Please refer to the link below. How can I configure the Commission Flow according to the requirements?
Of course you can change the Commissioning Flow inside QR code using Python script. Here is the variable: https://github.com/nrfconnect/sdk-connectedhomeip/blob/d56ca73159fd5973d839b14714f0a08b9695d4a8/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py#L425
Thank you for your assistance
I discovered another issue. Modifying the "generate_nrfconnect_chip_factory_data.py" script only affects the files generated by Python, such as build.txt. However, the QR code printed by the firmware during boot-up (i.e., [SVR]SetupQRCode) remains unchanged. After tracing through the SDK, I found that this value is hardcoded. Is there a way to modify it without changing the SDK itself?
It looks like you already have an ongoing ticket for the similar issue. Please continue your conversation there.
How to retrieve the Matter QR code?
As mentioned in the ticket, my colleague will get back to you there as soon as he gets updates from the developers.
Due to the summer vacations we are slightly short staffed and hence the slight delays.
-Priyanka
