Trouble with getting the nrf5340_audio_dk working
I have three nrf5340_audio_dk boards that were programmed with premade images for a BIS audio demo: one gateway and two headsets. I'm currently using VSCode with nRF Connect SDK and toolchain v2.9.1
The first thing I'm trying to do is build the nrf5340_audio project so that I can program it myself and make sure that I have a clean starting point
Then I need to modify the firmware to be in stereo mode and switch to the P10 external codec interface because I have a devkit for a stereo codec I need to wire up and test ASAP.
I'm currently stuck on getting one of the headset boards successfully reprogrammed. I used the buildprog tool with this .json file:
"nrf5340_audio_dk_snr": 1050189286,
"nrf5340_audio_dk_dev": "headset",
"channel": "right"
and then I modified both the prj.conf and prj_release.conf to add:
CONFIG_AUDIO_DEV=1
CONFIG_TRANSPORT_BIS=y
Then I built and programmed it using "python buildprog.py -c both -b release -d headset -p"
It looks like it built and programmed fine, and the .config file in \build\nrf5340_audio includes CONFIG_AUDIO_DEV and CONFIG_TRANSPORT_BIS so that looks correct.
It's not working though. LED3 is flashing and the LED that illuminates the devkit case lights up either magenta or blue depending on whether I have it set to right or left as it should, but there's no audio (I know the gateway is transmitting because I can hear audio on my unmodified headset board) and I see this on the board's serial port:
HL [00:26:39.470,764] <err> bt_mgmt_ctlr_cfg: No response from IPC or controll
er
HL [00:26:39.470,794] <err> bt_mgmt_ctlr_cfg: ERR_CHK Err_code: [-116] @ line:
67
HL [00:26:39.470,794] <err> os: r0/a1: 0x00000003 r1/a2: 0x00000002 r2/a3:
0x00000001
HL [00:26:39.470,794] <err> os: r3/a4: 0x00000003 r12/ip: 0x20002f58 r14/lr:
0x000545db
HL [00:26:39.470,794] <err> os: xpsr: 0x01000025
HL [00:26:39.470,794] <err> os: s[ 0]: 0x00000043 s[ 1]: 0x00000200 s[ 2]:
0x00000200 s[ 3]: 0x01000003
HL [00:26:39.470,825] <err> os: s[ 4]: 0x00000000 s[ 5]: 0x20003d48 s[ 6]:
0x00000000 s[ 7]: 0x00010913
HL [00:26:39.470,825] <err> os: s[ 8]: 0x000108e1 s[ 9]: 0x00039099 s[10]:
0x20003d48 s[11]: 0x00000000
HL [00:26:39.470,825] <err> os: s[12]: 0x000000a9 s[13]: 0x00000000 s[14]:
0x031fbc42 s[15]: 0x00038e19
HL [00:26:39.470,825] <err> os: fpscr: 0x00000000
HL [00:26:39.470,855] <err> os: Faulting instruction address (r15/pc): 0x00006
ef6
HL [00:26:39.470,886] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
HL [00:26:39.470,886] <err> os: Fault during interrupt handling
HL [00:26:39.470,886] <err> os: Current thread: 0x20004a20 (idle)
HL [00:26:39.470,886] <err> error_handler: Caught system error -- reason 3. En
tering infinite loop
Chatgpt says that serial port stuff means that the application core is trying to communicate with the network core, but the Net core isn’t responding over IPC.
Please help me figure out what I'm doing wrong.
Also, since my next step is to modify this firmware to support my new external codec, I'd really like to be able to debug. I see in the online documentation HERE a note that says "Building and programming using the nRF Connect for VS Code extension is currently not supported." What is causing that problem? If I'm just developing on one core or the other can I debug on that core? If it is possible to use VSCode for this, what would I need to put in my build configuration? I'm not sure what to put in fields like "Extra CMAKE arguments" etc to build for BIS receiver.
Thanks!
Glen
  • Well I guess erasing the gateway was a happy accident - now that I've successfully reprogrammed that and my headset board, audio is flowing. I guess the version I'm building is somehow incompatible with whatever was programmed on here before.
    A few questions:
    1) Is there a reason for that that I might need to be concerned about? Does this audio standard change from build to build? Are there other options beyond just CONFIG_TRANSPORT_BIS and getting the correct AUDIO_DEV that I need to be aware of? It still does not successfully connect with my other original board
    2) One of my original questions was about developing and specifically debugging with VSCode - what are the limitations there? Will I be able to debug?
    Glen
  • Hi Glen,
    You do not need to be concerned but you need to test your application to ensure it works as expected. Which audio standard are you referring to?
    There is documentation page which shows how to configure audio applications.
    You can look at these documentation resources - debugging applicationhow to debug and debugging concepts.
    Dejan
  • Thanks Dejan,
    The debugging question was related to the note in the documentation that for the audio project "Building and programming using the nRF Connect for VS Code extension is currently not supported." I assume that is because of the dual core processor and the complicated buildprog script, I was just curious if there was more information available on that, maybe if I'm just making changes to the application core I could build/program/debug the normal way?
    I've made good progress on this and I'm now starting to get my stereo codec working, but the sound is not right. I need to modify the project to use stereo instead of mono.
    1) Do I need to make changes in the BIS gateway or does it always broadcast stereo?  I found a config option called "CONFIG_MONO_TO_ALL_RECEIVERS". Do I just set that to =n for stereo?
    2) What do I need to change on the receiver side? I figured this would be documented somewhere but I haven't found it yet
    Glen
  • Hi Glen,
    Building and flashing application using VS Code extension should still work but using buildprog script helps in building and flashing of multiple kits simultaneously.
    BIS gateway always broadcasts stereo.
    There is no documentation on this. There was an unofficial test sample which was provided as-is without any warranty or guaranty that it will work. You can look at this discussion
    Dejan
  • Can you help me get my build configuration set up? If I use "Create a new application" to copy the audio application to a local folder and try to set up a build configuration for it I can't get it to compile. Here's what I've got now but I'm clearly missing something.
