Update issue with bootloader chain
Hi everyone, I'm trying to set up a bootloader chain using sysbuild (NSIB → MCUboot → APP) so that MCUboot can act as an upgradable bootloader. I'm working with the nRF54L15 and followed the guides:
https://docs.nordicsemi.com/bundle/ncs-latest/page/nrf/app_dev/bootloaders_dfu/mcuboot_nsib/bootloader_adding_sysbuild.html
https://docs.nordicsemi.com/bundle/ncs-3.0.1/page/nrf/applications/nrf_desktop/bootloader_dfu.html
With the firmware flashed, the full boot chain works fine. However, when I attempt to update the application using dfu_application.zip via the nRF Connect Device Manager, after the upload and test, the device reboots, but MCUboot can't find a bootable image.
Here's the relevant log output before and after the DFU update:
00> Booting nRF Connect SDK v3.0.1-9eb5615da66b
00> Using Zephyr OS v4.0.99-77f865b8f8d0
00> Fprotect disabled. No protection applied.
00> Attempting to boot slot 0.
00> Attempting to boot from address 0x10800.
00> I: Trying to get Firmware version
00> I: Firmware signature verified.
00> Firmware version 1
00> I: Setting monotonic counter (version: 1, slot: 0)
00> Booting (0x10800).
00> Booting MCUboot v2.1.0-dev-ae1ee57f3906
00> Using nRF Connect SDK v3.0.1-9eb5615da66b
00> I: Starting Direct-XIP bootloader
00> I: Primary slot: version=0.2.1+0
00> I: Secondary slot: version=0.2.1+0
00> I: Image 1 Primary slot: Image not found
00> I: Image 0 loaded from the primary slot
00> I: Image 1 loaded from the secondary slot
00> I: Bootloader chainload address offset: 0x2b000
00> I: Image version: v0.2.1
00> I: Jumping to the image slot
00> Booting My Application v0.2.1-475bc1ecb46c
(Connection lost)
00> I: Secondary slot: version=0.2.2+0
00> I: No slot to load for image 1
00> E: Unable to find bootable image
  • Hi again,
    I've picked up this case again since I stumbled across it when working on a similar issue. I believe what is wrong here is the keys you're using to sign the image with. In the original description it looks like MCUboot rejects the new app image in the update because it can not verify it. This is reflected in
    This sample is a bit different from what you want, but I believe you can dissect out what you don't want and add. The readme should also be sufficient w.r.t description of signing both NSIB and MCUBoot with the keys that you need to add at what step etc
    My sample Your project
    NSIB White check mark White check mark
    MCUboot White check mark White check mark
    BLE FOTA White check mark White check mark
    SPI External flash White check mark X
    Direct-XIP X White check mark
    Static partitioning White check mark White check mark
    KMU White check mark White check mark
    Custom private keys White check mark White check mark
    Please let me know if this is helpful. I may spend some time next week attempting to make a version that does not use SPI for external flash and uses direct-xip, but I can't give any guarantees that I have time available for said project since I belive this sample should get you there.
    8_54l15_chain_fota_ext.zip
    Andreas
  • Hi Andreas,
    Thanks for following up, and sorry for the late reply.
    I don’t think the issue is related to image verification. If that were the case, the logs would explicitly show a verification failure, and I wouldn’t be able to boot into the application after flashing. In my case, I can boot into the app just fine.
    I used your sample as a baseline and then added Direct-XIP and my pm_static setup that i previously provided, but I still ran into the same issue. The app boots fine after the initial flash, and I can see two images available. But after the upload of an updated image, I get the error that no bootable image can be found
    1425.8_54l15_chain_fota_ext.zip
    I had the time to review your app today. Initially I thought it had to do with your pm_static, but it's due to how the app is built. As I highlighted back in August, the sample I sent you is built to have the MCUboot secondary app on the external flash, whereas direct-xip requires it to be placed on the internal flash. You will have to remove anything that refers to placing the mcuboot secondary application slot on the external flash in sysbuild.conf and sysbuild/mcuboot.conf
    Andreas
  • Hi Andreas,
    I believe I have removed all references to placing the mcuboot secondary application slot on external flash, but I’m still seeing the same issue. In my original application, the secondary application was not placed on external flash either.
    Here are the logs and the sample I used.
    *** Booting MCUboot v2.1.0-dev-ae1ee57f3906 ***
    *** Using nRF Connect SDK v3.0.1-9eb5615da66b ***
    *** Using Zephyr OS v4.0.99-77f865b8f8d0 ***
    I: Primary   slot: version=4.9.0+0
    I: Secondary slot: version=4.9.0+0
    I: Bootloader chainload address offset: 0x4a000
    I: Image version: v4.9.0
    *** Booting My Application v4.9.0-7de04188b692 ***
    Starting 7_54L15_fota_ext sample
    I: 26 Sectors of 4096 bytes
    I: alloc wra: 0, f70
    I: data wra: 0, 10
    I: SoftDevice Controller build revision:
    I: 89 9a 50 8a 95 01 9c 58 |..P....X
    I: fc 39 d2 c1 10 04 ee 02 |.9......
    I: 64 ce 25 be             |d.%.
    I: HW Platform: Nordic Semiconductor (0x0002)
    I: HW Variant: nRF54Lx (0x0005)
    I: Firmware: Standard Bluetooth controInside main loop after encrypted dfu
    Connected
    I: Secondary slot: version=5.9.0+0
    8_54l15_chain_fota_no_ext.zip
  • Hi again,
    I revisited this case and I see that I may have misunderstood the status of this ticket a while back. Apologies for that.. Did you ever succeed in configuring direct XIP for either the sample you've been working on or for the Peripheral LBS sample as described here? https://docs.nordicsemi.com/bundle/ncs-3.0.1/page/nrf/app_dev/device_guides/nrf54l/fota_update.html#build_configuration_additions_for_mcuboot_in_the_direct-xip_mod
    Andreas
