[NRF9151] Modem does not connect after SIM deactivate/reactivate
I’m using the Thingy:91X board with the nRF9151 chip, modem firmware version 2.0.2, and SDK version 2.9.0.
We’re encountering a serious issue: the modem does not reconnect after the SIM has been deactivated and then reactivated.
I’ve tried:
  • sys_reboot(SYS_REBOOT_COLD)
  • Placing the modem offline (lte_lc_offline())
  • Shutting down the modem library (nrf_modem_lib_shutdown())
  • Forcing a hard reboot via the watchdog
None of these approaches has worked.
Do you have any suggestions for resolving this issue?
The only workaround so far (which isn’t acceptable) is to manually power the device off and on.
Mathieu
  • Hi Mathieu,
    Have you made some progress?
    Have you been able to capture modem trace, possibly following Achim's suggestion using modem trace snippet?
    Which mobile network operator does your device connect to?
    Due to frequent rebooting via watchdog, it could be that reset loop restriction was triggered.
    Dejan
  • Hi !
    We were not really able to make some progress.
    We were not able to get modem traces. I was not able to do it with UART1, since the uart1 is used for other purposes, and the connectivy_bridge is not used anymore. That's why we redirect all our app uart to RTT.
    So, i tried to use the RTT modem trace snippet.
    I also get the -63 error.
    By the way, i get nothing on channel 2, about modem traces. It remains empty
    Here is the command i used to build
    of course, i used the link given for the snippet.
    Well, it seems i won't be able to get some modem traces :)
    About the operator, i tried with a Onomondo sim until now.   My device connects to Bouygues Telecom Network (by using onomondo or Tele2).
    Tomorrow, i will check with some TELE2 sim, and a brand new Thingy91X. I'll give you more infos then.
    For additional information about capturing modem traces, you can refer to these links in documentation
    modem tracing and capturing modem trace using Cellular Monitor.
    I am looking forward to your update.
    Dejan
    Here are some news :)
    We were not able to plug our app with the tracing tools. But we are really stuck, so we changed our approch.
    We reproduced the problem by using the Nordic modem shell example.
    You will find attach all the command we did.  At the beginning, we are able to reach the network, we generate the problem by deactivating the sim and reactivating it later after having  done a at+CFUN=0 and at+CFUN1 (2/3 minutes after),
    By the end of the file, you can see we tried several stuff to connect but it never work.
    THe only way to reach the network again is by power cycling the thingy91x
    What are your thoughts ?
    > at AT+CFUN=1
    at AT+CFUN=1
    OK
    mosh:~$ > at AT%XCONNSTAT=1
    at AT%XCONNSTAT=1
    OK
    mosh:~$ > at AT%XCONNSTAT?
    at AT%XCONNSTAT?
    %XCONNSTAT: 0,0,0,0,0,0
    OK
    mosh:~$ > at AT+CMEE=1
    at AT+CMEE=1
    OK
    mosh:~$ > at AT%XSIM=1
    at AT%XSIM=1
    OK
    mosh:~$ > at AT+CEREG=5
    at AT+CEREG=5
    OK
    mosh:~$ > at AT%MDMEV=1
    at AT%MDMEV=1
    OK
    mosh:~$ > at AT%CESQ=1
    at AT%CESQ=1
    OK
    mosh:~$ > at AT+CGSN=1
    at AT+CGSN=1
    +CGSN: "359404230274905"
    OK
    mosh:~$ > at AT+CGMM
    at AT+CGMM
    nRF9151-LACA
    OK
    mosh:~$ > at AT+CEMODE?
    at AT+CEMODE?
    +CEMODE: 2
    OK
    mosh:~$ > at AT+CMEE?
    jH AT+CMEE?+SQ
    mosh:~$ at AT+CNEC?> at AT+CNEC?
    H+CNEC: 16
    OK
    mosh:~$ > at AT+CGEREP?
    at AT+CGEREP?
    +CGEREP: 1,0
    OK
    mosh:~$ > at AT+CIND=1,1,1
    at AT+CIND=1,1,1
    OK
    mosh:~$ > at AT+COPS=3,2
    at AT+COPS=3,2
    OK
    mosh:~$ > at AT+CGDCONT?
    at AT+CGDCONT?
    OK
    mosh:~$ > at AT+CGACT?
    at AT+CGACT?
    OK
    mosh:~$ > at AT+CESQ
    at AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
    mosh:~$ > at AT%XSIM?
    at AT%XSIM?
    %XSIM: 1
    OK
    mosh:~$ > at AT+CPIN?
    at AT+CPIN?H+CPIN: READY
    OK
    mosh:~$ > at AT+CIMI
    at AT+CIMI
    240075823634698
    OK
    mosh:~$ > at AT+CNEC=24
    at AT+CNEC=24
    OK
    mosh:~$ > at AT+CEER
    at AT+CEER
    OK
    mosh:~$ > at AT+CGEREP=1
    at AT+CGEREP=1
    Network registration status: searching
    OK
    Currently active system mode: LTE-M
    RRC mode: Connected
    mosh:~$ > at AT%XPOFWARN=1,30
    at AT%XPOFWARN=1,30
    LTE cell changed: ID: 25533958, Tracking area: 52644
    OK
    mosh:~$ > at AT%XVBATLVL=1
    at AT%XVBATLVL=1
    OK
    mosh:~$ > at AT+CGMI
    at AT+CGMI
    Nordic Semiconductor ASA
    OK
    mosh:~$ > at AT+CGMR
    at AT+CGMR
    mfw_nrf91x1_2.0.2
    OK
    at AT+CGSN
    359404230274905
    OK
    mosh:~$ > at AT%XMODEMUUID
    at AT%XMODEMUUID
    %XMODEMUUID: 320176d5-9f40-45fc-923b-2661ec18d547
    OK
    mosh:~$ > at AT%XDATAPRFL?
    at AT%XDATAPRFL?
    %XDATAPRFL: 2
    OK
    mosh:~$ > at AT+CEREG?
    at AT+CEREG?
    +CEREG: 5,2,"CDA4","01859E06",7
    OK
    mosh:~$ > at AT+CFUN?
    at AT+CFUN?
    +CFUN: 1
    OK
    at AT%CESQ=1
    OK
    mosh:~$ > at AT+CSCON=1
    at AT+CSCON=1
    OK
    mosh:~$ > at AT+CSCON?
    at AT+CSCON?
    +CSCON: 1,1
    OK
    mosh:~$ > at AT+CPAS
    at AT+CPAS
    +CPAS: 0
    OK
    mosh:~$ > at AT+CEDRXRDP
    at AT+CEDRXRDP
    +CEDRXRDP: 0
    OK
    mosh:~$ > at AT%XTIME=1
    at AT%XTIME=1
    OK
    mosh:~$ > at AT%CONEVAL
    at AT%CONEVAL
    %CONEVAL: 6
    OK
    mosh:~$ > at AT%XCBAND=?
    at AT%XCBAND=?
    %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66,85)
    OK
    at AT%XCBAND
    %XCBAND: 20
    OK
    mosh:~$ > at AT%HWVERSION
    at AT%HWVERSION
    %HWVERSION: nRF9151 LACA A0A
    OK
    mosh:~$ > at AT%XMODEMTRACE=1,2
    OK
    mosh:~$ > at AT%XSYSTEMMODE?
    at AT%XSYSTEMMODE?
    %XSYSTEMMODE: 1,1,1,3
    OK
    mosh:~$ > at AT%XICCID
    at AT%XICCID
    %XICCID: 89462038075015721859
    OK
    mosh:~$ > at AT%XEMPR?
    at AT%XEMPR?
    %XEMPR:
    OK
    at AT+CGDCONT?
    +CGDCONT: 0,"","","",0,0
    OK
    mosh:~$ > at AT+COPS?
    at AT+COPS?H+COPS: 0
    OK
    mosh:~$ > at AT%XMONITOR
    at AT%XMONITOR
    %XMONITOR: 2
    OK
    mosh:~$ > at AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    mosh:~$ > at AT+CPINR="SIM PIN2"
    +CPINR: "SIM PIN2",3
    OK
    mosh:~$ > at AT+CPINR="SIM PUK"
    +CPINR: "SIM PUK",10
    OK
    mosh:~$ > at AT+CPINR="SIM PUK2"
    +CPINR: "SIM PUK2",10
    OK
    at AT%XSIM?H%XSIM: 1
    OK
    PDN event: PDP context 0 activated
    PDN event: PDP context 0, PDN type IPv4 only allowed
    Modem domain event: Search done
    Network registration status: Connected - roaming
    PSM parameter update: TAU: 3240, Active time: -1 seconds
    Modem config for system mode: LTE-M - NB-IoT - GNSS
    Modem config for LTE preference: LTE-M is preferred, but PLMN selection is more important
    r׋e:       5046 mV
    Modem temperature:     25 C
    mosh:~$ Device ID:             nrf-359404230274905
    Operator full name:   "Orange F"
    Operator short name:  "Orange F"
    Operator PLMN:        "20801"
    Current cell id:       25533958 (0x01859E06)
    Current phy cell id:   290
    Current band:          20
    Current TAC:           52644 (0xCDA4)
    Current rsrp:          29: -112dBm
    Current snr:           24: 0dB
    Mobile network time and date: 25/08/06,14:34:44+08
    PDP context info 1:
    CID:                0
    PDN ID:             0
    PDP context active: yes
    PDP type:           IP
    APN:                m2m.tele2.com
    IPv4 MTU:           1280
    IPv4 address:       10.165.181.55
    IPv6 address:       ::
    IPv4 DNS address:   130.244.127.161, 130.244.127.169
    IPv6 DNS address:   2a00:800:1000:3::1, 2a00:800:1000:4::1
    RRC mode: Idle
    RRC mode: Connected
    Network registration status: not registered
    PDN event: PDP context 0 network detach
    RRC mode: Idle
    [00:04:44.344,329] <wrn> lte_lc: Registration rejected, EMM cause: 7, Cell ID: 25533958, Tracking area: 52644, LTE mode: 7
    mosh:~$ > at at+cfun=4
    at at+cfun=4
    Currently active system mode: None
    OK
    LTE cell changed: ID: -1, Tracking area: -1
    mosh:~$ > at at+cfun=0
    at at+cfun=0
    OK
    mosh:~$ > at at+cfun=1
    at at+cfun=1
    OK
    OK
    mosh:~$ > at AT%XSIM?H%XSIM: 1
    %XSIM: 1
    OK
    mosh:~$ >
    mosh:~$ >
    at AT%XMONITOR
    %XMONITOR: 5,"Orange F","Orange F","20801","CDA4",7,20,"01859E06",290,6400,31,28,"","11100000","11100000","01001001"
    OK
    mosh:~$ > at AT%XSIM=0
    at AT%XSIM=0
    ERROR
    at AT%XSIM
    ERROR
    at AT%XSIM=1
    OK
    mosh:~$ > at AT+CFUN=1
    at AT+CFUN=1
    OK
    at AT%XCONNSTAT=1
    OK
    at AT%XCONNSTAT?
    OK
    at AT+CMEE=1
    OK
    at AT%XSIM=1
    OK
    at AT+CEREG=5
    OK
    at AT%MDMEV=1
    OK
    at AT%CESQ=1
    OK
    at AT+CGSN=1
    OK
    at AT+CGMM
    nRF9151-LACA
    OK
    at AT+CEMODE?
    +CEMODE: 2
    OK
    at AT+CMEE?
    +CMEE: 1
    OK
    mosh:~$ > at AT+CNEC?
    at AT+CNEC?H+CNEC: 16
    OK
    at AT+CGEREP?
    +CGEREP: 1,0
    OK
    at AT+CIND=1,1,1
    OK
    at AT+COPS=3,2
    OK
    at AT+CGDCONT?
    +CGDCONT: 0,"IP","m2m.tele2.com","10.161.250.43",0,0
    OK
    at AT+CGACT?
    +CGACT: 0,1
    OK
    at AT+CESQ
    +CESQ: 99,99,255,255,17,32
    OK
    OK
    OK
    at AT+CIMI
    240075823634698
    OK
    at AT+CNEC=24
    OK
    at AT+CEER
    +CEER: "ESM 50"
    OK
    at AT+CGEREP=1
    OK
    at AT%XPOFWARN=1,30
    OK
    at AT%XVBATLVL=1
    OK
    at AT+CGMI
    OK
    at AT+CGMR
    mfw_nrf91x1_2.0.2
    OK
    at AT+CGSN
    359404230274905
    OK
    at AT%XMODEMUUID
    OK
    at AT%XDATAPRFL?
    %XDATAPRFL: 2
    OK
    at AT+CEREG?
    +CEREG: 5,5,"CDA4","01859E06",7,,,"11100000","11100000"
    OK
    at AT+CFUN?H+CFUN: 1
    OK
    at AT%CESQ=1
    OK
    at AT+CSCON=1
    OK
    at AT+CSCON?
    +CSCON: 1,0
    OK
    at AT+CPAS
    +CPAS: 0
    OK
    at AT+CEDRXRDP
    +CEDRXRDP: 4,"","",""
    OK
    at AT%XTIME=1
    OK
    at AT%CONEVAL
    %CONEVAL: 0,0,7,32,17,28,"01859E06","20801",290,6400,20,0,0,17,1,1,127
    OK
    at AT%XCBAND=?
    OK
    mosh:~$ at AT%XCBAND
    > at AT%XCBAND
    %XCBAND: 20
    OK
    at AT%HWVERSION
    OK
    OK
    at AT%XSYSTEMMODE?%XSYSTEMMODE: 1,1,1,3
    OK
    at AT%XICCID
    OK
    at AT%XEMPR?
    %XEMPR:
    OK
    at AT+CGDCONT?
    OK
    at AT+COPS?+=AM2~",7
    OK
    at AT%XMONITOR
    %XMONITOR: 5,"Orange F","Orange F","20801","CDA4",7,20,"01859E06",290,6400,33,29,"","11100000","11100000","01001001"
    OK
    +CPINR: "SIM PIN",3
    OK
    OK
    OK
    OK
    OK
    RRC mode: Connected
    RRC mode: Idle
    [00:08:51.386,901] <wrn> lte_lc: Registration rejected, EMM cause: 7, Cell ID: 25533958, Tracking area: 52644, LTE mode: 7
    mosh:~$ > at+CFUN=0
    at+CFUN=0
    at+CFUN=0: command not found
    mosh:~$ > at at+CFUN=0
    at at+CFUN=0
    OK
    mosh:~$ > at at+CFUN=1
    at at+CFUN=1
    OK
    mosh:~$ > at at+reg?
    at at+reg?
    ERROR
    mosh:~$ > at at+reg
    at at+reg
    ERROR
    mosh:~$ > at at+creg?
    at at+creg?ERROR
    at at+creg
    ERROR
    at AT+CGDCONT?
    OK
    at AT%XMONITOR
    %XMONITOR: 0
    OK
    at AT%XMONITOR
    %XMONITOR: 0
    OK
    at AT+CGDCONT?
    OK
    at at+CFUN=0
    OK
    at at+CFUN=1
    OK
    at at+cfun=4
    OK
    at at+cfun=0
    OK
    at at+cfun=1
    OK
    at at+cfun=4
    OK
    at at+cfun=0
    OK
    mosh:~$ > at at+cgatt=0
    at at+cgatt=0
    OK
    at at+cfun=1
    OK
    mosh:~$ > at at+creg=2
    at at+creg=2
    ERROR
    mosh:~$ > at at+cereg=2
    at at+cereg=2
    OK
    mosh:~$ > at at+csq
    at at+csq
    +CSQ: 99,99
    OK
    mosh:~$ > at at+csq
    at at+csq
    +CSQ: 99,99
    OK
    mosh:~$ > at at+csq
    at at+csq
    +CSQ: 99,99
    OK
    mosh:~$ > at at+cops
    at at+cops
    ERROR
    mosh:~$ > at at+cops?
    at at+cops?H+COPS: 0
    OK
    mosh:~$ > at at+cgdcont?
    at at+cgdcont?
    OK
    at at+CFUN=0
    OK
    mosh:~$ > at at+CGATT=0
    at at+CGATT=0
    OK
    mosh:~$ > at at+COPS=2
    at at+COPS=2
    ERROR
    at at+CFUN=1
    OK
    mosh:~$ > at at+COPS=0
    at at+COPS=0
    OK
    mosh:~$ > at AT+CGDCONT=1,\"IP",\"m2m.tele2.com\""
    OK
    at at+cereg=2
    OK
    mosh:~$ > at+cereg?
    at+cereg?
    at+cereg?: command not found
    mosh:~$ > at at+cereg?
    at at+cereg?
    +CEREG: 2,0
    OK
    mosh:~$ > at+cfun=0
    at+cfun=0
    at+cfun=0: command not found
    at at+cfun=0
    OK
    mosh:~$ > at at+cops=2
    at at+cops=2
    ERROR
    at at+cgatt=0
    OK
    mosh:~$ > at AT+CGDCONT=1,"IP","m2m.tele2.com"
    OK
    at at+cfun=1
    OK
    mosh:~$ > at at+cops=0
    at at+cops=0
    OK
    at at+cereg=2
    OK
    at at+cereg?
    +CEREG: 2,0
    OK
    at AT%XSYSTEMMODE?
    OK
    mosh:~$ > at AT%XSYSTEMMODE=1,0,0,0
    ERROR
    at at+cfun=0
    OK
    OK
    mosh:~$ > at at+cfun=20
    at at+cfun=20
    OK
    at AT%XSYSTEMMODE?
    %XSYSTEMMODE: 1,0,0,0
    OK
    at at+cgatt=0
    OK
    OK
    mosh:~$ > at AT+COPS=2
    at AT+COPS=2
    ERROR
    at AT+CFUN=1
    OK
    mosh:~$ > at AT+COPS=0
    at AT+COPS=0
    OK
    mosh:~$ > at AT+CEREG=2
    at AT+CEREG=2
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    mosh:~$ > at AT+CEREG=2,1
    at AT+CEREG=2,1
    OK
    mosh:~$ > at AT+CEREG=2,2
    at AT+CEREG=2,2
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    mosh:~$ > at AT+CFUN=0
    at AT+CFUN=0
    OK
    mosh:~$ > at AT+CGATT=0
    at AT+CGATT=0
    OK
    OK
    OK
    mosh:~$ > at AT+CFUN=15
    at AT+CFUN=15
    ERROR
    mosh:~$ > AT+CFUN=0
    AT+CFUN=0
    AT+CFUN=0: command not found
    mosh:~$ > at AT+CFUN=4
    at AT+CFUN=4
    OK
    at AT+CFUN=1
    OK
    mosh:~$ > AT+COPS=0
    AT+COPS=0
    AT+COPS=0: command not found
    at AT+COPS=0
    OK
    at AT+CEREG=2
    OK
    at AT+CEREG?
    +CEREG: 2,0
    OK
    at AT%XMONITOR
    %XMONITOR: 0
    OK
    at AT+COPS?+COPS: 0
    OK
    mosh:~$ at AT+CGDCONT?
    > at AT+CGDCONT?
    +CGDCONT: 1,"IP","m2m.tele2.com","",0,0
    OK
    at AT+CPIN?+CPIN: READY
    OK
    mosh:~$ > at AT%SCANMODE=1
    at AT%SCANMODE=1
    ERROR
    mosh:~$ > at AT%SCANCELL
    at AT%SCANCELL
    ERROR
    mosh:~$
  • i forgot to add, we tried this with 3 different Thingy91x, and with 2 different operators (TELE2 and Onomondo).
    And of course, we have good network coverage in our office :)
    Best
