....
    [00:00:59.481,628] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cd0:  7e 54 c0 fe 4c 0d b0 00 00 01 96 c3 e0 61 73 00  ~T..L........as.
    [00:00:59.499,114] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ce0:  00 04 03 00 47 30 45 02 21 00 a5 49 83 b5 26 2f  ....G0E.!..I..&/
    [00:00:59.516,601] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cf0:  0b db a4 e4 3a eb 5b 00 de 0c 11 33 0d 3a 18 5a  ....:.[....3.:.Z
    [00:00:59.534,057] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d00:  04 d9 d9 3e 3b 09 6e f6 f5 eb 02 20 27 dc ba ac  ...>;.n.... '...
    [00:00:59.551,544] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d10:  81 f1 f9 aa ce d2 ac eb 49 d4 dc 0a 69 8a 27 73  ........I...i.'s
    [00:00:59.569,030] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d20:  92 f0 cd b3 bf 68 08 7b 87 cc 73 19 30 0d 06 09  .....h.{..s.0...
    [00:00:59.586,517] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d30:  2a 86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00  *.H.............
    [00:00:59.604,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d40:  26 13 af 72 da b9 21 65 71 d4 c0 0f 3e 95 5f 24  &..r..!eq...>._$
    [00:00:59.621,459] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d50:  ac 98 6f 3b 55 ac 27 0e 1b b5 a1 21 6e 77 ba dc  ..o;U.'....!nw..
    [00:00:59.638,946] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d60:  f6 73 1a 2c e9 93 62 bf 99 6f e1 3c 66 a6 da 60  .s.,..b..o.<f..`
    [00:00:59.656,402] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d70:  97 fd c9 a1 1d 8c 3e ab 60 c1 1f 87 09 ea 9d 33  ......>.`......3
    [00:00:59.673,858] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d80:  54 03 69 39 76 1b db 91 d1 d7 97 1a 36 3a 6c 9f  T.i9v.......6:l.
    [00:00:59.691,345] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d90:  01 dd 47 59 5c 47 ee 6f 12 b3 bb bd 48 da b9 4e  ..GY\G.o....H..N
    [00:00:59.708,801] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0da0:  85 6c 62 54 a1 5e b9 2f 64 21 0b c8 30 24 1f e1  .lbT.^./d!..0$..
    [00:00:59.726,287] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0db0:  b1 8e 0e 9f 5f d8 ed e3 72 e1 27 81 33 7f 68 ef  ...._...r.'.3.h.
    [00:00:59.743,774] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dc0:  6b 81 de cf 5c cd 87 7f 68 b5 af a3 7f 4a 4c 1e  k...\...h....JL.
    [00:00:59.761,230] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dd0:  61 74 a9 7c 35 f9 e0 35 b3 9e 91 b4 86 b1 f4 45  at.|5..5.......E
    [00:00:59.778,717] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0de0:  4f 27 9b 5f 16 49 fe 59 e7 ac bb c3 e7 1e 73 3b  O'._.I.Y......s;
    [00:00:59.796,203] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0df0:  af 92 17 46 15 f7 4e 44 f4 94 a8 30 f5 c1 dd f8  ...F..ND...0....
    [00:00:59.813,659] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e00:  62 29 26 1e a7 7f f6 d2 8c 27 22 10 40 0d ea 21  b)&......'".@..!
    [00:00:59.831,146] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e10:  4b f2 f1 82 2d e3 51 0d 45 a8 df 38 52 56 ba b2  K...-.Q.E..8RV..
    [00:00:59.848,602] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e20:  57 a5 8f 66 c4 08 4f 81 67 08 27 5e 4a 8e 2b 65  W..f..O.g.'^J.+e
    [00:00:59.866,088] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e30:  90 0a d4 70 e3 34 56 b9 6f 4e 43 4f 3c 5b 89 05  ...p.4V.oNCO<[..
    [00:00:59.883,575] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e40:  00 05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02  ...0...0........
    [00:00:59.901,062] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e50:  02 10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10  ......|L.....f..
    [00:00:59.918,548] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e60:  7b 98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05  {.0...*.H.......
    [00:00:59.936,035] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e70:  00 30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53  .0G1.0...U....US
    [00:00:59.953,491] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e80:  31 22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c  1"0 ..U....Googl
    [00:00:59.970,977] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e90:  65 20 54 72 75 73 74 20 53 65 72 76 69 63 65 73  e Trust Services
    [00:00:59.988,464] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ea0:  20 4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47   LLC1.0...U....G
    [00:01:00.005,920] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0eb0:  54 53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33  TS Root R10...23
    [00:01:00.023,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ec0:  31 32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30  1213090000Z..290
    [00:01:00.040,893] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ed0:  32 32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09  220140000Z0;1.0.
    [00:01:00.058,380] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ee0:  06 03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55  ..U....US1.0...U
    [00:01:00.075,836] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ef0:  04 0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74  ....Google Trust
    [00:01:00.093,322] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f00:  20 53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55   Services1.0...U
    [00:01:00.110,809] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f10:  04 03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a  ....WR20.."0...*
    [00:01:00.128,295] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f20:  86 48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30  .H.............0
    [00:01:00.145,782] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f30:  82 01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8  ............E.p.
    [00:01:00.163,269] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f40:  53 9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac  S......FWW}...Z.
    [00:01:00.180,725] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f50:  46 f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16  F......../......
    [00:01:00.198,211] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f60:  5e a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59  ^......x/J.....Y
    [00:01:00.215,698] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f70:  3c 0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c  <......$.&..[dv|
    [00:01:00.233,184] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f80:  14 c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35  ../z..L.......#5
    [00:01:00.250,671] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f90:  20 a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9   ..i..N?.Y.`....
    [00:01:00.268,127] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fa0:  20 53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d   S...6Sm`M....v.
    [00:01:00.285,614] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fb0:  5c 08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2  \......sk..n.Oz.
    [00:01:00.303,100] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fc0:  f2 02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab  .....c..1.-u0...
    [00:01:00.320,587] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fd0:  c2 6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05  .n......g..%Wt..
    [00:01:00.338,073] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fe0:  b4 e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61  .....(..z..q..Ma
    [00:01:00.355,529] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ff0:  2e 61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d  .aW........y)...
    [00:01:00.377,960] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:01:00.396,209] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9961: Use configuration-specific verification callback
    Dead here...56.
    [00:01:00.526,184] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10020: x509_verify_cert() returned -9984 (-0x2700)
    [00:01:00.539,306] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5294: => send alert message
    [00:01:00.550,445] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5295: send alert level=2 message=48
    [00:01:00.561,950] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:00.572,631] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 21, version = [3:3], msglen = 2
    [00:01:00.586,547] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (7 bytes)
    [00:01:00.601,928] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  15 03 03 00 02 02 30                             ......0
    [00:01:00.618,347] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:00.628,967] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 7, out_left: 7
    [00:01:00.641,387] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 7 (-0xfffffff9)
    [00:01:00.653,930] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:00.664,520] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:00.675,109] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5306: <= send alert message
    [00:01:00.686,279] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10120: ! Certificate verification flags 00000008
    [00:01:00.702,270] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:01:00.712,524] <err> net_sock_tls: TLS handshake error: -0x2700
      File "<stdin>", line 1, in <module>
      File "sock_test.py", line 43, in step_1
    OSError: [Errno 113] ECONNABORTED
    >>> [00:01:01.275,848] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000aba8, pkt=(nil), st=-104, user_data=(nil)
    [00:01:01.286,865] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Set EOF flag on pkt 0x2005ebc0
    [00:01:19.799,133] <dbg> net_sock: zsock_received_cb: (tcp_work): ctx=0x2000aba8, pkt=(nil), st=-116, user_data=(nil)
    [00:01:19.810,211] <dbg> net_sock: zsock_received_cb: (tcp_work): Set EOF flag on pkt 0x2005ebc0
  • A call will not help, as I need to be able to recreate the scenario on my end. The issue is that it works in a contained sample, ie. https_client, but not in your sample. To be able to pinpoint this, I will need to run both scenarios, and then start trickling down to how they two differ.
    Well, we can do that in a call. It will be infinitely faster since I have everything already set up and can share my screen.
    It's been 13 days since I started this ticket. Even if it's a 5H call, it could still be done in a single day, not 13...
    Integrating a unsupported device into a project is not done in a day.
    Micropython is a platform that Nordic do not actively use for development. You are ofcourse free to make your decisions towards what you want to integrate into your own product, but please be aware that micropython is not a officially supported platform from us.
    The official recommendation from our side is to use nRF Connect SDK with our devices, and you have this working via a modified https_client sample towards your wanted domain.
    I will try to help you to ensure that your desired behavior is running in micropython, but to be able to do that, I must be able to compile and recreate the scenario at my end.
    This is a awfully complex process when I get sent one file after the other, when you could give me a .patch or .diff file to implement your local changes directly into the micropy tree.
    I am still seeing compilation issues and I'm quite certain that I have not placed your files into the correct folder/path, or performed something incorrectly.
    Can you please provide patches/diff files for your changes into the micropy repo?
    And please also share the hash that you've based your changes upon.
    You are currently using in-place logging, via this config:
    CONFIG_LOG_MODE_IMMEDIATE=y
    I understand why you choose this, but please be aware what this actually means. This means that the log entry occurs in the same context as the log message originated, and if this is logging large message quantities in a high priority thread/irq, it will block until the message is flushed.
    Be very aware that this will, due to its blocking behavior, cause timing related errors to emerge, like this hostname verification error:
    Try running without mbedtls debug logs, or adjust the log level:
    CONFIG_MBEDTLS_LOG_LEVEL_ERR=y
    CONFIG_MBEDTLS_DEBUG_C=y
    CONFIG_MBEDTLS_DEBUG_LEVEL=1
    Håkon
