SAADC channel interference due to software bad configuration or hardware design?
I am working on a new hardware design of analog sensors, which I want to sample their reading using SAADC.
I use nrf52832 PCA10040 DK, and softdevice s132 for sending data over BLE.
The thing is that I have been trying for a while to read properly the sensors which are connected to each other in a grid form as i will describe below. In order to evaluate my code first, I created the same grid with resistors, so I know the expected values.
the grid is:
Which is  9 resistors, with 3 signal lines and 3 power lines.
S0, S1, S2 are connected to the same analog pin A1,
S3, S4, S5 are connected to the same analog pin A2,
S6, S7, S8 are connected to the same analog pin A3. (every column of the grid is connected to the same analog input pin)
while
S0, S3, S6 are connected to the same power line, and respectively every row of the grid is connected to the same power line.
The idea is that if we disconnect every pin and set only V1 high and connect only A1 analog pin to the ADC, we will read the "signal" of the resistor S0 only without any interference of the rest.
However, I have not got yet the expected results and I would like some help if there is something wrong in the pin handling or generally in the code or maybe there is something wrong with the circuit that I have not thought and the reading of a specific resistor without cross-talk is impossible.
Here is the timeout handler in main that handles the changes of the selected sensor and saadc initializations
uint8_t column = 0;
uint8_t sensor = 0;
uint16_t total_sensors[9] = {0};
uint8_t count = 0;
void adjustment_functionality(void)
    ret_code_t err_code;
    uint16_t live_measurements_adj[3];
     if(!nrf_saadc_enable_check())
         if(column == 0)
            saadc_init_channel_0();
         else if(column == 1)
            saadc_init_channel_1();
         else if(column == 2)
            saadc_init_channel_2();
         connect_row(sensor);
         nrf_delay_ms(10);
     buffer_convert();
   //led_toggle(BLUE_LED);
   if(get_flag() == true)
        get_live_measurements(live_measurements_adj);
        total_sensors[sensor] = live_measurements_adj[0];
       //if(err_code == NRF_SUCCESS)
       //if(sensor == 0)
        NRF_LOG_INFO("Adjustment Sent (column %d, sensor %d)  %d %d %d  ", column, sensor,total_sensors[0],total_sensors[3],total_sensors[6]);
        NRF_LOG_INFO("                                        %d %d %d  ",total_sensors[1],total_sensors[4],total_sensors[7]);
        NRF_LOG_INFO("                                        %d %d %d  ",total_sensors[2],total_sensors[5],total_sensors[8]);
       count++;
       if(count==20)
           sensor++;
           if(sensor == 3 || sensor == 6)
                column++;
                saadc_abort();
                nrf_delay_ms(10);
           if(sensor == 9)
              column = 0;
              sensor = 0;
              saadc_abort();
              nrf_delay_ms(10);
            count = 0;
        set_flag_false();
   err_code = app_timer_start(m_measurements_timer_id, SAADC_INTERVAL, NULL);
the saadc initializations (I tried to use different channel for each analog pin)
void saadc_init_channel_0(void)
  nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
  nrf_saadc_channel_config_t channel0_config;
  m_saadc_calibrate = true;
  //Configure SAADC
  saadc_config.low_power_mode = true;                           //Enable low power mode.
  saadc_config.resolution = NRF_SAADC_RESOLUTION_14BIT;         //Set SAADC resolution to 14-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^14=4096 (when input voltage is VDD for channel gain setting of 1/4).
  saadc_config.oversample = NRF_SAADC_OVERSAMPLE_DISABLED;      //Set oversample to 4x. This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times.
  saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;       //Set SAADC interrupt to low priority.
  //Initialize SAADC
  err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback); //Initialize the SAADC with configuration and callback function. The application must then implement the saadc_callback function, which will be called when SAADC interrupt is triggered
  UNUSED_VARIABLE(err_code);
  //Configure SAADC channels
  channel0_config.reference  = NRF_SAADC_REFERENCE_VDD4;    //Set internal reference VDD/4.
  channel0_config.gain       = NRF_SAADC_GAIN1_4;           //Set input gain to 1/4. The maximum SAADC input voltage is then VDD/(1/4)= VDD. The single ended input range is then 0V-VDD.
  channel0_config.acq_time   = NRF_SAADC_ACQTIME_40US;      //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
  channel0_config.mode       = NRF_SAADC_MODE_SINGLE_ENDED; //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
  channel0_config.burst      = NRF_SAADC_BURST_DISABLED;    //Configure burst mode for channel 0. Burst is useful together with oversampling. When triggering the SAMPLE task in burst mode, the SAADC will sample "Oversample" number of times as fast as it can and then output a single averaged value to the RAM buffer. If burst mode is not enabled, the SAMPLE task needs to be triggered "Oversample" number of times to output a single averaged value to the RAM buffer.
  channel0_config.pin_p      = NRF_SAADC_INPUT_AIN2;        //Select the input pin for the channel.
  channel0_config.pin_n      = NRF_SAADC_INPUT_DISABLED;    //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
  channel0_config.resistor_p = NRF_SAADC_RESISTOR_PULLDOWN; //Disable the 13k pulldown resistor. (Bypass resistor ladder).
  channel0_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED; //Disable pulldown resistor on the input pin
  //Initialize SAADC channels
  err_code = nrf_drv_saadc_channel_init(0, &channel0_config);    //Initialize channel 0 with its configuration
  //nrf_drv_saadc_channel_uninit(1);
  //nrf_drv_saadc_channel_uninit(2);
  //connect_pulldown_resistors();
  nrf_gpio_cfg_input(4, NRF_GPIO_PIN_PULLDOWN);
  NRF_LOG_INFO(" SAADC INIT CHANNEL 0 -------");
void saadc_init_channel_1(void)
  nrf_saadc_channel_config_t channel1_config;
  //Configure SAADC
  //Initialize SAADC
  channel1_config.reference  = NRF_SAADC_REFERENCE_VDD4;    //Set internal reference VDD/4.
  channel1_config.gain       = NRF_SAADC_GAIN1_4;           //Set input gain to 1/4. The maximum SAADC input voltage is then VDD/(1/4)= VDD. The single ended input range is then 0V-VDD.
  channel1_config.acq_time   = NRF_SAADC_ACQTIME_40US;      //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
  channel1_config.mode       = NRF_SAADC_MODE_SINGLE_ENDED; //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
  channel1_config.burst      = NRF_SAADC_BURST_DISABLED;    //Configure burst mode for channel 0. Burst is useful together with oversampling. When triggering the SAMPLE task in burst mode, the SAADC will sample "Oversample" number of times as fast as it can and then output a single averaged value to the RAM buffer. If burst mode is not enabled, the SAMPLE task needs to be triggered "Oversample" number of times to output a single averaged value to the RAM buffer.
  channel1_config.pin_p      = NRF_SAADC_INPUT_AIN3;        //Select the input pin for the channel.
  channel1_config.pin_n      = NRF_SAADC_INPUT_DISABLED;    //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
  channel1_config.resistor_p = NRF_SAADC_RESISTOR_PULLDOWN; //Disable the 13k pulldown resistor. (Bypass resistor ladder).
  channel1_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED; //Disable pulldown resistor on the input pin
   err_code = nrf_drv_saadc_channel_init(1, &channel1_config);    //Initialize channel 0 with its configuration
  //nrf_drv_saadc_channel_uninit(0);
  nrf_gpio_cfg_input(5, NRF_GPIO_PIN_PULLDOWN);
  NRF_LOG_INFO(" SAADC INIT CHANNEL 1 -------");
void saadc_init_channel_2(void)
  nrf_saadc_channel_config_t channel2_config;
  //Configure SAADC
  //Initialize SAADC
  channel2_config.reference  = NRF_SAADC_REFERENCE_VDD4;    //Set internal reference VDD/4.
  channel2_config.gain       = NRF_SAADC_GAIN1_4;           //Set input gain to 1/4. The maximum SAADC input voltage is then VDD/(1/4)= VDD. The single ended input range is then 0V-VDD.
  channel2_config.acq_time   = NRF_SAADC_ACQTIME_40US;      //Set acquisition time. Set low acquisition time to enable maximum sampling frequency of 200kHz. Set high acquisition time to allow maximum source resistance up to 800 kohm, see the SAADC electrical specification in the PS.
  channel2_config.mode       = NRF_SAADC_MODE_SINGLE_ENDED; //Set SAADC as single ended. This means it will only have the positive pin as input, and the negative pin is shorted to ground (0V) internally.
  channel2_config.burst      = NRF_SAADC_BURST_DISABLED;    //Configure burst mode for channel 0. Burst is useful together with oversampling. When triggering the SAMPLE task in burst mode, the SAADC will sample "Oversample" number of times as fast as it can and then output a single averaged value to the RAM buffer. If burst mode is not enabled, the SAMPLE task needs to be triggered "Oversample" number of times to output a single averaged value to the RAM buffer.
  channel2_config.pin_p      = NRF_SAADC_INPUT_AIN4;        //Select the input pin for the channel.
  channel2_config.pin_n      = NRF_SAADC_INPUT_DISABLED;    //Since the SAADC is single ended, the negative pin is disabled. The negative pin is shorted to ground internally.
  channel2_config.resistor_p = NRF_SAADC_RESISTOR_PULLDOWN; //Disable the 13k pulldown resistor. (Bypass resistor ladder).
  channel2_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED; //Disable pulldown resistor on the input pin
   err_code = nrf_drv_saadc_channel_init(2, &channel2_config);    //Initialize channel 0 with its configuration
  nrf_gpio_cfg_input(28, NRF_GPIO_PIN_PULLDOWN);
  NRF_LOG_INFO(" SAADC INIT CHANNEL 2 -------");
the function that turns on and off the power lines for each row of sensors.
void connect_row(uint8_t sensor)
  if(sensor==0 || sensor==3 || sensor==6)
      NRF_LOG_INFO("CONNECT ROW 1 (0, 3, 6) for sensor %d", sensor);
      //nrf_gpio_pin_clear(V2);
      //nrf_delay_ms(10);
      //nrf_gpio_pin_clear(V3);
      //nrf_delay_ms(10);
      nrf_gpio_cfg_input(V2, NRF_GPIO_PIN_NOPULL);
      nrf_gpio_input_disconnect(V2);
      nrf_gpio_cfg_input(V3, NRF_GPIO_PIN_NOPULL);
      nrf_gpio_input_disconnect(V3);
      nrf_gpio_cfg_output(V1);
      nrf_gpio_pin_set(V1);
      nrf_delay_ms(10);
  else if(sensor==1 || sensor==4 || sensor==7)
      NRF_LOG_INFO("CONNECT ROW 2 (1, 4, 7) for sensor %d", sensor);
      //nrf_gpio_pin_clear(V1);
      //nrf_delay_ms(10);
      //nrf_delay_ms(10);
      nrf_gpio_cfg_input(V1, NRF_GPIO_PIN_NOPULL);
      nrf_gpio_input_disconnect(V1);
      nrf_gpio_cfg_output(V2);
      nrf_gpio_pin_set(V2);
      nrf_delay_ms(10);
  else //row 3
      NRF_LOG_INFO("CONNECT ROW 3 (2, 5, 8) for sensor %d", sensor);
      //nrf_delay_ms(10);
      //nrf_delay_ms(10);
      nrf_gpio_cfg_output(V3);
      nrf_gpio_pin_set(V3);
      nrf_delay_ms(10);
So, what I did so far is :
1. Initialize saadc channel 0 (which is for S0,S1,S2)
  1.1. Turn on V1, take 20 samples of S0
   1.2 Disconnect V1 and turn on V2, take samples of S1,
   1.3 Disconnect V1, turn on V3, take samples of S2,
2. Initialize saadc channel 1 (which is for S3,S4,S5)
  2.1. Disconnect V3, turn on V1, take samples of S3 etc...
Expected values (since there is an internal resistor 13k and using the formula of pull-down resistor):
[S0,  S3, S6]       [15232,  9259,  3550]
[S1,  S4, S7]   =  [14015,  6086,  1884]
[S2,  S5, S8]       [12034,  914,     441]
And what i get is this :
So the first column is quite close, but the rest isn't. Is it something impossible due to hardware design what i am trying to achieve or am I doing something wrong?
I will also try with a multiplexer while i am waiting for an answer here..
Thank you in advance
  • The pull-downs for both port io and SAADC must be turned off for the other two analogue channels when reading an analogue channel. For example for reading channel V2/A3 both V1 and V3 pins must be floated (inputs) and both A1 and A2 pins must have both port io and SAADC pull-downs turned off:
    Uncomment all these
    Edit all the functions like nrf_drv_saadc_channel_uninit() to also turn off the port pull-down
    Edit: Ah this will not work easily I'm afraid. I just looked at your updated schematic and see that the effective resistor is still affected by the other resistors. Instead of (say) measuring S6 using V1/A3 the measured value would be approximately:
     S6 || (S7 + ((S4+S3) || (S1+S0))) || (S8 + ((S5+S3) || (S2+S0)))
    which explains why the measured value is higher than expected. S0 is less affected since it has the lowest resistance value.
    Without knowing what the "resistors" (the analogue sensors) consist of, it is not clear whether this is simple to pre-calculate by applying the parallel resistor values in the formula; easier if only a single resistor changes value at a time.
  • To simplify the equations the floating Vn drives could be driven high to parallel the measured resistor or driven low to parallel the 12k net pulldown resistance. For V1:A3 measuring S6 driving V2 and V3 high S6 would then be more simply seen as:
     S6 || S7 || S8
    V1, V2 and V3 outputs should be High-Drive H0H1 to reduce the output pin FET series resistance; Standard-Drive L0L1 is something like 160 Ohm and H0H1 is something like 35 Ohm.
    I'm assuming adding series schottky diodes is not an option?
    Yes I tried this but didn't help.
    Could you please by the way explain to me how did you calculate this formula ? How/why the rest resistors affect the one that is about to be measured, even if we have "disconnected" the rest of the pins (Vx and saadc pins)?
     S6 || S7 || S8
    I will try this and come back at you
    It is an option, this is what I tried right now.. but I can do it with some constraints.
    The grid is a ready-made sensor that I want to read, so the only points in the circuit where I can integrate something are at the black "X" below, which are the wires going to my electronics.
    I connected 1N5817 diodes at the points but with no effect.
    Maybe I should try with MOSFET too?
     S6 || S7 || S8
    I tried this but didnt get good results, except if I did something wrong.
    To read S6 (V1 and A3) I configure the pins as follows:
    nrf_gpio_cfg(V2, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_cfg(V3, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    the same configuration is made for every S0-S8
    but I get :
    [S0, S3, S6]
    [S1, S4, S7]
    [S2, S5, S8]
