Enabling the TLS layer to get a HTTPS connection going.
7343.nrf7002dk_nrf5340_cpuapp_ns.conf3124.prj.confHello everyone.
WE're trying to make a https connection with google.com and execute a GET request.
Wifi connection is working; DHCP seems to be working (my personal assumption given the log message we get: "Resolved: [(1, 1, 6, '', ('142.250.201.206', 443))]" which indicates that getaddrinfo() works); but when trying to initiate the socket via TLS, something strange happens: we get the error "OSError: 109".
Inserting some debug prints inside subsys/net/lib/sockets/, we found the culprit to be the function "int zsock_setsockopt_ctx(struct net_context *ctx, int level, int optname, const void *optval, socklen_t optlen)".
The function call that triggers error 109 is:  res = setsockopt(socket->ctx, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
No matter what other option we try to set via setsockopt(), it will fail with the 109 error since the implementation for setsockopt() is somehow set to sockets_inet.c (whose implementation does not recognise SOL_TLS as a valid in its switches) instead of sockets_tls.c (which has handling for SOL_TLS in its switches). My personal hunch is that the config options set in the project are somehow wrong. Can someone please take a look over our .conf files? Maybe we can find the culprit. :)
We can provide any extra code snippets that are necessary for debugging and/ or run any tests. Have a great day and hope to hear from you soon!
  • Another breakthrough Håkon!
    By increasing
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=30000
    The TLS handshake gets even further (possibly to the final step):
    >>> print("Connecting to:", result[0][-1])
    Connecting to: ('142.251.39.78', 443)
    >>> s.connect(result[0][-1])
    Dead here...5. DNS message size: 44
    DNS message content (hex):44 05 81 80 00 01 00 01 00 00 00 00 06 67 6f 6f 67 6c 65 03 63 6f 6d 00 00 01 00 01 c0 0c 00 01 00 01 00 00 00 c6 00 04 8e fb 27 4e
    Dead here...6
    Dead here...7
    Dead here...60. tls->options.sec_tag_list.sec_tag_count: 1
    Dead here...61. tag: 16842753
    Dead here...63. Nr of credentials: 4
    counting... 0; cred type: 1; cred tag: 16842753
    Dead here...64. Found cred: 0
    Dead here...62. Counting: 0
    Dead here...65. Adding CA certificate
    Dead here...66. Parsing CA certificate
    Dead here...69
    Dead here...66.5. Parsing CA certificate done. err: 0
    Credentials set: 0
    counting... 1; cred type: 0; cred tag: 0
    counting... 2; cred type: 0; cred tag: 0
    counting... 3; cred type: 0; cred tag: 0
    [00:01:01.644,531] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:01:01.663,360] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:01.673,645] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:01.684,234] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:01.694,824] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:01:01.707,489] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:01.718,078] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:01.728,668] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:01:01.741,241] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0921: => write client hello
    [00:01:01.753,051] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: dumping 'client hello, random bytes' (32 bytes)
    [00:01:01.766,662] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0000:  06 c2 7f 68 36 b0 41 1d 08 ab fd e8 9b e0 f8 cf  ...h6.A.........
    [00:01:01.782,470] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0010:  cc 1d c8 2b 4f 03 0f 81 f3 d0 60 67 45 c5 b8 88  ...+O.....`gE...
    [00:01:01.798,034] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0512: dumping 'session id' (0 bytes)
    [00:01:01.809,967] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:01.825,927] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:01:01.841,674] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:01.857,360] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:01:01.872,863] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:01.888,793] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:01:01.904,571] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:01.920,227] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:01:01.935,760] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:01:01.950,988] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:01:01.965,972] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:01:01.981,628] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:01:01.997,070] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:01:02.012,908] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:01:02.028,503] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:01:02.043,731] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:01:02.058,715] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:01:02.074,401] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:01:02.089,813] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:01:02.105,651] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:02.121,246] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0388: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:01:02.133,636] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0397: client hello, got 21 cipher suites
    [00:01:02.145,904] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0041: client hello, adding server name extension: google.com
    [00:01:02.159,881] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0231: client hello, adding supported_groups extension
    [00:01:02.173,278] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(001d)
    [00:01:02.184,753] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: x25519 ( 1d )
    [00:01:02.196,197] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(0017)
    [00:01:02.207,672] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: secp256r1 ( 17 )
    [00:01:02.219,390] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: dumping 'Supported groups extension' (6 bytes)
    [00:01:02.232,818] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: 0000:  00 04 00 1d 00 17                                ......
    [00:01:02.247,497] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9505: adding signature_algorithms extension
    [00:01:02.259,765] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:02.273,071] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [603] ecdsa_secp521r1_sha512
    [00:01:02.286,437] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [601] rsa_pkcs1_sha512
    [00:01:02.299,224] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [601] rsa_pkcs1_sha512
    [00:01:02.312,072] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:02.325,347] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [503] ecdsa_secp384r1_sha384
    [00:01:02.338,714] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [501] rsa_pkcs1_sha384
    [00:01:02.351,501] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [501] rsa_pkcs1_sha384
    [00:01:02.364,349] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:02.377,655] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [403] ecdsa_secp256r1_sha256
    [00:01:02.391,021] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [401] rsa_pkcs1_sha256
    [00:01:02.403,778] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [401] rsa_pkcs1_sha256
    [00:01:02.416,625] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0105: client hello, adding supported_point_formats extension
    [00:01:02.431,121] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    [00:01:02.444,671] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0165: generating new ecjpake parameters
    [00:01:02.553,344] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0338: client hello, adding extended_master_secret extension
    [00:01:02.567,749] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0372: client hello, adding session ticket extension
    [00:01:02.581,481] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0689: client hello, total extension length: 395
    [00:01:02.594,360] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: dumping 'client hello extensions' (395 bytes)
    [00:01:02.607,818] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0000:  01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f 67 6c  ...........googl
    [00:01:02.623,626] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0010:  65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00 17 00  e.com...........
    [00:01:02.639,434] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0020:  0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 03 04  ................
    [00:01:02.655,242] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0030:  01 00 0b 00 02 01 00 01 00 01 4a 41 04 60 db fd  ..........JA.`..
    [00:01:02.671,051] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0040:  7d 6d 39 33 49 24 ed f8 6f ed 1d 62 8e 56 9b c6  }m93I$..o..b.V..
    [00:01:02.686,859] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0050:  f7 8e 72 6c ac 9a 0e cd a6 17 b7 5d 7b bf a2 7f  ..rl.......]{...
    [00:01:02.702,636] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0060:  3e 08 71 87 f1 c7 80 7a 38 78 68 cb 1f 7c d0 0f  >.q....z8xh..|..
    [00:01:02.718,444] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0070:  c5 96 2a bd 0b 14 b8 d7 cd df c0 93 44 41 04 e4  ..*.........DA..
    [00:01:02.734,252] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0080:  a0 1c 73 61 82 aa ec 9d ed 30 24 2e 67 5e ca 8a  ..sa.....0$.g^..
    [00:01:02.750,061] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0090:  2b 2b 35 c5 19 9c c7 64 88 93 b2 b4 c4 4b b2 59  ++5....d.....K.Y
    [00:01:02.765,838] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00a0:  6a 66 6a 8c fd 34 e5 dd 42 dd a3 62 b6 4a c9 9a  jfj..4..B..b.J..
    [00:01:02.781,646] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00b0:  96 fe ba 0a 3b 64 d1 4c dc fe bf 94 03 d0 a5 20  ....;d.L.......
    [00:01:02.797,424] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00c0:  e9 6f 97 c2 3b 6b 50 81 d9 14 c0 13 f1 ec dc fc  .o..;kP.........
    [00:01:02.813,232] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00d0:  87 8f 04 07 32 87 78 bf 80 e5 5c 23 a9 9b 9b 3f  ....2.x...\#...?
    [00:01:02.829,040] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00e0:  41 04 8a c0 3f 2d ac 20 d6 6e 03 4b 40 45 97 1f  A...?-. .n.K@E..
    [00:01:02.844,848] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00f0:  27 62 f9 6c f4 05 85 e1 f8 fc 34 a9 1a c5 77 b7  'b.l......4...w.
    [00:01:02.860,656] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0100:  85 7d e7 da 49 81 14 8f a5 92 5a b4 f3 35 2a 80  .}..I.....Z..5*.
    [00:01:02.876,464] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0110:  7a 79 51 86 60 a1 3f eb 96 3b 1e 09 80 85 0c 85  zyQ.`.?..;......
    [00:01:02.892,242] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0120:  1c 75 41 04 7f d5 17 f8 73 cd 0c c2 ec ac 66 f7  .uA.....s.....f.
    [00:01:02.908,050] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0130:  9b 8d d2 48 a6 32 42 06 87 74 42 6f 5a b9 96 9a  ...H.2B..tBoZ...
    [00:01:02.923,828] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0140:  b3 68 16 af b6 7b 52 40 e7 aa 32 a0 41 73 58 e0  .h...{[email protected].
    [00:01:02.939,636] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0150:  9f 10 89 0b 22 18 6f 9f 03 4c fb 37 1d c8 da a5  ....".o..L.7....
    [00:01:02.955,444] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0160:  3d b7 2e b0 20 c8 a9 b9 34 cd 13 e0 ab 17 25 67  =... ...4.....%g
    [00:01:02.971,221] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0170:  88 2c 8f 7e 71 2f bc 16 b5 a2 ac d8 f2 3f 48 e6  .,.~q/.......?H.
    [00:01:02.986,968] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0180:  88 92 37 32 29 00 17 00 00 00 23                 ..72).....#
    [00:01:03.003,295] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:01:03.014,801] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:03.025,451] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 482
    [00:01:03.039,550] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (487 bytes)
    [00:01:03.055,206] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 01 e2 01 00 01 de 03 03 06 c2 7f 68 36  ..............h6
    [00:01:03.072,662] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  b0 41 1d 08 ab fd e8 9b e0 f8 cf cc 1d c8 2b 4f  .A............+O
    [00:01:03.090,118] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  03 0f 81 f3 d0 60 67 45 c5 b8 88 00 00 2a c0 24  .....`gE.....*.$
    [00:01:03.107,604] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  c0 28 c0 0a c0 14 c0 23 c0 27 c0 09 c0 13 00 3d  .(.....#.'.....=
    [00:01:03.125,061] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  00 35 c0 2a c0 0f c0 26 c0 05 00 3c 00 2f c0 29  .5.*...&...<./.)
    [00:01:03.142,517] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0050:  c0 0e c0 25 c0 04 00 ff 01 00 01 8b 00 00 00 0f  ...%............
    [00:01:03.160,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0060:  00 0d 00 00 0a 67 6f 6f 67 6c 65 2e 63 6f 6d 00  .....google.com.
    [00:01:03.177,459] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0070:  0a 00 06 00 04 00 1d 00 17 00 0d 00 0e 00 0c 06  ................
    [00:01:03.194,946] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0080:  03 06 01 05 03 05 01 04 03 04 01 00 0b 00 02 01  ................
    [00:01:03.212,402] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0090:  00 01 00 01 4a 41 04 60 db fd 7d 6d 39 33 49 24  ....JA.`..}m93I$
    [00:01:03.229,858] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00a0:  ed f8 6f ed 1d 62 8e 56 9b c6 f7 8e 72 6c ac 9a  ..o..b.V....rl..
    [00:01:03.247,344] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00b0:  0e cd a6 17 b7 5d 7b bf a2 7f 3e 08 71 87 f1 c7  .....]{...>.q...
    [00:01:03.264,801] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00c0:  80 7a 38 78 68 cb 1f 7c d0 0f c5 96 2a bd 0b 14  .z8xh..|....*...
    [00:01:03.282,287] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00d0:  b8 d7 cd df c0 93 44 41 04 e4 a0 1c 73 61 82 aa  ......DA....sa..
    [00:01:03.299,743] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00e0:  ec 9d ed 30 24 2e 67 5e ca 8a 2b 2b 35 c5 19 9c  ...0$.g^..++5...
    [00:01:03.317,199] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00f0:  c7 64 88 93 b2 b4 c4 4b b2 59 6a 66 6a 8c fd 34  .d.....K.Yjfj..4
    [00:01:03.334,686] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0100:  e5 dd 42 dd a3 62 b6 4a c9 9a 96 fe ba 0a 3b 64  ..B..b.J......;d
    [00:01:03.352,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0110:  d1 4c dc fe bf 94 03 d0 a5 20 e9 6f 97 c2 3b 6b  .L....... .o..;k
    [00:01:03.369,598] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0120:  50 81 d9 14 c0 13 f1 ec dc fc 87 8f 04 07 32 87  P.............2.
    [00:01:03.387,054] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0130:  78 bf 80 e5 5c 23 a9 9b 9b 3f 41 04 8a c0 3f 2d  x...\#...?A...?-
    [00:01:03.404,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0140:  ac 20 d6 6e 03 4b 40 45 97 1f 27 62 f9 6c f4 05  . .n.K@E..'b.l..
    [00:01:03.421,997] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0150:  85 e1 f8 fc 34 a9 1a c5 77 b7 85 7d e7 da 49 81  ....4...w..}..I.
    [00:01:03.439,453] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0160:  14 8f a5 92 5a b4 f3 35 2a 80 7a 79 51 86 60 a1  ....Z..5*.zyQ.`.
    [00:01:03.456,909] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0170:  3f eb 96 3b 1e 09 80 85 0c 85 1c 75 41 04 7f d5  ?..;.......uA...
    [00:01:03.474,365] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0180:  17 f8 73 cd 0c c2 ec ac 66 f7 9b 8d d2 48 a6 32  ..s.....f....H.2
    [00:01:03.491,821] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0190:  42 06 87 74 42 6f 5a b9 96 9a b3 68 16 af b6 7b  B..tBoZ....h...{
    [00:01:03.509,277] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01a0:  52 40 e7 aa 32 a0 41 73 58 e0 9f 10 89 0b 22 18  [email protected].....".
    [00:01:03.526,763] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01b0:  6f 9f 03 4c fb 37 1d c8 da a5 3d b7 2e b0 20 c8  o..L.7....=... .
    [00:01:03.544,219] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01c0:  a9 b9 34 cd 13 e0 ab 17 25 67 88 2c 8f 7e 71 2f  ..4.....%g.,.~q/
    [00:01:03.561,676] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01d0:  bc 16 b5 a2 ac d8 f2 3f 48 e6 88 92 37 32 29 00  .......?H...72).
    [00:01:03.579,040] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01e0:  17 00 00 00 23 00 00                             ....#..
    [00:01:03.595,458] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:03.606,048] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:01:03.617,584] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:1014: <= write client hello
    [00:01:03.628,936] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:03.639,556] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 487, out_left: 487
    [00:01:03.652,496] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 487 (-0xfffffe19)
    [00:01:03.665,222] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:03.675,842] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:03.688,385] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:03.700,286] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:03.710,784] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:03.721,282] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:03.732,513] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:03.743,652] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:03.802,368] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:03.813,964] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:03.824,279] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:03.834,838] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:03.845,458] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:01:03.858,032] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:01:03.869,934] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:03.880,432] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:03.890,930] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:03.902,160] 01:03.905,853] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0e0, st=0, user_data=(nil)
    [1;33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:03.926,849] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:03.940,277] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:03.950,805] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:03.965,270] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 3f                                   ....?
    [00:01:03.981,567] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 63
    [00:01:03.995,605] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:04.006,469] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 68
    [00:01:04.017,791] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 68
    [00:01:04.029,083] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 63 (-0xffffffc1)
    [00:01:04.042,602] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:04.053,131] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (68 bytes)
    [00:01:04.068,328] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 38 16 91 21  ....?...;..h8..!
    [00:01:04.085,784] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  5c 3a 35 6f 1a 00 c1 3e b8 a1 74 8a 48 b4 a7 69  \:5o...>..t.H..i
    [00:01:04.103,271] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  ea 51 46 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  .QFDOWNGRD......
    [00:01:04.120,727] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:01:04.138,092] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  00 23 00 00                                      .#..
    [00:01:04.154,266] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 63, type = 2, hslen = 63
    [00:01:04.167,846] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 63, 0..63 of 63
    [00:01:04.180,389] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (68 bytes)
    [00:01:04.194,976] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 38 16 91 21  ....?...;..h8..!
    [00:01:04.213,073] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  5c 3a 35 6f 1a 00 c1 3e b8 a1 74 8a 48 b4 a7 69  \:5o...>..t.H..i
    [00:01:04.230,651] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  ea 51 46 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  .QFDOWNGRD......
    [00:01:04.248,138] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:01:04.265,472] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  00 23 00 00                                      .#..
    [00:01:04.281,951] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:01:04.292,449] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: dumping 'server hello, version' (2 bytes)
    [00:01:04.305,938] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: 0000:  03 03                                            ..
    [00:01:04.320,800] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1291: server hello, current time: 1748506257
    [00:01:04.333,923] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: dumping 'server hello, random bytes' (32 bytes)
    [00:01:04.348,083] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0000:  68 38 16 91 21 5c 3a 35 6f 1a 00 c1 3e b8 a1 74  h8..!\:5o...>..t
    [00:01:04.364,410] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0010:  8a 48 b4 a7 69 ea 51 46 44 4f 57 4e 47 52 44 01  .H..i.QFDOWNGRD.
    [00:01:04.380,462] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1363: server hello, session id len.: 0
    [00:01:04.393,096] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1364: dumping 'server hello, session id' (0 bytes)
    [00:01:04.406,738] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1388: no session has been resumed
    [00:01:04.418,884] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1391: server hello, chosen ciphersuite: c009
    [00:01:04.432,006] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1392: server hello, compress alg.: 0
    [00:01:04.444,458] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1427: server hello, chosen ciphersuite: TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:01:04.460,357] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1448: server hello, total extension length: 19
    [00:01:04.473,907] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1518: found extended_master_secret extension
    [00:01:04.487,030] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1466: found renegotiation extension
    [00:01:04.499,359] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1545: found supported_point_formats extension
    [00:01:04.512,573] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0844: point format selected: 0
    [00:01:04.526,367] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1531: found session_ticket extension
    [00:01:04.538,787] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1662: <= parse server hello
    [00:01:04.550,689] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:04.561,248] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:04.571,868] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:04.584,960] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:01:04.595,977] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:04.606,475] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:04.616,973] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:01:04.628,204] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:01:04.639,434] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:01:04.652,862] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:04.663,391] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:04.677,856] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:01:04.694,152] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:01:04.708,343] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:04.718,872] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 6330
    [00:01:04.730,895] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 6330
    [00:01:04.743,103] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1291 (-0xfffffaf5)
    [00:01:04.756,835] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6330
    [00:01:04.768,524] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:04.811,950] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0e0, st=0, user_data=(nil)
    [00:01:04.823,486] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:04.833,801] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:04.844,360] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:04.854,980] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:04.868,072] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:01:04.879,089] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:04.889,587] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:04.900,085] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 5
    [00:01:04.911,529] <wr[00:01:04.916,076] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:04.935,577] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:04.950,042] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:01:04.966,339] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:01:04.980,560] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:04.991,088] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 6330
    [00:01:05.003,387] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6330
    [00:01:05.015,136] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:01:05.028,869] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6330
    [00:01:05.040,557] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:05.080,383] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:05.091,979] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:05.102,264] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:05.112,854] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:05.123,443] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:05.136,535] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:01:05.147,552] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:05.158,050] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:05.168,579] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 5
    [00:01:05.179,992] 00:01:05.183,959] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0e0, st=0, user_data=(nil)
    33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:05.204,010] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:05.218,475] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:01:05.234,771] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:01:05.248,992] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:05.259,490] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 6330
    [00:01:05.271,820] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6330
    [00:01:05.283,569] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:01:05.297,302] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6330
    [00:01:05.308,990] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:05.354,919] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0e0, st=0, user_data=(nil)
    [00:01:05.366,455] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:05.376,770] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:05.387,329] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:05.397,949] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:05.411,041] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:01:05.422,058] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:05.432,556] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:05.443,084] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 5
    [00:01:05.454,498] 00:01:05.458,496] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:05.478,546] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:05.493,011] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:01:05.509,307] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:01:05.523,498] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:05.534,027] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 6330
    [00:01:05.546,356] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6330
    [00:01:05.558,105] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:01:05.571,838] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6330
    [00:01:05.583,526] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:05.631,500] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0a0, st=0, user_data=(nil)
    [00:01:05.643,035] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:01:05.653,350] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:05.663,909] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:01:05.674,530] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:01:05.687,622] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:01:05.698,638] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:01:05.709,136] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:05.719,665] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 5
    [00:01:05.731,109] 00:01:05.735,015] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=0x2005f0e0, st=0, user_data=(nil)
    [00:01:05.755,065] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:01:05.769,531] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:01:05.785,797] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:01:05.800,018] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:01:05.810,546] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 6330
    [00:01:05.822,784] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6330
    [00:01:05.834,503] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 942 (-0xfffffc52)
    [00:01:05.848,114] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:01:05.858,642] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (6330 bytes)
    [00:01:05.873,992] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 18 b5 0b 00 18 b1 00 18 ae 00 0e 30 30  ..............00
    [00:01:05.891,479] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  82 0e 2c 30 82 0d 14 a0 03 02 01 02 02 10 19 33  ..,0...........3
    [00:01:05.908,935] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  d8 04 bd 0a 9c 28 09 9b 33 bd ff fd 96 50 30 0d  .....(..3....P0.
    [00:01:05.926,391] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:01:05.943,847] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:01:05.961,334] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:01:05.978,790] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:01:05.996,246] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:01:06.013,702] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0080:  30 34 32 39 31 39 32 38 31 30 5a 17 0d 32 35 30  0429192810Z..250
    [00:01:06.031,188] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0090:  37 32 32 31 39 32 38 30 39 5a 30 17 31 15 30 13  722192809Z0.1.0.
    [00:01:06.048,645] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:01:06.066,101] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:01:06.083,587] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 1b fc  ..*.H.=....B....
    [00:01:06.101,043] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00d0:  46 ef d3 74 0b ab 12 d6 bc 2c da 45 2b 23 41 c6  F..t.....,.E+#A.
    [00:01:06.118,530] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00e0:  d1 5e 48 d1 39 48 ac ec b3 ec e5 22 1a 31 04 60  .^H.9H.....".1.`
    [00:01:06.135,986] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00f0:  d7 8b da 5b 08 18 b7 9b c6 df 6d 77 85 f2 f0 25  ...[......mw...%
    [00:01:06.153,442] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0100:  66 99 38 84 e9 a1 aa e2 d9 3c 43 7d ff f6 a3 82  f.8......<C}....
    [00:01:06.170,928] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0110:  0c 19 30 82 0c 15 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:01:06.188,385] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:01:06.205,871] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:01:06.223,327] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:01:06.240,814] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0150:  04 16 04 14 4c d1 c7 d3 76 9e a8 18 19 37 fd 21  ....L...v....7.!
    [00:01:06.258,270] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0160:  81 15 93 58 f9 f5 5b e2 30 1f 06 03 55 1d 23 04  ...X..[.0...U.#.
    [00:01:06.275,726] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:01:06.293,212] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:01:06.310,668] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:01:06.328,125] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:01:06.345,611] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:01:06.363,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:01:06.381,286] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:01:06.398,742] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:01:06.416,198] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:01:06.433,685] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:01:06.451,141] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:01:06.468,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:01:06.486,083] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:01:06.503,540] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:01:06.521,026] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:01:06.538,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:01:06.555,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:01:06.573,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:01:06.590,881] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:01:06.608,367] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:01:06.625,823] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:01:06.643,280] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:01:06.660,736] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:01:06.678,222] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:01:06.695,678] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:01:06.713,165] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:01:06.730,621] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:01:06.748,077] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:01:06.765,533] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:01:06.783,020] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:01:06.800,476] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:01:06.817,932] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:01:06.835,388] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:01:06.852,874] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:01:06.870,330] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:01:06.887,786] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:01:06.905,273] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:01:06.922,729] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:01:06.940,185] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:01:06.957,641] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:01:06.975,128] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:01:06.992,584] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:01:07.010,040] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:01:07.027,496] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:07.044,952] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:01:07.062,438] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:01:07.079,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:01:07.097,351] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:01:07.114,837] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:01:07.132,293] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:01:07.149,749] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:01:07.167,236] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:01:07.184,692] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:01:07.202,148] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:01:07.219,635] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:01:07.237,091] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:01:07.254,547] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:01:07.272,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:01:07.289,459] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:01:07.306,945] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:01:07.324,401] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:01:07.341,857] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:01:07.359,344] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:01:07.376,800] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:01:07.394,287] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:01:07.411,743] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:01:07.429,199] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:01:07.446,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:01:07.464,141] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:07.481,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:01:07.499,725] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:01:07.517,211] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:01:07.534,667] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:01:07.552,154] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:01:07.569,610] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:01:07.587,066] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:01:07.604,553] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:01:07.622,009] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:01:07.639,465] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:01:07.656,951] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:01:07.674,407] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:01:07.691,864] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:01:07.709,350] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:01:07.726,806] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:01:07.744,262] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:01:07.761,749] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:01:07.779,205] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:01:07.796,661] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:01:07.814,147] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:01:07.831,634] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:01:07.849,090] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:01:07.866,577] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:01:07.884,033] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:01:07.901,519] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:01:07.918,975] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:01:07.936,462] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:01:07.953,918] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:01:07.971,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:01:07.988,861] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:01:08.006,317] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:01:08.023,803] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:01:08.041,259] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:01:08.058,746] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:01:08.076,232] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:01:08.093,688] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:01:08.111,145] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:01:08.128,631] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:01:08.146,118] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:01:08.163,574] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:01:08.181,060] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:01:08.198,516] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:01:08.216,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:01:08.233,459] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:01:08.250,946] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:01:08.268,402] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:01:08.285,858] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:01:08.303,344] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:01:08.320,800] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:01:08.338,256] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:01:08.355,712] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:01:08.373,168] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:01:08.390,625] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:01:08.408,111] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:01:08.425,567] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:01:08.443,023] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:01:08.460,510] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:01:08.477,966] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:01:08.495,452] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:01:08.512,908] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:01:08.530,395] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:01:08.547,851] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:01:08.565,307] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:01:08.582,794] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:01:08.600,250] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:01:08.617,706] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:01:08.635,192] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:01:08.652,648] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:01:08.670,104] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:01:08.687,591] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:01:08.705,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:01:08.722,503] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:01:08.739,990] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:01:08.757,446] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:01:08.774,932] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:01:08.792,388] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:01:08.809,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:01:08.827,331] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:01:08.844,787] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:01:08.862,274] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:01:08.879,730] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:01:08.897,216] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:01:08.914,672] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:01:08.932,128] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:01:08.949,584] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:01:08.967,071] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:01:08.984,527] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:01:09.001,983] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:01:09.019,439] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:01:09.036,926] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:01:09.054,382] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:01:09.071,868] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:01:09.089,324] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:01:09.106,811] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:01:09.124,267] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:01:09.141,723] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:01:09.159,210] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:01:09.176,666] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:01:09.194,122] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:01:09.211,578] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:01:09.229,064] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:01:09.246,520] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:01:09.263,977] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c20:  2e 63 72 6c 30 82 01 03 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:01:09.281,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c30:  79 02 04 02 04 81 f4 04 81 f1 00 ef 00 76 00 cc  y............v..
    [00:01:09.298,919] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c40:  fb 0f 6a 85 71 09 65 fe 95 9b 53 ce e9 b2 7c 22  ..j.q.e...S...|"
    [00:01:09.316,375] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c50:  e9 85 5c 0d 97 8d b6 a9 7e 54 c0 fe 4c 0d b0 00  ..\.....~T..L...
    [00:01:09.333,862] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c60:  00 01 96 83 3c 65 27 00 00 04 03 00 47 30 45 02  ....<e'.....G0E.
    [00:01:09.351,318] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c70:  21 00 d6 2d e1 f2 b0 cc ea 06 f7 14 01 27 9d aa  !..-.........'..
    [00:01:09.368,774] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c80:  48 e6 86 7c fc 47 3a 9e 88 84 98 7f 33 3f 18 b2  H..|.G:.....3?..
    [00:01:09.386,260] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c90:  8f 07 02 20 5a 71 48 4a b5 c9 61 8a 16 67 ae 0d  ... ZqHJ..a..g..
    [00:01:09.403,717] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ca0:  eb f1 84 b8 82 50 0f 79 1c 17 8b d1 22 21 08 f6  .....P.y...."!..
    [00:01:09.421,203] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cb0:  45 40 ee 83 00 75 00 12 f1 4e 34 bd 53 72 4c 84  [email protected].
    [00:01:09.438,659] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cc0:  06 19 c3 8f 3f 7a 13 f8 e7 b5 62 87 88 9c 6d 30  ....?z....b...m0
    [00:01:09.456,115] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cd0:  05 84 eb e5 86 26 3a 00 00 01 96 83 3c 64 de 00  .....&:.....<d..
    [00:01:09.473,602] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ce0:  00 04 03 00 46 30 44 02 20 2d a6 02 00 0f 03 96  ....F0D. -......
    [00:01:09.491,058] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cf0:  96 0a 2f 15 b1 24 b2 08 cf 1a de 07 a6 3a bc af  ../..$.......:..
    [00:01:09.508,514] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d00:  9c c4 32 15 9e 81 a4 a0 50 02 20 60 65 11 cf 62  ..2.....P. `e..b
    [00:01:09.526,000] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d10:  e9 40 23 48 a7 b5 43 85 e2 a3 b7 de 9f ca 20 3b  .@#H..C....... ;
    [00:01:09.543,457] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d20:  a4 27 87 d9 8a 59 4c 58 1e 80 7b 30 0d 06 09 2a  .'...YLX..{0...*
    [00:01:09.560,913] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d30:  86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00 7f  .H..............
    [00:01:09.578,399] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d40:  84 07 40 92 d7 94 69 f6 f2 53 ed c5 24 55 13 d9  [email protected]..$U..
    [00:01:09.595,855] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d50:  f4 0d 5c 74 d9 20 41 1a c9 df 5d e1 36 74 88 f3  ..\t. A...].6t..
    [00:01:09.613,311] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d60:  60 68 c0 3e 71 9d 07 2d 2d 1b e4 ff ec ee 1b 62  `h.>q..--......b
    [00:01:09.630,798] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d70:  25 ec d0 e3 54 e3 62 5f 32 f2 f2 c1 3a 1f 5a e8  %...T.b_2...:.Z.
    [00:01:09.648,254] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d80:  c3 62 27 d2 d3 86 37 28 45 d3 91 ee f6 df 7e 85  .b'...7(E.....~.
    [00:01:09.665,710] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d90:  bb 7a b4 9c 0a 4c 36 a7 d5 90 ed bd 27 0e c0 a5  .z...L6.....'...
    [00:01:09.683,197] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0da0:  c8 df d7 04 e7 58 56 96 4d c4 55 09 ca 8a ff 83  .....XV.M.U.....
    [00:01:09.700,653] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0db0:  51 95 7b f3 f8 95 b0 10 e3 5a 13 08 64 6d 6b be  Q.{......Z..dmk.
    [00:01:09.718,109] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dc0:  81 74 7e 7f 75 ea 10 7d ae 29 fb c2 55 51 14 5c  .t~.u..}.)..UQ.\
    [00:01:09.735,565] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dd0:  f3 9e cd 3c c6 a5 da f6 95 f9 8e 48 d2 65 4b eb  ...<.......H.eK.
    [00:01:09.753,051] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0de0:  b4 8b 7f e0 85 27 f7 a1 3a 1e 55 cd a3 b6 58 9e  .....'..:.U...X.
    [00:01:09.771,301] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0df0:  c6 23 2a 38 8a 97 b2 13 00 17 6c 33 28 57 f6 91  .#*8......l3(W..
    [00:01:09.788,757] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e00:  12 7d f8 65 c7 c5 fd 5a 3f a9 42 51 af 1f 38 d7  .}.e...Z?.BQ..8.
    [00:01:09.806,213] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e10:  b7 f0 1e 88 f3 1d 8c 2d 0a fa 0e 40 26 a2 63 a5  .......-...@&.c.
    [00:01:09.823,699] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e20:  4f 4d 9c df 7b ec a5 79 5b cc cc 6e 9d bf d6 82  OM..{..y[..n....
    [00:01:09.841,156] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e30:  75 81 77 86 50 64 f3 06 c1 85 89 b6 8a fd 4c 00  u.w.Pd........L.
    [00:01:09.858,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e40:  05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02 02  ..0...0.........
    [00:01:09.876,068] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e50:  10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10 7b  .....|L.....f..{
    [00:01:09.893,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e60:  98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05 00  .0...*.H........
    [00:01:09.911,010] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e70:  30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53 31  0G1.0...U....US1
    [00:01:09.928,497] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e80:  22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c 65  "0 ..U....Google
    [00:01:09.945,953] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e90:  20 54 72 75 73 74 20 53 65 72 76 69 63 65 73 20   Trust Services
    [00:01:09.963,409] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ea0:  4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47 54  LLC1.0...U....GT
    [00:01:09.980,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0eb0:  53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33 31  S Root R10...231
    [00:01:09.998,352] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ec0:  32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30 32  213090000Z..2902
    [00:01:10.015,808] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ed0:  32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09 06  20140000Z0;1.0..
    [00:01:10.033,294] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ee0:  03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55 04  .U....US1.0...U.
    [00:01:10.050,750] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ef0:  0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74 20  ...Google Trust
    [00:01:10.068,237] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f00:  53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55 04  Services1.0...U.
    [00:01:10.085,723] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f10:  03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a 86  ...WR20.."0...*.
    [00:01:10.103,179] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f20:  48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30 82  H.............0.
    [00:01:10.120,666] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f30:  01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8 53  ...........E.p.S
    [00:01:10.138,122] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f40:  9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac 46  ......FWW}...Z.F
    [00:01:10.155,609] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f50:  f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16 5e  ......../......^
    [00:01:10.173,065] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f60:  a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59 3c  ......x/J.....Y<
    [00:01:10.190,521] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f70:  0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c 14  ......$.&..[dv|.
    [00:01:10.208,007] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f80:  c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35 20  ./z..L.......#5
    [00:01:10.225,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f90:  a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9 20  ..i..N?.Y.`....
    [00:01:10.242,919] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fa0:  53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d 5c  S...6Sm`M....v.\
    [00:01:10.260,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fb0:  08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2 f2  ......sk..n.Oz..
    [00:01:10.277,862] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fc0:  02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab c2  ....c..1.-u0....
    [00:01:10.295,318] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fd0:  6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05 b4  n......g..%Wt...
    [00:01:10.312,805] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fe0:  e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61 2e  ....(..z..q..Ma.
    [00:01:10.330,261] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ff0:  61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d 2f  aW........y).../
    [00:01:10.347,503] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 6325, type = 11, hslen = 6325
    [00:01:10.361,511] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 6325, 0..6325 of 6325
    [00:01:10.375,457] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (6330 bytes)
    [00:01:10.390,197] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 18 b5 0b 00 18 b1 00 18 ae 00 0e 30 30  ..............00
    [00:01:10.407,684] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  82 0e 2c 30 82 0d 14 a0 03 02 01 02 02 10 19 33  ..,0...........3
    [00:01:10.425,140] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  d8 04 bd 0a 9c 28 09 9b 33 bd ff fd 96 50 30 0d  .....(..3....P0.
    [00:01:10.442,596] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:01:10.460,083] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:01:10.477,539] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:01:10.495,025] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:01:10.512,481] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:01:10.529,937] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0080:  30 34 32 39 31 39 32 38 31 30 5a 17 0d 32 35 30  0429192810Z..250
    [00:01:10.547,424] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0090:  37 32 32 31 39 32 38 30 39 5a 30 17 31 15 30 13  722192809Z0.1.0.
    [00:01:10.564,910] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:01:10.582,366] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:01:10.599,853] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 1b fc  ..*.H.=....B....
    [00:01:10.617,309] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00d0:  46 ef d3 74 0b ab 12 d6 bc 2c da 45 2b 23 41 c6  F..t.....,.E+#A.
    [00:01:10.634,765] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00e0:  d1 5e 48 d1 39 48 ac ec b3 ec e5 22 1a 31 04 60  .^H.9H.....".1.`
    [00:01:10.652,252] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00f0:  d7 8b da 5b 08 18 b7 9b c6 df 6d 77 85 f2 f0 25  ...[......mw...%
    [00:01:10.669,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0100:  66 99 38 84 e9 a1 aa e2 d9 3c 43 7d ff f6 a3 82  f.8......<C}....
    [00:01:10.687,194] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0110:  0c 19 30 82 0c 15 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:01:10.704,650] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:01:10.722,137] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:01:10.739,624] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:01:10.757,110] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0150:  04 16 04 14 4c d1 c7 d3 76 9e a8 18 19 37 fd 21  ....L...v....7.!
    [00:01:10.774,566] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0160:  81 15 93 58 f9 f5 5b e2 30 1f 06 03 55 1d 23 04  ...X..[.0...U.#.
    [00:01:10.792,053] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:01:10.809,509] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:01:10.826,995] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:01:10.844,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:01:10.861,938] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:01:10.879,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:01:10.896,881] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:01:10.914,337] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:01:10.931,823] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:01:10.949,279] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:01:10.966,766] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:01:10.984,222] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:01:11.001,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:01:11.019,165] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:01:11.036,621] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:01:11.054,107] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:01:11.071,563] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:01:11.089,019] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:01:11.106,506] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:01:11.123,962] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:01:11.141,448] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:01:11.158,905] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:01:11.176,361] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:01:11.193,847] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:01:11.211,334] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:01:11.228,790] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:01:11.246,246] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:01:11.263,732] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:01:11.281,188] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:01:11.298,675] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:01:11.316,131] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:01:11.333,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:01:11.351,074] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:01:11.368,560] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:01:11.386,016] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:01:11.403,503] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:01:11.420,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:01:11.438,415] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:01:11.455,902] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:01:11.473,388] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:01:11.490,844] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:01:11.508,331] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:01:11.525,787] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:01:11.543,243] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:11.560,729] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:01:11.578,186] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:01:11.595,672] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:01:11.613,128] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:01:11.630,584] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:01:11.648,071] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:01:11.665,527] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:01:11.683,013] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:01:11.700,469] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:01:11.717,926] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:01:11.735,412] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:01:11.752,868] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:01:11.770,355] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:01:11.787,811] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:01:11.805,267] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:01:11.822,753] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:01:11.840,209] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:01:11.857,666] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:01:11.875,122] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:01:11.892,608] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:01:11.910,064] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:01:11.927,520] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:01:11.945,007] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:01:11.962,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:01:11.979,919] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:01:11.997,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:01:12.014,862] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:01:12.032,318] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:01:12.049,774] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:01:12.067,260] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:01:12.084,716] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:01:12.102,172] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:01:12.119,628] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:01:12.137,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:01:12.154,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:01:12.172,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:01:12.189,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:01:12.206,939] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:01:12.224,395] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:01:12.241,851] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:01:12.259,307] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:01:12.276,763] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:01:12.294,250] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:01:12.311,706] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:01:12.329,162] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:01:12.346,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:01:12.364,105] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:01:12.381,561] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:01:12.399,017] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:01:12.416,473] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:01:12.433,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:01:12.451,416] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:01:12.468,872] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:01:12.486,358] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:01:12.503,784] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:01:12.521,270] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:01:12.538,726] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:01:12.556,182] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:01:12.573,638] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:01:12.591,094] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:01:12.608,551] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:01:12.626,007] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:01:12.643,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:01:12.660,919] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:01:12.678,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:01:12.695,861] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:01:12.713,317] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:01:12.730,773] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:01:12.748,260] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:01:12.765,716] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:01:12.783,172] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:01:12.800,628] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:01:12.818,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:01:12.835,540] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:01:12.852,996] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:01:12.870,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:01:12.887,939] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:01:12.905,395] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:01:12.922,851] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:01:12.940,307] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:01:12.957,794] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:01:12.975,250] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:01:12.992,706] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:01:13.010,192] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:01:13.027,648] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:01:13.045,104] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:01:13.062,591] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:01:13.080,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:01:13.097,503] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:01:13.114,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:01:13.132,415] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:01:13.149,902] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:01:13.167,358] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:01:13.184,814] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:01:13.202,301] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:01:13.219,757] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:01:13.237,213] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:01:13.254,669] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:01:13.272,155] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:01:13.289,611] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:01:13.307,098] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:01:13.324,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:01:13.342,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:01:13.359,497] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:01:13.376,983] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:01:13.394,439] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:01:13.411,926] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:01:13.429,382] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:01:13.446,838] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:01:13.464,324] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:01:13.481,781] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:01:13.499,237] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:01:13.516,693] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:01:13.534,179] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:01:13.551,635] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:01:13.569,091] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:01:13.586,547] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:01:13.604,034] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:01:13.621,490] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:01:13.638,946] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:01:13.656,402] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:01:13.673,889] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:01:13.691,345] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:01:13.708,831] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:01:13.726,287] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:01:13.743,743] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:01:13.761,230] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:01:13.778,686] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c20:  2e 63 72 6c 30 82 01 03 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:01:13.796,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c30:  79 02 04 02 04 81 f4 04 81 f1 00 ef 00 76 00 cc  y............v..
    [00:01:13.813,629] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c40:  fb 0f 6a 85 71 09 65 fe 95 9b 53 ce e9 b2 7c 22  ..j.q.e...S...|"
    [00:01:13.831,085] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c50:  e9 85 5c 0d 97 8d b6 a9 7e 54 c0 fe 4c 0d b0 00  ..\.....~T..L...
    [00:01:13.848,571] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c60:  00 01 96 83 3c 65 27 00 00 04 03 00 47 30 45 02  ....<e'.....G0E.
    [00:01:13.866,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c70:  21 00 d6 2d e1 f2 b0 cc ea 06 f7 14 01 27 9d aa  !..-.........'..
    [00:01:13.883,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c80:  48 e6 86 7c fc 47 3a 9e 88 84 98 7f 33 3f 18 b2  H..|.G:.....3?..
    [00:01:13.900,970] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c90:  8f 07 02 20 5a 71 48 4a b5 c9 61 8a 16 67 ae 0d  ... ZqHJ..a..g..
    [00:01:13.918,426] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ca0:  eb f1 84 b8 82 50 0f 79 1c 17 8b d1 22 21 08 f6  .....P.y...."!..
    [00:01:13.935,882] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cb0:  45 40 ee 83 00 75 00 12 f1 4e 34 bd 53 72 4c 84  [email protected].
    [00:01:13.953,338] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cc0:  06 19 c3 8f 3f 7a 13 f8 e7 b5 62 87 88 9c 6d 30  ....?z....b...m0
    [00:01:13.970,825] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cd0:  05 84 eb e5 86 26 3a 00 00 01 96 83 3c 64 de 00  .....&:.....<d..
    [00:01:13.988,281] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ce0:  00 04 03 00 46 30 44 02 20 2d a6 02 00 0f 03 96  ....F0D. -......
    [00:01:14.005,737] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cf0:  96 0a 2f 15 b1 24 b2 08 cf 1a de 07 a6 3a bc af  ../..$.......:..
    [00:01:14.023,193] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d00:  9c c4 32 15 9e 81 a4 a0 50 02 20 60 65 11 cf 62  ..2.....P. `e..b
    [00:01:14.040,649] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d10:  e9 40 23 48 a7 b5 43 85 e2 a3 b7 de 9f ca 20 3b  .@#H..C....... ;
    [00:01:14.058,135] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d20:  a4 27 87 d9 8a 59 4c 58 1e 80 7b 30 0d 06 09 2a  .'...YLX..{0...*
    [00:01:14.075,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d30:  86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00 7f  .H..............
    [00:01:14.093,048] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d40:  84 07 40 92 d7 94 69 f6 f2 53 ed c5 24 55 13 d9  [email protected]..$U..
    [00:01:14.110,504] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d50:  f4 0d 5c 74 d9 20 41 1a c9 df 5d e1 36 74 88 f3  ..\t. A...].6t..
    [00:01:14.127,960] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d60:  60 68 c0 3e 71 9d 07 2d 2d 1b e4 ff ec ee 1b 62  `h.>q..--......b
    [00:01:14.145,416] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d70:  25 ec d0 e3 54 e3 62 5f 32 f2 f2 c1 3a 1f 5a e8  %...T.b_2...:.Z.
    [00:01:14.162,902] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d80:  c3 62 27 d2 d3 86 37 28 45 d3 91 ee f6 df 7e 85  .b'...7(E.....~.
    [00:01:14.180,358] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d90:  bb 7a b4 9c 0a 4c 36 a7 d5 90 ed bd 27 0e c0 a5  .z...L6.....'...
    [00:01:14.197,814] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0da0:  c8 df d7 04 e7 58 56 96 4d c4 55 09 ca 8a ff 83  .....XV.M.U.....
    [00:01:14.215,301] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0db0:  51 95 7b f3 f8 95 b0 10 e3 5a 13 08 64 6d 6b be  Q.{......Z..dmk.
    [00:01:14.232,757] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dc0:  81 74 7e 7f 75 ea 10 7d ae 29 fb c2 55 51 14 5c  .t~.u..}.)..UQ.\
    [00:01:14.250,213] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dd0:  f3 9e cd 3c c6 a5 da f6 95 f9 8e 48 d2 65 4b eb  ...<.......H.eK.
    [00:01:14.267,669] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0de0:  b4 8b 7f e0 85 27 f7 a1 3a 1e 55 cd a3 b6 58 9e  .....'..:.U...X.
    [00:01:14.285,156] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0df0:  c6 23 2a 38 8a 97 b2 13 00 17 6c 33 28 57 f6 91  .#*8......l3(W..
    [00:01:14.302,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e00:  12 7d f8 65 c7 c5 fd 5a 3f a9 42 51 af 1f 38 d7  .}.e...Z?.BQ..8.
    [00:01:14.320,068] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e10:  b7 f0 1e 88 f3 1d 8c 2d 0a fa 0e 40 26 a2 63 a5  .......-...@&.c.
    [00:01:14.337,554] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e20:  4f 4d 9c df 7b ec a5 79 5b cc cc 6e 9d bf d6 82  OM..{..y[..n....
    [00:01:14.355,010] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e30:  75 81 77 86 50 64 f3 06 c1 85 89 b6 8a fd 4c 00  u.w.Pd........L.
    [00:01:14.373,199] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e40:  05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02 02  ..0...0.........
    [00:01:14.390,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e50:  10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10 7b  .....|L.....f..{
    [00:01:14.408,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e60:  98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05 00  .0...*.H........
    [00:01:14.425,598] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e70:  30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53 31  0G1.0...U....US1
    [00:01:14.443,054] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e80:  22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c 65  "0 ..U....Google
    [00:01:14.460,510] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e90:  20 54 72 75 73 74 20 53 65 72 76 69 63 65 73 20   Trust Services
    [00:01:14.477,996] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ea0:  4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47 54  LLC1.0...U....GT
    [00:01:14.495,452] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0eb0:  53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33 31  S Root R10...231
    [00:01:14.512,908] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ec0:  32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30 32  213090000Z..2902
    [00:01:14.530,395] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ed0:  32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09 06  20140000Z0;1.0..
    [00:01:14.547,851] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ee0:  03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55 04  .U....US1.0...U.
    [00:01:14.565,307] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ef0:  0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74 20  ...Google Trust
    [00:01:14.582,763] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f00:  53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55 04  Services1.0...U.
    [00:01:14.600,219] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f10:  03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a 86  ...WR20.."0...*.
    [00:01:14.617,706] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f20:  48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30 82  H.............0.
    [00:01:14.635,162] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f30:  01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8 53  ...........E.p.S
    [00:01:14.652,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f40:  9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac 46  ......FWW}...Z.F
    [00:01:14.670,074] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f50:  f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16 5e  ......../......^
    [00:01:14.687,561] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f60:  a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59 3c  ......x/J.....Y<
    [00:01:14.705,017] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f70:  0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c 14  ......$.&..[dv|.
    [00:01:14.722,473] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f80:  c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35 20  ./z..L.......#5
    [00:01:14.739,929] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f90:  a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9 20  ..i..N?.Y.`....
    [00:01:14.757,415] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fa0:  53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d 5c  S...6Sm`M....v.\
    [00:01:14.774,871] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fb0:  08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2 f2  ......sk..n.Oz..
    [00:01:14.792,327] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fc0:  02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab c2  ....c..1.-u0....
    [00:01:14.809,783] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fd0:  6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05 b4  n......g..%Wt...
    [00:01:14.827,270] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fe0:  e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61 2e  ....(..z..q..Ma.
    [00:01:14.844,726] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ff0:  61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d 2f  aW........y).../
    [00:01:14.867,187] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:01:14.884,796] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9963: Use configuration-specific verification callback
    [00:01:15.009,979] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10020: x509_verify_cert() returned -9984 (-0x2700)
    [00:01:15.023,040] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5296: => send alert message
    [00:01:15.034,179] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5297: send alert level=2 message=48
    [00:01:15.045,684] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:01:15.056,335] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 21, version = [3:3], msglen = 2
    [00:01:15.070,220] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (7 bytes)
    [00:01:15.085,601] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  15 03 03 00 02 02 30                             ......0
    [00:01:15.101,989] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:01:15.112,609] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 7, out_left: 7
    [00:01:15.125,000] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 7 (-0xfffffff9)
    [00:01:15.137,542] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:01:15.148,132] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:01:15.158,721] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5308: <= send alert message
    [00:01:15.169,860] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10120: ! Certificate verification flags 00000008
    [00:01:15.185,699] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:01:15.195,953] <err> net_sock_tls: TLS handshake error: -0x2700
      File "<stdin>", line 1, in <module>
    OSError: [Errno 113] ECONNABORTED
    >>> print("TCP Connected.")[00:01:15.273,406] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=(nil), st=-104, user_data=(nil)
    [00:01:15.284,393] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Set EOF flag on pkt 0x2005f0e0
    [00:01:16.216,979] <wrn> net_tcp: net_pkt alloc failure
    [00:01:17.026,123] <err> net_tcp: TCP failed to allocate buffer in retransmission
    [00:01:17.268,676] <dbg> net_sock: zsock_received_cb: (tcp_work): ctx=0x2000b0e8, pkt=(nil), st=-116, user_data=(nil)
    [00:01:17.279,754] <dbg> net_sock: zsock_received_cb: (tcp_work): Set EOF flag on pkt 0x2005f0e0
    It seems the certificate is rejected and also we don't have enough memory to allocate for a retransmission.
  • Moving forward again!
    The previous issue was that the certificate wasn't generated and included at all in the MBEDTLS library. After comparing the https_client sample with our project and got it working now. The TLS connection is still ultimately failing, but I advanced so much that I think it's 80% done.
    Current log:
    >>> print("Connecting to:", result[0][-1])
    Connecting to: ('142.251.39.46', 443)
    >>> s.connect(result[0][-1])
    Dead here...5. DNS message size: 44
    DNS message content (hex):0f 70 81 80 00 01 00 01 00 00 00 00 06 67 6f 6f 67 6c 65 03 63 6f 6d 00 00 01 00 01 c0 0c 00 01 00 01 00 00 00 a8 00 04 8e fb 27 2e
    Dead here...6
    Dead here...7
    Dead here...60. tls->options.sec_tag_list.sec_tag_count: 1
    Dead here...61. tag: 16842753
    Dead here...63. Nr of credentials: 4
    counting... 0; cred type: 1; cred tag: 16842753
    Dead here...64. Found cred: 0
    Dead here...62. Counting: 0
    Dead here...65. Adding CA certificate
    Dead here...66. Parsing CA certificate
    Dead here...69
    Dead here...66.5. Parsing CA certificate done. err: 0
    Credentials set: 0
    counting... 1; cred type: 0; cred tag: 0
    counting... 2; cred type: 0; cred tag: 0
    counting... 3; cred type: 0; cred tag: 0
    [00:02:43.532,928] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:1331: The SSL configuration is tls12 only.
    [00:02:43.551,757] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:02:43.562,042] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:43.572,631] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:43.583,251] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_HELLO_REQUEST
    [00:02:43.595,886] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:43.606,475] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:43.617,095] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:02:43.629,669] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0921: => write client hello
    [00:02:43.641,479] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: dumping 'client hello, random bytes' (32 bytes)
    [00:02:43.655,090] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0000:  cc 20 47 f4 c0 76 ad 72 58 95 42 f8 aa 7c b3 e1  . G..v.rX.B..|..
    [00:02:43.670,928] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0487: 0010:  45 a6 b4 fb cf 24 73 f5 ee 1f a3 76 53 0b da 35  E....$s....vS..5
    [00:02:43.686,492] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0512: dumping 'session id' (0 bytes)
    [00:02:43.698,425] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:02:43.714,385] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:02:43.730,133] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:02:43.745,819] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:02:43.761,322] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:02:43.777,252] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:02:43.793,029] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:02:43.808,715] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:02:43.824,249] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:02:43.839,477] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:02:43.854,461] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:02:43.870,147] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:02:43.885,589] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:02:43.901,428] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:02:43.917,053] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:02:43.932,281] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:02:43.947,265] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:02:43.962,951] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:02:43.978,363] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:02:43.994,232] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    [00:02:44.009,826] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0388: adding EMPTY_RENEGOTIATION_INFO_SCSV
    [00:02:44.022,216] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0397: client hello, got 21 cipher suites
    [00:02:44.034,484] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0041: client hello, adding server name extension: google.com
    [00:02:44.048,492] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0231: client hello, adding supported_groups extension
    [00:02:44.061,859] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(001d)
    [00:02:44.073,333] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: x25519 ( 1d )
    [00:02:44.084,808] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0250: got supported group(0017)
    [00:02:44.096,282] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0282: NamedGroup: secp256r1 ( 17 )
    [00:02:44.108,001] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: dumping 'Supported groups extension' (6 bytes)
    [00:02:44.121,459] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0302: 0000:  00 04 00 1d 00 17                                ......
    [00:02:44.136,108] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9505: adding signature_algorithms extension
    [00:02:44.148,406] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [603] ecdsa_secp521r1_sha512
    [00:02:44.161,712] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [603] ecdsa_secp521r1_sha512
    [00:02:44.175,109] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [601] rsa_pkcs1_sha512
    [00:02:44.187,866] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [601] rsa_pkcs1_sha512
    [00:02:44.200,744] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [503] ecdsa_secp384r1_sha384
    [00:02:44.214,050] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [503] ecdsa_secp384r1_sha384
    [00:02:44.227,447] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [501] rsa_pkcs1_sha384
    [00:02:44.240,203] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [501] rsa_pkcs1_sha384
    [00:02:44.253,082] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [403] ecdsa_secp256r1_sha256
    [00:02:44.266,387] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [403] ecdsa_secp256r1_sha256
    [00:02:44.279,754] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9525: got signature scheme [401] rsa_pkcs1_sha256
    [00:02:44.292,541] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9534: sent signature scheme [401] rsa_pkcs1_sha256
    [00:02:44.305,389] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0105: client hello, adding supported_point_formats extension
    [00:02:44.319,915] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0150: client hello, adding ecjpake_kkpp extension
    [00:02:44.333,465] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0165: generating new ecjpake parameters
    [00:02:44.442,169] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0338: client hello, adding extended_master_secret extension
    [00:02:44.456,604] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0372: client hello, adding session ticket extension
    [00:02:44.470,367] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0689: client hello, total extension length: 395
    [00:02:44.483,215] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: dumping 'client hello extensions' (395 bytes)
    [00:02:44.496,704] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0000:  01 8b 00 00 00 0f 00 0d 00 00 0a 67 6f 6f 67 6c  ...........googl
    [00:02:44.512,512] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0010:  65 2e 63 6f 6d 00 0a 00 06 00 04 00 1d 00 17 00  e.com...........
    [00:02:44.528,320] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0020:  0d 00 0e 00 0c 06 03 06 01 05 03 05 01 04 03 04  ................
    [00:02:44.544,158] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0030:  01 00 0b 00 02 01 00 01 00 01 4a 41 04 8f b8 6f  ..........JA...o
    [00:02:44.559,967] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0040:  1c f8 8f 48 73 24 24 19 f1 4a d0 4d 6f ee f2 0b  ...Hs$$..J.Mo...
    [00:02:44.575,775] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0050:  2a 29 33 60 ee 81 06 3f 5c cd e2 1c a6 a4 ea a0  *)3`...?\.......
    [00:02:44.591,583] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0060:  56 22 d4 64 a3 fc 17 27 3b ab ca ad 16 12 24 f4  V".d...';.....$.
    [00:02:44.607,391] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0070:  84 42 f8 a5 45 c4 9c 08 1f 3f 42 d4 47 41 04 f8  .B..E....?B.GA..
    [00:02:44.623,168] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0080:  72 cf 2f b2 ac 62 13 e9 8f e5 ef 38 d1 b1 1d b6  r./..b.....8....
    [00:02:44.638,977] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0090:  45 4b c6 eb 63 17 2c ce b6 d4 6f 64 ce 80 81 73  EK..c.,...od...s
    [00:02:44.654,785] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00a0:  70 7c 19 41 88 0d 21 55 11 9a f8 5d b1 62 83 8f  p|.A..!U...].b..
    [00:02:44.670,593] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00b0:  54 8e 6c 9c 9f 60 e4 37 3e 54 51 0c e7 71 26 20  T.l..`.7>TQ..q&
    [00:02:44.686,401] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00c0:  7e 1d 35 23 57 b0 43 44 cb 69 85 0b d6 4d 39 3a  ~.5#W.CD.i...M9:
    [00:02:44.702,209] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00d0:  39 97 2e 88 a9 b7 70 d6 7f 90 2c bd 43 55 9e d4  9.....p...,.CU..
    [00:02:44.718,017] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00e0:  41 04 fb ef 2d 84 ec c2 66 cd 60 7e d1 96 0d cd  A...-...f.`~....
    [00:02:44.733,825] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 00f0:  11 1c 6d 41 18 de 16 ec 64 96 6d 3c 4a bc e1 d4  ..mA....d.m<J...
    [00:02:44.749,633] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0100:  48 c2 a5 73 e5 85 03 24 a0 01 f8 35 b8 0b 41 b0  H..s...$...5..A.
    [00:02:44.765,472] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0110:  f2 b5 22 19 db 8c cd 29 f0 65 e4 9d fb 63 c5 34  .."....).e...c.4
    [00:02:44.781,280] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0120:  a5 6c 41 04 88 8c c1 61 6b 4d a5 a7 fc 0b 5d 51  .lA....akM....]Q
    [00:02:44.797,088] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0130:  2e 31 9e 60 a7 df 83 ce 4b df 14 db 70 5b 14 2e  .1.`....K...p[..
    [00:02:44.812,896] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0140:  a6 1d 7b c6 bc a2 d6 67 65 61 4f 90 f5 ac a9 0a  ..{....geaO.....
    [00:02:44.828,704] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0150:  4f f5 75 c2 e0 b9 61 c4 aa 5d 3e 44 69 fd 18 79  O.u...a..]>Di..y
    [00:02:44.844,512] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0160:  55 1e ea 0e 20 72 ec ff 07 59 9b 78 9e 9a 1e a0  U... r...Y.x....
    [00:02:44.860,321] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0170:  09 d3 4b 39 36 96 84 a6 53 e1 00 09 e1 c4 a3 49  ..K96...S......I
    [00:02:44.876,098] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0691: 0180:  6c 70 cd f6 75 00 17 00 00 00 23                 lp..u.....#
    [00:02:44.892,425] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:02:44.903,961] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:02:44.914,611] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 482
    [00:02:44.928,710] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (487 bytes)
    [00:02:44.944,366] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 01 e2 01 00 01 de 03 03 cc 20 47 f4 c0  ............ G..
    [00:02:44.961,822] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  76 ad 72 58 95 42 f8 aa 7c b3 e1 45 a6 b4 fb cf  v.rX.B..|..E....
    [00:02:44.979,309] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  24 73 f5 ee 1f a3 76 53 0b da 35 00 00 2a c0 24  $s....vS..5..*.$
    [00:02:44.996,795] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  c0 28 c0 0a c0 14 c0 23 c0 27 c0 09 c0 13 00 3d  .(.....#.'.....=
    [00:02:45.014,282] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  00 35 c0 2a c0 0f c0 26 c0 05 00 3c 00 2f c0 29  .5.*...&...<./.)
    [00:02:45.031,738] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0050:  c0 0e c0 25 c0 04 00 ff 01 00 01 8b 00 00 00 0f  ...%............
    [00:02:45.049,224] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0060:  00 0d 00 00 0a 67 6f 6f 67 6c 65 2e 63 6f 6d 00  .....google.com.
    [00:02:45.066,741] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0070:  0a 00 06 00 04 00 1d 00 17 00 0d 00 0e 00 0c 06  ................
    [00:02:45.084,228] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0080:  03 06 01 05 03 05 01 04 03 04 01 00 0b 00 02 01  ................
    [00:02:45.101,684] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0090:  00 01 00 01 4a 41 04 8f b8 6f 1c f8 8f 48 73 24  ....JA...o...Hs$
    [00:02:45.119,171] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00a0:  24 19 f1 4a d0 4d 6f ee f2 0b 2a 29 33 60 ee 81  $..J.Mo...*)3`..
    [00:02:45.136,657] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00b0:  06 3f 5c cd e2 1c a6 a4 ea a0 56 22 d4 64 a3 fc  .?\.......V".d..
    [00:02:45.154,144] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00c0:  17 27 3b ab ca ad 16 12 24 f4 84 42 f8 a5 45 c4  .';.....$..B..E.
    [00:02:45.171,600] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00d0:  9c 08 1f 3f 42 d4 47 41 04 f8 72 cf 2f b2 ac 62  ...?B.GA..r./..b
    [00:02:45.189,086] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00e0:  13 e9 8f e5 ef 38 d1 b1 1d b6 45 4b c6 eb 63 17  .....8....EK..c.
    [00:02:45.206,573] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 00f0:  2c ce b6 d4 6f 64 ce 80 81 73 70 7c 19 41 88 0d  ,...od...sp|.A..
    [00:02:45.224,029] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0100:  21 55 11 9a f8 5d b1 62 83 8f 54 8e 6c 9c 9f 60  !U...].b..T.l..`
    [00:02:45.241,516] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0110:  e4 37 3e 54 51 0c e7 71 26 20 7e 1d 35 23 57 b0  .7>TQ..q& ~.5#W.
    [00:02:45.259,002] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0120:  43 44 cb 69 85 0b d6 4d 39 3a 39 97 2e 88 a9 b7  CD.i...M9:9.....
    [00:02:45.276,489] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0130:  70 d6 7f 90 2c bd 43 55 9e d4 41 04 fb ef 2d 84  p...,.CU..A...-.
    [00:02:45.293,945] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0140:  ec c2 66 cd 60 7e d1 96 0d cd 11 1c 6d 41 18 de  ..f.`~......mA..
    [00:02:45.311,431] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0150:  16 ec 64 96 6d 3c 4a bc e1 d4 48 c2 a5 73 e5 85  ..d.m<J...H..s..
    [00:02:45.328,918] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0160:  03 24 a0 01 f8 35 b8 0b 41 b0 f2 b5 22 19 db 8c  .$...5..A..."...
    [00:02:45.346,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0170:  cd 29 f0 65 e4 9d fb 63 c5 34 a5 6c 41 04 88 8c  .).e...c.4.lA...
    [00:02:45.363,861] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0180:  c1 61 6b 4d a5 a7 fc 0b 5d 51 2e 31 9e 60 a7 df  .akM....]Q.1.`..
    [00:02:45.381,347] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0190:  83 ce 4b df 14 db 70 5b 14 2e a6 1d 7b c6 bc a2  ..K...p[....{...
    [00:02:45.398,834] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01a0:  d6 67 65 61 4f 90 f5 ac a9 0a 4f f5 75 c2 e0 b9  .geaO.....O.u...
    [00:02:45.416,290] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01b0:  61 c4 aa 5d 3e 44 69 fd 18 79 55 1e ea 0e 20 72  a..]>Di..yU... r
    [00:02:45.433,776] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01c0:  ec ff 07 59 9b 78 9e 9a 1e a0 09 d3 4b 39 36 96  ...Y.x......K96.
    [00:02:45.451,263] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01d0:  84 a6 53 e1 00 09 e1 c4 a3 49 6c 70 cd f6 75 00  ..S......Ilp..u.
    [00:02:45.468,658] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 01e0:  17 00 00 00 23 00 00                             ....#..
    [00:02:45.485,076] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:02:45.495,666] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:02:45.507,202] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:1014: <= write client hello
    [00:02:45.518,585] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:45.529,205] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 487, out_left: 487
    [00:02:45.542,144] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 487 (-0xfffffe19)
    [00:02:45.554,901] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:02:45.565,521] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:02:45.578,094] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:02:45.589,996] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:45.600,494] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:45.611,022] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:02:45.622,222] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:02:45.633,392] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:02:45.701,263] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb40, st=0, user_data=(nil)
    [00:02:45.712,860] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:02:45.723,144] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:45.733,734] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:45.744,354] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO
    [00:02:45.756,927] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1196: => parse server hello
    [00:02:45.768,829] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:45.779,327] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:45.789,855] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:02:45.801,086] 00:02:45.804,840] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb80, st=0, user_data=(nil)
    1;33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:02:45.825,805] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:02:45.839,233] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:45.849,792] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:45.864,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 3f                                   ....?
    [00:02:45.880,554] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 63
    [00:02:45.894,622] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:45.905,548] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 68
    [00:02:45.916,870] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 68
    [00:02:45.928,161] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 63 (-0xffffffc1)
    [00:02:45.941,711] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:45.952,239] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (68 bytes)
    [00:02:45.967,468] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 38 4e a6 a9  ....?...;..h8N..
    [00:02:45.984,924] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  76 1e f1 85 31 c4 10 83 3c 9f e8 a3 7b 02 06 dd  v...1...<...{...
    [00:02:46.002,410] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  59 b8 f7 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  Y..DOWNGRD......
    [00:02:46.019,897] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:02:46.037,261] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  00 23 00 00                                      .#..
    [00:02:46.053,466] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 63, type = 2, hslen = 63
    [00:02:46.067,077] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 63, 0..63 of 63
    [00:02:46.079,589] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (68 bytes)
    [00:02:46.094,207] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 3f 02 00 00 3b 03 03 68 38 4e a6 a9  ....?...;..h8N..
    [00:02:46.111,663] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  76 1e f1 85 31 c4 10 83 3c 9f e8 a3 7b 02 06 dd  v...1...<...{...
    [00:02:46.129,150] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  59 b8 f7 44 4f 57 4e 47 52 44 01 00 c0 09 00 00  Y..DOWNGRD......
    [00:02:46.146,636] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  13 00 17 00 00 ff 01 00 01 00 00 0b 00 02 01 00  ................
    [00:02:46.164,001] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  00 23 00 00                                      .#..
    [00:02:46.180,511] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:02:46.191,009] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: dumping 'server hello, version' (2 bytes)
    [00:02:46.204,498] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1270: 0000:  03 03                                            ..
    [00:02:46.219,970] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1291: server hello, current time: 1748520614
    [00:02:46.233,215] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: dumping 'server hello, random bytes' (32 bytes)
    [00:02:46.247,344] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0000:  68 38 4e a6 a9 76 1e f1 85 31 c4 10 83 3c 9f e8  h8N..v...1...<..
    [00:02:46.263,702] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1301: 0010:  a3 7b 02 06 dd 59 b8 f7 44 4f 57 4e 47 52 44 01  .{...Y..DOWNGRD.
    [00:02:46.279,785] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1363: server hello, session id len.: 0
    [00:02:46.292,388] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1364: dumping 'server hello, session id' (0 bytes)
    [00:02:46.306,030] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1388: no session has been resumed
    [00:02:46.318,206] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1391: server hello, chosen ciphersuite: c009
    [00:02:46.331,329] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1392: server hello, compress alg.: 0
    [00:02:46.343,780] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1427: server hello, chosen ciphersuite: TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:02:46.359,680] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1448: server hello, total extension length: 19
    [00:02:46.373,260] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1518: found extended_master_secret extension
    [00:02:46.386,383] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1466: found renegotiation extension
    [00:02:46.398,712] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1545: found supported_point_formats extension
    [00:02:46.411,926] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:0844: point format selected: 0
    [00:02:46.425,750] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1531: found session_ticket extension
    [00:02:46.438,171] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1662: <= parse server hello
    [00:02:46.450,073] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:46.460,662] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:46.471,282] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:02:46.484,375] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:02:46.495,422] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:46.505,920] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:46.516,448] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:02:46.527,679] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:02:46.538,909] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:02:46.552,337] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:46.562,866] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:46.577,331] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:02:46.593,658] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:02:46.607,879] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:46.618,408] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 6330
    [00:02:46.630,432] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 6330
    [00:02:46.642,639] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1291 (-0xfffffaf5)
    [00:02:46.656,402] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6330
    [00:02:46.668,090] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:02:46.713,653] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:02:46.725,250] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:02:46.735,534] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:46.746,124] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:46.756,744] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:02:46.769,866] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:02:46.780,883] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:46.791,381] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:46.801,910] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 5
    [00:02:46.813,354] 00:02:46.817,169] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb40, st=0, user_data=(nil)
    1;33m<wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:46.837,402] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:46.851,867] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:02:46.868,164] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:02:46.882,385] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:46.892,913] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 1296, nb_want: 6330
    [00:02:46.905,242] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 1296, nb_want: 6330
    [00:02:46.916,992] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:02:46.930,755] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6330
    [00:02:46.942,443] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:02:46.993,316] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb40, st=0, user_data=(nil)
    [00:02:47.004,882] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:02:47.015,197] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:47.025,756] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:47.036,376] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:02:47.049,468] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:02:47.060,516] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:47.071,014] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:47.081,542] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 5
    [00:02:47.092,956] 00:02:47.096,893] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:02:47.116,973] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:47.131,439] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:02:47.147,735] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:02:47.161,926] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:47.172,454] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 2660, nb_want: 6330
    [00:02:47.184,783] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 2660, nb_want: 6330
    [00:02:47.196,533] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:02:47.210,266] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6330
    [00:02:47.221,954] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:02:47.264,770] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:02:47.276,367] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:02:47.286,651] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:47.297,241] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:47.307,861] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:02:47.320,953] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:02:47.331,970] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:47.342,468] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:47.352,996] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 5
    [00:02:47.364,410] 00:02:47.368,316] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb40, st=0, user_data=(nil)
    [00:02:47.388,458] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:47.402,923] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:02:47.419,219] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:02:47.433,441] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:47.443,969] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 4024, nb_want: 6330
    [00:02:47.456,298] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 4024, nb_want: 6330
    [00:02:47.468,017] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 1364 (-0xfffffaac)
    [00:02:47.481,781] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6330
    [00:02:47.493,469] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:02:47.535,797] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb40, st=0, user_data=(nil)
    [00:02:47.547,363] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4663: => handshake
    [00:02:47.557,678] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:47.568,237] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:47.578,857] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CERTIFICATE
    [00:02:47.591,949] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8095: => parse certificate
    [00:02:47.602,966] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:47.613,464] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:47.623,992] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 5
    [00:02:47.635,437] <wrn> mbedtls: WEST_TOPDIR/modules/cry[00:02:47.642,974] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=0x2005eb80, st=0, user_data=(nil)
    [00:02:47.659,454] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:47.673,919] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 18 b5                                   .....
    [00:02:47.690,216] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 6325
    [00:02:47.704,437] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:47.714,965] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5388, nb_want: 6330
    [00:02:47.727,203] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5388, nb_want: 6330
    [00:02:47.738,952] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 942 (-0xfffffc52)
    [00:02:47.752,563] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:47.763,092] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (6330 bytes)
    [00:02:47.778,472] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 18 b5 0b 00 18 b1 00 18 ae 00 0e 30 30  ..............00
    [00:02:47.795,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  82 0e 2c 30 82 0d 14 a0 03 02 01 02 02 10 19 33  ..,0...........3
    [00:02:47.813,415] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  d8 04 bd 0a 9c 28 09 9b 33 bd ff fd 96 50 30 0d  .....(..3....P0.
    [00:02:47.830,902] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:02:47.848,388] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:02:47.865,844] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:02:47.883,331] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:02:47.900,787] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:02:47.918,273] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0080:  30 34 32 39 31 39 32 38 31 30 5a 17 0d 32 35 30  0429192810Z..250
    [00:02:47.935,760] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0090:  37 32 32 31 39 32 38 30 39 5a 30 17 31 15 30 13  722192809Z0.1.0.
    [00:02:47.953,216] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:02:47.970,703] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:02:47.988,189] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 1b fc  ..*.H.=....B....
    [00:02:48.005,645] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00d0:  46 ef d3 74 0b ab 12 d6 bc 2c da 45 2b 23 41 c6  F..t.....,.E+#A.
    [00:02:48.023,132] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00e0:  d1 5e 48 d1 39 48 ac ec b3 ec e5 22 1a 31 04 60  .^H.9H.....".1.`
    [00:02:48.040,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 00f0:  d7 8b da 5b 08 18 b7 9b c6 df 6d 77 85 f2 f0 25  ...[......mw...%
    [00:02:48.058,074] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0100:  66 99 38 84 e9 a1 aa e2 d9 3c 43 7d ff f6 a3 82  f.8......<C}....
    [00:02:48.075,561] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0110:  0c 19 30 82 0c 15 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:02:48.093,048] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:02:48.110,504] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:02:48.127,990] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:02:48.145,446] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0150:  04 16 04 14 4c d1 c7 d3 76 9e a8 18 19 37 fd 21  ....L...v....7.!
    [00:02:48.162,933] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0160:  81 15 93 58 f9 f5 5b e2 30 1f 06 03 55 1d 23 04  ...X..[.0...U.#.
    [00:02:48.180,419] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:02:48.197,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:02:48.215,362] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:02:48.232,849] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:02:48.250,305] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:02:48.268,463] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:02:48.286,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:02:48.303,527] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:02:48.321,014] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:02:48.338,470] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:02:48.355,926] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:02:48.373,413] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:02:48.390,869] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:02:48.408,355] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:02:48.425,811] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:02:48.443,298] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:02:48.460,784] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:02:48.478,240] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:02:48.495,727] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:02:48.513,183] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:02:48.530,670] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:02:48.548,156] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:02:48.565,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:02:48.583,099] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:02:48.600,555] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:02:48.618,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:02:48.635,498] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:02:48.652,984] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:02:48.670,471] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:02:48.687,927] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:02:48.705,413] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:02:48.722,869] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:02:48.740,356] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:02:48.757,843] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:02:48.775,299] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:02:48.792,785] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:02:48.810,241] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:02:48.827,728] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:02:48.845,214] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:02:48.862,670] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:02:48.880,157] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:02:48.897,644] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:02:48.915,130] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:02:48.932,586] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:02:48.950,073] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:02:48.967,529] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:02:48.985,015] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:02:49.002,471] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:02:49.019,958] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:02:49.037,414] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:02:49.054,901] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:02:49.072,357] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:02:49.089,843] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:02:49.107,299] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:02:49.124,786] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:02:49.142,272] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:02:49.159,729] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:02:49.177,215] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:02:49.194,671] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:02:49.212,158] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:02:49.229,644] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:02:49.247,100] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:02:49.264,587] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:02:49.282,043] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:02:49.299,530] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:02:49.316,986] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:02:49.334,472] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:02:49.351,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:02:49.369,415] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:02:49.386,993] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:02:49.405,120] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:02:49.422,607] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:02:49.440,063] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:02:49.457,550] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:02:49.475,006] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:02:49.492,492] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:02:49.509,979] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:02:49.527,435] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:02:49.544,921] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:02:49.562,377] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:02:49.579,864] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:02:49.597,320] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:02:49.614,776] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:02:49.632,263] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:02:49.649,719] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:02:49.667,205] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:02:49.684,661] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:02:49.702,148] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:02:49.719,604] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:02:49.737,091] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:02:49.754,547] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:02:49.772,033] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:02:49.789,489] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:02:49.806,945] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:02:49.824,432] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:02:49.841,888] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:02:49.859,375] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:02:49.876,831] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:02:49.894,287] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:02:49.911,773] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:02:49.929,229] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:02:49.946,685] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:02:49.964,172] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:02:49.981,628] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:02:49.999,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:02:50.016,571] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:02:50.034,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:02:50.051,513] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:02:50.068,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:02:50.086,456] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:02:50.103,942] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:02:50.121,398] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:02:50.138,885] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:02:50.156,341] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:02:50.173,828] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:02:50.191,284] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:02:50.208,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:02:50.226,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:02:50.243,713] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:02:50.261,169] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:02:50.278,656] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:02:50.296,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:02:50.313,598] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:02:50.331,085] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:02:50.348,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:02:50.366,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:02:50.383,483] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:02:50.400,970] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:02:50.418,457] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:02:50.435,913] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:02:50.453,399] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:02:50.470,886] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:02:50.488,372] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:02:50.505,828] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:02:50.523,315] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:02:50.540,771] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:02:50.558,258] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:02:50.575,714] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:02:50.593,200] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:02:50.610,656] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:02:50.628,143] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:02:50.645,599] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:02:50.663,085] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:02:50.680,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:02:50.697,998] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:02:50.715,484] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:02:50.732,940] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:02:50.750,427] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:02:50.767,883] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:02:50.785,369] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:02:50.802,825] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:02:50.820,312] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:02:50.837,768] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:02:50.855,255] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:02:50.872,741] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:02:50.890,197] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:02:50.907,684] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:02:50.925,140] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:02:50.943,359] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:02:50.960,845] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:02:50.978,302] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:02:50.995,758] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:02:51.013,244] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:02:51.030,731] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:02:51.048,187] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:02:51.065,673] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:02:51.083,129] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:02:51.100,616] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:02:51.118,072] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:02:51.135,559] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:02:51.153,015] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:02:51.170,501] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c20:  2e 63 72 6c 30 82 01 03 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:02:51.187,988] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c30:  79 02 04 02 04 81 f4 04 81 f1 00 ef 00 76 00 cc  y............v..
    [00:02:51.205,444] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c40:  fb 0f 6a 85 71 09 65 fe 95 9b 53 ce e9 b2 7c 22  ..j.q.e...S...|"
    [00:02:51.222,930] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c50:  e9 85 5c 0d 97 8d b6 a9 7e 54 c0 fe 4c 0d b0 00  ..\.....~T..L...
    [00:02:51.240,417] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c60:  00 01 96 83 3c 65 27 00 00 04 03 00 47 30 45 02  ....<e'.....G0E.
    [00:02:51.257,873] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c70:  21 00 d6 2d e1 f2 b0 cc ea 06 f7 14 01 27 9d aa  !..-.........'..
    [00:02:51.275,360] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c80:  48 e6 86 7c fc 47 3a 9e 88 84 98 7f 33 3f 18 b2  H..|.G:.....3?..
    [00:02:51.292,816] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0c90:  8f 07 02 20 5a 71 48 4a b5 c9 61 8a 16 67 ae 0d  ... ZqHJ..a..g..
    [00:02:51.310,272] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ca0:  eb f1 84 b8 82 50 0f 79 1c 17 8b d1 22 21 08 f6  .....P.y...."!..
    [00:02:51.327,758] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cb0:  45 40 ee 83 00 75 00 12 f1 4e 34 bd 53 72 4c 84  [email protected].
    [00:02:51.345,214] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cc0:  06 19 c3 8f 3f 7a 13 f8 e7 b5 62 87 88 9c 6d 30  ....?z....b...m0
    [00:02:51.362,701] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cd0:  05 84 eb e5 86 26 3a 00 00 01 96 83 3c 64 de 00  .....&:.....<d..
    [00:02:51.380,157] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ce0:  00 04 03 00 46 30 44 02 20 2d a6 02 00 0f 03 96  ....F0D. -......
    [00:02:51.397,644] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0cf0:  96 0a 2f 15 b1 24 b2 08 cf 1a de 07 a6 3a bc af  ../..$.......:..
    [00:02:51.415,100] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d00:  9c c4 32 15 9e 81 a4 a0 50 02 20 60 65 11 cf 62  ..2.....P. `e..b
    [00:02:51.432,586] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d10:  e9 40 23 48 a7 b5 43 85 e2 a3 b7 de 9f ca 20 3b  .@#H..C....... ;
    [00:02:51.450,042] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d20:  a4 27 87 d9 8a 59 4c 58 1e 80 7b 30 0d 06 09 2a  .'...YLX..{0...*
    [00:02:51.467,529] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d30:  86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00 7f  .H..............
    [00:02:51.484,985] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d40:  84 07 40 92 d7 94 69 f6 f2 53 ed c5 24 55 13 d9  [email protected]..$U..
    [00:02:51.503,082] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d50:  f4 0d 5c 74 d9 20 41 1a c9 df 5d e1 36 74 88 f3  ..\t. A...].6t..
    [00:02:51.520,599] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d60:  60 68 c0 3e 71 9d 07 2d 2d 1b e4 ff ec ee 1b 62  `h.>q..--......b
    [00:02:51.538,055] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d70:  25 ec d0 e3 54 e3 62 5f 32 f2 f2 c1 3a 1f 5a e8  %...T.b_2...:.Z.
    [00:02:51.555,511] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d80:  c3 62 27 d2 d3 86 37 28 45 d3 91 ee f6 df 7e 85  .b'...7(E.....~.
    [00:02:51.572,998] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0d90:  bb 7a b4 9c 0a 4c 36 a7 d5 90 ed bd 27 0e c0 a5  .z...L6.....'...
    [00:02:51.590,454] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0da0:  c8 df d7 04 e7 58 56 96 4d c4 55 09 ca 8a ff 83  .....XV.M.U.....
    [00:02:51.607,940] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0db0:  51 95 7b f3 f8 95 b0 10 e3 5a 13 08 64 6d 6b be  Q.{......Z..dmk.
    [00:02:51.625,396] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dc0:  81 74 7e 7f 75 ea 10 7d ae 29 fb c2 55 51 14 5c  .t~.u..}.)..UQ.\
    [00:02:51.642,883] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0dd0:  f3 9e cd 3c c6 a5 da f6 95 f9 8e 48 d2 65 4b eb  ...<.......H.eK.
    [00:02:51.660,339] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0de0:  b4 8b 7f e0 85 27 f7 a1 3a 1e 55 cd a3 b6 58 9e  .....'..:.U...X.
    [00:02:51.677,825] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0df0:  c6 23 2a 38 8a 97 b2 13 00 17 6c 33 28 57 f6 91  .#*8......l3(W..
    [00:02:51.695,281] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e00:  12 7d f8 65 c7 c5 fd 5a 3f a9 42 51 af 1f 38 d7  .}.e...Z?.BQ..8.
    [00:02:51.712,768] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e10:  b7 f0 1e 88 f3 1d 8c 2d 0a fa 0e 40 26 a2 63 a5  .......-...@&.c.
    [00:02:51.730,224] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e20:  4f 4d 9c df 7b ec a5 79 5b cc cc 6e 9d bf d6 82  OM..{..y[..n....
    [00:02:51.747,711] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e30:  75 81 77 86 50 64 f3 06 c1 85 89 b6 8a fd 4c 00  u.w.Pd........L.
    [00:02:51.765,197] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e40:  05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02 02  ..0...0.........
    [00:02:51.782,684] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e50:  10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10 7b  .....|L.....f..{
    [00:02:51.800,140] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e60:  98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05 00  .0...*.H........
    [00:02:51.817,626] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e70:  30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53 31  0G1.0...U....US1
    [00:02:51.835,083] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e80:  22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c 65  "0 ..U....Google
    [00:02:51.852,539] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0e90:  20 54 72 75 73 74 20 53 65 72 76 69 63 65 73 20   Trust Services
    [00:02:51.870,025] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ea0:  4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47 54  LLC1.0...U....GT
    [00:02:51.888,153] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0eb0:  53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33 31  S Root R10...231
    [00:02:51.905,670] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ec0:  32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30 32  213090000Z..2902
    [00:02:51.923,126] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ed0:  32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09 06  20140000Z0;1.0..
    [00:02:51.940,612] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ee0:  03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55 04  .U....US1.0...U.
    [00:02:51.958,099] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ef0:  0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74 20  ...Google Trust
    [00:02:51.975,555] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f00:  53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55 04  Services1.0...U.
    [00:02:51.993,041] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f10:  03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a 86  ...WR20.."0...*.
    [00:02:52.010,498] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f20:  48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30 82  H.............0.
    [00:02:52.027,984] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f30:  01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8 53  ...........E.p.S
    [00:02:52.045,440] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f40:  9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac 46  ......FWW}...Z.F
    [00:02:52.062,927] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f50:  f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16 5e  ......../......^
    [00:02:52.080,383] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f60:  a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59 3c  ......x/J.....Y<
    [00:02:52.097,869] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f70:  0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c 14  ......$.&..[dv|.
    [00:02:52.115,325] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f80:  c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35 20  ./z..L.......#5
    [00:02:52.132,812] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0f90:  a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9 20  ..i..N?.Y.`....
    [00:02:52.150,299] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fa0:  53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d 5c  S...6Sm`M....v.\
    [00:02:52.167,755] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fb0:  08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2 f2  ......sk..n.Oz..
    [00:02:52.185,241] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fc0:  02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab c2  ....c..1.-u0....
    [00:02:52.202,728] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fd0:  6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05 b4  n......g..%Wt...
    [00:02:52.220,184] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0fe0:  e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61 2e  ....(..z..q..Ma.
    [00:02:52.237,670] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0ff0:  61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d 2f  aW........y).../
    [00:02:52.254,913] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 6325, type = 11, hslen = 6325
    [00:02:52.268,951] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 6325, 0..6325 of 6325
    [00:02:52.282,867] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (6330 bytes)
    [00:02:52.297,637] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 18 b5 0b 00 18 b1 00 18 ae 00 0e 30 30  ..............00
    [00:02:52.315,124] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  82 0e 2c 30 82 0d 14 a0 03 02 01 02 02 10 19 33  ..,0...........3
    [00:02:52.332,580] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  d8 04 bd 0a 9c 28 09 9b 33 bd ff fd 96 50 30 0d  .....(..3....P0.
    [00:02:52.350,067] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  06 09 2a 86 48 86 f7 0d 01 01 0b 05 00 30 3b 31  ..*.H........0;1
    [00:02:52.367,523] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  0b 30 09 06 03 55 04 06 13 02 55 53 31 1e 30 1c  .0...U....US1.0.
    [00:02:52.385,009] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0050:  06 03 55 04 0a 13 15 47 6f 6f 67 6c 65 20 54 72  ..U....Google Tr
    [00:02:52.402,465] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0060:  75 73 74 20 53 65 72 76 69 63 65 73 31 0c 30 0a  ust Services1.0.
    [00:02:52.419,952] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0070:  06 03 55 04 03 13 03 57 52 32 30 1e 17 0d 32 35  ..U....WR20...25
    [00:02:52.437,408] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0080:  30 34 32 39 31 39 32 38 31 30 5a 17 0d 32 35 30  0429192810Z..250
    [00:02:52.454,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0090:  37 32 32 31 39 32 38 30 39 5a 30 17 31 15 30 13  722192809Z0.1.0.
    [00:02:52.472,351] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00a0:  06 03 55 04 03 0c 0c 2a 2e 67 6f 6f 67 6c 65 2e  ..U....*.google.
    [00:02:52.489,837] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00b0:  63 6f 6d 30 59 30 13 06 07 2a 86 48 ce 3d 02 01  com0Y0...*.H.=..
    [00:02:52.507,293] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00c0:  06 08 2a 86 48 ce 3d 03 01 07 03 42 00 04 1b fc  ..*.H.=....B....
    [00:02:52.524,780] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00d0:  46 ef d3 74 0b ab 12 d6 bc 2c da 45 2b 23 41 c6  F..t.....,.E+#A.
    [00:02:52.542,236] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00e0:  d1 5e 48 d1 39 48 ac ec b3 ec e5 22 1a 31 04 60  .^H.9H.....".1.`
    [00:02:52.559,722] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 00f0:  d7 8b da 5b 08 18 b7 9b c6 df 6d 77 85 f2 f0 25  ...[......mw...%
    [00:02:52.577,178] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0100:  66 99 38 84 e9 a1 aa e2 d9 3c 43 7d ff f6 a3 82  f.8......<C}....
    [00:02:52.594,635] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0110:  0c 19 30 82 0c 15 30 0e 06 03 55 1d 0f 01 01 ff  ..0...0...U.....
    [00:02:52.612,121] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0120:  04 04 03 02 07 80 30 13 06 03 55 1d 25 04 0c 30  ......0...U.%..0
    [00:02:52.629,577] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0130:  0a 06 08 2b 06 01 05 05 07 03 01 30 0c 06 03 55  ...+.......0...U
    [00:02:52.647,064] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0140:  1d 13 01 01 ff 04 02 30 00 30 1d 06 03 55 1d 0e  .......0.0...U..
    [00:02:52.664,520] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0150:  04 16 04 14 4c d1 c7 d3 76 9e a8 18 19 37 fd 21  ....L...v....7.!
    [00:02:52.682,006] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0160:  81 15 93 58 f9 f5 5b e2 30 1f 06 03 55 1d 23 04  ...X..[.0...U.#.
    [00:02:52.699,462] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0170:  18 30 16 80 14 de 1b 1e ed 79 15 d4 3e 37 24 c3  .0.......y..>7$.
    [00:02:52.716,918] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0180:  21 bb ec 34 39 6d 42 b2 30 30 58 06 08 2b 06 01  !..49mB.00X..+..
    [00:02:52.734,405] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0190:  05 05 07 01 01 04 4c 30 4a 30 21 06 08 2b 06 01  ......L0J0!..+..
    [00:02:52.751,861] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01a0:  05 05 07 30 01 86 15 68 74 74 70 3a 2f 2f 6f 2e  ...0...http://o.
    [00:02:52.769,317] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01b0:  70 6b 69 2e 67 6f 6f 67 2f 77 72 32 30 25 06 08  pki.goog/wr20%..
    [00:02:52.786,804] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01c0:  2b 06 01 05 05 07 30 02 86 19 68 74 74 70 3a 2f  +.....0...http:/
    [00:02:52.804,260] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01d0:  2f 69 2e 70 6b 69 2e 67 6f 6f 67 2f 77 72 32 2e  /i.pki.goog/wr2.
    [00:02:52.821,746] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01e0:  63 72 74 30 82 09 f0 06 03 55 1d 11 04 82 09 e7  crt0.....U......
    [00:02:52.839,202] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 01f0:  30 82 09 e3 82 0c 2a 2e 67 6f 6f 67 6c 65 2e 63  0.....*.google.c
    [00:02:52.856,689] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0200:  6f 6d 82 16 2a 2e 61 70 70 65 6e 67 69 6e 65 2e  om..*.appengine.
    [00:02:52.874,145] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0210:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 09 2a 2e 62 64  google.com..*.bd
    [00:02:52.891,601] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0220:  6e 2e 64 65 76 82 15 2a 2e 6f 72 69 67 69 6e 2d  n.dev..*.origin-
    [00:02:52.909,088] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0230:  74 65 73 74 2e 62 64 6e 2e 64 65 76 82 12 2a 2e  test.bdn.dev..*.
    [00:02:52.926,544] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0240:  63 6c 6f 75 64 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  cloud.google.com
    [00:02:52.944,030] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0250:  82 18 2a 2e 63 72 6f 77 64 73 6f 75 72 63 65 2e  ..*.crowdsource.
    [00:02:52.961,486] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0260:  67 6f 6f 67 6c 65 2e 63 6f 6d 82 18 2a 2e 64 61  google.com..*.da
    [00:02:52.979,675] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0270:  74 61 63 6f 6d 70 75 74 65 2e 67 6f 6f 67 6c 65  tacompute.google
    [00:02:52.997,161] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0280:  2e 63 6f 6d 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63  .com..*.google.c
    [00:02:53.014,648] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0290:  61 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 63 6c 82 0e  a..*.google.cl..
    [00:02:53.032,104] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02a0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 69 6e 82 0e  *.google.co.in..
    [00:02:53.049,591] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02b0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 6a 70 82 0e  *.google.co.jp..
    [00:02:53.067,047] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02c0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 2e 75 6b 82 0f  *.google.co.uk..
    [00:02:53.084,533] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02d0:  2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 72 82  *.google.com.ar.
    [00:02:53.102,020] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02e0:  0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 61 75  .*.google.com.au
    [00:02:53.119,476] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 02f0:  82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e 62  ..*.google.com.b
    [00:02:53.136,962] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0300:  72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 2e  r..*.google.com.
    [00:02:53.154,418] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0310:  63 6f 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f 6d  co..*.google.com
    [00:02:53.171,905] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0320:  2e 6d 78 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63 6f  .mx..*.google.co
    [00:02:53.189,361] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0330:  6d 2e 74 72 82 0f 2a 2e 67 6f 6f 67 6c 65 2e 63  m.tr..*.google.c
    [00:02:53.206,848] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0340:  6f 6d 2e 76 6e 82 0b 2a 2e 67 6f 6f 67 6c 65 2e  om.vn..*.google.
    [00:02:53.224,304] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0350:  64 65 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 65 73 82  de..*.google.es.
    [00:02:53.241,790] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0360:  0b 2a 2e 67 6f 6f 67 6c 65 2e 66 72 82 0b 2a 2e  .*.google.fr..*.
    [00:02:53.259,246] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0370:  67 6f 6f 67 6c 65 2e 68 75 82 0b 2a 2e 67 6f 6f  google.hu..*.goo
    [00:02:53.276,733] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0380:  67 6c 65 2e 69 74 82 0b 2a 2e 67 6f 6f 67 6c 65  gle.it..*.google
    [00:02:53.294,189] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0390:  2e 6e 6c 82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 6c  .nl..*.google.pl
    [00:02:53.311,645] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03a0:  82 0b 2a 2e 67 6f 6f 67 6c 65 2e 70 74 82 0f 2a  ..*.google.pt..*
    [00:02:53.329,132] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03b0:  2e 67 6f 6f 67 6c 65 61 70 69 73 2e 63 6e 82 11  .googleapis.cn..
    [00:02:53.346,618] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03c0:  2a 2e 67 6f 6f 67 6c 65 76 69 64 65 6f 2e 63 6f  *.googlevideo.co
    [00:02:53.364,074] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03d0:  6d 82 0c 2a 2e 67 73 74 61 74 69 63 2e 63 6e 82  m..*.gstatic.cn.
    [00:02:53.381,561] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03e0:  10 2a 2e 67 73 74 61 74 69 63 2d 63 6e 2e 63 6f  .*.gstatic-cn.co
    [00:02:53.399,017] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 03f0:  6d 82 0f 67 6f 6f 67 6c 65 63 6e 61 70 70 73 2e  m..googlecnapps.
    [00:02:53.416,503] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0400:  63 6e 82 11 2a 2e 67 6f 6f 67 6c 65 63 6e 61 70  cn..*.googlecnap
    [00:02:53.433,959] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0410:  70 73 2e 63 6e 82 11 67 6f 6f 67 6c 65 61 70 70  ps.cn..googleapp
    [00:02:53.451,446] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0420:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:02:53.468,933] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0430:  6c 65 61 70 70 73 2d 63 6e 2e 63 6f 6d 82 0c 67  leapps-cn.com..g
    [00:02:53.486,389] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0440:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 0e 2a 2e 67  kecnapps.cn..*.g
    [00:02:53.503,875] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0450:  6b 65 63 6e 61 70 70 73 2e 63 6e 82 12 67 6f 6f  kecnapps.cn..goo
    [00:02:53.521,362] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0460:  67 6c 65 64 6f 77 6e 6c 6f 61 64 73 2e 63 6e 82  gledownloads.cn.
    [00:02:53.538,818] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0470:  14 2a 2e 67 6f 6f 67 6c 65 64 6f 77 6e 6c 6f 61  .*.googledownloa
    [00:02:53.556,304] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0480:  64 73 2e 63 6e 82 10 72 65 63 61 70 74 63 68 61  ds.cn..recaptcha
    [00:02:53.573,791] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0490:  2e 6e 65 74 2e 63 6e 82 12 2a 2e 72 65 63 61 70  .net.cn..*.recap
    [00:02:53.591,247] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04a0:  74 63 68 61 2e 6e 65 74 2e 63 6e 82 10 72 65 63  tcha.net.cn..rec
    [00:02:53.608,734] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04b0:  61 70 74 63 68 61 2d 63 6e 2e 6e 65 74 82 12 2a  aptcha-cn.net..*
    [00:02:53.626,220] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04c0:  2e 72 65 63 61 70 74 63 68 61 2d 63 6e 2e 6e 65  .recaptcha-cn.ne
    [00:02:53.643,676] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04d0:  74 82 0b 77 69 64 65 76 69 6e 65 2e 63 6e 82 0d  t..widevine.cn..
    [00:02:53.661,163] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04e0:  2a 2e 77 69 64 65 76 69 6e 65 2e 63 6e 82 11 61  *.widevine.cn..a
    [00:02:53.678,649] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 04f0:  6d 70 70 72 6f 6a 65 63 74 2e 6f 72 67 2e 63 6e  mpproject.org.cn
    [00:02:53.696,105] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0500:  82 13 2a 2e 61 6d 70 70 72 6f 6a 65 63 74 2e 6f  ..*.ampproject.o
    [00:02:53.713,592] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0510:  72 67 2e 63 6e 82 11 61 6d 70 70 72 6f 6a 65 63  rg.cn..ampprojec
    [00:02:53.731,079] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0520:  74 2e 6e 65 74 2e 63 6e 82 13 2a 2e 61 6d 70 70  t.net.cn..*.ampp
    [00:02:53.748,565] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0530:  72 6f 6a 65 63 74 2e 6e 65 74 2e 63 6e 82 17 67  roject.net.cn..g
    [00:02:53.766,021] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0540:  6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63 73 2d  oogle-analytics-
    [00:02:53.783,508] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0550:  63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65  cn.com..*.google
    [00:02:53.800,994] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0560:  2d 61 6e 61 6c 79 74 69 63 73 2d 63 6e 2e 63 6f  -analytics-cn.co
    [00:02:53.818,450] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0570:  6d 82 17 67 6f 6f 67 6c 65 61 64 73 65 72 76 69  m..googleadservi
    [00:02:53.835,937] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0580:  63 65 73 2d 63 6e 2e 63 6f 6d 82 19 2a 2e 67 6f  ces-cn.com..*.go
    [00:02:53.853,424] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0590:  6f 67 6c 65 61 64 73 65 72 76 69 63 65 73 2d 63  ogleadservices-c
    [00:02:53.870,910] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05a0:  6e 2e 63 6f 6d 82 11 67 6f 6f 67 6c 65 76 61 64  n.com..googlevad
    [00:02:53.888,366] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05b0:  73 2d 63 6e 2e 63 6f 6d 82 13 2a 2e 67 6f 6f 67  s-cn.com..*.goog
    [00:02:53.905,853] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05c0:  6c 65 76 61 64 73 2d 63 6e 2e 63 6f 6d 82 11 67  levads-cn.com..g
    [00:02:53.923,339] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05d0:  6f 6f 67 6c 65 61 70 69 73 2d 63 6e 2e 63 6f 6d  oogleapis-cn.com
    [00:02:53.940,795] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05e0:  82 13 2a 2e 67 6f 6f 67 6c 65 61 70 69 73 2d 63  ..*.googleapis-c
    [00:02:53.958,282] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 05f0:  6e 2e 63 6f 6d 82 15 67 6f 6f 67 6c 65 6f 70 74  n.com..googleopt
    [00:02:53.975,738] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0600:  69 6d 69 7a 65 2d 63 6e 2e 63 6f 6d 82 17 2a 2e  imize-cn.com..*.
    [00:02:53.993,194] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0610:  67 6f 6f 67 6c 65 6f 70 74 69 6d 69 7a 65 2d 63  googleoptimize-c
    [00:02:54.010,681] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0620:  6e 2e 63 6f 6d 82 12 64 6f 75 62 6c 65 63 6c 69  n.com..doublecli
    [00:02:54.028,137] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0630:  63 6b 2d 63 6e 2e 6e 65 74 82 14 2a 2e 64 6f 75  ck-cn.net..*.dou
    [00:02:54.045,623] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0640:  62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65 74 82  bleclick-cn.net.
    [00:02:54.063,079] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0650:  18 2a 2e 66 6c 73 2e 64 6f 75 62 6c 65 63 6c 69  .*.fls.doublecli
    [00:02:54.080,566] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0660:  63 6b 2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 2e 64  ck-cn.net..*.g.d
    [00:02:54.098,022] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0670:  6f 75 62 6c 65 63 6c 69 63 6b 2d 63 6e 2e 6e 65  oubleclick-cn.ne
    [00:02:54.115,509] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0680:  74 82 0e 64 6f 75 62 6c 65 63 6c 69 63 6b 2e 63  t..doubleclick.c
    [00:02:54.132,995] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0690:  6e 82 10 2a 2e 64 6f 75 62 6c 65 63 6c 69 63 6b  n..*.doubleclick
    [00:02:54.150,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06a0:  2e 63 6e 82 14 2a 2e 66 6c 73 2e 64 6f 75 62 6c  .cn..*.fls.doubl
    [00:02:54.167,938] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06b0:  65 63 6c 69 63 6b 2e 63 6e 82 12 2a 2e 67 2e 64  eclick.cn..*.g.d
    [00:02:54.185,424] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06c0:  6f 75 62 6c 65 63 6c 69 63 6b 2e 63 6e 82 11 64  oubleclick.cn..d
    [00:02:54.202,911] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06d0:  61 72 74 73 65 61 72 63 68 2d 63 6e 2e 6e 65 74  artsearch-cn.net
    [00:02:54.220,397] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06e0:  82 13 2a 2e 64 61 72 74 73 65 61 72 63 68 2d 63  ..*.dartsearch-c
    [00:02:54.237,854] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 06f0:  6e 2e 6e 65 74 82 1d 67 6f 6f 67 6c 65 74 72 61  n.net..googletra
    [00:02:54.255,340] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0700:  76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63 6e  veladservices-cn
    [00:02:54.272,827] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0710:  2e 63 6f 6d 82 1f 2a 2e 67 6f 6f 67 6c 65 74 72  .com..*.googletr
    [00:02:54.290,283] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0720:  61 76 65 6c 61 64 73 65 72 76 69 63 65 73 2d 63  aveladservices-c
    [00:02:54.307,769] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0730:  6e 2e 63 6f 6d 82 18 67 6f 6f 67 6c 65 74 61 67  n.com..googletag
    [00:02:54.325,225] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0740:  73 65 72 76 69 63 65 73 2d 63 6e 2e 63 6f 6d 82  services-cn.com.
    [00:02:54.342,712] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0750:  1a 2a 2e 67 6f 6f 67 6c 65 74 61 67 73 65 72 76  .*.googletagserv
    [00:02:54.360,168] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0760:  69 63 65 73 2d 63 6e 2e 63 6f 6d 82 17 67 6f 6f  ices-cn.com..goo
    [00:02:54.377,655] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0770:  67 6c 65 74 61 67 6d 61 6e 61 67 65 72 2d 63 6e  gletagmanager-cn
    [00:02:54.395,111] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0780:  2e 63 6f 6d 82 19 2a 2e 67 6f 6f 67 6c 65 74 61  .com..*.googleta
    [00:02:54.412,597] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0790:  67 6d 61 6e 61 67 65 72 2d 63 6e 2e 63 6f 6d 82  gmanager-cn.com.
    [00:02:54.430,053] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07a0:  18 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61 74 69  .googlesyndicati
    [00:02:54.447,540] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07b0:  6f 6e 2d 63 6e 2e 63 6f 6d 82 1a 2a 2e 67 6f 6f  on-cn.com..*.goo
    [00:02:54.465,026] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07c0:  67 6c 65 73 79 6e 64 69 63 61 74 69 6f 6e 2d 63  glesyndication-c
    [00:02:54.482,482] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07d0:  6e 2e 63 6f 6d 82 24 2a 2e 73 61 66 65 66 72 61  n.com.$*.safefra
    [00:02:54.499,969] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07e0:  6d 65 2e 67 6f 6f 67 6c 65 73 79 6e 64 69 63 61  me.googlesyndica
    [00:02:54.517,425] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 07f0:  74 69 6f 6e 2d 63 6e 2e 63 6f 6d 82 16 61 70 70  tion-cn.com..app
    [00:02:54.534,912] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0800:  2d 6d 65 61 73 75 72 65 6d 65 6e 74 2d 63 6e 2e  -measurement-cn.
    [00:02:54.552,398] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0810:  63 6f 6d 82 18 2a 2e 61 70 70 2d 6d 65 61 73 75  com..*.app-measu
    [00:02:54.569,854] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0820:  72 65 6d 65 6e 74 2d 63 6e 2e 63 6f 6d 82 0b 67  rement-cn.com..g
    [00:02:54.587,341] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0830:  76 74 31 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76  vt1-cn.com..*.gv
    [00:02:54.604,827] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0840:  74 31 2d 63 6e 2e 63 6f 6d 82 0b 67 76 74 32 2d  t1-cn.com..gvt2-
    [00:02:54.622,283] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0850:  63 6e 2e 63 6f 6d 82 0d 2a 2e 67 76 74 32 2d 63  cn.com..*.gvt2-c
    [00:02:54.639,770] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0860:  6e 2e 63 6f 6d 82 0b 32 6d 64 6e 2d 63 6e 2e 6e  n.com..2mdn-cn.n
    [00:02:54.657,257] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0870:  65 74 82 0d 2a 2e 32 6d 64 6e 2d 63 6e 2e 6e 65  et..*.2mdn-cn.ne
    [00:02:54.674,713] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0880:  74 82 14 67 6f 6f 67 6c 65 66 6c 69 67 68 74 73  t..googleflights
    [00:02:54.692,199] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0890:  2d 63 6e 2e 6e 65 74 82 16 2a 2e 67 6f 6f 67 6c  -cn.net..*.googl
    [00:02:54.709,686] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08a0:  65 66 6c 69 67 68 74 73 2d 63 6e 2e 6e 65 74 82  eflights-cn.net.
    [00:02:54.727,142] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08b0:  0c 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 0e 2a  .admob-cn.com..*
    [00:02:54.744,628] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08c0:  2e 61 64 6d 6f 62 2d 63 6e 2e 63 6f 6d 82 14 67  .admob-cn.com..g
    [00:02:54.762,084] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08d0:  6f 6f 67 6c 65 73 61 6e 64 62 6f 78 2d 63 6e 2e  ooglesandbox-cn.
    [00:02:54.779,571] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08e0:  63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 73 61 6e  com..*.googlesan
    [00:02:54.797,027] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 08f0:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 1e 2a 2e 73  dbox-cn.com..*.s
    [00:02:54.814,514] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0900:  61 66 65 6e 75 70 2e 67 6f 6f 67 6c 65 73 61 6e  afenup.googlesan
    [00:02:54.831,970] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0910:  64 62 6f 78 2d 63 6e 2e 63 6f 6d 82 0d 2a 2e 67  dbox-cn.com..*.g
    [00:02:54.849,456] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0920:  73 74 61 74 69 63 2e 63 6f 6d 82 14 2a 2e 6d 65  static.com..*.me
    [00:02:54.866,912] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0930:  74 72 69 63 2e 67 73 74 61 74 69 63 2e 63 6f 6d  tric.gstatic.com
    [00:02:54.884,399] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0940:  82 0a 2a 2e 67 76 74 31 2e 63 6f 6d 82 11 2a 2e  ..*.gvt1.com..*.
    [00:02:54.901,885] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0950:  67 63 70 63 64 6e 2e 67 76 74 31 2e 63 6f 6d 82  gcpcdn.gvt1.com.
    [00:02:54.919,342] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0960:  0a 2a 2e 67 76 74 32 2e 63 6f 6d 82 0e 2a 2e 67  .*.gvt2.com..*.g
    [00:02:54.936,828] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0970:  63 70 2e 67 76 74 32 2e 63 6f 6d 82 10 2a 2e 75  cp.gvt2.com..*.u
    [00:02:54.954,284] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0980:  72 6c 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82 16 2a  rl.google.com..*
    [00:02:54.971,771] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0990:  2e 79 6f 75 74 75 62 65 2d 6e 6f 63 6f 6f 6b 69  .youtube-nocooki
    [00:02:54.989,227] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09a0:  65 2e 63 6f 6d 82 0b 2a 2e 79 74 69 6d 67 2e 63  e.com..*.ytimg.c
    [00:02:55.006,713] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09b0:  6f 6d 82 0a 61 69 2e 61 6e 64 72 6f 69 64 82 0b  om..ai.android..
    [00:02:55.024,200] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09c0:  61 6e 64 72 6f 69 64 2e 63 6f 6d 82 0d 2a 2e 61  android.com..*.a
    [00:02:55.041,656] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09d0:  6e 64 72 6f 69 64 2e 63 6f 6d 82 13 2a 2e 66 6c  ndroid.com..*.fl
    [00:02:55.059,143] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09e0:  61 73 68 2e 61 6e 64 72 6f 69 64 2e 63 6f 6d 82  ash.android.com.
    [00:02:55.076,599] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 09f0:  04 67 2e 63 6e 82 06 2a 2e 67 2e 63 6e 82 04 67  .g.cn..*.g.cn..g
    [00:02:55.094,085] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a00:  2e 63 6f 82 06 2a 2e 67 2e 63 6f 82 06 67 6f 6f  .co..*.g.co..goo
    [00:02:55.111,541] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a10:  2e 67 6c 82 0a 77 77 77 2e 67 6f 6f 2e 67 6c 82  .gl..www.goo.gl.
    [00:02:55.129,028] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a20:  14 67 6f 6f 67 6c 65 2d 61 6e 61 6c 79 74 69 63  .google-analytic
    [00:02:55.146,484] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a30:  73 2e 63 6f 6d 82 16 2a 2e 67 6f 6f 67 6c 65 2d  s.com..*.google-
    [00:02:55.163,970] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a40:  61 6e 61 6c 79 74 69 63 73 2e 63 6f 6d 82 0a 67  analytics.com..g
    [00:02:55.181,427] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a50:  6f 6f 67 6c 65 2e 63 6f 6d 82 12 67 6f 6f 67 6c  oogle.com..googl
    [00:02:55.198,913] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a60:  65 63 6f 6d 6d 65 72 63 65 2e 63 6f 6d 82 14 2a  ecommerce.com..*
    [00:02:55.216,369] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a70:  2e 67 6f 6f 67 6c 65 63 6f 6d 6d 65 72 63 65 2e  .googlecommerce.
    [00:02:55.233,856] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a80:  63 6f 6d 82 08 67 67 70 68 74 2e 63 6e 82 0a 2a  com..ggpht.cn..*
    [00:02:55.251,312] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0a90:  2e 67 67 70 68 74 2e 63 6e 82 0a 75 72 63 68 69  .ggpht.cn..urchi
    [00:02:55.268,798] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0aa0:  6e 2e 63 6f 6d 82 0c 2a 2e 75 72 63 68 69 6e 2e  n.com..*.urchin.
    [00:02:55.286,285] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ab0:  63 6f 6d 82 08 79 6f 75 74 75 2e 62 65 82 0b 79  com..youtu.be..y
    [00:02:55.303,771] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ac0:  6f 75 74 75 62 65 2e 63 6f 6d 82 0d 2a 2e 79 6f  outube.com..*.yo
    [00:02:55.321,258] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ad0:  75 74 75 62 65 2e 63 6f 6d 82 11 6d 75 73 69 63  utube.com..music
    [00:02:55.338,714] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ae0:  2e 79 6f 75 74 75 62 65 2e 63 6f 6d 82 13 2a 2e  .youtube.com..*.
    [00:02:55.356,201] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0af0:  6d 75 73 69 63 2e 79 6f 75 74 75 62 65 2e 63 6f  music.youtube.co
    [00:02:55.373,687] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b00:  6d 82 14 79 6f 75 74 75 62 65 65 64 75 63 61 74  m..youtubeeducat
    [00:02:55.391,174] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b10:  69 6f 6e 2e 63 6f 6d 82 16 2a 2e 79 6f 75 74 75  ion.com..*.youtu
    [00:02:55.408,630] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b20:  62 65 65 64 75 63 61 74 69 6f 6e 2e 63 6f 6d 82  beeducation.com.
    [00:02:55.426,116] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b30:  0f 79 6f 75 74 75 62 65 6b 69 64 73 2e 63 6f 6d  .youtubekids.com
    [00:02:55.443,572] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b40:  82 11 2a 2e 79 6f 75 74 75 62 65 6b 69 64 73 2e  ..*.youtubekids.
    [00:02:55.461,059] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b50:  63 6f 6d 82 05 79 74 2e 62 65 82 07 2a 2e 79 74  com..yt.be..*.yt
    [00:02:55.478,546] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b60:  2e 62 65 82 1a 61 6e 64 72 6f 69 64 2e 63 6c 69  .be..android.cli
    [00:02:55.496,032] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b70:  65 6e 74 73 2e 67 6f 6f 67 6c 65 2e 63 6f 6d 82  ents.google.com.
    [00:02:55.513,488] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b80:  13 2a 2e 61 6e 64 72 6f 69 64 2e 67 6f 6f 67 6c  .*.android.googl
    [00:02:55.530,975] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0b90:  65 2e 63 6e 82 12 2a 2e 63 68 72 6f 6d 65 2e 67  e.cn..*.chrome.g
    [00:02:55.548,461] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ba0:  6f 6f 67 6c 65 2e 63 6e 82 16 2a 2e 64 65 76 65  oogle.cn..*.deve
    [00:02:55.565,948] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bb0:  6c 6f 70 65 72 73 2e 67 6f 6f 67 6c 65 2e 63 6e  lopers.google.cn
    [00:02:55.583,404] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bc0:  82 15 2a 2e 61 69 73 74 75 64 69 6f 2e 67 6f 6f  ..*.aistudio.goo
    [00:02:55.600,891] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bd0:  67 6c 65 2e 63 6f 6d 30 13 06 03 55 1d 20 04 0c  gle.com0...U. ..
    [00:02:55.618,377] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0be0:  30 0a 30 08 06 06 67 81 0c 01 02 01 30 36 06 03  0.0...g.....06..
    [00:02:55.635,864] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0bf0:  55 1d 1f 04 2f 30 2d 30 2b a0 29 a0 27 86 25 68  U.../0-0+.).'.%h
    [00:02:55.653,350] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c00:  74 74 70 3a 2f 2f 63 2e 70 6b 69 2e 67 6f 6f 67  ttp://c.pki.goog
    [00:02:55.670,806] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c10:  2f 77 72 32 2f 6f 42 46 59 59 61 68 7a 67 56 49  /wr2/oBFYYahzgVI
    [00:02:55.688,293] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c20:  2e 63 72 6c 30 82 01 03 06 0a 2b 06 01 04 01 d6  .crl0.....+.....
    [00:02:55.705,780] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c30:  79 02 04 02 04 81 f4 04 81 f1 00 ef 00 76 00 cc  y............v..
    [00:02:55.723,236] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c40:  fb 0f 6a 85 71 09 65 fe 95 9b 53 ce e9 b2 7c 22  ..j.q.e...S...|"
    [00:02:55.740,722] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c50:  e9 85 5c 0d 97 8d b6 a9 7e 54 c0 fe 4c 0d b0 00  ..\.....~T..L...
    [00:02:55.758,178] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c60:  00 01 96 83 3c 65 27 00 00 04 03 00 47 30 45 02  ....<e'.....G0E.
    [00:02:55.775,665] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c70:  21 00 d6 2d e1 f2 b0 cc ea 06 f7 14 01 27 9d aa  !..-.........'..
    [00:02:55.793,121] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c80:  48 e6 86 7c fc 47 3a 9e 88 84 98 7f 33 3f 18 b2  H..|.G:.....3?..
    [00:02:55.810,607] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0c90:  8f 07 02 20 5a 71 48 4a b5 c9 61 8a 16 67 ae 0d  ... ZqHJ..a..g..
    [00:02:55.828,094] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ca0:  eb f1 84 b8 82 50 0f 79 1c 17 8b d1 22 21 08 f6  .....P.y...."!..
    [00:02:55.845,550] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cb0:  45 40 ee 83 00 75 00 12 f1 4e 34 bd 53 72 4c 84  [email protected].
    [00:02:55.863,037] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cc0:  06 19 c3 8f 3f 7a 13 f8 e7 b5 62 87 88 9c 6d 30  ....?z....b...m0
    [00:02:55.880,493] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cd0:  05 84 eb e5 86 26 3a 00 00 01 96 83 3c 64 de 00  .....&:.....<d..
    [00:02:55.897,979] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ce0:  00 04 03 00 46 30 44 02 20 2d a6 02 00 0f 03 96  ....F0D. -......
    [00:02:55.915,466] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0cf0:  96 0a 2f 15 b1 24 b2 08 cf 1a de 07 a6 3a bc af  ../..$.......:..
    [00:02:55.932,952] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d00:  9c c4 32 15 9e 81 a4 a0 50 02 20 60 65 11 cf 62  ..2.....P. `e..b
    [00:02:55.950,408] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d10:  e9 40 23 48 a7 b5 43 85 e2 a3 b7 de 9f ca 20 3b  .@#H..C....... ;
    [00:02:55.967,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d20:  a4 27 87 d9 8a 59 4c 58 1e 80 7b 30 0d 06 09 2a  .'...YLX..{0...*
    [00:02:55.985,382] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d30:  86 48 86 f7 0d 01 01 0b 05 00 03 82 01 01 00 7f  .H..............
    [00:02:56.002,838] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d40:  84 07 40 92 d7 94 69 f6 f2 53 ed c5 24 55 13 d9  [email protected]..$U..
    [00:02:56.020,324] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d50:  f4 0d 5c 74 d9 20 41 1a c9 df 5d e1 36 74 88 f3  ..\t. A...].6t..
    [00:02:56.037,811] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d60:  60 68 c0 3e 71 9d 07 2d 2d 1b e4 ff ec ee 1b 62  `h.>q..--......b
    [00:02:56.055,267] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d70:  25 ec d0 e3 54 e3 62 5f 32 f2 f2 c1 3a 1f 5a e8  %...T.b_2...:.Z.
    [00:02:56.072,753] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d80:  c3 62 27 d2 d3 86 37 28 45 d3 91 ee f6 df 7e 85  .b'...7(E.....~.
    [00:02:56.090,209] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0d90:  bb 7a b4 9c 0a 4c 36 a7 d5 90 ed bd 27 0e c0 a5  .z...L6.....'...
    [00:02:56.107,696] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0da0:  c8 df d7 04 e7 58 56 96 4d c4 55 09 ca 8a ff 83  .....XV.M.U.....
    [00:02:56.125,152] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0db0:  51 95 7b f3 f8 95 b0 10 e3 5a 13 08 64 6d 6b be  Q.{......Z..dmk.
    [00:02:56.142,639] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dc0:  81 74 7e 7f 75 ea 10 7d ae 29 fb c2 55 51 14 5c  .t~.u..}.)..UQ.\
    [00:02:56.160,095] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0dd0:  f3 9e cd 3c c6 a5 da f6 95 f9 8e 48 d2 65 4b eb  ...<.......H.eK.
    [00:02:56.177,551] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0de0:  b4 8b 7f e0 85 27 f7 a1 3a 1e 55 cd a3 b6 58 9e  .....'..:.U...X.
    [00:02:56.195,037] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0df0:  c6 23 2a 38 8a 97 b2 13 00 17 6c 33 28 57 f6 91  .#*8......l3(W..
    [00:02:56.212,493] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e00:  12 7d f8 65 c7 c5 fd 5a 3f a9 42 51 af 1f 38 d7  .}.e...Z?.BQ..8.
    [00:02:56.229,980] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e10:  b7 f0 1e 88 f3 1d 8c 2d 0a fa 0e 40 26 a2 63 a5  .......-...@&.c.
    [00:02:56.247,436] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e20:  4f 4d 9c df 7b ec a5 79 5b cc cc 6e 9d bf d6 82  OM..{..y[..n....
    [00:02:56.264,923] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e30:  75 81 77 86 50 64 f3 06 c1 85 89 b6 8a fd 4c 00  u.w.Pd........L.
    [00:02:56.282,379] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e40:  05 0f 30 82 05 0b 30 82 02 f3 a0 03 02 01 02 02  ..0...0.........
    [00:02:56.299,865] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e50:  10 7f f0 05 a0 7c 4c de d1 00 ad 9d 66 a5 10 7b  .....|L.....f..{
    [00:02:56.317,352] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e60:  98 30 0d 06 09 2a 86 48 86 f7 0d 01 01 0b 05 00  .0...*.H........
    [00:02:56.334,808] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e70:  30 47 31 0b 30 09 06 03 55 04 06 13 02 55 53 31  0G1.0...U....US1
    [00:02:56.352,294] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e80:  22 30 20 06 03 55 04 0a 13 19 47 6f 6f 67 6c 65  "0 ..U....Google
    [00:02:56.369,750] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0e90:  20 54 72 75 73 74 20 53 65 72 76 69 63 65 73 20   Trust Services
    [00:02:56.387,237] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ea0:  4c 4c 43 31 14 30 12 06 03 55 04 03 13 0b 47 54  LLC1.0...U....GT
    [00:02:56.404,693] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0eb0:  53 20 52 6f 6f 74 20 52 31 30 1e 17 0d 32 33 31  S Root R10...231
    [00:02:56.422,149] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ec0:  32 31 33 30 39 30 30 30 30 5a 17 0d 32 39 30 32  213090000Z..2902
    [00:02:56.439,636] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ed0:  32 30 31 34 30 30 30 30 5a 30 3b 31 0b 30 09 06  20140000Z0;1.0..
    [00:02:56.457,122] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ee0:  03 55 04 06 13 02 55 53 31 1e 30 1c 06 03 55 04  .U....US1.0...U.
    [00:02:56.474,578] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ef0:  0a 13 15 47 6f 6f 67 6c 65 20 54 72 75 73 74 20  ...Google Trust
    [00:02:56.492,065] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f00:  53 65 72 76 69 63 65 73 31 0c 30 0a 06 03 55 04  Services1.0...U.
    [00:02:56.509,521] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f10:  03 13 03 57 52 32 30 82 01 22 30 0d 06 09 2a 86  ...WR20.."0...*.
    [00:02:56.527,008] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f20:  48 86 f7 0d 01 01 01 05 00 03 82 01 0f 00 30 82  H.............0.
    [00:02:56.544,494] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f30:  01 0a 02 82 01 01 00 a9 ff 9c 7f 45 1e 70 a8 53  ...........E.p.S
    [00:02:56.561,950] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f40:  9f ca d9 e5 0d de 46 57 57 7d bc 8f 9a 5a ac 46  ......FWW}...Z.F
    [00:02:56.579,437] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f50:  f1 84 9a bb 91 db c9 fb 2f 01 fb 92 09 00 16 5e  ......../......^
    [00:02:56.596,893] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f60:  a0 1c f8 c1 ab f9 78 2f 4a cc d8 85 a2 d8 59 3c  ......x/J.....Y<
    [00:02:56.614,349] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f70:  0e d3 18 fb b1 f5 24 0d 26 ee b6 5b 64 76 7c 14  ......$.&..[dv|.
    [00:02:56.631,835] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f80:  c7 2f 7a ce a8 4c b7 f4 d9 08 fc df 87 23 35 20  ./z..L.......#5
    [00:02:56.649,291] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0f90:  a8 e2 69 e2 8c 4e 3f b1 59 fa 60 a2 1e b3 c9 20  ..i..N?.Y.`....
    [00:02:56.666,748] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fa0:  53 19 82 ca 36 53 6d 60 4d e9 00 91 fc 76 8d 5c  S...6Sm`M....v.\
    [00:02:56.684,234] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fb0:  08 0f 0a c2 dc f1 73 6b c5 13 6e 0a 4f 7a c2 f2  ......sk..n.Oz..
    [00:02:56.701,690] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fc0:  02 1c 2e b4 63 83 da 31 f6 2d 75 30 b2 fb ab c2  ....c..1.-u0....
    [00:02:56.719,146] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fd0:  6e db a9 c0 0e b9 f9 67 d4 c3 25 57 74 eb 05 b4  n......g..%Wt...
    [00:02:56.736,602] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0fe0:  e9 8e b5 de 28 cd cc 7a 14 e4 71 03 cb 4d 61 2e  ....(..z..q..Ma.
    [00:02:56.754,089] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0ff0:  61 57 c5 19 a9 0b 98 84 1a e8 79 29 d9 b2 8d 2f  aW........y).../
    [00:02:56.776,550] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:02:56.794,158] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9963: Use configuration-specific verification callback
    [00:02:57.270,904] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:10125: Certificate verification flags clear
    [00:02:57.283,111] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8209: <= parse certificate
    [00:02:57.294,128] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:57.304,718] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:57.315,338] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_KEY_EXCHANGE
    [00:02:57.328,552] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2090: => parse server key exchange
    [00:02:57.341,064] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:57.351,562] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:57.362,091] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:02:57.373,321] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:02:57.384,521] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:02:57.397,949] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:57.408,508] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:57.422,973] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 74                                   ....t
    [00:02:57.439,270] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 116
    [00:02:57.453,399] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:57.463,928] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 121
    [00:02:57.475,341] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 121
    [00:02:57.486,724] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 116 (-0xffffff8c)
    [00:02:57.500,335] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:57.510,894] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (121 bytes)
    [00:02:57.526,184] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 74 0c 00 00 70 03 00 1d 20 ff 77 86  ....t...p... .w.
    [00:02:57.543,640] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0010:  3f 4d a5 ab a7 cf b0 40 eb 3c ce f6 26 28 99 1f  ?M.....@.<..&(..
    [00:02:57.561,126] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0020:  82 4c 19 6b dd a8 92 21 cf a8 f5 bb 6e 04 03 00  .L.k...!....n...
    [00:02:57.578,582] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0030:  48 30 46 02 21 00 b1 0e 89 34 bd ca 3b 5e d0 21  H0F.!....4..;^.!
    [00:02:57.596,069] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0040:  8a 9e 5d c7 0f 2b ef fc 42 61 87 8f 37 57 db 4a  ..]..+..Ba..7W.J
    [00:02:57.613,525] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0050:  95 81 86 3a 98 47 02 21 00 9f cb 6c ac 73 72 b5  ...:.G.!...l.sr.
    [00:02:57.631,011] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0060:  86 bc 88 7d b0 b9 5e e1 e8 a5 82 c1 7e ef 83 6f  ...}..^.....~..o
    [00:02:57.648,406] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0070:  69 9e f4 a3 56 26 e6 82 61                       i...V&..a
    [00:02:57.665,039] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 116, type = 12, hslen = 116
    [00:02:57.678,894] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 116, 0..116 of 116
    [00:02:57.691,680] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (121 bytes)
    [00:02:57.706,359] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 74 0c 00 00 70 03 00 1d 20 ff 77 86  ....t...p... .w.
    [00:02:57.723,846] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0010:  3f 4d a5 ab a7 cf b0 40 eb 3c ce f6 26 28 99 1f  ?M.....@.<..&(..
    [00:02:57.741,333] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0020:  82 4c 19 6b dd a8 92 21 cf a8 f5 bb 6e 04 03 00  .L.k...!....n...
    [00:02:57.758,789] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0030:  48 30 46 02 21 00 b1 0e 89 34 bd ca 3b 5e d0 21  H0F.!....4..;^.!
    [00:02:57.776,275] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0040:  8a 9e 5d c7 0f 2b ef fc 42 61 87 8f 37 57 db 4a  ..]..+..Ba..7W.J
    [00:02:57.793,731] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0050:  95 81 86 3a 98 47 02 21 00 9f cb 6c ac 73 72 b5  ...:.G.!...l.sr.
    [00:02:57.811,218] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0060:  86 bc 88 7d b0 b9 5e e1 e8 a5 82 c1 7e ef 83 6f  ...}..^.....~..o
    [00:02:57.828,613] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0070:  69 9e f4 a3 56 26 e6 82 61                       i...V&..a
    [00:02:57.845,306] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:02:57.855,804] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: dumping 'server key exchange' (112 bytes)
    [00:02:57.869,445] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0000:  03 00 1d 20 ff 77 86 3f 4d a5 ab a7 cf b0 40 eb  ... .w.?M.....@.
    [00:02:57.885,772] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0010:  3c ce f6 26 28 99 1f 82 4c 19 6b dd a8 92 21 cf  <..&(...L.k...!.
    [00:02:57.902,099] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0020:  a8 f5 bb 6e 04 03 00 48 30 46 02 21 00 b1 0e 89  ...n...H0F.!....
    [00:02:57.918,457] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0030:  34 bd ca 3b 5e d0 21 8a 9e 5d c7 0f 2b ef fc 42  4..;^.!..]..+..B
    [00:02:57.934,783] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0040:  61 87 8f 37 57 db 4a 95 81 86 3a 98 47 02 21 00  a..7W.J...:.G.!.
    [00:02:57.951,110] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0050:  9f cb 6c ac 73 72 b5 86 bc 88 7d b0 b9 5e e1 e8  ..l.sr....}..^..
    [00:02:57.967,468] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2177: 0060:  a5 82 c1 7e ef 83 6f 69 9e f4 a3 56 26 e6 82 61  ...~..oi...V&..a
    [00:02:57.983,795] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1806: ECDH curve: x25519
    [00:02:57.995,452] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1813: value of 'ECDH: Qp(X)' (255 bits) is:
    [00:02:58.008,697] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1813:  6e bb f5 a8 cf 21 92 a8 dd 6b 19 4c 82 1f 99 28
    [00:02:58.022,857] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1813:  26 f6 ce 3c eb 40 b0 cf a7 ab a5 4d 3f 86 77 ff
    [00:02:58.036,865] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1813: value of 'ECDH: Qp(Y)' (0 bits) is:
    [00:02:58.049,682] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:1813:  00
    [00:02:58.059,814] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2372: dumping 'signature' (72 bytes)
    [00:02:58.072,479] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2372: 0000:  30 46 02 21 00 b1 0e 89 34 bd ca 3b 5e d0 21 8a  0F.!....4..;^.!.
    [00:02:58.088,806] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2372: 0010:  9e 5d c7 0f 2b ef fc 42 61 87 8f 37 57 db 4a 95  .]..+..Ba..7W.J.
    [00:02:58.105,133] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2372: 0020:  81 86 3a 98 47 02 21 00 9f cb 6c ac 73 72 b5 86  ..:.G.!...l.sr..
    [00:02:58.121,459] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2372: 0030:  bc 88 7d b0 b9 5e e1 e8 a5 82 c1 7e ef 83 6f 69  ..}..^.....~..oi
    [00:02:58.137,695] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2372: 0040:  9e f4 a3 56 26 e6 82 61                          ...V&..a
    [00:02:58.153,076] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:9305: Perform mbedtls-based computation of digest of ServerKeyExchange
    [00:02:58.167,907] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2389: dumping 'parameters hash' (32 bytes)
    [00:02:58.181,091] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2389: 0000:  db 2f 29 25 87 9f 3b f6 2a ec 86 7d 2b 35 fc 0d  ./)%..;.*..}+5..
    [00:02:58.197,418] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2389: 0010:  c1 a2 f6 96 1a c3 e6 98 bd e1 50 69 86 2a ae 34  ..........Pi.*.4
    [00:02:58.266,082] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2460: <= parse server key exchange
    [00:02:58.278,533] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:58.289,123] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:58.299,743] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CERTIFICATE_REQUEST
    [00:02:58.312,957] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2499: => parse certificate request
    [00:02:58.325,439] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:58.335,968] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:58.346,466] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:02:58.357,727] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:02:58.368,927] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
    [00:02:58.382,354] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:58.392,913] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: dumping 'input record header' (5 bytes)
    [00:02:58.407,379] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3964: 0000:  16 03 03 00 04                                   .....
    [00:02:58.423,675] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3966: input record: msgtype = 22, version = [0x303], msglen = 4
    [00:02:58.437,622] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:58.448,150] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 5, nb_want: 9
    [00:02:58.459,777] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 5, nb_want: 9
    [00:02:58.470,977] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2319: ssl->f_recv(_timeout)() returned 4 (-0xfffffffc)
    [00:02:58.484,436] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2341: <= fetch input
    [00:02:58.494,964] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: dumping 'input record from network' (9 bytes)
    [00:02:58.510,009] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4073: 0000:  16 03 03 00 04 0e 00 00 00                       .........
    [00:02:58.526,641] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3239: handshake message: msglen = 4, type = 14, hslen = 4
    [00:02:58.540,130] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3328: sole handshake fragment: 4, 0..4 of 4
    [00:02:58.552,368] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: dumping 'reassembled record' (9 bytes)
    [00:02:58.566,802] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3398: 0000:  16 03 03 00 04 0e 00 00 00                       .........
    [00:02:58.583,404] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:02:58.593,902] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2525: got no certificate request
    [00:02:58.605,957] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2661: <= parse certificate request
    [00:02:58.618,469] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:58.629,058] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:58.639,678] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_HELLO_DONE
    [00:02:58.652,679] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2672: => parse server hello done
    [00:02:58.665,008] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:58.675,537] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4366: reuse previously read message
    [00:02:58.687,347] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4370: <= read record
    [00:02:58.697,845] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2700: <= parse server hello done
    [00:02:58.710,174] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:58.720,764] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:58.731,384] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_CERTIFICATE
    [00:02:58.744,476] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7690: => write certificate
    [00:02:58.755,523] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7701: <= skip write certificate
    [00:02:58.766,967] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:58.777,557] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:58.788,208] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_KEY_EXCHANGE
    [00:02:58.801,391] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2715: => write client key exchange
    [00:02:58.824,645] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2861: value of 'ECDH: Q(X)' (255 bits) is:
    [00:02:58.837,799] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2861:  74 ca 30 4a c7 da 28 d0 2a 22 3f e0 0c c5 eb e4
    [00:02:58.851,989] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2861:  3d 68 c2 02 0a 65 f5 a7 53 a4 0f f0 28 06 0e 4a
    [00:02:58.865,997] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2861: value of 'ECDH: Q(Y)' (0 bits) is:
    [00:02:58.878,723] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2861:  00
    [00:02:58.899,139] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2889: value of 'ECDH: z' (254 bits) is:
    [00:02:58.911,987] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2889:  33 17 df 2a 1b dd 61 31 01 0f c4 42 a2 db 41 5d
    [00:02:58.926,177] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:2889:  bc f0 21 0e a5 d8 66 27 80 51 2c e5 96 2a c0 bf
    [00:02:58.940,155] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:02:58.951,690] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:02:58.962,341] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 37
    [00:02:58.976,348] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (42 bytes)
    [00:02:58.991,882] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 00 25 10 00 00 21 20 4a 0e 06 28 f0 0f  ....%...! J..(..
    [00:02:59.009,368] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  a4 53 a7 f5 65 0a 02 c2 68 3d e4 eb c5 0c e0 3f  .S..e...h=.....?
    [00:02:59.026,763] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  22 2a d0 28 da c7 4a 30 ca 74                    "*.(..J0.t
    [00:02:59.043,426] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:59.054,046] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 42, out_left: 42
    [00:02:59.066,650] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 42 (-0xffffffd6)
    [00:02:59.079,315] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:02:59.089,904] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:02:59.100,494] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:02:59.112,030] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:3210: <= write client key exchange
    [00:02:59.124,542] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:59.135,131] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:59.145,751] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CERTIFICATE_VERIFY
    [00:02:59.158,843] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:3258: => write certificate verify
    [00:02:59.171,264] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7304: => derive keys
    [00:02:59.181,762] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7428: => calc verify
    [00:02:59.192,443] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7446: dumping 'calculated verify result' (32 bytes)
    [00:02:59.205,627] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7446: 0000:  d3 9c fe f1 e0 ce 24 a5 56 82 bd 2b 16 06 15 bd  ......$.V..+....
    [00:02:59.221,160] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7446: 0010:  19 1c 84 cc e8 85 aa 80 2d 15 f7 42 d7 36 27 de  ........-..B.6'.
    [00:02:59.236,450] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7447: <= calc verify
    [00:02:59.247,009] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7147: dumping 'session hash for extended master secret' (32 bytes)
    [00:02:59.261,505] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7147: 0000:  d3 9c fe f1 e0 ce 24 a5 56 82 bd 2b 16 06 15 bd  ......$.V..+....
    [00:02:59.277,038] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7147: 0010:  19 1c 84 cc e8 85 aa 80 2d 15 f7 42 d7 36 27 de  ........-..B.6'.
    [00:02:59.294,311] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7287: dumping 'premaster secret' (32 bytes)
    [00:02:59.306,793] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7287: 0000:  bf c0 2a 96 e5 2c 51 80 27 66 d8 a5 0e 21 f0 bc  ..*..,Q.'f...!..
    [00:02:59.322,326] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7287: 0010:  5d 41 db a2 42 c4 0f 01 31 61 dd 1b 2a df 17 33  ]A..B...1a..*..3
    [00:02:59.342,376] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8842: ciphersuite = TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:02:59.355,773] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8844: dumping 'master secret' (48 bytes)
    [00:02:59.368,011] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8844: 0000:  84 44 ee 1f 6c b4 f0 0b 83 da 63 07 b4 26 ef a2  .D..l.....c..&..
    [00:02:59.383,544] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8844: 0010:  63 17 6b 01 68 f5 34 87 7b b3 a0 09 9e f8 06 06  c.k.h.4.{.......
    [00:02:59.399,078] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8844: 0020:  df a9 ef f9 53 39 82 49 8b 48 d1 9a 31 42 29 39  ....S9.I.H..1B)9
    [00:02:59.414,398] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8845: dumping 'random bytes' (64 bytes)
    [00:02:59.428,466] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8845: 0000:  68 38 4e a6 a9 76 1e f1 85 31 c4 10 83 3c 9f e8  h8N..v...1...<..
    [00:02:59.445,953] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8845: 0010:  a3 7b 02 06 dd 59 b8 f7 44 4f 57 4e 47 52 44 01  .{...Y..DOWNGRD.
    [00:02:59.463,409] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8845: 0020:  cc 20 47 f4 c0 76 ad 72 58 95 42 f8 aa 7c b3 e1  . G..v.rX.B..|..
    [00:02:59.480,895] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8845: 0030:  45 a6 b4 fb cf 24 73 f5 ee 1f a3 76 53 0b da 35  E....$s....vS..5
    [00:02:59.498,107] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: dumping 'key block' (256 bytes)
    [00:02:59.511,993] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0000:  a1 ff d5 40 ed d0 e8 a4 51 60 c2 2c fb d7 29 08  [email protected]`.,..).
    [00:02:59.529,479] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0010:  76 b7 90 48 76 c2 83 b5 44 6d 61 ba f4 53 68 10  v..Hv...Dma..Sh.
    [00:02:59.546,936] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0020:  76 56 92 1a 9e 2f cc 95 01 b5 ea 41 6d b2 c8 f2  vV.../.....Am...
    [00:02:59.564,422] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0030:  6e d8 0b 6c 6d 39 3d 6b 48 b2 49 55 b1 ab 02 60  n..lm9=kH.IU...`
    [00:02:59.581,878] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0040:  78 de 9c 10 d7 b4 3a 21 29 11 94 b9 5d a6 37 aa  x.....:!)...].7.
    [00:02:59.599,365] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0050:  e8 57 ba e4 89 b0 cd 2a 91 f6 16 0c d6 74 51 d9  .W.....*.....tQ.
    [00:02:59.617,309] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0060:  fa 15 78 c6 09 51 2c 20 3a a1 3d d4 35 3f 25 80  ..x..Q, :.=.5?%.
    [00:02:59.634,765] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0070:  86 c0 42 f1 90 90 97 7b 8a ca 24 90 7f 58 35 00  ..B....{..$..X5.
    [00:02:59.652,221] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0080:  38 88 4a cb 42 8f ff 2e a1 b2 02 b9 6c a4 2d 44  8.J.B.......l.-D
    [00:02:59.669,708] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 0090:  af 31 fd 08 2d ca 45 66 5b a9 77 cf 4c a7 3d 2f  .1..-.Ef[.w.L.=/
    [00:02:59.687,164] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 00a0:  62 8e 23 23 a9 36 53 ba c8 12 bd 0c dc e6 3d b4  b.##.6S.......=.
    [00:02:59.704,620] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 00b0:  87 ed 69 b0 e0 60 78 56 e8 08 c8 0e f6 58 e0 3e  ..i..`xV.....X.>
    [00:02:59.722,106] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 00c0:  9e 18 92 0f 07 9f 77 0f 7f 50 f0 38 4d 7a e7 d8  ......w..P.8Mz..
    [00:02:59.739,562] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 00d0:  29 52 a0 ee 0e d8 4c 91 1d d4 be 74 6a 5f 6d 98  )R....L....tj_m.
    [00:02:59.757,019] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 00e0:  f1 8d 31 cd da c4 38 27 a7 94 01 7e 32 92 05 1b  ..1...8'...~2...
    [00:02:59.774,475] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8846: 00f0:  3a 12 cc ea 1c 26 b5 37 75 04 ce 2d 9e 4e cc c8  :....&.7u..-.N..
    [00:02:59.791,931] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8964: keylen: 16, minlen: 48, ivlen: 16, maclen: 20
    [00:02:59.805,358] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7355: <= derive keys
    [00:02:59.815,826] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:3280: <= skip write certificate verify
    [00:02:59.828,674] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:59.839,233] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:59.849,853] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_CHANGE_CIPHER_SPEC
    [00:02:59.863,555] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5317: => write change cipher spec
    [00:02:59.875,183] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:02:59.886,749] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:02:59.897,399] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 20, version = [3:3], msglen = 1
    [00:02:59.911,315] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (6 bytes)
    [00:02:59.926,666] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  14 03 03 00 01 01                                ......
    [00:02:59.942,993] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:59.953,582] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 6, out_left: 6
    [00:02:59.965,576] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 6 (-0xfffffffa)
    [00:02:59.978,118] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:02:59.988,708] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:02:59.999,298] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:03:00.010,864] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:5330: <= write change cipher spec
    [00:03:00.022,491] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:03:00.033,081] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:03:00.043,670] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_CLIENT_FINISHED
    [00:03:00.056,518] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8440: => write finished
    [00:03:00.067,291] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8274: => calc finished tls
    [00:03:00.078,460] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8291: dumping 'finished output' (32 bytes)
    [00:03:00.092,803] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8291: 0000:  d3 9c fe f1 e0 ce 24 a5 56 82 bd 2b 16 06 15 bd  ......$.V..+....
    [00:03:00.110,748] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8291: 0010:  19 1c 84 cc e8 85 aa 80 2d 15 f7 42 d7 36 27 de  ........-..B.6'.
    [00:03:00.128,967] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8301: dumping 'calc finished result' (12 bytes)
    [00:03:00.141,754] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8301: 0000:  24 fe 38 62 17 f6 d1 8f d3 df 35 73              $.8b......5s
    [00:03:00.156,677] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8305: <= calc finished
    [00:03:00.167,388] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8490: switching to new transform spec for outbound data
    [00:03:00.180,664] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2784: => write handshake message
    [00:03:00.192,260] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2944: => write record
    [00:03:00.202,819] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:0936: => encrypt buf
    [00:03:00.213,348] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:0958: dumping 'before encrypt: output payload' (16 bytes)
    [00:03:00.229,003] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:0958: 0000:  14 00 00 0c 24 fe 38 62 17 f6 d1 8f d3 df 35 73  ....$.8b......5s
    [00:03:00.246,459] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1099: dumping 'computed mac' (20 bytes)
    [00:03:00.260,528] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1099: 0000:  ed 2c d7 27 81 90 2c 8f 81 04 57 43 07 fa c6 54  .,.'..,...WC...T
    [00:03:00.277,862] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1099: 0010:  82 64 d4 c3                                      .d..
    [00:03:00.294,464] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1305: before encrypt: msglen = 48, including 16 bytes of IV and 12 bytes of padding
    [00:03:00.310,302] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:1475: <= encrypt buf
    [00:03:00.320,831] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3028: output record: msgtype = 22, version = [3:3], msglen = 64
    [00:03:00.334,838] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: dumping 'output record sent to network' (69 bytes)
    [00:03:00.350,372] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0000:  16 03 03 00 40 80 cf d5 9c 57 d9 8a 22 89 94 84  [email protected].."...
    [00:03:00.367,858] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0010:  d2 f0 cd c2 7e 0c 48 a7 7d fa 5d c7 e1 34 34 c0  ....~.H.}.]..44.
    [00:03:00.385,314] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0020:  13 d1 e7 a2 73 f8 d6 0c b4 17 dc cb b5 d8 6b 53  ....s.........kS
    [00:03:00.402,801] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0030:  88 45 9a 83 99 1d ac 86 ff 54 8d ca 85 2b 0e 9f  .E.......T...+..
    [00:03:00.420,135] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3033: 0040:  7d f6 c2 20 40                                   }.. @
    [00:03:00.436,370] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:03:00.446,990] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 69, out_left: 69
    [00:03:00.459,136] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 69 (-0xffffffbb)
    [00:03:00.471,801] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:03:00.482,391] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:03:00.492,980] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:03:00.504,516] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8543: <= write finished
    [00:03:00.515,289] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:03:00.525,878] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:03:00.536,499] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4582: client state: MBEDTLS_SSL_SERVER_CHANGE_CIPHER_SPEC
    [00:03:00.550,201] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:3386: => parse new session ticket
    [00:03:00.562,622] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:03:00.573,120] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:03:00.583,648] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:03:00.594,848] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:03:00.606,018] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4674: <= handshake
    [00:03:00.788,665] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=(nil), st=-104, user_data=(nil)
    [00:03:00.799,682] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Marked socket 0x2000ab88 as peer-closed
    [00:03:00.810,058] <err> net_sock_tls: TLS underlying socket poll error -104
      File "<stdin>", line 1, in <module>
    OSError: [Errno 104] ECONNRESET
    >>> print("TCP Connected.")[00:03:02.573,638] <dbg> net_sock: zsock_received_cb: (tcp_work): ctx=0x2000ab88, pkt=(nil), st=-116, user_data=(nil)
    [00:03:02.584,716] <dbg> net_sock: zsock_received_cb: (tcp_work): Marked socket 0x2000ab88 as peer-closed
    As far as I can tell, the reason the TLS connection fails is because of the cyphersuite being used:
    I think Google wants a newer and safer one. Will continue the investigation.
    Glad that you figured out the cert issue.
    Could you share your newest config now? Both the .conf files and your compiled down .config file?
    The reason why I ask for this is because you have two issue in your former log:
    [00:01:15.195,953] <err> net_sock_tls: TLS handshake error: -0x2700
    This is the error for the certificate, ie. this return code from mbedtls:
    https://github.com/nrfconnect/sdk-mbedtls/blob/v3.5.2-ncs2-branch/include/mbedtls/x509.h#L70-L71
    But, you are also seeing this error:
    [00:01:15.273,406] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000b0e8, pkt=(nil), st=-104, user_data=(nil)
    [00:01:15.284,393] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Set EOF flag on pkt 0x2005f0e0
    [00:01:16.216,979] <wrn> net_tcp: net_pkt alloc failure
    [00:01:17.026,123] <err> net_tcp: TCP failed to allocate buffer in retransmission
    This is a net buf based error issue, indicating that the network stack is out of memory.
    These are the ciphers that is listed in the client hello:
    [00:02:43.698,425] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:02:43.714,385] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:02:43.730,133] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:02:43.745,819] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:02:43.761,322] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:02:43.777,252] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:02:43.793,029] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:02:43.808,715] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:02:43.824,249] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:02:43.839,477] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:02:43.854,461] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA384
    [00:02:43.870,147] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:02:43.885,589] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:02:43.901,428] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:02:43.917,053] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:02:43.932,281] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:02:43.947,265] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:02:43.962,951] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:02:43.978,363] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:02:43.994,232] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0370: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    We can check what your computer uses via. openssl:
    openssl s_client -showcerts -servername google.com -connect google.com:443 --tls1_2 </dev/null
    Which will show the full CA chain, and some details related to the link:
    New, TLSv1.2, Cipher is ECDHE-ECDSA-CHACHA20-POLY1305
    Server public key is 256 bit
    Secure Renegotiation IS supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    SSL-Session:
    And here's the debug log from https_client when connecting to google.com:
    https_client_google_mbedtls_debuglog.txt
    LOG and shell seems to print things twice in this debug output, but filtering on the ciphers in the client hello shows >50 ciphers supported by the client:
    [00:00:19.557,220] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4520: client state: MBEDTLS_SSL_CLIENT_HELLO
    [00:00:19.557,312] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0919: => write client hello
    [00:00:19.557,617] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0486: dumping 'client hello, random bytes' (32 bytes)
    [00:00:19.557,922] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0486: 0000:  2f 0a 46 64 8f 33 a9 c3 29 c3 fc 5d de 2b 12 58  /.Fd.3..)..].+.X
    [00:00:19.558,258] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0486: 0010:  f5 cf 87 0d 27 a9 ca c3 0a 6a 3e 68 ad bc 9c 9e  ....'....j>h....
    [00:00:19.558,349] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0511: dumping 'session id' (0 bytes)
    [00:00:19.558,471] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: cca8, TLS-ECDHE-RSA-WITH-CHACHA20-POLY1305-S6
    [00:00:19.559,173] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 009f, TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
    [00:00:19.558,624] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: cca9, TLS-ECDHE-ECDSA-WITH-CHACHA20-POLY13056
    [00:00:19.558,776] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: ccaa, TLS-DHE-RSA-WITH-CHACHA20-POLY1305-SHA6
    [00:00:19.558,898] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c02c, TLS-ECDHE-ECDSA-WITH-AES-256-GCM-SHA384
    [00:00:19.559,051] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c030, TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384
    [00:00:19.559,326] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0ad, TLS-ECDHE-ECDSA-WITH-AES-256-CCM
    [00:00:19.559,448] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c09f, TLS-DHE-RSA-WITH-AES-256-CCM
    [00:00:19.559,600] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c024, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA384
    [00:00:19.560,272] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 0039, TLS-DHE-RSA-WITH-AES-256-CBC-SHA
    [00:00:19.559,722] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c028, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA384
    [00:00:19.559,875] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 006b, TLS-DHE-RSA-WITH-AES-256-CBC-SHA256
    [00:00:19.559,997] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c00a, TLS-ECDHE-ECDSA-WITH-AES-256-CBC-SHA
    [00:00:19.560,150] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c014, TLS-ECDHE-RSA-WITH-AES-256-CBC-SHA
    [00:00:19.560,424] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0af, TLS-ECDHE-ECDSA-WITH-AES-256-CCM-8
    [00:00:19.560,546] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0a3, TLS-DHE-RSA-WITH-AES-256-CCM-8
    [00:00:19.560,699] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c02b, TLS-ECDHE-ECDSA-WITH-AES-128-GCM-SHA256
    [00:00:19.560,821] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c02f, TLS-ECDHE-RSA-WITH-AES-128-GCM-SHA256
    [00:00:19.560,974] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 009e, TLS-DHE-RSA-WITH-AES-128-GCM-SHA256
    [00:00:19.561,096] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0ac, TLS-ECDHE-ECDSA-WITH-AES-128-CCM
    [00:00:19.561,218] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c09e, TLS-DHE-RSA-WITH-AES-128-CCM
    [00:00:19.561,370] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c023, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA256
    [00:00:19.561,523] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c027, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA256
    [00:00:19.561,645] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 0067, TLS-DHE-RSA-WITH-AES-128-CBC-SHA256
    [00:00:19.561,798] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c009, TLS-ECDHE-ECDSA-WITH-AES-128-CBC-SHA
    [00:00:19.561,920] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c013, TLS-ECDHE-RSA-WITH-AES-128-CBC-SHA
    [00:00:19.562,042] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 0033, TLS-DHE-RSA-WITH-AES-128-CBC-SHA
    [00:00:19.562,194] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0ae, TLS-ECDHE-ECDSA-WITH-AES-128-CCM-8
    [00:00:19.562,316] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0a2, TLS-DHE-RSA-WITH-AES-128-CCM-8
    [00:00:19.562,622] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0ff, TLS-ECJPAKE-WITH-AES-128-CCM-8
    [00:00:19.562,744] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 009d, TLS-RSA-WITH-AES-256-GCM-SHA384
    [00:00:19.562,866] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c09d, TLS-RSA-WITH-AES-256-CCM
    [00:00:19.563,018] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 003d, TLS-RSA-WITH-AES-256-CBC-SHA256
    [00:00:19.563,140] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 0035, TLS-RSA-WITH-AES-256-CBC-SHA
    [00:00:19.563,293] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c032, TLS-ECDH-RSA-WITH-AES-256-GCM-SHA384
    [00:00:19.563,446] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c02a, TLS-ECDH-RSA-WITH-AES-256-CBC-SH4
    [00:00:19.563,568] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c00f, TLS-ECDH-RSA-WITH-AES-256-CBC-SHA
    [00:00:19.564,147] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c0a1, TLS-RSA-WITH-AES-256-CCM-8
    [00:00:19.563,720] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c02e, TLS-ECDH-ECDSA-WITH-AES-256-GCM-S4
    [00:00:19.563,873] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c026, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA384
    [00:00:19.564,025] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c005, TLS-ECDH-ECDSA-WITH-AES-256-CBC-SHA
    [00:00:19.564,270] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 009c, TLS-RSA-WITH-AES-128-GCM-SHA256
    [00:00:19.564,422] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c09c, TLS-RSA-WITH-AES-128-CCM
    [00:00:19.564,544] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 003c, TLS-RSA-WITH-AES-128-CBC-SHA256
    [00:00:19.564,666] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: 002f, TLS-RSA-WITH-AES-128-CBC-SHA
    [00:00:19.564,819] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c031, TLS-ECDH-RSA-WITH-AES-128-GCM-SHA256
    [00:00:19.564,971] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c029, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA256
    [00:00:19.565,093] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c00e, TLS-ECDH-RSA-WITH-AES-128-CBC-SHA
    [00:00:19.565,246] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c02d, TLS-ECDH-ECDSA-WITH-AES-128-GCM-SHA256
    [00:00:19.565,399] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c025, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA256
    [00:00:19.565,551] <inf> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_client.c:0369: client hello, add ciphersuite: c004, TLS-ECDH-ECDSA-WITH-AES-128-CBC-SHA
    I think this issue is more related to the buffering than the amount of ciphers available when renegotiation is sent.
    If you share your full .config file, it should be possible to check your buffering in both the zephyr network subsys, as well as the overall system heap size.
    HĂĄkon
  • The lack of memory isn't such a big issue. Note that I mentioned that that error happens when I retry opening the socket in the same session. So, if I try once, it fails, then I try again and run out of memory. Most likely cause is that I do no freeing of the socket upon failure. But that's a small issue (for now) since the connection doesn't work in the first place.
    Regarding the cyphers: it's interesting that in our project Mbedtls decides to expose only 9 cyphers, and even so, google.com selects the weakest of them all and ultimately drops the connection.
    6724.prj.conf2514.nrf7002dk_nrf5340_cpuapp_ns.conf4670.configs.c
    I've attached all config files to this message. The Kconfig I'll paste here as a code section since the site doesn't allow uploading this type of file directly:
    # This file is part of the MicroPython project, http://micropython.org/
    # The MIT License (MIT)
    # Copyright 2020 NXP
    # Permission is hereby granted, free of charge, to any person obtaining a copy
    # of this software and associated documentation files (the "Software"), to deal
    # in the Software without restriction, including without limitation the rights
    # to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
    # copies of the Software, and to permit persons to whom the Software is
    # furnished to do so, subject to the following conditions:
    # The above copyright notice and this permission notice shall be included in
    # all copies or substantial portions of the Software.
    # THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    # IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    # FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
    # AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
    # LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
    # OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
    # THE SOFTWARE.
    menu "MicroPython Options"
    config MICROPY_CONFIGFILE
    	string "Configuration file"
    	default "mpconfigport_minimal.h"
    config MICROPY_HEAP_SIZE
    	int "Heap size"
    	default 49152
    config MICROPY_VFS_FAT
    	bool "FatFS file system"
    config MICROPY_VFS_LFS1
    	bool "LittleFs version 1 file system"
    config MICROPY_VFS_LFS2
    	bool "LittleFs version 2 file system"
    config CONNECTION_IDLE_TIMEOUT
    	int "Time to be waited for a station to connect"
    	default 30
    # choice WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_CHOICE
    #     default WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG
    # endchoice
    config NRF70_QSPI_ENCRYPTION_KEY
    	string "16 bytes QSPI encryption key, only for testing purposes"
    	depends on BOARD_NRF7002DK_NRF5340_CPUAPP
    	help
    	  Specify the QSPI encryption key
    config SOFTAP_SAMPLE_DHCPV4_POOL_START
    	string "Start address of DHCPv4 pool"
    	default "192.168.1.2"
    	help
    	  Set the start IP address of DHCPv4 pool.
    config STA_CONN_TIMEOUT_SEC
    	int "Overall Connection timeout i.e., time to be waited for a station to connect and get an IP address"
    	# Zephyr DHCP retry is 1 minute, so set the default to 70 seconds
    	default 70
    	# 512 has no special meaning, just a reasonable upper limit
    	range 0 512
    	help
    	  Specify the connection timeout, in seconds. This is the overall timeout i.e., time to be waited for
    	  a station to connect and get an IP address. DHCP retries should be taken into account when setting
    	  this value. If the timeout is set to 0, the connection will not timeout.
    config STA_SAMPLE_START_WIFI_THREAD_STACK_SIZE
    	int "Stack size for Wi-Fi start thread"
    	default 4096
    	help
    	  Set the stack size for the Wi-Fi start thread.
    config SAMPLE_TFM_MBEDTLS
    	bool "Use TF-M and MbedTLS"
    	depends on NRF_MODEM_LIB
    	help
    	  Use TF-M and MbedTLS in this sample instead of using
    	  the offloaded TLS stack in the modem.
    config HTTPS_HOSTNAME
    	string "HTTPS hostname"
    	default "google.com"
    endmenu # MicroPython Options
    source "Kconfig.zephyr"
    Also, please see my latest run, which was in my last comment (before this one). The most recent error that I got is -104:
    [00:02:15.651,733] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:15.662,322] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2368: message length: 69, out_left: 69
    [00:02:15.674,468] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2375: ssl->f_send() returned 69 (-0xffffffbb)
    [00:02:15.687,103] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2402: <= flush output
    [00:02:15.697,692] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3081: <= write record
    [00:02:15.708,251] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2905: <= write handshake message
    [00:02:15.719,787] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8541: <= write finished
    [00:02:15.730,560] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2354: => flush output
    [00:02:15.741,119] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2363: <= flush output
    [00:02:15.751,739] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4580: client state: MBEDTLS_SSL_SERVER_CHANGE_CIPHER_SPEC
    [00:02:15.765,441] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls12_client.c:3386: => parse new session ticket
    [00:02:15.777,832] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4298: => read record
    [00:02:15.788,330] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2156: => fetch input
    [00:02:15.798,828] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2296: in_left: 0, nb_want: 5
    [00:02:15.810,028] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:2316: in_left: 0, nb_want: 5
    [00:02:15.821,197] <wrn> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:4672: <= handshake
    [00:02:15.892,517] <dbg> net_sock: zsock_received_cb: (rx_q[0]): ctx=0x2000ab88, pkt=(nil), st=-104, user_data=(nil)
    [00:02:15.903,533] <dbg> net_sock: zsock_received_cb: (rx_q[0]): Marked socket 0x2000ab88 as peer-closed
    [00:02:15.913,879] <err> net_sock_tls: TLS underlying socket poll error -104
  • Also worth mentioning: when I compare my logs to the ones you provided, I noticed that google send a lot of "DOWNGRD" messages to our board. Example:
    [00:01:12.319,671] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8843: dumping 'random bytes' (64 bytes)
    [00:01:12.333,709] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8843: 0000:  68 3d 72 b9 5c 14 a5 f7 55 d2 34 72 87 9f 35 1f  h=r.\...U.4r..5.
    [00:01:12.351,165] <dbg> mbedtls: zephyr_mbedtls_debug: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:8843: 0010:  95 36 4b 51 48 2f c1 95 44 4f 57 4e 47 52 44 01  .6KQH/..DOWNGRD.
    While your logs show no such message.
    Edit: I'm still hoping that you'll agree to a call so we can solve this faster. Slight smile
