DPPI_PRESENT functions in modules/hal/nordic/nrfx/hal/nrf_gpiote.h questions.
Hi, I have two concerns about the functions nrf_gpiote_subscribe_set, nrf_gpiote_subscribe_clear, nrf_gpiote_publish_set, and nrf_gpiote_publish_clear. The expression
 *((volatile uint32_t *) ((uint8_t *) p_reg + (uint32_t) event + 0x80uL))
Given pointer arithmetic, the 0x80uL is the same as numerically adding 0x200 to the other terms. However, the Product Spec shows an offset of 0x180, rather than 0x200. I am confused therefore why the number in the code is not 0x60uL. Am I missing something?
Also, I want to put together some code that will publish an event from a gpiote pin changing state, to be subscribed by a timer. In addition to my concern about the functions' correctness, I have not seen any examples of them being used in the SDK. I don't know if that means I am on the wrong track, or that this is something that has not been done frequently.
Thanks for help.
Burt Silverman
    The event that comes in is of this enum:
    https://github.com/zephyrproject-rtos/hal_nordic/blob/master/nrfx/hal/nrf_gpiote.h#L241-L254
    The function _publish_set, that includes the line that you mention:
    https://github.com/zephyrproject-rtos/hal_nordic/blob/master/nrfx/hal/nrf_gpiote.h#L846-L847
    And here is the register definition for nRF9160:
    https://docs.nordicsemi.com/bundle/ps_nrf9160/page/gpiote.html#d558e398
    It takes in an event, lets say (EVENTS_IN[0] + 0x80) = PUBLISH_IN[0] and writes to this register.
    There is a couple of cases on this matter here in devzone, for instance in this thread:
     GPIO event shall increment counter without CPU
    Let me know if you run into any issues!
    Håkon
  • Hi Hakon,
    Sorry I was not very sharp with my pointer arithmetic: now I see that p_reg is cast as a pointer to uint8_t so the offset of 0x80uL is obviously correct for the two subscribe functions. However, looking at the register list you pointed to, again, the PUBLISH_IN registers are at offset 0x180. But the offset in nrf_gpiote.h is shown as 0x80 for both the two subscribe functions and the two publish functions. Isn't that a bug in the publish function definitions? Maybe people are using other functions and that's why there hasn't been a problem? (I will find out as I try examples in the code you pointed me to.)
    I appreciate the link you sent GPIO event shall increment counter without CPU: that wil be tremendously useful.
    Not sure I understand. For nrf_gpiote_subscribe_ functions, you take in the type nrf_gpiote_task_t, which is a offsetof the TASKS_OUT/SET/CLR, which starts from 0. Add 0x80 to this, and you get the SUBSCRIBE_OUT/SET/CLR register.
    enum type nrf_gpiote_event_t is a offsetof() the EVENTS_IN[] events, so it will be 0x100 + 0x80 for the first entry, resulting in reading/writing to register PUBLISH_IN[].
    Håkon
  • Sorry, Hakon, I need to work harder at reading carefully; I am embarrassed!
    Another question, is there any way you have time to update timed_signals_ncs240 for ncs302, or is that an exercise I need to do? It looks like the low level drivers change pretty quickly!
    Burt
  • Hello Hakon,
    I think I have done the job of updating ncs240 for ncs302. There was a small bump at v2.5 and a large one at v2.6, and then no changes were required to get code that at least builds on v3.0.2. I have not tested anything operationally, and I have a few ugly spots that I need to look at. I thought I would let you know what I have been up to.
    Burt
