NRF5340DK unable to control few GPIOs
Hi
we are developing a prototype with NRF5340DK, for which we needed to control few set of GPIOs.
we wrote our code in the assumption that it's pretty straight forward and found that the GPIOs are not toggling.
So we made a firmware just to toggle the defined GPIOs for every 1 seconds (as simple as it is)
these are following GPIOs defined to toggle
P0.28
P0.22
P0.23
P0.14
P0.13
P0.15
P0.16
P0.17
our observation,
only P0.28 is toggling as expected
P0.22 is always high and all other Pins are just low all the time
Below is our code
#include <zephyr/kernel.h>
#include <zephyr/device.h>
// Helper macro to define pin with controller + number
#define PIN_DEF(port_label, pin_num) \
    { .port = DEVICE_DT_GET(DT_NODELABEL(port_label)), \
      .pin = pin_num, \
      .dt_flags = GPIO_OUTPUT_INACTIVE }
static const struct gpio_dt_spec my_pins[] = {
    PIN_DEF(gpio0, 28), // P0.28
    PIN_DEF(gpio0, 22), // P0.22
    PIN_DEF(gpio0, 18), // P0.23
    PIN_DEF(gpio0, 14), // P0.14
    PIN_DEF(gpio0, 13), // P0.13
    PIN_DEF(gpio0, 15), // P0.15
    PIN_DEF(gpio0, 16), // P0.16
    PIN_DEF(gpio0, 17), // P0.17
void main(void)
    int ret;
    printk("Configuring pins...\n");
    // Configure pins
    for (int i = 0; i < ARRAY_SIZE(my_pins); i++) {
        if (!device_is_ready(my_pins[i].port)) {
            printk("Port not ready for pin %d\n", my_pins[i].pin);
            return;
        ret = gpio_pin_configure_dt(&my_pins[i], GPIO_OUTPUT_INACTIVE);
        if (ret < 0) {
            printk("Error configuring P0.%d\n", my_pins[i].pin);
            return;
        printk("Configured P0.%d\n", my_pins[i].pin);
    // Toggle sequentially
    while (1) {
            // Toggle pin
            gpio_pin_toggle_dt(&my_pins[i]);
        // Delay before next pin toggle
        k_sleep(K_SECONDS(1));
Below is our Proj.conf
CONFIG_GPIO=y
# General config
CONFIG_LOG=y
# CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_PRINTK=y
# declare 32KHz crystal is Internal RC
CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK=y
# I2C
CONFIG_I2C=y
CONFIG_NRFX_TWIM1=y
we didnot use any specific devicetree seperately
we configured the project for NRF5340DK_CPUAPP (secure)
Zephyr, NRF SDK 2.6.1
Regards
Surya Thanush
