nrf54L15 LFRC 32KHz clock configuration issue
We are trying to get our nRF54L15 running, but are running into clock issues. The hardware is configured without an external 32kHz crystal, so we want to rely on the NRF54's internal RC for our low-speed clock. We need to configure the GRTC to use the internal RC, not the external LFXO. We have set the following clock-related Kconfig options to accomplish this:
CONFIG_CLOCK_CONTROL=y
CONFIG_CLOCK_CONTROL_NRF=y
CONFIG_NRFX_CLOCK=y
CONFIG_NRF_GRTC_TIMER=y
CONFIG_NRF_GRTC_START_SYSCOUNTER=y
CONFIG_NRFX_GRTC=y
CONFIG_NRFX_CLOCK_LF_SRC_RC=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
We also have our device-tree set up as follows (relevant snippets):
#include <nordic/nrf54l15_cpuapp.dtsi>
&lfxo {
    status = "disabled";
    load-capacitors = "internal";
    load-capacitance-femtofarad = <7000>;
    clock-frequency = <32768>;
&hfxo {
    status = "okay";
    clock-frequency = <32000000>;
    load-capacitance-femtofarad = <17000>; // 17pF per BM15C datasheet
&grtc {
    owned-channels = <0 1 2>;
    status = "okay";
&clock {
    status = "okay";
However, when we run our application with the debugger enabled, we are stuck in clock initialization -- in the GRTC initialization. github.com/.../nrfy_grtc.h. More precisely, we get stuck inside of the sys counter ready check. Upon inspecting the GRTC registers, we see that the GRTC is configured in CLKSEL to use the LFXO. However, it should be it should be configured to use the RC per my Kconfig options. I have verified from KConfig output that the necessary config options are enabled.
We are at a loss as to why the GRTC is not configured to use the RC, as it is explicitly set to do so in our configuration. Any help would be greatly appreciated.
  • Hi PPatel,
    As far as I know you would need to remove the lfxo from the device tree. Please add this to an overlay file (app.overlay for example):
    /delete-node/ &lfxo;
    grtc {
          /delete-property/ clocks;
          /delete-property/ clock-names;
          clocks = <&pclk>;
          clock-names = "hfclock";
    And this is also required: https://github.com/zephyrproject-rtos/zephyr/pull/89670
    Please try to test with one of our sample in the SDK so we can align easier.
  • Hi Hung,
    I added the changes you suggested.
    I modified our prj.conf / XXX_defconfig to the following:
    # Enable UART driver
    CONFIG_SERIAL=y
    # Enable console
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    # Enable GPIO
    CONFIG_GPIO=y
    # Enable MPU
    CONFIG_ARM_MPU=y
    # Enable hardware stack protection
    CONFIG_HW_STACK_PROTECTION=y
    # use grtc as system timer
    # Enable LFRC (internal RC oscillator)
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_FREQUENCY=32768
    # Disable LFXO (external 32kHz crystal)
    # Disable synthesized LFCLK from HFCLK
    Also modified the Blinky sample to the minimal:
    #include <stdio.h>
    #include <zephyr/kernel.h>
    #define SLEEP_TIME_MS   1000
        uint32_t counter = 0;
        while (1) {
            printf("Counter: %u\n", counter++);
            k_msleep(SLEEP_TIME_MS);
        return 0;
    With the above changes,
    For NRF54L15 DevKit I see GRTC (GLOBAL_GRTC_NS)-->CLKCFG(0x00020001)-->CLKSEL-->LFLPRC and can confirm Counter value incrementing on UART.
    With the same changes,
    For FANSTEL BM15C (NRF54L15) module, I see GRTC (GLOBAL_GRTC_NS)-->CLKCFG(0x00000001)-->CLKSEL-->LFXO.
    I get stuck with this call stack:
    nrfy_grtc_sys_counter_start(NRF_GRTC_Type * p_reg, _Bool busy_wait) (PATH\modules\hal\nordic\nrfx\haly\nrfy_grtc.h:987)
    nrfx_grtc_syscounter_start(_Bool busy_wait, uint8_t * p_main_cc_channel) (PATH\modules\hal\nordic\nrfx\drivers\src\nrfx_grtc.c:566)
    sys_clock_driver_init() (PATH\zephyr\drivers\timer\nrf_grtc_timer.c:483)
    z_sys_init_run_level(enum init_level level) (PATH\zephyr\kernel\init.c:377)
    z_cstart() (PATH\zephyr\kernel\init.c:801)
    z_prep_c() (PATH\zephyr\arch\arm\core\cortex_m\prep_c.c:220)
    z_arm_reset() (PATH\zephyr\arch\arm\core\cortex_m\reset.S:207)
    Can you please suggest if I need additional changes to make this work on FANSTEL BM15C module ?
    Thanks!
  • Hi PPatel,
    Could you tell how you built for the DK and how you built for the FANSTEL board ?
    I assume you have different board files ?
    Have you added the overlay I mentioned in the last reply ?
    If you simply flash the hex file built for the DK on the FANSTEL, would it work ?
    I would guess there could be an issue with the board file made for the FANSTEL.
    Please also check the .config file in \build\blinky\zephyr\ when you build for FANSTEL and check if you have CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y there. Please try to compile to the same .config file when you build for the DK.
  • Hi Hung,
    Yes, I have 2 different board files for the DK and the FANSTEL board.
    Yes, I added overlay but it still doesn't work.
    Flashing HEX built for the DK on the FANSTEL doesn't work.
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC=y and all the other CONFIGs which worked on the DK, I copied those directly for the FANSTEL. But it still doesn't work.
  • Hi PPatel,
    I did a quick test here and it seems to work in my case. I cut SB4 and SB3 on the DK so that the crystal was not connected. When I flashed the default Blinky it doesn't run (meaning the XTAL has been disconnected) but when I modify the blinky to use RC it start to blink.
    Could you try to flash the following hex file to see if it run on the FANSTEL ?
    I assume you don't have anything special on FANSTEL that may block the run of the blink example ? For example if P2.09 (LED0) is used for something else ?
    Have you pulled this https://github.com/zephyrproject-rtos/zephyr/pull/89670 There are 2 commits needed.
    6428.merged.hex
    blinky_RC_2.zip
