Please refer to the link below. How can I configure the Commission Flow according to the requirements?
Yes in the link that you attached, it looks like there is an added field "commissioning-flow" but we don't see any usage of it in the code - which again is understandable, as FW should not have such information.
But anyway, this is correct the commissioning flow should be configured when generating QR code - which is not bound to the FW build process.
-Priyanka
Then I’d like to confirm one last thing: does Nordic’s generate_nrfconnect_chip_factory_data.py already handle this task by default? Because the parameters of generate_nrfconnect_chip_factory_data.py don’t seem to include this option.
You can test it with this command and you should see" Custom flow: 0 (STANDARD)"
./chip-tool payload parse-setup-payload <QR code>
We do not have option to specify the commissioning-flow in these scripts. It would be useful for the QR code generation indeed - however I guess you are using your own scripting for Matter QR code generation.
-Priyanka
I'm using Nordic's generate_nrfconnect_chip_factory_data.py to generate the QR code, so does that mean this Python script can't change the Commission Flow?
