J-Link DLL error when flashing Ezurio BL54L15 via nRF54L-DK — SWD trace shows persistent ACK FAULT
I'm trying to flash an external board using the Ezurio BL54L15 module, with the nRF54L15-DK as the debugger. SWD is connected via the DK's Debug Out header to the module's SWDIO and SWDCLK pins. Power and ground are supplied independently, and the SELECT pin on the SWD connector is grounded.
Flashing consistently fails with the following error:
Error: One or more batch tasks failed: * 1057720359: Device error: Failed to write DebugPort register 0x08: Unknown Error in J-Link DLL (error code = -1) (Generic)
To investigate, I captured the SWD trace — attached below — which shows persistent ACK FAULT responses during AccessPort Read CSW transactions. Key observations:
  • Initial CSW reads return 0xFFFFFFFD (DbgSwEnable=1, Prot=0x7F, SPIDEN=1, Mode=0xF) with ACK OK and valid parity.
  • DRW writes (e.g., 0x8827CFFD, 0x27CE4BFD) succeed early on.
  • Midway through, Write CSW returns ACK WAIT, followed by ACK FAULT on subsequent Read CSW.
  • Multiple Line Reset sequences occur, with repeated attempts to reconfigure CSW using Mode=0x1, 0x5, and 0xF.
  • Eventually, all CSW reads fail with ACK FAULT, even after resets.
Would appreciate help with:
  • Diagnosing the J-Link DLL error in this context
  • Valid CSW mode values for nRF54L15 targets
  • Conditions that trigger persistent ACK FAULT
  • Recovery strategies after AP fault
  • Any quirks specific to the Ezurio BL54L15 module or its debug interface
    Trace (Saleae Logic 2) is attached. Thanks in advance!
2656.SWD_capture.sal
0184.SWD_capture.csv
