Hello Nordic team,
I'm developing firmware for a custom board based on the nRF54L15, where the LEDs are connected to GPIOs on port 2. These pins do not support hardware PWM, so I want to use the nordic,nrf-sw-pwm driver to enable PWM functionality in software.
I based my setup on the nRF54L15DK and PWM LED sample and added the following overlay:
sw_pwm: pwm_sw {
status = "okay";
compatible = "nordic,nrf-sw-pwm";
channel-gpios = <&gpio2 8 GPIO_ACTIVE_HIGH>;
clock-prescaler = <0>;
generator = <&timer00>;
#pwm-cells = <3>;
pwm_leds {
compatible = "pwm-leds";
status = "okay";
red_pwm_led: led_0 {
pwms = <&sw_pwm 0 PWM_MSEC(20) PWM_POLARITY_NORMAL>;
label = "Red PWM LED";
&timer00 {
status = "okay";
My prj.conf
CONFIG_LOG=y CONFIG_LOG_MODE_IMMEDIATE=y CONFIG_PWM=y CONFIG_PWM_NRF_SW=y CONFIG_LED=y
However, the build fails with the following error:
nrfx_gpiote.h:75:33: error: 'NRF_GPIOTEDT_N_S_soc_S_peripheral_50000000_S_gpio_50400_P_gpiote_instance_IDX_0_PH_P_instance' undeclared here (not in a function)
It seems that the macro NRF_GPIOTEDT_* is not properly generated.
Questions:
Is
nordic,nrf-sw-pwmsupported on the nRF54L15? -
What is the correct way to enable and use the
nrf-sw-pwmdriver with GPIO port 2 on this platform? -
Are there any limitations or required configurations for using
GPIOTEorTIMERwithnrf-sw-pwmon nRF54L15? -
Could you recommend the proper way to integrate and configure this driver in the project?
SDK version 2.9.0
I also tried using SDK version 3.0.0. It also has this error, but besides it there is also an error related to RTC
Thank you in advance!
Oleksandr
