[NRF9151] Modem does not connect after SIM deactivate/reactivate
I’m using the Thingy:91X board with the nRF9151 chip, modem firmware version 2.0.2, and SDK version 2.9.0.
We’re encountering a serious issue: the modem does not reconnect after the SIM has been deactivated and then reactivated.
I’ve tried:
  • sys_reboot(SYS_REBOOT_COLD)
  • Placing the modem offline (lte_lc_offline())
  • Shutting down the modem library (nrf_modem_lib_shutdown())
  • Forcing a hard reboot via the watchdog
None of these approaches has worked.
Do you have any suggestions for resolving this issue?
The only workaround so far (which isn’t acceptable) is to manually power the device off and on.
Mathieu
  • I tried retesting using the lte_lc_power_off / lte_lc_normal cycle on disconnection, but now my device doesn’t connect at all, it just hangs after the “Searching” event (the same thing happens when I deactivate/reactivate the SIM but this SIM was always activated).
    I enabled tracing as described here: https://docs.nordicsemi.com/bundle/ncs-2.9.0/page/nrf/libraries/modem/nrf_modem_lib/nrf_modem_lib_trace.html, but all I get are these logs:
    [00:00:01.526,733] <inf> modem_trace_backend: Modem_trace RTT backend channel 1
    [00:00:01.526,733] <inf> nrf_modem_lib_trace: Trace thread ready
    [00:00:01.534,637] <inf> nrf_modem_lib_trace: Trace level override: 2
    [00:00:01.782,501] <err> nrf_modem_lib_trace: trace_backend.write failed with err: -63
    [00:00:08.544,372] <err> nrf_modem_lib_trace: trace_backend.write failed with err: -63
    [00:00:13.396,179] <inf> lte_monitor: Network: Searching
    I haven’t changed anything in this software version, and it was working fine two weeks ago. I’m really lost.
  • I haven’t changed anything in this software version, and it was working fine two weeks ago. I’m really lost.
    You added the power_off/normal cycle and the modem trace via RTT.
    I would start removing both and retest. If you use versioning, that may be easier to checkout a last working version and retest that.
    And then adding one change step by step and see, if both stops the device from working or just one.
    I'm used to trace the mode via UART and sometimes use the FLASH to keep a the trace for a time span (and afterward write that to the UART).
    I never tried the RTT interface for the modem trace before, but at least using a nRF9151-DK, NCS 2.9.2, Ubuntu doesn't work for me either. I enabled it via the snippet, it start to report quite a lot of "trace_backend.write failed with err: -63". But using
    nrfjprog --reset && JLinkRTTLogger -Device NRF9151_XXCA -If SWD -Speed 50000  modemtracesrtt.bin
    (see How to capture nrf9160 modem traces using RTT? )
    only reports:
    SEGGER J-Link RTT Logger
    Compiled Mar  5 2025 14:51:21
    (c) 2016-2017 SEGGER Microcontroller GmbH, www.segger.com
             Solutions for real time microcontroller applications
    Default logfile path: /home/achim/.config/SEGGER
    Connected to:
      SEGGER J-Link (unknown)
      S/N: 1051240195
    Searching for RTT Control Block...OK.
    3 up-channels found:
    0: Terminal
    1:
    2:
    Selected RTT Channel description:
      Index: 1
      Name:
    Output file: modemtracesrtt.bin
    Getting RTT data from target. Press any key to quit.
    Transfer rate: 0 Bytes/s Data written: 0 Bytes 0
    Not sure, may be this requires someone from Nordic to retest the modem trace via RTT.
  • You added the power_off/normal cycle and the modem trace via RTT.
    That’s the problem: I flashed the same software that worked two weeks ago, but now this board won’t connect, even though it connects fine on another board. I think we received a defective batch, I’ve already thrown away five or six boards.
    The modem sends a “Searching” event and then does nothing. That’s why I tried enabling modem tracing. But when I read its output over UART the data appears garbled, even though my DTS settings (baud rate, pins, etc.) are correct and I’m using 1,000,000 baud / 8 data bits / 1 start bit / 1 stop bit / no parity. I don’t know why the output isn’t legible, so I’m switching to RTT instead.
    I really don’t understand why I’m having modem issues; I’ve never seen this with the Thingy:91 and I haven’t changed anything in my code.
    On startup I call:
    1. nrf_modem_lib_init()
    2. modem_info_init()
    3. modem_info_rsrp_register()
    4. lte_lc_connect_async()
    On shutdown I call:
    • lte_lc_offline()
    I have another board running exactly the same software and it works fine (I’d rather not deactivate/reactivate its SIM because I need it for something else).
    Am I doing something wrong in my initialization sequence?
    Can you show how you enable tracing over UART and RTT?
    You can read more about modem tracing and modem trace module in the documentation.
    Dejan
  • I don't know, how Mathieu enabled the modem trace, in my test I did it with the snippets "west build -S nrf91-modem-trace-uart ..." and "west build -S nrf91-modem-trace-rtt ...".
    With the UART it works, with RTT I wasn't able to get the trace and got only warnings in the logging console instead.
    NCS 2.9.2, nRF9151-DK, mfw 2.0.2.
    Ubuntu, JLinkRTTLogger V8.18
    (As already mentioned above.)
    But the modem trace is rather a side issue.
