Problems to use fixed PIN value to perform pairing
Hello everyone,
I'm using the ble_app_uart example code in my MDBT50Q-U512k. I have been made some modifications according to my application. I need use fixed value pin to pairing my device with my smartphone, but I can't do it because the modifications that I'm trying to use, generate random PIN. I need use 555555 PIN value to pairing... Below here is my code:
 * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_hids.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "ble_dis.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_wdt.h"
#include "nrfx_wdt.h"
#include "app_error.h"
//#include "nrf_drv_wdt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define MANUFACTURER_NAME "Nordic"
#define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                0                                           /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(10000, UNIT_10_MS)             /**< Connection supervisory timeout (10 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
#define PINO_TX NRF_GPIO_PIN_MAP(1,5)
#define PINO_RX NRF_GPIO_PIN_MAP(0,19)
BLE_HIDS_DEF(m_hids, NRF_SDH_BLE_PERIPHERAL_LINK_COUNT,
             0, // No Input Reports
             0, // No Output Reports
             0  // No Feature Reports
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
// Declarar buffers estáticos para as chaves
static ble_gap_enc_key_t m_enc_key_own;
static ble_gap_id_key_t  m_id_key_own;
static ble_gap_enc_key_t m_enc_key_peer;
static ble_gap_id_key_t  m_id_key_peer;
//uint8_t passkey[] = "012345"; // 4 dígitos + dois zeros, se preferir
static ble_gap_sec_keyset_t m_sec_keyset;
static ble_gap_sec_params_t m_sec_params;
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},
    {BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE}
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_HID);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
    if (p_evt->type == BLE_NUS_EVT_COMM_STARTED)
    printf("NUS COMM_STARTED: notificações ativadas!\n");
    const char msg[] = "Dispositivo pareado com sucesso!\r\n";
    uint16_t len = strlen(msg);
    uint32_t err_code = ble_nus_data_send(&m_nus, (uint8_t*)msg, &len, m_conn_handle);
    if (err_code != NRF_SUCCESS)
        printf("Erro ao enviar após COMM_STARTED: 0x%X\n", err_code);
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
// Adicione esta nova função em algum lugar do seu main.c
// Substitua a sua função hids_init por esta versão corrigida
static void hids_init(void)
    ret_code_t               err_code;
    ble_hids_init_t          hids_init_obj;
    uint8_t                  hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler               = NULL;
    hids_init_obj.error_handler             = NULL;
    hids_init_obj.is_kb                     = false;
    hids_init_obj.is_mouse                  = false;
    // CONFIGURAÇÃO DE SEGURANÇA CORRETA PARA SDKs MAIS NOVOS
    // Define a permissão para a característica "HID Information"
    //BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hids_init_obj.hid_info_attr_perm);
    hids_init_obj.hid_information.bcd_hid        = 0x0111; // Versão 1.11
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    // Como não temos reports (teclas, etc), deixamos os contadores em 0
    hids_init_obj.inp_rep_count         = 0;
    hids_init_obj.p_inp_rep_array       = NULL;
    hids_init_obj.outp_rep_count        = 0;
    hids_init_obj.p_outp_rep_array      = NULL;
    hids_init_obj.feature_rep_count     = 0;
    hids_init_obj.p_feature_rep_array   = NULL;
     * AS LINHAS ABAIXO CAUSARAM O ERRO E FORAM REMOVIDAS,
     * POIS 'rep_char_attr' NÃO EXISTE MAIS NESTA STRUCT.
     * hids_init_obj.rep_char_attr.read_perm  = SEC_OPEN;
     * hids_init_obj.rep_char_attr.write_perm = SEC_OPEN;
     * hids_init_obj.rep_char_attr.cccd_write_perm = SEC_OPEN;
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
    hids_init();
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            //sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            printf("Bluetooth Conectado\n");
            //err_code = sd_ble_gap_authenticate(m_conn_handle, &m_sec_params);
            //APP_ERROR_CHECK(err_code);
            printf("Bluetooth Desconectado\n");
            printf("Respondendo BLE_GAP_EVT_SEC_PARAMS_REQUEST\n");
            // Preencha os ponteiros do keyset corretamente
            memset(&m_sec_keyset, 0, sizeof(m_sec_keyset));
            m_sec_keyset.keys_own.p_enc_key  = &m_enc_key_own;
            m_sec_keyset.keys_own.p_id_key   = &m_id_key_own;
            m_sec_keyset.keys_peer.p_enc_key = &m_enc_key_peer;
            m_sec_keyset.keys_peer.p_id_key  = &m_id_key_peer;
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_SUCCESS,
                                                   &m_sec_params,
                                                   &m_sec_keyset);
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
                uint8_t passkey[6] = {'5', '5', '5', '5', '5', '5'}; // BLE espera 6 caracteres
                printf("Enviando PIN para pareamento...\n");
                err_code = sd_ble_gap_auth_key_reply(
                    p_ble_evt->evt.gap_evt.conn_handle,
                    BLE_GAP_AUTH_KEY_TYPE_PASSKEY,
                    passkey
        case BLE_GAP_EVT_PASSKEY_DISPLAY:
            //char passkey_str[7];
            //memcpy(passkey_str, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, 6);
            //passkey_str[6] = '\0'; // termina a string
            //printf("PIN para pareamento: %s\n", passkey_str);
            ////printf("PIN para pareamento: %06u\n", p_ble_evt->evt.gap_evt.params.passkey_display.passkey);}
        case BLE_GAP_EVT_AUTH_STATUS:
            const ble_gap_evt_auth_status_t * auth_status = &p_ble_evt->evt.gap_evt.params.auth_status;
            printf("Auth status: 0x%02X\n", auth_status->auth_status);
            printf("Bonded: %d\n", auth_status->bonded);
            //if (auth_status->auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
            //    const char msg[] = "Pareamento concluído com sucesso!\r\n";
            //    uint16_t len = strlen(msg);
            //    err_code = ble_nus_data_send(&m_nus, (uint8_t*)msg, &len, m_conn_handle);
            //    if (err_code != NRF_SUCCESS)
            //        printf("Erro ao enviar notificação: 0x%X\n", err_code);
        }break;
        //    const ble_gap_evt_auth_status_t * auth_status = &p_ble_evt->evt.gap_evt.params.auth_status;
        //    printf("Auth status: 0x%02X\n", auth_status->auth_status);
        //    printf("Bonded: %d\n", auth_status->bonded);
        //} break;
            // Agora sim, inicie o pareamento aqui
            //ble_gap_sec_params_t sec_params = m_sec_params;
            //err_code = sd_ble_gap_authenticate(m_conn_handle, &sec_params);
        //case BLE_GATTS_EVT_SYS_ATTR_MISSING:
        //    err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0, 0);
        //    APP_ERROR_CHECK(err_code);
        //    break;
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = PINO_RX,//19,//RX_PIN_NUMBER,
        .tx_pin_no    = PINO_TX,//23, //TX_PIN_NUMBER,
        .rts_pin_no   = 0,//RTS_PIN_NUMBER,
        .cts_pin_no   = 0,//CTS_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;//BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
    //printf("Erro no advertising start: 0x%08X", err_code);
//Peer_manager-------------------------------------------------------------------------------------------
// Peer Manager Init
static void peer_manager_init(void)
    memset(&m_sec_params, 0, sizeof(m_sec_params));
    m_sec_params.bond           = 1;
    m_sec_params.mitm           = 1;  // MITM protection ativado (necessário para PIN)
    m_sec_params.lesc           = 0;
    m_sec_params.io_caps        = BLE_GAP_IO_CAPS_DISPLAY_ONLY; // ? Sem entrada ou saída
    m_sec_params.oob            = 0;
    m_sec_params.min_key_size   = 7;
    m_sec_params.max_key_size   = 16;
    m_sec_params.kdist_own.enc  = 1;
    m_sec_params.kdist_own.id   = 1;
    m_sec_params.kdist_peer.enc = 1;
    m_sec_params.kdist_peer.id  = 1;
//Dis_init----------------------------------------------------------------------------------------------------
static void dis_init(void)
    ble_dis_init_t dis_init_obj;
    memset(&dis_init_obj, 0, sizeof(dis_init_obj));
    ble_srv_ascii_to_utf8(&dis_init_obj.manufact_name_str, (char *)MANUFACTURER_NAME);
    dis_init_obj.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init_obj);
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
    printf("\n[ERRO CRÍTICO]\n");
    printf("ID: 0x%08lX\n", id);
    printf("PC: 0x%08lX\n", pc);
    printf("INFO: 0x%08lX\n", info);
    // Se info for um ponteiro válido, pode conter mais informações:
    error_info_t * err_info = (error_info_t *)info;
    printf("Código de erro: 0x%08lX\n", err_info->err_code);
    printf("Linha: %lu\n", err_info->line_num);
    printf("Arquivo: %s\n", err_info->p_file_name);
    //NRF_BREAKPOINT_COND; // Permite parar no debug
    //while (1); // trava para análise
//watchdog-------------------------------------------------------------------------------------------
nrf_drv_wdt_channel_id m_channel_id;  // Canal do Watchdog
void wdt_event_handler(void)
    printf("Watchdog atuando..."); // usa a funo no init// Se o watchdog não for alimentado a tempo, o sistema será reiniciado
void wdt_init(void)
    uint32_t err_code;
    // Inicializa o watchdog com um timeout de 5 segundos
    err_code = nrf_drv_wdt_init(NULL, wdt_event_handler);
    // Aloca um canal para alimentar o watchdog
    err_code = nrf_drv_wdt_channel_alloc(&m_channel_id);
    // Ativa o watchdog
    nrf_drv_wdt_enable();
void feed_wdt(void)
    nrf_drv_wdt_channel_feed(m_channel_id); // Alimenta o watchdog
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    //buttons_leds_init(&erase_bonds);
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    dis_init();
    services_init();
    peer_manager_init();
    advertising_init();
    conn_params_init();
    //wdt_init(); // Inicializa o Watchdog
    // Start execution.
    printf("\r\nModulo BLE Nordic\r\n");
    advertising_start();
    // Enter main loop.
    for (;;)
        //feed_wdt();  // Alimenta o watchdog para evitar reset
        idle_state_handle();
I'm using SDK nRF5_SDK_17.1.0_ddde560 version, and I modified my ble_nus_init function inside the ble_nuc.c file replacing the features to using secure pairing.
uint32_t ble_nus_init(ble_nus_t * p_nus, ble_nus_init_t const * p_nus_init)
    ble_uuid_t            ble_uuid;
    ble_uuid128_t         nus_base_uuid = NUS_BASE_UUID;
    ble_add_char_params_t add_char_params;
    VERIFY_PARAM_NOT_NULL(p_nus);
    VERIFY_PARAM_NOT_NULL(p_nus_init);
    // Initialize the service structure.
    p_nus->data_handler = p_nus_init->data_handler;
    /**@snippet [Adding proprietary Service to the SoftDevice] */
    // Add a custom base UUID.
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_nus->uuid_type;
    ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
    // Add the service.
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &ble_uuid,
                                        &p_nus->service_handle);
    // Add the RX Characteristic.
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid                     = BLE_UUID_NUS_RX_CHARACTERISTIC;
    add_char_params.uuid_type                = p_nus->uuid_type;
    add_char_params.max_len                  = BLE_NUS_MAX_RX_CHAR_LEN;
    add_char_params.init_len                 = sizeof(uint8_t);
    add_char_params.is_var_len               = true;
    add_char_params.char_props.write         = 1;
    add_char_params.char_props.write_wo_resp = 1;
    //add_char_params.read_access  = SEC_OPEN;
    //add_char_params.write_access = SEC_OPEN;
    add_char_params.read_access  = SEC_MITM;
    add_char_params.write_access = SEC_MITM;
    err_code = characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->rx_handles);
        return err_code;
    // Add the TX Characteristic.
    /**@snippet [Adding proprietary characteristic to the SoftDevice] */
    add_char_params.uuid              = BLE_UUID_NUS_TX_CHARACTERISTIC;
    add_char_params.max_len           = BLE_NUS_MAX_TX_CHAR_LEN;
    add_char_params.char_props.notify = 1;
    //add_char_params.cccd_write_access = SEC_OPEN;
    add_char_params.write_access      = SEC_NO_ACCESS;
    add_char_params.cccd_write_access = SEC_MITM;
    return characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->tx_handles);
Anyone can help me to solve it? Regards
