Update issue with bootloader chain
Hi everyone, I'm trying to set up a bootloader chain using sysbuild (NSIB → MCUboot → APP) so that MCUboot can act as an upgradable bootloader. I'm working with the nRF54L15 and followed the guides:
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/bootloaders_dfu/mcuboot_nsib/bootloader_adding_sysbuild.html
https://docs.nordicsemi.com/bundle/ncs-3.0.1/page/nrf/applications/nrf_desktop/bootloader_dfu.html
With the firmware flashed, the full boot chain works fine. However, when I attempt to update the application using dfu_application.zip via the nRF Connect Device Manager, after the upload and test, the device reboots, but MCUboot can't find a bootable image.
Here's the relevant log output before and after the DFU update:
00> Booting nRF Connect SDK v3.0.1-9eb5615da66b
00> Using Zephyr OS v4.0.99-77f865b8f8d0
00> Fprotect disabled. No protection applied.
00> Attempting to boot slot 0.
00> Attempting to boot from address 0x10800.
00> I: Trying to get Firmware version
00> I: Firmware signature verified.
00> Firmware version 1
00> I: Setting monotonic counter (version: 1, slot: 0)
00> Booting (0x10800).
00> Booting MCUboot v2.1.0-dev-ae1ee57f3906
00> Using nRF Connect SDK v3.0.1-9eb5615da66b
00> I: Starting Direct-XIP bootloader
00> I: Primary slot: version=0.2.1+0
00> I: Secondary slot: version=0.2.1+0
00> I: Image 1 Primary slot: Image not found
00> I: Image 0 loaded from the primary slot
00> I: Image 1 loaded from the secondary slot
00> I: Bootloader chainload address offset: 0x2b000
00> I: Image version: v0.2.1
00> I: Jumping to the image slot
00> Booting My Application v0.2.1-475bc1ecb46c
(Connection lost)
00> I: Secondary slot: version=0.2.2+0
00> I: No slot to load for image 1
00> E: Unable to find bootable image
  • Is this from any customization that you've done or does the default nsib bootloader source code trigger this warning?
    It is the default nsib bootloader source code
    Did you move a way from the direct-xip solution you had?
    Nope, this is my full sysbuild.conf:
    SB_CONFIG_BOOT_SIGNATURE_TYPE_ED25519=y
    SB_CONFIG_MCUBOOT_SIGNATURE_USING_KMU=y
    SB_CONFIG_BOOT_SIGNATURE_KEY_FILE="${ZEPHYR_BASE}/../m_band/ota/keys/ed25519_priv_key.pem"
    SB_CONFIG_BOOTLOADER_MCUBOOT=y
    SB_CONFIG_MCUBOOT_MODE_DIRECT_XIP_WITH_REVERT=y
    SB_CONFIG_SECURE_BOOT_APPCORE=y
    SB_CONFIG_SECURE_BOOT_SIGNING_KEY_FILE="${ZEPHYR_BASE}/../m_band/ota/keys/secure_boot_ed25519_priv_key.pem"
    SB_CONFIG_MCUBOOT_APP_SYNC_UPDATEABLE_IMAGES=y
    SB_CONFIG_MCUBOOT_UPDATEABLE_IMAGES=1
    SB_CONFIG_SECURE_BOOT_MCUBOOT_VERSION="2.1.0+0"
    Sorry for the delayed response. Andreas will be away for some time, so I’ll be looking into this issue in the meantime.
    Could you share a minimal project that I can run locally to reproduce the issue? I’m asking because I don’t see any specific problem or not sure why it is failing and may need to check internally.
    Also, I believe the smp_svr_mini_boot sample aligns with your use case, is that correct?
    Kind Regards,
    Abhijith
    You're correct that the smp_svr_mini_boot sample aligns in some ways, but my issue specifically relates to migrating to a two-stage bootloader setupnot the single-stage Direct-XIP configuration used in that sample.
    The issue started after enabling the following sysbuild configuration flags:
    Also, to help isolate the problem, I tried running the smp_svr_mini_boot sample using SDK 3.1.0-preview4, but encountered the following error:
    /home/tcunha/zp/zephyr/scripts/kconfig/kconfig.py: /home/tcunha/zp/nrf/soc/nordic/nrf71/Kconfig.defconfig:33: error: couldn't parse 'default $(dt_nodelabel_int_prop,grtc,clock-frequency) if NRF_GRTC_TIMER': macro expanded to blank string
    CMake Error at /home/tcunha/zp/zephyr/cmake/modules/kconfig.cmake:396 (message):
      command failed with return code: 1
    Sorry for getting back to you a bit late. It's summer vacation here in Norway, and many are on vacation, which creates some delay in getting back to the issue.
    It's not recommended to try this version of the SDK, as it is not a stable release. I recommend using version 3.0.2, as it is the latest stable release.
    Kind Regards,
    Abhijith
    Thanks for the reply, totally understand about the summer holidays.
    I get your point about using a stable SDK, but it looks like the smp_svr_mini_boot sample isn’t available in version 3.0.2. That’s why I tried it with 3.1.0-preview4 to isolate the issue.
    Is there an alternative sample you’d recommend?
