Incorrect output from nPM1300 when powered through VBUS
Hi there,
I've designed a custom board implementing the nPM1300 and am currently in the process of examining the board without any firmware. Throughout testing, I have tried to power on the board using VBUS and VBAT.
The issue I am facing is:
- The output of VSYS and VOUT1/VOUT2 are correct when powering directly through VBAT using a power supply set at 3.7V. The current draw of the system sits at around 30 mA.
- The output of VSYS is incorrect (approx. 2V) when powered directly through VBUS using a power supply set at 5V. The current draw of the system is 0-0.5 mA.
- This causes the output of VOUT1/VOUT2 and an external buck regulator that I have connected to VSYS to be incorrect.
- The only additional connection to VBUS apart from the nPM1300 VBUS input is an ESD protection diode.
- I have also tried powering through VBUS using a USB cable connected to a power bank and laptop. When using the power bank, it delivers 5.15V into VBUS for around 20 seconds before dropping to around 2V.
Is this a hardware or firmware issue? I understand that there are some functions that can only be programmed through firmware, however I was under the assumption that the buck regulators and basic functionality (including being powered through VBUS) were possible without any firmware commands.
Thank you!
  • Hi Tharaka,
    After doing some testing today, I've found the following:
    - It turns out VBUS is the one collapsing from 5.15 V to around 2 V after approx. 20 seconds. When powered by VBUS, VSYS starts at around 2V while VBUS sits at 5.15V and then begins to decay once VBUS collapses.
    - I tried to short the VSET1 and VSET2 resistors using tweezers on start-up, however there was no change to the VBUS/VSYS behaviour.
    - I tried powering through VBUS and then shorting VBUS and VSYS to bypass the regulator to charge up the capacitors. From there, I tried turning off and then turning on the PSU quickly to see if it still worked afterwards. It did not.
    - I've attached a screenshot of the schematic below. The three 10uF capacitors were implemented similar to the application example. However, I did add an additional 4.7uF capacitor to VSYS for an external buck regulator connected to the VSYS rail. Could it be this addition that is adding too much capacitance to VSYS?
    - The capacitance at VOUT1 and 2 are 10uF.
    Thank you!
  • Hi
    So based on your new information,
    VBUS is collapsing, not VSYS:
    This indicates the power supply itself is shutting down/limiting, not the nPM1300's internal regulation.
    VBUS is an input for nPM1300. The only way it can make it collapse is pulling too much current on it compared to what it can deliver. However, when VBUS is at 2.00 V, then nPM1300 will not pull any current on it,  so it it stays at 2.00V it is not because nPM1300 pulls current.
    So the problem appears to be upstream of the nPM1300, not within it.
    Could there be a possible short or excessive loading somewhere in the circuit draw curremnt from VBUS?
    Or issue with PSU ?
    Also,
    Disabling DCDCs didn't help:
    Rules out excessive DCDC inrush current as the root cause
    Bypass test failed:
    Pre-charging capacitors via VBUS-VSYS short didn't create lasting fix ,confirms it's not just a startup transient issue
    This extra 4.7 uF capacitance at VSYS looks reasonable and shouldn't cause the issue.
    Regards
    Tharaka
  • Hi Tharaka, thank you for the ideas.
    - When testing VBUS using a power supply connected directly to the rail, there do not seem to be any signs of high current draw causing the power supply to shut down or limit. The PSU current remains near-zero but sometimes pulls a couple mA.
    - The only thing connected to VBUS is an ESD protection diode placed near the USB port.
    - I will double check tomorrow whether I successfully turned off BUCK1 and 2, so I will give an update on that.
    - If the power source seems to be the issue, why would it function normally once bypassing the regulator temporarily with the VBUS/VSYS short?
    - Would you have any other suggestions for testing that I could do for a better idea of the root cause?
    Thank you Slight smile
  • - After investigating today, you were correct in assuming that VBUS collapsed due to the power supply. The power bank would anomalously 'turn off' and run at 2V after a period of time. I decided to test again using an oscilloscope and power through a USB cable connected to a PC. When powering through a PC, VBUS no longer collapses. However, VSYS sits at 1.8V with small periodic voltage spikes. On the other hand, when powered through VBAT, VSYS sits at VBAT stably.
    - I am unable to turn off BUCK1 and 2 when powered through VBUS and shorting VSET1 and VSET2. However, when powered through VBAT, I am able to turn off the bucks as intended.
  • Have you tried disconnecting the buck converter TPSM82821S you have in the schematic? Maybe it has too high inrush current at startup that will exceed the current limit.
