nRF SDK 2.9.2: BT_CTLR_RX_BUFFERS unsatisfied dependencies: BT_LL_SW_SPLIT (=n)
I need help with this issue. I'm updating the code from SDK 2.4.2 to SDK 2.9.2. I had change the device tree to HWM2 and I'm using sysbuild.
The build log is showing this warning:
warning: BT_CTLR_RX_BUFFERS (defined at subsys/bluetooth\controller/Kconfig:225) was assigned the
value '10' but got the value ''. Check these unsatisfied dependencies: BT_LL_SW_SPLIT (=n). See
docs.zephyrproject.org/.../kconfig.html and/or look up
BT_CTLR_RX_BUFFERS in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
After I had set CONFIG_BT_LL_SW_SPLIT in HCI_IPC_CONF I got more errors:
After a day trying to figure out what I'm missing I decided to use the hello world sample with nrf5340dk and I got the same error. Below I copied the log.
./cfs-file/__key/communityserver-discussions-components-files/4/compilation-log.txt
Here my test code using the hello_world sample.
/cfs-file/__key/communityserver-discussions-components-files/4/0005.hello_5F00_world.zip
