Thingy 91 x Do not connect to the cloud
Dir Sir
I have bought thingy 91 X for evaluation purposes
After activation of the Sim and, I have a constant green Led on
The device does not connect to the web application
This the LINK Status command on the AT command replay
mosh:~$ link status
Modem functional mode: normal
Network registration status: Connected - roaming
Modem config for system mode: LTE-M
Modem config for LTE preference: No preference, automatically selected by the modem
Currently active system mode: LTE-M
Battery voltage: 4934 mV
Modem temperature: 23 C
Device ID: nrf-359404230233869
Operator full name: "HOT-strong together"
Operator short name: "HM "
Operator PLMN: "42507"
Current cell id: 11261442 (0x00ABD602)
Current phy cell id: 234
Current band: 3
Current TAC: 24132 (0x5E44)
Current rsrp: 38: -103dBm
Current snr: 22: -2dB
Mobile network time and date: 25/07/06,10:07:37+12
PDP context info 1:
CID: 0
PDN ID: 0
PDP context active: yes
PDP type: IP
APN: onomondo
IPv4 MTU: 1360
IPv4 address: 100.92.99.234
IPv6 address: ::
IPv4 DNS address: 172.30.8.5, 172.30.8.6
IPv6 DNS address: ::, ::
What is the problem ? and how can I solve it ?
    can you provide application logs and modem trace? What application are you running? Just modem shell?
  • I am using of the shelf, our of the BOX Thingy 91 X tracker application
    According to the on line training: Introducing the Thingy:91 X – The Ultimate Cellular IoT Prototyping Platform - YouTube
    After start up the box LED should blink in blue indication that device has connected to Nordic RF cloud, should be out of the box experience, But I am getting constant green LED, What does it mean ? according to the manual waiting for GPS info, is this correct ? Please me the commands you want me to insert so you can get the systems logs that you want to check
    Thanks
    Ishay
  • Also see attached Modem log
    mosh:~$ link status
    Battery voltage: 4731 mV
    Modem temperature: 27 C
    Operator full name: "HOTMOBILE"
    Operator short name: "HOTMOBILE"
    Current cell id: 4708099 (0x0047D703)
    Current phy cell id: 320
    Current band: 3
    Current TAC: 2411 (0x096B)
    Current rsrp: 28: -113dBm
    Current snr: 24: 0dB
    Mobile network time and date: 25/07/09,03:58:12+12
    PDP context info 1:
    CID: 0
    PDN ID: 0
    PDP type: IP
    APN: onomondo
    IPv4 MTU: 1360
    IPv6 address: ::
    So it seems that the modem is connected but no data is transmitted to the cloud
